First of all, I’m sorry, if this is the wrong category.
I have a usb hub connected internaly into a PCI socket.
Some vendors tag it like linux compatible, THIS POST seems to confirm it, but it’s kinda hard to find out information about it.
After boot and login into the system, the card is recognized and works for a minute or two and them the devices are not acessible anymore, everyrthing connected to it keep the lights on, a regular pendrive is showed in gnome disk like a “Drive Thumb”, but no information about it is showed and it’s not possible to acess it through Dolphin, terminal, even disks have no mounting or formating options for the pendrive. Pendrive now contains a windows 10 image created with fedora media writer through the motherboard usb.
In the usb hub, I have a Davinci Resolve dongle, that works fine on the first minute after the login, and doesn’t after the “disconnect” (or whatever it is).
Already tried to add the
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbcore.autosuspend=-1 apparmor=1 security=apparmor udev.log_priority=3"
on grub and run a
update-grub
after, and doesn’t solve the issue.
Also tryied disable things using tlpui and doens’t work either, even remove tlp doens’t solve the problem.
Motherboard BIOS has no energy saving option enabled, also disabled regular energy saving options on KDE config.
Also switched the power cable, and nothing.
Error -110 listed in some command, is refered like a power cycle on some old posts, but, disconnect the cable, wait a little and them plug again, didn’t solve either.
INXI -FAZY
Kernel: 5.18.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=86b39b27-cc8f-4870-b934-a0d73dc2dcf5 rw quiet splash
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2802
date: 10/21/2020
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x71 (113)
stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2387 high: 3593 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2280 2: 2053
3: 2193 4: 2052 5: 3512 6: 2196 7: 2196 8: 2196 9: 2195 10: 2064 11: 2078
12: 3593 13: 2552 14: 2183 15: 2150 16: 2192 17: 2812 18: 2053 19: 2059
20: 2192 21: 2192 22: 2050 23: 3565 24: 2697 bogomips: 182133
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB]
vendor: ASUSTeK DUAL-GTX1060-O6G driver: nvidia v: 515.57
alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Pascal process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.0
chip-ID: 10de:1c03 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 4000x2560 s-dpi: 107 s-size: 950x608mm (37.40x23.94")
s-diag: 1128mm (44.41")
Monitor-1: HDMI-0 pos: primary,bottom-r res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: HDMI-1 pos: primary,top-left res: 1440x2560 hz: 60 dpi: 108
size: 340x600mm (13.39x23.62") diag: 690mm (27.15") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
v: 4.6.0 NVIDIA 515.57 direct render: Yes
Device-1: NVIDIA GP106 High Definition Audio
vendor: ASUSTeK DUAL-GTX1060-O6G driver: snd_hda_intel v: kernel
bus-ID: 7-3:4 chip-ID: 0951:16df pcie: gen: 3 class-ID: 0300 speed: 8 GT/s
serial: <filter> lanes: 16 bus-ID: 0a:00.1 chip-ID: 10de:10f1
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Kingston HyperX QuadCast type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: Kingston HyperX Cloud Orbit 3D 8Ch type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 7-4:5 chip-ID: 0951:16fe
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.18.7-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.52 running: yes
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-5:3 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Local Storage: total: 10.22 TiB used: 2.99 TiB (29.3%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung
model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 47.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 512 B
rev: 111110WD temp: 47.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 480GB SSD
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0BB3 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD20EZAZ-00GGJB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A80 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD40PURZ-85TTDY0 size: 3.64 TiB block-size: physical: 4096 B
ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
ID-1: / raw-size: 232.38 GiB size: 227.68 GiB (97.97%)
used: 94.39 GiB (41.5%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:3
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:4
ID-3: /home raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 270.95 GiB (59.2%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 60 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 54 C
Processes: 401 Uptime: 29m wakeups: 0 Memory: 31.25 GiB
used: 4.46 GiB (14.3%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1653
pacman: 1618 lib: 341 flatpak: 35 Shell: Zsh v: 5.9 running-in: konsole
inxi: 3.3.19
USB-DEVICES
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev=05.18
S: Manufacturer=Linux 5.18.7-1-MANJARO xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=0000:05:00.0
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
D: Ver= 2.10 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=2109 ProdID=3431 Rev=04.20
S: Product=USB2.0 Hub
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=256ms
T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=1.5 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=096e ProdID=0201 Rev=01.11
S: Manufacturer=OEM
S: Product=USB DONGLE
S: SerialNumber=8279CED13D9E898C
C: #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 0 Cls=03(HID ) Sub=00 Prot=00 Driver=(none)
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 4
D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev=05.18
T: Bus=02 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 2 Spd=5000 MxCh= 4
P: Vendor=2109 ProdID=0813 Rev=90.15
S: Manufacturer=VIA Labs, Inc.
