USB devices stop being recognized after disconnecting the charger when the battery is fully charged
Hello everyone,
Background:
  • I installed Manjaro Linux on Sunday, 2024-04-14.
  • This issue has been persistent since the installation.
  • I have tested with various USB devices, including storage devices and headphones, and they all stop working after disconnecting the charger when the battery is fully charged.
Troubleshooting Steps Tried:
  • I opened tlpui to turn off USB_AUTOSUSPEND and turn on all of the EXCLUDE options.
  • I went to /lib/udev/rules.d/69-libmtp.rules and commented out the following line:
    ENV{ID_MTP_DEVICE}!="1", ENV{MTP_NO_PROBE}!="1", ENV{COLOR_MEASUREMENT_DEVICE}!="1", ENV{ID_GPHOTO}!="1", ENV{libsane_matched}!="yes", ATTR{bDeviceClass}=="00|02|06|ef|ff", PROGRAM="/usr/lib/udev/mtp-probe /sys$env{DEVPATH} $attr{busnum} $attr{devnum}", RESULT=="1", SYMLINK+="libmtp-%k", ENV{ID_MTP_DEVICE}="1", ENV{ID_MEDIA_PLAYER}="1"
    Then, I ran sudo udevadm control --reload-rules and sudo udevadm trigger.
  • I was able to resolve the problem by reinstalling the package udev after undoing the prior changes, but the problems every time fill my battery.
System Information:
  • Manjaro Linux version: PRETTY_NAME=β€œManjaro Linux”
  • Kernel version: 6.6.26-1-MANJARO
  • The issue persists across reboots and power cycles.
Here are the results of some commands that might help diagnose the issue just after facing the issue:
sudo dmesg | tail
[   21.134938] block nvme0n1: No UUID available providing old NGUID
[  601.606428] docker0: port 1(vethd54f430) entered blocking state
[  601.606455] docker0: port 1(vethd54f430) entered disabled state
[  601.606482] vethd54f430: entered allmulticast mode
[  601.606585] vethd54f430: entered promiscuous mode
[  601.902508] eth0: renamed from vethfb1a60d
[  601.923265] docker0: port 1(vethd54f430) entered blocking state
[  601.923274] docker0: port 1(vethd54f430) entered forwarding state
[ 2860.898984] acer_wmi: Unknown function number - 8 - 0
[ 2861.187526] xhci_hcd 0000:05:00.3: WARNING: Host System Error
lsusb
Bus 001 Device 002: ID 0408:a031 Quanta Computer, Inc. VGA WebCam
Bus 001 Device 003: ID 046d:0a8f Logitech, Inc. H390 headset with microphone
Bus 001 Device 004: ID 04ca:3015 Lite-On Technology Corp. Qualcomm Atheros QCA9377 Bluetooth
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
lspci -v
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Root Complex
	Subsystem: Acer Incorporated [ALI] Raven/Raven2 Root Complex
	Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 IOMMU
	Subsystem: Acer Incorporated [ALI] Raven/Raven2 IOMMU
	Flags: bus master, fast devsel, latency 0, IRQ 25
	Capabilities: <access denied>
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
	Flags: fast devsel, IOMMU group 0
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
	Subsystem: Acer Incorporated [ALI] Raven/Raven2 PCIe GPP Bridge [6:0]
	Flags: bus master, fast devsel, latency 0, IRQ 26, IOMMU group 1
	Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
	I/O behind bridge: 3000-3fff [size=4K] [16-bit]
	Memory behind bridge: c0c00000-c0dfffff [size=2M] [32-bit]
	Prefetchable memory behind bridge: c0e00000-c0ffffff [size=2M] [32-bit]
	Kernel driver in use: pcieport
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 2
	Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
	I/O behind bridge: [disabled] [32-bit]
	Memory behind bridge: c0200000-c03fffff [size=2M] [32-bit]
	Prefetchable memory behind bridge: [disabled] [64-bit]
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 3
	Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
	I/O behind bridge: 2000-2fff [size=4K] [16-bit]
	Memory behind bridge: c0b00000-c0bfffff [size=1M] [32-bit]
00:01.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 PCIe GPP Bridge [6:0] (prog-if 00 [Normal decode])
	Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 4
	Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
	Memory behind bridge: c0a00000-c0afffff [size=1M] [32-bit]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-1fh) PCIe Dummy Host Bridge
	Flags: fast devsel, IOMMU group 5
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A (prog-if 00 [Normal decode])
	Subsystem: Acer Incorporated [ALI] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus A
	Flags: bus master, fast devsel, latency 0, IRQ 30, IOMMU group 6
	Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
	I/O behind bridge: 1000-1fff [size=4K] [16-bit]
	Memory behind bridge: c0500000-c09fffff [size=5M] [32-bit]
	Prefetchable memory behind bridge: b0000000-c01fffff [size=258M] [32-bit]
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B (prog-if 00 [Normal decode])
	Subsystem: Acer Incorporated [ALI] Raven/Raven2 Internal PCIe GPP Bridge 0 to Bus B
	Flags: bus master, fast devsel, latency 0, IRQ 31, IOMMU group 7
	Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
	Memory behind bridge: c0400000-c04fffff [size=1M] [32-bit]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
	Subsystem: Acer Incorporated [ALI] FCH SMBus Controller
	Flags: 66MHz, medium devsel, IOMMU group 8
	Kernel driver in use: piix4_smbus
	Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
	Subsystem: Acer Incorporated [ALI] FCH LPC Bridge
	Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 8
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 0
	Flags: fast devsel, IOMMU group 9
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 3
	Kernel driver in use: k10temp
	Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Raven/Raven2 Device 24: Function 7
02:00.0 Network controller: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter (rev 31)
	Subsystem: Lite-On Communications Inc Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
	Flags: bus master, fast devsel, latency 0, IRQ 73, IOMMU group 10
	Memory at c0200000 (64-bit, non-prefetchable) [size=2M]
	Kernel driver in use: ath10k_pci
	Kernel modules: ath10k_pci
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 15)
	Subsystem: Acer Incorporated [ALI] RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
