Hi everybody
Manjaro KDE/Plasma with all latest updates, kernel 6.14.6-2-MANJARO.
When I’m connecting any USB drive to comp, pop-up comes with message:
I’ve noticed, that clicking on “Mount” doesn’t have any effect, if automount option is active in settings:
Disk is actually mounted, it works, but there’s no “Safely remove” option, and I can do it from console only.
If I am disabling this option in settings, then everything is ok, “Mount” can be clicked and menu is changed so I can use"Safely remove" option as usual:
I cannot say when exactly this happened, I’m absolutely sure it was working properly before.
I think this is an error.
Hi @teimuraz1962 ,
That is what automount is supposed to do. It auto matically mounts the device for you.
teimuraz1962:
Is there an Eject button? I think it’s the same.
There is no unmount command - only the eject button or the Safely Remove which completely remove the device from the file manager.
I cannot remember if there ever was an unmount command in dolphin because I mostly use pcmanfm-qt which provides both an unmount and an eject command.
There is, in the context menu for the device I’ve mounted and unmounted an ISO with it only yesterday.
In dolphin I have that behaviour for an ISO too - but not for USB disk devices.
With pcmanfm-qt - I have both eject and unmount - but not with dolphin