S: Product=USB3.0 Hub
E: Ad=81(I) Atr=13(Int.) MxPS= 2 Ivl=16ms
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 6
S: SerialNumber=0000:07:00.1
T: Bus=03 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1b1c ProdID=1b3e Rev=03.14
S: Manufacturer=Corsair
S: Product=Corsair Gaming SCIMITAR PRO RGB Mouse
S: SerialNumber=17019027AF3A24015B951F3EF5001BC6
C: #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr=300mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=02 Driver=usbhid
E: Ad=81(I) Atr=03(Int.) MxPS= 64 Ivl=1ms
I: If#= 1 Alt= 0 #EPs= 2 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
E: Ad=02(O) Atr=03(Int.) MxPS= 64 Ivl=1ms
E: Ad=82(I) Atr=03(Int.) MxPS= 64 Ivl=1ms
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=10000 MxCh= 4
D: Ver= 3.10 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
T: Bus=05 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 6
S: SerialNumber=0000:07:00.3
T: Bus=05 Lev=01 Prnt=01 Port=05 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
P: Vendor=0b05 ProdID=18f3 Rev=01.00
S: Manufacturer=AsusTek Computer Inc.
S: Product=AURA LED Controller
S: SerialNumber=9876543210
C: #Ifs= 2 Cfg#= 1 Atr=a0 MxPwr=16mA
I: If#= 0 Alt= 0 #EPs= 0 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 2 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
E: Ad=82(I) Atr=03(Int.) MxPS= 32 Ivl=4ms
T: Bus=06 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=10000 MxCh= 4
T: Bus=07 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 4
S: SerialNumber=0000:0c:00.3
T: Bus=07 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
P: Vendor=056a ProdID=030e Rev=01.00
S: Manufacturer=Wacom Co.,Ltd.
S: Product=Intuos PS
C: #Ifs= 3 Cfg#= 1 Atr=80 MxPwr=498mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=2ms
I: If#= 1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
E: Ad=82(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
I: If#= 2 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=02 Driver=usbhid
E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
T: Bus=08 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=10000 MxCh= 4
LSUSB
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 005: ID 0951:16fe Kingston Technology HyperX Cloud Orbit 3D 8Ch
Bus 007 Device 004: ID 0951:16df Kingston Technology HyperX QuadCast
Bus 007 Device 003: ID 1b1c:1b2d Corsair K95 RGB Platinum Keyboard [RGP0056]
Bus 007 Device 002: ID 056a:030e Wacom Co., Ltd CTL-480 [Intuos Pen (S)]
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 002: ID 0b05:18f3 ASUSTek Computer, Inc. AURA LED Controller
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 003: ID 0bda:8771 Realtek Semiconductor Corp. Bluetooth Radio
Bus 003 Device 002: ID 1b1c:1b3e Corsair Corsair Gaming SCIMITAR PRO RGB Mouse
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 2109:0813 VIA Labs, Inc. VL813 Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 085c:0a00 ColorVision, Inc. Datacolor SpyderX
Bus 001 Device 007: ID 0930:6545 Toshiba Corp. Kingston DataTraveler 102/2.0 / HEMA Flash Drive 2 GB / PNY Attache 4GB Stick
Bus 001 Device 006: ID 0fd9:006d Elgato Systems GmbH Stream Deck original V2
Bus 001 Device 004: ID 2109:2813 VIA Labs, Inc. VL813 Hub
Bus 001 Device 003: ID 096e:0201 Feitian Technologies, Inc. USB DONGLE
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
LSUSB -T -V
/: Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 10000M