	Flags: fast devsel, IRQ 68, IOMMU group 11
	I/O ports at 2000 [size=256]
	Memory at c0b04000 (64-bit, non-prefetchable) [size=4K]
	Memory at c0b00000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: r8169
	Kernel modules: r8169
04:00.0 Non-Volatile memory controller: Intel Corporation SSD 670p Series [Keystone Harbor] (rev 03) (prog-if 02 [NVM Express])
	Subsystem: Intel Corporation SSD 670p Series [Keystone Harbor]
	Flags: bus master, fast devsel, latency 0, IRQ 52, IOMMU group 12
	Memory at c0a00000 (64-bit, non-prefetchable) [size=16K]
	Kernel driver in use: nvme
	Kernel modules: nvme
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series] (rev c2) (prog-if 00 [VGA controller])
	Subsystem: Acer Incorporated [ALI] Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series]
	Flags: bus master, fast devsel, latency 0, IRQ 43, IOMMU group 13
	Memory at b0000000 (64-bit, prefetchable) [size=256M]
	Memory at c0000000 (64-bit, prefetchable) [size=2M]
	I/O ports at 1000 [size=256]
	Memory at c0900000 (32-bit, non-prefetchable) [size=512K]
	Kernel driver in use: amdgpu
	Kernel modules: amdgpu
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
	Subsystem: Acer Incorporated [ALI] Raven/Raven2/Fenghuang HDMI/DP Audio Controller
	Flags: bus master, fast devsel, latency 0, IRQ 70, IOMMU group 14
	Memory at c09c8000 (32-bit, non-prefetchable) [size=16K]
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
	Subsystem: Acer Incorporated [ALI] Family 17h (Models 10h-1fh) Platform Security Processor
	Flags: bus master, fast devsel, latency 0, IRQ 32, IOMMU group 14
	Memory at c0800000 (32-bit, non-prefetchable) [size=1M]
	Memory at c09ce000 (32-bit, non-prefetchable) [size=8K]
	Kernel driver in use: ccp
	Kernel modules: ccp
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1 (prog-if 30 [XHCI])
	Subsystem: Acer Incorporated [ALI] Raven USB 3.1
	Flags: bus master, fast devsel, latency 0, IRQ 34, IOMMU group 14
	Memory at c0700000 (64-bit, non-prefetchable) [size=1M]
	Kernel driver in use: xhci_hcd
	Kernel modules: xhci_pci
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Raven USB 3.1 (prog-if 30 [XHCI])
	Flags: fast devsel, IRQ 43, IOMMU group 14
	Memory at c0600000 (64-bit, non-prefetchable) [size=1M]
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
	Subsystem: Acer Incorporated [ALI] ACP/ACP3X/ACP6x Audio Coprocessor
	Flags: bus master, fast devsel, latency 0, IRQ 65, IOMMU group 14
	Memory at c0980000 (32-bit, non-prefetchable) [size=256K]
	Kernel driver in use: snd_pci_acp3x
	Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
	Subsystem: Acer Incorporated [ALI] Family 17h/19h HD Audio Controller
	Flags: bus master, fast devsel, latency 0, IRQ 71, IOMMU group 14
	Memory at c09c0000 (32-bit, non-prefetchable) [size=32K]
05:00.7 Non-VGA unclassified device: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/Renoir Non-Sensor Fusion Hub KMDF driver
	Subsystem: Acer Incorporated [ALI] Raven/Raven2/Renoir Non-Sensor Fusion Hub KMDF driver
	Flags: fast devsel, IRQ 34, IOMMU group 14
	Memory at c0500000 (32-bit, non-prefetchable) [size=1M]
	Memory at c09cc000 (32-bit, non-prefetchable) [size=8K]
	Kernel driver in use: i2c_amd_mp2
	Kernel modules: i2c_amd_mp2_pci
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 61) (prog-if 01 [AHCI 1.0])
	Subsystem: Acer Incorporated [ALI] FCH SATA Controller [AHCI mode]
	Flags: bus master, fast devsel, latency 0, IRQ 33, IOMMU group 15
	Memory at c0400000 (32-bit, non-prefetchable) [size=2K]
	Kernel driver in use: ahci
lsmod
Module                  Size  Used by
xt_nat                 12288  1
xt_tcpudp              16384  3
veth                   40960  0
rfcomm                102400  4
snd_seq_dummy          12288  0
snd_hrtimer            12288  1
snd_seq               131072  7 snd_seq_dummy
xt_conntrack           12288  1
xt_MASQUERADE          16384  2
nf_conntrack_netlink    61440  0
iptable_nat            12288  1
nf_nat                 65536  3 xt_nat,iptable_nat,xt_MASQUERADE
nf_conntrack          208896  5 xt_conntrack,nf_nat,xt_nat,nf_conntrack_netlink,xt_MASQUERADE
nf_defrag_ipv6         24576  1 nf_conntrack
nf_defrag_ipv4         12288  1 nf_conntrack
libcrc32c              12288  2 nf_conntrack,nf_nat
xt_addrtype            12288  2
iptable_filter         12288  1
br_netfilter           36864  0
bridge                438272  1 br_netfilter
stp                    12288  1 bridge
llc                    16384  2 bridge,stp
ccm                    20480  3
cmac                   12288  3
algif_hash             12288  1
algif_skcipher         12288  1
af_alg                 36864  6 algif_hash,algif_skcipher
overlay               225280  1
bnep                   36864  2
qrtr                   57344  4
btusb                  86016  0
uvcvideo              176128  4
squashfs               94208  0
btrtl                  32768  1 btusb
videobuf2_vmalloc      20480  1 uvcvideo
snd_usb_audio         466944  2
btintel                57344  1 btusb
uvc                    12288  1 uvcvideo
videobuf2_memops       16384  1 videobuf2_vmalloc
btbcm                  24576  1 btusb
snd_usbmidi_lib        49152  1 snd_usb_audio
videobuf2_v4l2         40960  1 uvcvideo
btmtk                  12288  1 btusb
snd_ump                36864  1 snd_usb_audio
videodev              389120  4 videobuf2_v4l2,uvcvideo
snd_rawmidi            53248  2 snd_usbmidi_lib,snd_ump
bluetooth            1097728  34 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
videobuf2_common       94208  4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
snd_seq_device         16384  3 snd_seq,snd_ump,snd_rawmidi
mc                     90112  7 videodev,snd_usb_audio,videobuf2_v4l2,uvcvideo,videobuf2_common
ecdh_generic           16384  2 bluetooth
intel_rapl_msr         20480  0
intel_rapl_common      45056  1 intel_rapl_msr
edac_mce_amd           53248  0
snd_sof_amd_vangogh    16384  0
snd_sof_amd_rembrandt    16384  0
kvm_amd               204800  0
snd_sof_amd_renoir     16384  0