/: Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 1: Dev 2, If 2, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 3, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 3, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 4, If 2, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 3: Dev 4, If 0, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 3: Dev 4, If 3, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 4, If 1, Class=Audio, Driver=snd-usb-audio, 12M
|__ Port 4: Dev 5, If 0, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 4: Dev 5, If 1, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 4: Dev 5, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 4: Dev 5, If 3, Class=Human Interface Device, Driver=usbhid, 480M
/: Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 10000M
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 480M
|__ Port 6: Dev 2, If 0, Class=Vendor Specific Class, Driver=, 12M
|__ Port 6: Dev 2, If 2, Class=Human Interface Device, Driver=usbhid, 12M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 10000M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 480M
|__ Port 5: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
|__ Port 5: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
|__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 3, If 0, Class=Human Interface Device, Driver=, 1.5M
|__ Port 2: Dev 4, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 7, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 1: Dev 6, If 0, Class=Human Interface Device, Driver=usbfs, 480M
|__ Port 3: Dev 5, If 0, Class=Vendor Specific Class, Driver=, 12M
SUDO DMESG | GREP USB
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=86b39b27-cc8f-4870-b934-a0d73dc2dcf5 rw quiet splash usbcore.autosuspend=-1 apparmor=1 security=apparmor udev.log_priority=3
[ 0.053335] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=86b39b27-cc8f-4870-b934-a0d73dc2dcf5 rw quiet splash usbcore.autosuspend=-1 apparmor=1 security=apparmor udev.log_priority=3
[ 0.345113] usbcore: registered new interface driver usbfs
[ 0.345113] usbcore: registered new interface driver hub
[ 0.345113] usbcore: registered new device driver usb
[ 0.503834] usbcore: registered new interface driver usbserial_generic
[ 0.503836] usbserial: USB Serial support registered for generic
[ 1.254171] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
[ 1.254172] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.254173] usb usb1: Product: xHCI Host Controller
[ 1.254174] usb usb1: Manufacturer: Linux 5.18.7-1-MANJARO xhci-hcd
[ 1.254175] usb usb1: SerialNumber: 0000:05:00.0
[ 1.254294] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.18
[ 1.254295] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.254296] usb usb2: Product: xHCI Host Controller
[ 1.254297] usb usb2: Manufacturer: Linux 5.18.7-1-MANJARO xhci-hcd
[ 1.254298] usb usb2: SerialNumber: 0000:05:00.0
[ 1.255173] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
[ 1.255174] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.255175] usb usb3: Product: xHCI Host Controller
[ 1.255175] usb usb3: Manufacturer: Linux 5.18.7-1-MANJARO xhci-hcd
[ 1.255176] usb usb3: SerialNumber: 0000:07:00.1
[ 1.255630] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.255642] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.18