snd_sof_amd_acp        69632  3 snd_sof_amd_rembrandt,snd_sof_amd_vangogh,snd_sof_amd_renoir
snd_ctl_led            24576  0
ath10k_pci             65536  0
snd_sof_pci            24576  3 snd_sof_amd_rembrandt,snd_sof_amd_vangogh,snd_sof_amd_renoir
kvm                  1376256  1 kvm_amd
snd_sof_xtensa_dsp     16384  1 snd_sof_amd_acp
irqbypass              12288  1 kvm
ath10k_core           774144  1 ath10k_pci
snd_sof               425984  2 snd_sof_amd_acp,snd_sof_pci
snd_hda_codec_realtek   200704  1
crct10dif_pclmul       12288  1
joydev                 24576  0
crc32_pclmul           12288  0
vfat                   20480  1
snd_hda_codec_generic   114688  1 snd_hda_codec_realtek
snd_sof_utils          16384  1 snd_sof
ath                    40960  1 ath10k_core
polyval_clmulni        12288  0
fat                   106496  1 vfat
ledtrig_audio          12288  2 snd_ctl_led,snd_hda_codec_generic
snd_soc_core          462848  1 snd_sof
snd_hda_codec_hdmi     94208  1
polyval_generic        12288  1 polyval_clmulni
mousedev               24576  0
snd_hda_intel          65536  2
gf128mul               16384  1 polyval_generic
snd_compress           28672  1 snd_soc_core
snd_intel_dspcfg       40960  2 snd_hda_intel,snd_sof
ghash_clmulni_intel    16384  0
ac97_bus               12288  1 snd_soc_core
mac80211             1572864  1 ath10k_core
sha512_ssse3           53248  0
snd_intel_sdw_acpi     16384  1 snd_intel_dspcfg
snd_pcm_dmaengine      16384  1 snd_soc_core
sha256_ssse3           32768  0
snd_pci_ps             28672  0
sha1_ssse3             32768  0
snd_hda_codec         225280  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_rpl_pci_acp6x      16384  0
aesni_intel           360448  6
snd_acp_pci            12288  0
crypto_simd            16384  1 aesni_intel
snd_acp_legacy_common    16384  1 snd_acp_pci
snd_hda_core          151552  5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
cryptd                 28672  3 crypto_simd,ghash_clmulni_intel
snd_pci_acp6x          20480  0
libarc4                12288  1 mac80211
snd_hwdep              20480  2 snd_usb_audio,snd_hda_codec
snd_pci_acp5x          16384  0
hid_multitouch         32768  0
snd_pcm               204800  14 snd_sof_amd_acp,snd_hda_codec_hdmi,snd_pci_acp6x,snd_hda_intel,snd_usb_audio,snd_hda_codec,snd_sof,snd_compress,snd_soc_core,snd_sof_utils,snd_hda_core,snd_pci_ps,snd_pcm_dmaengine
r8169                 114688  0
snd_rn_pci_acp3x       24576  0
rapl                   20480  0
acer_wmi               36864  0
snd_acp_config         16384  8 snd_rn_pci_acp3x,snd_pci_acp6x,snd_pci_acp5x,snd_sof_amd_rembrandt,snd_sof_amd_vangogh,snd_acp_pci,snd_pci_ps,snd_sof_amd_renoir
cfg80211             1339392  3 ath,mac80211,ath10k_core
snd_timer              53248  3 snd_seq,snd_hrtimer,snd_pcm
sparse_keymap          12288  1 acer_wmi
realtek                40960  1
snd_soc_acpi           16384  2 snd_sof_amd_acp,snd_acp_config
snd                   155648  27 snd_ctl_led,snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_usb_audio,snd_usbmidi_lib,snd_hda_codec,snd_hda_codec_realtek,snd_sof,snd_timer,snd_compress,snd_soc_core,snd_ump,snd_pcm,snd_rawmidi
sp5100_tco             20480  0
mdio_devres            12288  1 r8169
wdat_wdt               20480  0
wmi_bmof               12288  0
pcspkr                 12288  0
i2c_piix4              32768  0
soundcore              16384  2 snd_ctl_led,snd
ccp                   159744  1 kvm_amd
i2c_amd_mp2_pci        24576  0
k10temp                16384  0
snd_pci_acp3x          16384  0
acpi_cpufreq           32768  0
rfkill                 40960  7 acer_wmi,bluetooth,cfg80211
libphy                229376  3 r8169,mdio_devres,realtek
acer_wireless          16384  0
i2c_hid_acpi           12288  0
i2c_hid                40960  1 i2c_hid_acpi
mac_hid                12288  0
crypto_user            20480  0
loop                   40960  0
fuse                  212992  5
dm_mod                225280  0
nfnetlink              20480  3 nf_conntrack_netlink
bpf_preload            20480  0
ip_tables              36864  2 iptable_filter,iptable_nat
x_tables               69632  8 xt_conntrack,iptable_filter,xt_tcpudp,xt_addrtype,xt_nat,ip_tables,iptable_nat,xt_MASQUERADE
ext4                 1175552  1
crc32c_generic         12288  0
crc16                  12288  2 bluetooth,ext4
mbcache                16384  1 ext4
jbd2                  221184  1 ext4
usbhid                 77824  0
amdgpu              12480512  12
i2c_algo_bit           20480  1 amdgpu
drm_ttm_helper         12288  1 amdgpu
ttm                   110592  2 amdgpu,drm_ttm_helper
serio_raw              16384  0
drm_exec               12288  1 amdgpu
atkbd                  40960  0
drm_suballoc_helper    12288  1 amdgpu
libps2                 20480  1 atkbd
amdxcp                 12288  1 amdgpu
drm_buddy              20480  1 amdgpu
vivaldi_fmap           12288  1 atkbd
nvme                   65536  2
gpu_sched              57344  1 amdgpu
crc32c_intel           16384  3
drm_display_helper    229376  1 amdgpu
xhci_pci               28672  0
nvme_core             245760  3 nvme
i8042                  53248  1 acer_wmi
cec                    86016  1 drm_display_helper
xhci_pci_renesas       24576  1 xhci_pci
nvme_common            24576  1 nvme_core
video                  77824  2 acer_wmi,amdgpu
serio                  28672  4 serio_raw,atkbd,i8042
wmi                    45056  3 video,acer_wmi,wmi_bmof
journalctl -xe
abr 19 06:22:32 angel-feliz rtkit-daemon[1250]: Supervising 10 threads of 7 processes of 1 users.
abr 19 06:22:32 angel-feliz rtkit-daemon[1250]: Successfully made thread 8217 of process 7752 owned by '1000' RT at priority 10.
abr 19 06:22:32 angel-feliz rtkit-daemon[1250]: Supervising 11 threads of 8 processes of 1 users.
abr 19 06:22:34 angel-feliz rtkit-daemon[1250]: Supervising 11 threads of 8 processes of 1 users.
abr 19 06:22:56 angel-feliz rtkit-daemon[1250]: Supervising 11 threads of 8 processes of 1 users.
abr 19 06:23:19 angel-feliz rtkit-daemon[1250]: Supervising 11 threads of 8 processes of 1 users.
abr 19 06:24:41 angel-feliz wpa_supplicant[662]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-68 noise=-97 txrate=6000
abr 19 06:25:06 angel-feliz rtkit-daemon[1250]: Supervising 10 threads of 7 processes of 1 users.
abr 19 06:25:06 angel-feliz rtkit-daemon[1250]: Successfully made thread 8527 of process 8238 owned by '1000' RT at priority 10.
abr 19 06:25:06 angel-feliz rtkit-daemon[1250]: Supervising 11 threads of 8 processes of 1 users.
abr 19 06:25:07 angel-feliz wpa_supplicant[662]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-62 noise=-98 txrate=6000
abr 19 06:25:08 angel-feliz rtkit-daemon[1250]: Supervising 11 threads of 8 processes of 1 users.
abr 19 06:25:29 angel-feliz sudo[8595]:    angel : TTY=pts/0 ; PWD=/home/angel ; USER=root ; COMMAND=/usr/bin/dmesg
abr 19 06:25:29 angel-feliz sudo[8595]: pam_unix(sudo:session): session opened for user root(uid=0) by angel(uid=1000)
abr 19 06:25:29 angel-feliz sudo[8595]: pam_unix(sudo:session): session closed for user root
abr 19 06:25:35 angel-feliz rtkit-daemon[1250]: Supervising 11 threads of 8 processes of 1 users.
abr 19 06:26:13 angel-feliz wpa_supplicant[662]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-89 noise=-98 txrate=6000
abr 19 06:26:13 angel-feliz wpa_supplicant[662]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-63 noise=-98 txrate=6000
abr 19 06:30:32 angel-feliz rtkit-daemon[1250]: Supervising 11 threads of 8 processes of 1 users.
abr 19 06:31:10 angel-feliz rtkit-daemon[1250]: Supervising 10 threads of 7 processes of 1 users.
abr 19 06:31:37 angel-feliz rtkit-daemon[1250]: Supervising 10 threads of 7 processes of 1 users.
abr 19 06:32:37 angel-feliz rtkit-daemon[1250]: Supervising 10 threads of 7 processes of 1 users.
abr 19 06:33:37 angel-feliz rtkit-daemon[1250]: Supervising 10 threads of 7 processes of 1 users.
abr 19 06:34:04 angel-feliz wpa_supplicant[662]: wlp2s0: WPA: Group rekeying completed with c0:f6:c2:78:30:44 [GTK=TKIP]
abr 19 06:34:37 angel-feliz rtkit-daemon[1250]: Supervising 10 threads of 7 processes of 1 users.
set mark: ...skipping...
lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
nvme0n1     259:0    0 953.9G  0 disk
β”œβ”€nvme0n1p1 259:1    0   100M  0 part /boot/efi
β”œβ”€nvme0n1p2 259:2    0    16M  0 part
β”œβ”€nvme0n1p3 259:3    0  97.9G  0 part
β”œβ”€nvme0n1p4 259:4    0   567M  0 part
└─nvme0n1p5 259:5    0 855.3G  0 part /
systemctl status
    State: running
    Units: 412 loaded (incl. loaded aliases)
     Jobs: 0 queued
   Failed: 0 units
    Since: Fri 2024-04-19 07:18:50 AST; 57min ago
  systemd: 255.4-1-manjaro
   CGroup: /
           β”œβ”€init.scope
           β”‚ └─1 /sbin/init splash
           β”œβ”€system.slice
           β”‚ β”œβ”€ModemManager.service
           β”‚ β”‚ └─742 /usr/bin/ModemManager
           β”‚ β”œβ”€NetworkManager.service
           β”‚ β”‚ └─666 /usr/bin/NetworkManager --no-daemon
           β”‚ β”œβ”€accounts-daemon.service
           β”‚ β”‚ └─877 /usr/lib/accounts-daemon
           β”‚ β”œβ”€avahi-daemon.service
           β”‚ β”‚ β”œβ”€668 "avahi-daemon: running [angel-feliz.local]"
           β”‚ β”‚ └─713 "avahi-daemon: chroot helper"
           β”‚ β”œβ”€bluetooth.service
           β”‚ β”‚ └─799 /usr/lib/bluetooth/bluetoothd
           β”‚ β”œβ”€colord.service
           β”‚ β”‚ └─1495 /usr/lib/colord
           β”‚ β”œβ”€containerd.service
           β”‚ β”‚ β”œβ”€ 823 /usr/bin/containerd
           β”‚ β”‚ └─3631 /usr/bin/containerd-shim-runc-v2 -namespace moby -id b4336d336ccd86b380cd253df805a121f6b27bdad9930b81b3d52a42feae4be5 -address /run/containerd/containerd.sock
           β”‚ β”œβ”€cronie.service
           β”‚ β”‚ └─834 /usr/sbin/crond -n
           β”‚ β”œβ”€cups.service
           β”‚ β”‚ └─810 /usr/bin/cupsd -l
           β”‚ β”œβ”€dbus-broker.service
           β”‚ β”‚ β”œβ”€664 /usr/bin/dbus-broker-launch --scope system --audit
           β”‚ β”‚ └─665 dbus-broker --log 4 --controller 9 --machine-id d462a153c48b45e58f043ea552ae2fe4 --max-bytes 536870912 --max-fds 4096 --max-matches 131072 --audit
           β”‚ β”œβ”€docker-b4336d336ccd86b380cd253df805a121f6b27bdad9930b81b3d52a42feae4be5.scope
           β”‚ β”‚ β”œβ”€3653 /usr/lib/rstudio-server/bin/rserver --server-daemonize 0 --auth-none 1
           β”‚ β”‚ β”œβ”€6181 /usr/lib/rstudio-server/bin/rsession -u rstudio --session-use-secure-cookies 0 --session-root-path / --session-same-site 0 --session-use-file-storage 1 --launcher-token DA67F045
           β”‚ β”‚ └─6200 /usr/local/lib/R/bin/exec/R --no-save --no-restore --vanilla -s -f /tmp/Rtmpx5iCD9/renv-watchdog-ea18c7ad35.R
           β”‚ β”œβ”€docker.service
           β”‚ β”‚ β”œβ”€ 910 /usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock
           β”‚ β”‚ β”œβ”€3606 /usr/bin/docker-proxy -proto tcp -host-ip 0.0.0.0 -host-port 8787 -container-ip 172.17.0.2 -container-port 8787
           β”‚ β”‚ └─3614 /usr/bin/docker-proxy -proto tcp -host-ip :: -host-port 8787 -container-ip 172.17.0.2 -container-port 8787
           β”‚ β”œβ”€lightdm.service
           β”‚ β”‚ β”œβ”€869 /usr/bin/lightdm
           β”‚ β”‚ └─876 /usr/lib/Xorg :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
           β”‚ β”œβ”€polkit.service
           β”‚ β”‚ └─669 /usr/lib/polkit-1/polkitd --no-debug
           β”‚ β”œβ”€rtkit-daemon.service
           β”‚ β”‚ └─1403 /usr/lib/rtkit-daemon
           β”‚ β”œβ”€system-syncthing.slice
           β”‚ β”‚ └─syncthing@angel.service
           β”‚ β”‚   β”œβ”€811 /usr/bin/syncthing serve --no-browser --no-restart --logflags=0
           β”‚ β”‚   └─839 /usr/bin/syncthing serve --no-browser --no-restart --logflags=0
           β”‚ β”œβ”€systemd-journald.service
           β”‚ β”‚ └─272 /usr/lib/systemd/systemd-journald
           β”‚ β”œβ”€systemd-logind.service
           β”‚ β”‚ └─671 /usr/lib/systemd/systemd-logind
           β”‚ β”œβ”€systemd-timesyncd.service
           β”‚ β”‚ └─653 /usr/lib/systemd/systemd-timesyncd
           β”‚ β”œβ”€systemd-udevd.service
           β”‚ β”‚ └─udev
           β”‚ β”‚   └─399 /usr/lib/systemd/systemd-udevd
           β”‚ β”œβ”€systemd-userdbd.service
           β”‚ β”‚ β”œβ”€ 371 /usr/lib/systemd/systemd-userdbd
           β”‚ β”‚ β”œβ”€7275 "systemd-userwork: waiting..."