[ 1.255643] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.255644] usb usb4: Product: xHCI Host Controller
[ 1.255644] usb usb4: Manufacturer: Linux 5.18.7-1-MANJARO xhci-hcd
[ 1.255645] usb usb4: SerialNumber: 0000:07:00.1
[ 1.256909] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
[ 1.256910] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.256912] usb usb5: Product: xHCI Host Controller
[ 1.256913] usb usb5: Manufacturer: Linux 5.18.7-1-MANJARO xhci-hcd
[ 1.256914] usb usb5: SerialNumber: 0000:07:00.3
[ 1.257891] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.257908] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.18
[ 1.257910] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.257911] usb usb6: Product: xHCI Host Controller
[ 1.257912] usb usb6: Manufacturer: Linux 5.18.7-1-MANJARO xhci-hcd
[ 1.257913] usb usb6: SerialNumber: 0000:07:00.3
[ 1.258930] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.18
[ 1.258932] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.258934] usb usb7: Product: xHCI Host Controller
[ 1.258935] usb usb7: Manufacturer: Linux 5.18.7-1-MANJARO xhci-hcd
[ 1.258936] usb usb7: SerialNumber: 0000:0c:00.3
[ 1.259145] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.259161] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.18
[ 1.259162] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.259163] usb usb8: Product: xHCI Host Controller
[ 1.259164] usb usb8: Manufacturer: Linux 5.18.7-1-MANJARO xhci-hcd
[ 1.259166] usb usb8: SerialNumber: 0000:0c:00.3
[ 1.508287] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.508293] usb 3-1: new full-speed USB device number 2 using xhci_hcd
[ 1.508297] usb 5-6: new full-speed USB device number 2 using xhci_hcd
[ 1.511621] usb 7-1: new full-speed USB device number 2 using xhci_hcd
[ 1.650577] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.20
[ 1.650580] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.650581] usb 1-1: Product: USB2.0 Hub
[ 1.661929] usb 5-6: config 1 has an invalid interface number: 2 but max is 1
[ 1.661931] usb 5-6: config 1 has no interface number 1
[ 1.673926] usb 5-6: New USB device found, idVendor=0b05, idProduct=18f3, bcdDevice= 1.00
[ 1.673929] usb 5-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.673931] usb 5-6: Product: AURA LED Controller
[ 1.673932] usb 5-6: Manufacturer: AsusTek Computer Inc.
[ 1.673933] usb 5-6: SerialNumber: 9876543210
[ 1.674941] usb 7-1: New USB device found, idVendor=056a, idProduct=030e, bcdDevice= 1.00
[ 1.674944] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.674946] usb 7-1: Product: Intuos PS
[ 1.674951] usb 7-1: Manufacturer: Wacom Co.,Ltd.
[ 1.677293] usb 3-1: New USB device found, idVendor=1b1c, idProduct=1b3e, bcdDevice= 3.14
[ 1.677296] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.677297] usb 3-1: Product: Corsair Gaming SCIMITAR PRO RGB Mouse
[ 1.677298] usb 3-1: Manufacturer: Corsair
[ 1.677299] usb 3-1: SerialNumber: 17019027AF3A24015B951F3EF5001BC6
[ 1.804965] usb 7-2: new full-speed USB device number 3 using xhci_hcd
[ 1.808402] usb 3-5: new full-speed USB device number 3 using xhci_hcd
[ 1.813597] usb 2-2: new SuperSpeed USB device number 2 using xhci_hcd
[ 1.930351] usb 2-2: New USB device found, idVendor=2109, idProduct=0813, bcdDevice=90.15
[ 1.930354] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.930356] usb 2-2: Product: USB3.0 Hub
[ 1.930357] usb 2-2: Manufacturer: VIA Labs, Inc.