           β”‚ β”‚ β”œβ”€7276 "systemd-userwork: waiting..."
           β”‚ β”‚ └─7401 "systemd-userwork: waiting..."
           β”‚ β”œβ”€udisks2.service
           β”‚ β”‚ └─1577 /usr/lib/udisks2/udisksd
           β”‚ β”œβ”€upower.service
           β”‚ β”‚ └─1460 /usr/lib/upowerd
           β”‚ └─wpa_supplicant.service
           β”‚   └─804 /usr/bin/wpa_supplicant -u -s -O /run/wpa_supplicant
           └─user.slice
             └─user-1000.slice
               β”œβ”€session-2.scope
               β”‚ β”œβ”€1271 lightdm --session-child 13 20
               β”‚ β”œβ”€1310 xfce4-session
               β”‚ β”œβ”€1368 /usr/bin/ssh-agent -s
               β”‚ β”œβ”€1378 xfwm4
               β”‚ β”œβ”€1411 xfce4-panel
               β”‚ β”œβ”€1428 Thunar --daemon
               β”‚ β”œβ”€1434 /usr/lib/xfce4/panel/wrapper-2.0 /usr/lib/xfce4/panel/plugins/libwhiskermenu.so 8 16777223 whiskermenu "Whisker Menu" "Show a menu to easily access installed applications"
               β”‚ β”œβ”€1438 /usr/lib/xfce4/panel/wrapper-2.0 /usr/lib/xfce4/panel/plugins/libbattery.so 14 16777224 battery "Battery Monitor" "Show and monitor the battery status"
               β”‚ β”œβ”€1440 /usr/lib/xfce4/panel/wrapper-2.0 /usr/lib/xfce4/panel/plugins/libsystray.so 6 16777225 systray "Status Tray Plugin" "Provides status notifier items (application indicators) and legacy systray items"
               β”‚ β”œβ”€1443 xfdesktop
               β”‚ β”œβ”€1444 /usr/lib/xfce4/panel/wrapper-2.0 /usr/lib/xfce4/panel/plugins/libpulseaudio-plugin.so 9 16777226 pulseaudio "PulseAudio Plugin" "Adjust the audio volume of the PulseAudio sound system"
               β”‚ β”œβ”€1480 xfce4-clipman
               β”‚ β”œβ”€1484 xiccd
               β”‚ β”œβ”€1485 xcape -e Super_L Alt_L F1
               β”‚ β”œβ”€1489 pamac-tray
               β”‚ β”œβ”€1494 msm_notifier
               β”‚ β”œβ”€1496 /usr/lib/geoclue-2.0/demos/agent
               β”‚ β”œβ”€1506 xfce4-screensaver
               β”‚ β”œβ”€1518 nm-applet
               β”‚ β”œβ”€1521 /usr/bin/python /usr/bin/blueman-applet
               β”‚ β”œβ”€1523 xfce4-power-manager
               β”‚ β”œβ”€1527 /usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1
               β”‚ β”œβ”€1708 /usr/bin/python /usr/bin/blueman-tray
               β”‚ β”œβ”€1756 /usr/lib/firefox/firefox
               β”‚ β”œβ”€1870 /usr/lib/firefox/firefox -contentproc -parentBuildID 20240416221418 -prefsLen 32178 -prefMapSize 243195 -appDir /usr/lib/firefox/browser {ca5e1c64-5e02-41a7-89e3-f3dc9f6b56cd} 1756 true socket
               β”‚ β”œβ”€1884 /usr/lib/firefox/firefox -contentproc -childID 1 -isForBrowser -prefsLen 32319 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {9c0ed008-b974-47c2-84f6-5a7f346a57f0} 1756 true tab
               β”‚ β”œβ”€1944 /usr/lib/firefox/firefox -contentproc -childID 2 -isForBrowser -prefsLen 38169 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {dfa5d816-c1dc-4295-b6c5-32282e9a89e6} 1756 true tab
               β”‚ β”œβ”€2011 /usr/lib/firefox/firefox -contentproc -parentBuildID 20240416221418 -sandboxingKind 0 -prefsLen 38223 -prefMapSize 243195 -appDir /usr/lib/firefox/browser {46e9594b-b5ee-4911-b35b-e09d0a3dd6a9} 1756 true utility
               β”‚ β”œβ”€2031 /usr/lib/firefox/firefox -contentproc -childID 4 -isForBrowser -prefsLen 31994 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {20593a5a-7871-4b00-9c0f-7c7ac9e10ff6} 1756 true tab
               β”‚ β”œβ”€2045 /usr/bin/keepassxc-proxy /home/angel/.mozilla/native-messaging-hosts/org.keepassxc.keepassxc_browser.json keepassxc-browser@keepassxc.org
               β”‚ β”œβ”€2159 /usr/lib/firefox/firefox -contentproc -childID 7 -isForBrowser -prefsLen 32051 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {36750c43-92b5-4886-b038-4a2d86f7ddcf} 1756 true tab
               β”‚ β”œβ”€2273 xfsettingsd --replace
               β”‚ β”œβ”€2333 /usr/lib/firefox/firefox -contentproc -childID 8 -isForBrowser -prefsLen 32051 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {da02aaa9-6b43-404b-8ef8-6de52f621366} 1756 true tab
               β”‚ β”œβ”€3070 /usr/lib/firefox/firefox -contentproc -childID 20 -isForBrowser -prefsLen 32051 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {1e721803-c03a-44bd-b333-a3da7c9f733a} 1756 true tab
               β”‚ β”œβ”€3194 /usr/lib/firefox/firefox -contentproc -childID 23 -isForBrowser -prefsLen 32051 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {ad978a30-263b-474f-917d-3eb2a63800f6} 1756 true tab
               β”‚ β”œβ”€3245 /usr/lib/firefox/firefox -contentproc -parentBuildID 20240416221418 -prefsLen 38280 -prefMapSize 243195 -appDir /usr/lib/firefox/browser {227e35b8-de54-41c0-aeac-901d3d3bc55a} 1756 true rdd
               β”‚ β”œβ”€4529 /usr/bin/xfce4-terminal
               β”‚ β”œβ”€4541 bash
               β”‚ β”œβ”€4734 /usr/lib/firefox/firefox -contentproc -childID 41 -isForBrowser -prefsLen 32051 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {93d03465-af5a-400f-b0ca-9ec55d4fb2f4} 1756 true tab
               β”‚ β”œβ”€5491 /usr/lib/firefox/firefox -contentproc -childID 56 -isForBrowser -prefsLen 32051 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {da59c34a-c2a1-43b8-bb01-9f1346230d36} 1756 true tab