[ 1.968240] usb 3-5: New USB device found, idVendor=0bda, idProduct=8771, bcdDevice= 2.00
[ 1.968243] usb 3-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.968244] usb 3-5: Product: Bluetooth Radio
[ 1.968245] usb 3-5: Manufacturer: Realtek
[ 1.968246] usb 3-5: SerialNumber: 00E04C239987
[ 1.970930] usb 7-2: New USB device found, idVendor=1b1c, idProduct=1b2d, bcdDevice= 3.29
[ 1.970933] usb 7-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.970935] usb 7-2: Product: Corsair Gaming K95 RGB PLATINUM Keyboard
[ 1.970936] usb 7-2: Manufacturer: Corsair
[ 1.970937] usb 7-2: SerialNumber: 15021018AF1E1C455A6FFE4FF5001BC0
[ 1.991632] usb 1-1.1: new low-speed USB device number 3 using xhci_hcd
[ 2.090511] usb 1-1.1: New USB device found, idVendor=096e, idProduct=0201, bcdDevice= 1.11
[ 2.090514] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.090516] usb 1-1.1: Product: USB DONGLE
[ 2.090517] usb 1-1.1: Manufacturer: OEM
[ 2.090517] usb 1-1.1: SerialNumber: 8279CED13D9E898C
[ 2.101632] usb 7-3: new full-speed USB device number 4 using xhci_hcd
[ 2.165068] usb 1-1.2: new high-speed USB device number 4 using xhci_hcd
[ 2.257427] usb 1-1.2: New USB device found, idVendor=2109, idProduct=2813, bcdDevice=90.14
[ 2.257430] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.257432] usb 1-1.2: Product: USB2.0 Hub
[ 2.257433] usb 1-1.2: Manufacturer: VIA Labs, Inc.
[ 2.260942] usb 7-3: New USB device found, idVendor=0951, idProduct=16df, bcdDevice= 1.00
[ 2.260945] usb 7-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.260947] usb 7-3: Product: HyperX Quadcast
[ 2.260948] usb 7-3: Manufacturer: Kingston
[ 2.260948] usb 7-3: SerialNumber: 4110
[ 2.338400] usb 1-1.3: new full-speed USB device number 5 using xhci_hcd
[ 2.388298] usb 7-4: new high-speed USB device number 5 using xhci_hcd
[ 2.435264] usb 1-1.3: New USB device found, idVendor=085c, idProduct=0a00, bcdDevice= 1.00
[ 2.435267] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.435268] usb 1-1.3: Product: Datacolor SpyderX
[ 2.435269] usb 1-1.3: Manufacturer: Datacolor
[ 2.435270] usb 1-1.3: SerialNumber: 0001
[ 2.561734] usb 1-1.2.1: new high-speed USB device number 6 using xhci_hcd
[ 2.665708] usb 1-1.2.1: New USB device found, idVendor=0fd9, idProduct=006d, bcdDevice= 2.00
[ 2.665711] usb 1-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.665712] usb 1-1.2.1: Product: Stream Deck
[ 2.665713] usb 1-1.2.1: Manufacturer: Elgato
[ 2.665714] usb 1-1.2.1: SerialNumber: AL49I2C04112
[ 2.751735] usb 1-1.2.3: new high-speed USB device number 7 using xhci_hcd
[ 2.858535] usb 1-1.2.3: New USB device found, idVendor=0930, idProduct=6545, bcdDevice= 1.00
[ 2.858538] usb 1-1.2.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.858539] usb 1-1.2.3: Product: DataTraveler 2.0
[ 2.858540] usb 1-1.2.3: Manufacturer: Kingston
[ 2.858541] usb 1-1.2.3: SerialNumber: 50E549C20249EE50294002F6
[ 3.251571] usb 7-4: New USB device found, idVendor=0951, idProduct=16fe, bcdDevice= 0.73
[ 3.251574] usb 7-4: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 3.251576] usb 7-4: Product: HyperX Cloud Orbit 3D 8Ch
[ 3.251577] usb 7-4: Manufacturer: HyperX Cloud Orbit 3D 8Ch