               β”‚ β”œβ”€6138 /usr/lib/firefox/firefox -contentproc -childID 69 -isForBrowser -prefsLen 32051 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {542a984b-7bc1-4422-aaac-5133bebc791c} 1756 true tab
               β”‚ β”œβ”€6637 /usr/lib/firefox/firefox -contentproc -childID 73 -isForBrowser -prefsLen 32051 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {9ebfead5-83a2-4ea9-b7b0-a72dde83e2ff} 1756 true tab
               β”‚ β”œβ”€6952 /usr/lib/firefox/firefox -contentproc -childID 75 -isForBrowser -prefsLen 32051 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {758c66ce-b8a7-4f4f-8466-eeac76a7ed19} 1756 true tab
               β”‚ β”œβ”€7051 /usr/lib/firefox/firefox -contentproc -childID 76 -isForBrowser -prefsLen 32051 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {046eea1c-2ba1-41dc-a02f-9a5ca062d2f2} 1756 true tab
               β”‚ β”œβ”€7053 /usr/lib/firefox/firefox -contentproc -childID 77 -isForBrowser -prefsLen 32051 -prefMapSize 243195 -jsInitLen 234952 -parentBuildID 20240416221418 -greomni /usr/lib/firefox/omni.ja -appomni /usr/lib/firefox/browser/omni.ja -appDir /usr/lib/firefox/browser {52c1e989-5d89-46b6-adb9-3f6e48260718} 1756 true tab
               β”‚ β”œβ”€7399 systemctl status
               β”‚ β”œβ”€7400 less
               β”‚ └─7402 systemctl status
               └─user@1000.service
                 β”œβ”€app.slice
                 β”‚ β”œβ”€app-dbus\x2d:1.11\x2dorg.a11y.atspi.Registry.slice
                 β”‚ β”‚ └─dbus-:1.11-org.a11y.atspi.Registry@0.service
                 β”‚ β”‚   └─1362 /usr/lib/at-spi2-registryd --use-gnome-session
                 β”‚ β”œβ”€app-dbus\x2d:1.2\x2dorg.xfce.Xfconf.slice
                 β”‚ β”‚ └─dbus-:1.2-org.xfce.Xfconf@5.service
                 β”‚ β”‚   └─7281 /usr/lib/xfce4/xfconf/xfconfd
                 β”‚ β”œβ”€gnome-keyring-daemon.service
                 β”‚ β”‚ └─1302 /usr/bin/gnome-keyring-daemon --foreground --components=pkcs11,secrets --control-directory=/run/user/1000/keyring
                 β”‚ β”œβ”€gpg-agent.service
                 β”‚ β”‚ └─1376 /usr/bin/gpg-agent --supervised
                 β”‚ β”œβ”€xdg-desktop-portal-gtk.service
                 β”‚ β”‚ └─1597 /usr/lib/xdg-desktop-portal-gtk
                 β”‚ └─xfce4-notifyd.service
                 β”‚   └─1464 /usr/lib/xfce4/notifyd/xfce4-notifyd
                 β”œβ”€init.scope
                 β”‚ β”œβ”€1288 /usr/lib/systemd/systemd --user
                 β”‚ └─1290 "(sd-pam)"
                 └─session.slice
                   β”œβ”€at-spi-dbus-bus.service
                   β”‚ β”œβ”€1348 /usr/lib/at-spi-bus-launcher
                   β”‚ β”œβ”€1354 /usr/bin/dbus-broker-launch --config-file=/usr/share/defaults/at-spi2/accessibility.conf --scope user
                   β”‚ └─1355 dbus-broker --log 4 --controller 9 --machine-id d462a153c48b45e58f043ea552ae2fe4 --max-bytes 100000000000000 --max-fds 6400000 --max-matches 5000000000
                   β”‚ β”œβ”€1308 /usr/bin/dbus-broker-launch --scope user
                   β”‚ └─1309 dbus-broker --log 4 --controller 10 --machine-id d462a153c48b45e58f043ea552ae2fe4 --max-bytes 100000000000000 --max-fds 25000000000000 --max-matches 5000000000
                   β”œβ”€gvfs-afc-volume-monitor.service
                   β”‚ └─1656 /usr/lib/gvfs-afc-volume-monitor
                   β”œβ”€gvfs-daemon.service
                   β”‚ β”œβ”€1332 /usr/lib/gvfsd
                   β”‚ β”œβ”€1338 /usr/lib/gvfsd-fuse /run/user/1000/gvfs -f
                   β”‚ β”œβ”€1690 /usr/lib/gvfsd-trash --spawner :1.7 /org/gtk/gvfs/exec_spaw/0
                   β”‚ β”œβ”€5526 /usr/lib/gvfsd-network --spawner :1.7 /org/gtk/gvfs/exec_spaw/1
                   β”‚ └─5545 /usr/lib/gvfsd-dnssd --spawner :1.7 /org/gtk/gvfs/exec_spaw/3
                   β”œβ”€gvfs-gphoto2-volume-monitor.service
                   β”‚ └─1668 /usr/lib/gvfs-gphoto2-volume-monitor
                   β”œβ”€gvfs-metadata.service
                   β”‚ └─1699 /usr/lib/gvfsd-metadata
                   β”œβ”€gvfs-mtp-volume-monitor.service
                   β”‚ └─1662 /usr/lib/gvfs-mtp-volume-monitor
                   β”œβ”€gvfs-udisks2-volume-monitor.service
                   β”‚ └─1552 /usr/lib/gvfs-udisks2-volume-monitor
                   β”œβ”€pipewire-pulse.service
                   β”‚ └─1399 /usr/bin/pipewire-pulse
                   β”œβ”€pipewire.service
                   β”‚ └─1394 /usr/bin/pipewire
                   β”œβ”€wireplumber.service
                   β”‚ └─1398 /usr/bin/wireplumber
                   β”œβ”€xdg-desktop-portal.service
                   β”‚ └─1548 /usr/lib/xdg-desktop-portal
                   β”œβ”€xdg-document-portal.service
                   β”‚ β”œβ”€1562 /usr/lib/xdg-document-portal
                   β”‚ └─1592 fusermount3 -o rw,nosuid,nodev,fsname=portal,auto_unmount,subtype=portal -- /run/user/1000/doc
                   └─xdg-permission-store.service
                     └─1578 /usr/lib/xdg-permission-store
Thank you in advance for your time and assistance.
Look into power-saving. I think the name op the app is TLP. However, not using a laptop, I can’t give you more information than that.
tlp is part of the standard install with xfce, anyway. You can modify /etc/tlp.conf to figure out what you want to do, or install tlpui from the official repositories for a GUI.
He did apparently try that.
Just in case here is my current configuration
sudo cat /etc/tlp.conf
# /etc/tlp.conf - TLP user configuration (version 1.6.1)
# See full explanation: https://linrunner.de/tlp/settings
# Copyright (c) 2023 Thomas Koch <linrunner at gmx.net> and others.
# SPDX-License-Identifier: GPL-2.0-or-later
# Settings are read in the following order:
# 1. Intrinsic defaults
# 2. /etc/tlp.d/*.conf - Drop-in customization snippets
# 3. /etc/tlp.conf     - User configuration (this file)
# Notes:
# - In case of identical parameters, the last occurence has precedence
# - This also means, parameters enabled here will override anything else
# - However you may append values to a parameter already defined as intrinsic
#   default or in a previously read file: use PARAMETER+="add values"
# - IMPORTANT: all parameters here are disabled; remove the leading '#' if you
#   like to enable a feature without default or have a value different from the
#   default
# - Default *: intrinsic default that is effective when the parameter is missing
#   or disabled by a leading '#'; use PARAM="" to disable an intrinsic default
# - Default <none>: do nothing or use kernel/hardware defaults
# - IMPORTANT: parameters must always be specified pairwise i.e. for
#   both AC and BAT. Omitting one of the two makes the set value effective for
#   both power sources, since a change only occurs when different values are
#   defined.
# tlp - Parameters for power saving
# Set to 0 to disable, 1 to enable TLP.
# Default: 1
#TLP_ENABLE=1
# Control how warnings about invalid settings are issued:
#   0=disabled,
#   1=background tasks (boot, resume, change of power source) report to syslog,
#   2=shell commands report to the terminal (stderr),
#   3=combination of 1 and 2
# Default: 3
#TLP_WARN_LEVEL=3
# Operation mode when no power supply can be detected: AC, BAT.
# Concerns some desktop and embedded hardware only.
# Default: <none>
#TLP_DEFAULT_MODE=AC
# Operation mode select: 0=depend on power source, 1=always use TLP_DEFAULT_MODE
# Note: use in conjunction with TLP_DEFAULT_MODE=BAT for BAT settings on AC.
# Default: 0
#TLP_PERSISTENT_DEFAULT=0
# Power supply classes to ignore when determining operation mode: AC, USB, BAT.
# Separate multiple classes with spaces.
# Note: try on laptops where operation mode AC/BAT is incorrectly detected.
# Default: <none>
#TLP_PS_IGNORE="BAT"