[ 3.251578] usb 7-4: SerialNumber: HyperX Cloud Orbit 3D 8Ch
[ 3.636342] usb-storage 1-1.2.3:1.0: USB Mass Storage device detected
[ 3.636421] scsi host9: usb-storage 1-1.2.3:1.0
[ 3.636465] usbcore: registered new interface driver usb-storage
[ 3.639115] usbcore: registered new interface driver uas
[ 3.640012] hid-generic 0003:0B05:18F3.0001: hiddev96,hidraw0: USB HID v1.11 Device [AsusTek Computer Inc. AURA LED Controller] on usb-0000:07:00.3-6/input2
[ 3.647169] hid-generic 0003:056A:030E.0002: hiddev97,hidraw1: USB HID v1.10 Device [Wacom Co.,Ltd. Intuos PS] on usb-0000:0c:00.3-1/input0
[ 3.652069] hid-generic 0003:056A:030E.0003: hiddev98,hidraw2: USB HID v1.10 Device [Wacom Co.,Ltd. Intuos PS] on usb-0000:0c:00.3-1/input1
[ 3.658041] input: Wacom Co.,Ltd. Intuos PS as /devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-1/7-1:1.2/0003:056A:030E.0004/input/input2
[ 3.658092] hid-generic 0003:056A:030E.0004: input,hidraw3: USB HID v1.10 Mouse [Wacom Co.,Ltd. Intuos PS] on usb-0000:0c:00.3-1/input2
[ 3.684317] input: Corsair Corsair Gaming K95 RGB PLATINUM Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-2/7-2:1.0/0003:1B1C:1B2D.0007/input/input3
[ 3.738386] input: Corsair Corsair Gaming K95 RGB PLATINUM Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-2/7-2:1.0/0003:1B1C:1B2D.0007/input/input4
[ 3.738419] input: Corsair Corsair Gaming K95 RGB PLATINUM Keyboard as /devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-2/7-2:1.0/0003:1B1C:1B2D.0007/input/input5
[ 3.738453] input: Corsair Corsair Gaming K95 RGB PLATINUM Keyboard Mouse as /devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-2/7-2:1.0/0003:1B1C:1B2D.0007/input/input6
[ 3.738527] hid-generic 0003:1B1C:1B2D.0007: input,hiddev99,hidraw4: USB HID v1.11 Keyboard [Corsair Corsair Gaming K95 RGB PLATINUM Keyboard] on usb-0000:0c:00.3-2/input0
[ 3.744086] hid-generic 0003:1B1C:1B2D.0008: hiddev100,hidraw5: USB HID v1.11 Device [Corsair Corsair Gaming K95 RGB PLATINUM Keyboard] on usb-0000:0c:00.3-2/input1
[ 3.744103] usbhid 1-1.1:1.0: couldn't find an input interrupt endpoint
[ 3.749084] input: Kingston HyperX Quadcast Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-3/7-3:1.3/0003:0951:16DF.0009/input/input7
[ 3.805149] hid-generic 0003:0951:16DF.0009: input,hiddev101,hidraw6: USB HID v1.00 Device [Kingston HyperX Quadcast] on usb-0000:0c:00.3-3/input3
[ 3.805637] input: Elgato Stream Deck as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:03.0/0000:05:00.0/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1:1.0/0003:0FD9:006D.000A/input/input9
[ 3.861945] hid-generic 0003:0FD9:006D.000A: input,hidraw7: USB HID v1.10 Device [Elgato Stream Deck] on usb-0000:05:00.0-1.2.1/input0
[ 3.868691] input: HyperX Cloud Orbit 3D 8Ch HyperX Cloud Orbit 3D 8Ch Consumer Control as /devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-4/7-4:1.3/0003:0951:16FE.000B/input/input10
[ 3.925022] input: HyperX Cloud Orbit 3D 8Ch HyperX Cloud Orbit 3D 8Ch as /devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-4/7-4:1.3/0003:0951:16FE.000B/input/input11
[ 3.925078] hid-generic 0003:0951:16FE.000B: input,hiddev102,hidraw8: USB HID v1.11 Device [HyperX Cloud Orbit 3D 8Ch HyperX Cloud Orbit 3D 8Ch] on usb-0000:0c:00.3-4/input3
[ 3.925095] usbcore: registered new interface driver usbhid
[ 3.925095] usbhid: USB HID core driver
[ 3.928804] input: Corsair Corsair Gaming SCIMITAR PRO RGB Mouse as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:07:00.1/usb3/3-1/3-1:1.0/0003:1B1C:1B3E.0005/input/input12
[ 3.928874] corsair 0003:1B1C:1B3E.0005: input,hiddev103,hidraw9: USB HID v1.11 Mouse [Corsair Corsair Gaming SCIMITAR PRO RGB Mouse] on usb-0000:07:00.1-1/input0
[ 3.928926] corsair 0003:1B1C:1B3E.0006: hiddev104,hidraw10: USB HID v1.11 Device [Corsair Corsair Gaming SCIMITAR PRO RGB Mouse] on usb-0000:07:00.1-1/input1
[ 4.449988] input: Wacom Intuos S Pen as /devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-1/7-1:1.0/0003:056A:030E.0002/input/input14
[ 4.450061] wacom 0003:056A:030E.0002: hidraw1: USB HID v1.10 Device [Wacom Co.,Ltd. Intuos PS] on usb-0000:0c:00.3-1/input0
[ 4.450216] input: Wacom Intuos S Pad as /devices/pci0000:00/0000:00:08.1/0000:0c:00.3/usb7/7-1/7-1:1.1/0003:056A:030E.0003/input/input19
[ 4.450426] wacom 0003:056A:030E.0003: hidraw2: USB HID v1.10 Device [Wacom Co.,Ltd. Intuos PS] on usb-0000:0c:00.3-1/input1
[ 4.665707] usbcore: registered new interface driver btusb
[ 5.121841] usbcore: registered new interface driver snd-usb-audio
[ 200.730341] usb 1-1.2-port3: cannot reset (err = -110)
[ 201.743651] usb 1-1.2-port3: cannot reset (err = -110)
[ 202.756978] usb 1-1.2-port3: cannot reset (err = -110)
[ 203.770313] usb 1-1.2-port3: cannot reset (err = -110)
[ 204.783644] usb 1-1.2-port3: cannot reset (err = -110)
[ 204.783650] usb 1-1.2-port3: Cannot enable. Maybe the USB cable is bad?
[ 205.797693] usb 1-1.2-port3: cannot disable (err = -110)
[ 206.810338] usb 1-1.2-port3: cannot reset (err = -110)
[ 207.824135] usb 1-1.2-port3: cannot reset (err = -110)
[ 208.836957] usb 1-1.2-port3: cannot reset (err = -110)
[ 209.850305] usb 1-1.2-port3: cannot reset (err = -110)
[ 210.863613] usb 1-1.2-port3: cannot reset (err = -110)
[ 210.863617] usb 1-1.2-port3: Cannot enable. Maybe the USB cable is bad?
[ 211.877175] usb 1-1.2-port3: cannot disable (err = -110)
[ 212.890272] usb 1-1.2-port3: cannot reset (err = -110)
[ 213.903607] usb 1-1.2-port3: cannot reset (err = -110)
[ 214.916925] usb 1-1.2-port3: cannot reset (err = -110)
[ 215.930258] usb 1-1.2-port3: cannot reset (err = -110)
[ 216.943585] usb 1-1.2-port3: cannot reset (err = -110)
[ 216.943589] usb 1-1.2-port3: Cannot enable. Maybe the USB cable is bad?
[ 217.960248] usb 1-1.2-port3: cannot disable (err = -110)
[ 218.970241] usb 1-1.2-port3: cannot reset (err = -110)
[ 219.983598] usb 1-1.2-port3: cannot reset (err = -110)
[ 220.996939] usb 1-1.2-port3: cannot reset (err = -110)
[ 222.010253] usb 1-1.2-port3: cannot reset (err = -110)
[ 223.023598] usb 1-1.2-port3: cannot reset (err = -110)
[ 223.023604] usb 1-1.2-port3: Cannot enable. Maybe the USB cable is bad?
[ 224.036912] usb 1-1.2-port3: cannot disable (err = -110)
[ 225.050258] usb 1-1.2-port3: cannot disable (err = -110)
[ 1129.979291] usb 1-1.1: usbfs: USBDEVFS_CONTROL failed cmd GUI Thread rqt 128 rq 6 len 255 ret -110