# Seconds laptop mode has to wait after the disk goes idle before doing a sync.
# Non-zero value enables, zero disables laptop mode.
# Default: 0 (AC), 2 (BAT)
#DISK_IDLE_SECS_ON_AC=0
#DISK_IDLE_SECS_ON_BAT=2
# Dirty page values (timeouts in secs).
# Default: 15 (AC), 60 (BAT)
#MAX_LOST_WORK_SECS_ON_AC=15
#MAX_LOST_WORK_SECS_ON_BAT=60
# Select a CPU scaling driver operation mode.
# Intel CPU with intel_pstate driver:
#   active, passive.
# AMD Zen 2 or newer CPU with amd-pstate_driver as of kernel 6.3/6.4(*):
#   active, passive, guided(*).
# Default: <none>
#CPU_DRIVER_OPMODE_ON_AC=active
#CPU_DRIVER_OPMODE_ON_BAT=active
# Select a CPU frequency scaling governor.
# Intel CPU with intel_pstate driver or
# AMD CPU with amd-pstate driver in active mode ('amd-pstate-epp'):
#   performance, powersave(*).
# Intel CPU with intel_pstate driver in passive mode ('intel_cpufreq') or
# AMD CPU with amd-pstate driver in passive or guided mode ('amd-pstate') or
# Intel, AMD and other CPU brands with acpi-cpufreq driver:
#   conservative, ondemand(*), userspace, powersave, performance, schedutil(*).
# Use tlp-stat -p to show the active driver and available governors.
# Important:
#   Governors marked (*) above are power efficient for *almost all* workloads
#   and therefore kernel and most distributions have chosen them as defaults.
#   You should have done your research about advantages/disadvantages *before*
#   changing the governor.
# Default: <none>
#CPU_SCALING_GOVERNOR_ON_AC=powersave
#CPU_SCALING_GOVERNOR_ON_BAT=powersave
# Set the min/max frequency available for the scaling governor.
# Possible values depend on your CPU. For available frequencies see
# the output of tlp-stat -p.
# Notes:
# - Min/max frequencies must always be specified for both AC *and* BAT
# - Not recommended for use with the intel_pstate driver, use
#   CPU_MIN/MAX_PERF_ON_AC/BAT below instead
# Default: <none>
#CPU_SCALING_MIN_FREQ_ON_AC=0
#CPU_SCALING_MAX_FREQ_ON_AC=0
#CPU_SCALING_MIN_FREQ_ON_BAT=0
#CPU_SCALING_MAX_FREQ_ON_BAT=0
# Set CPU energy/performance policies EPP and EPB:
#   performance, balance_performance, default, balance_power, power.
# Values are given in order of increasing power saving.
# Requires:
# * Intel CPU
#   EPP: Intel Core i 6th gen. or newer CPU with intel_pstate driver
#   EPB: Intel Core i 2nd gen. or newer CPU with intel_pstate driver
#     as of kernel 5.2; alternatively module msr and
#     x86_energy_perf_policy from linux-tools
#   EPP and EPB are mutually exclusive: when EPP is available, Intel CPUs
#   will not honor EPB. Only the matching feature will be applied by TLP.
# * AMD Zen 2 or newer CPU
#   EPP: amd-pstate driver in active mode ('amd-pstate-epp') as of kernel 6.3
# Default: balance_performance (AC), balance_power (BAT)
#CPU_ENERGY_PERF_POLICY_ON_AC=balance_performance
#CPU_ENERGY_PERF_POLICY_ON_BAT=balance_power
# Set Intel CPU P-state performance: 0..100 (%).
# Limit the max/min P-state to control the power dissipation of the CPU.
# Values are stated as a percentage of the available performance.
# Requires Intel Core i 2nd gen. or newer CPU with intel_pstate driver.
# Default: <none>
#CPU_MIN_PERF_ON_AC=0
#CPU_MAX_PERF_ON_AC=100
#CPU_MIN_PERF_ON_BAT=0
#CPU_MAX_PERF_ON_BAT=30
# Set the CPU "turbo boost" (Intel) or "turbo core" (AMD) feature:
#   0=disable, 1=allow.
# Allows to raise the maximum frequency/P-state of some cores if the
# CPU chip is not fully utilized and below it's intended thermal budget.
# Note: a value of 1 does *not* activate boosting, it just allows it.
# Default: <none>
#CPU_BOOST_ON_AC=1
#CPU_BOOST_ON_BAT=0
# Set Intel/AMD CPU dynamic boost feature:
#   0=disable, 1=enable.
# Improve performance by increasing minimum P-state limit dynamically
# whenever a task previously waiting on I/O is selected to run.
# Requires:
# * Intel Core i  6th gen. or newer CPU: intel_pstate driver in active mode
# * AMD Zen 2 or newer CPU: amd-pstate driver in active mode ('amd-pstate-epp')
#   provided by a yet unreleased kernel 6.x
# Default: <none>
#CPU_HWP_DYN_BOOST_ON_AC=1
#CPU_HWP_DYN_BOOST_ON_BAT=0
# Kernel NMI Watchdog:
#   0=disable (default, saves power), 1=enable (for kernel debugging only).
# Default: 0
#NMI_WATCHDOG=0
# Select platform profile:
#   performance, balanced, low-power.
# Controls system operating characteristics around power/performance levels,
# thermal and fan speed. Values are given in order of increasing power saving.
# Note: check the output of tlp-stat -p to determine availability on your
# hardware and additional profiles such as: balanced-performance, quiet, cool.
# Default: <none>
#PLATFORM_PROFILE_ON_AC=performance
#PLATFORM_PROFILE_ON_BAT=low-power
# System suspend mode:
#   s2idle: Idle standby - a pure software, light-weight, system sleep state,
#   deep: Suspend to RAM - the whole system is put into a low-power state,
#     except for memory, usually resulting in higher savings than s2idle.
# CAUTION: changing suspend mode may lead to system instability and even
# data loss. As for the availability of different modes on your system,
# check the output of tlp-stat -s. If unsure, stick with the system default
# by not enabling this.
# Default: <none>
#MEM_SLEEP_ON_AC=s2idle
#MEM_SLEEP_ON_BAT=deep
# Define disk devices on which the following DISK/AHCI_RUNTIME parameters act.
# Separate multiple devices with spaces.
# Devices can be specified by disk ID also (lookup with: tlp diskid).
# Default: "nvme0n1 sda"
#DISK_DEVICES="nvme0n1 sda"
# Disk advanced power management level: 1..254, 255 (max saving, min, off).
# Levels 1..127 may spin down the disk; 255 allowable on most drives.
# Separate values for multiple disks with spaces. Use the special value 'keep'
# to keep the hardware default for the particular disk.
# Default: 254 (AC), 128 (BAT)
#DISK_APM_LEVEL_ON_AC="254 254"
#DISK_APM_LEVEL_ON_BAT="128 128"
# Exclude disk classes from advanced power management (APM):
#   sata, ata, usb, ieee1394.
# CAUTION: USB and IEEE1394 disks may fail to mount or data may get corrupted
# with APM enabled. Be careful and make sure you have backups of all affected
# media before removing 'usb' or 'ieee1394' from the denylist!
# Default: "usb ieee1394"
#DISK_APM_CLASS_DENYLIST="usb ieee1394"
# Hard disk spin down timeout:
#   0:        spin down disabled
#   1..240:   timeouts from 5s to 20min (in units of 5s)
#   241..251: timeouts from 30min to 5.5 hours (in units of 30min)
# See 'man hdparm' for details.
# Default: <none>
#DISK_SPINDOWN_TIMEOUT_ON_AC="0 0"
#DISK_SPINDOWN_TIMEOUT_ON_BAT="0 0"
# Select I/O scheduler for the disk devices.
# Multi queue (blk-mq) schedulers:
#   mq-deadline(*), none, kyber, bfq
# Single queue schedulers:
#   deadline(*), cfq, bfq, noop
# (*) recommended.
# to keep the kernel default scheduler for the particular disk.
# Notes:
# - Multi queue (blk-mq) may need kernel boot option 'scsi_mod.use_blk_mq=1'
#   and 'modprobe mq-deadline-iosched|kyber|bfq' on kernels < 5.0
# - Single queue schedulers are legacy now and were removed together with
#   the old block layer in kernel 5.0
# Default: keep
#DISK_IOSCHED="mq-deadline mq-deadline"
# AHCI link power management (ALPM) for SATA disks:
#   min_power, med_power_with_dipm(*), medium_power, max_performance.
# (*) recommended.
# Multiple values separated with spaces are tried sequentially until success.
# Default: med_power_with_dipm (AC & BAT)
#SATA_LINKPWR_ON_AC="med_power_with_dipm"
#SATA_LINKPWR_ON_BAT="med_power_with_dipm"
# Exclude SATA links from AHCI link power management (ALPM).
# SATA links are specified by their host. Refer to the output of
# tlp-stat -d to determine the host; the format is "hostX".
# Separate multiple hosts with spaces.
# Default: <none>
#SATA_LINKPWR_DENYLIST="host1"
# Runtime Power Management for NVMe, SATA, ATA and USB disks
# as well as SATA ports:
#   on=disable, auto=enable.
# Note: SATA controllers are PCIe bus devices and handled by RUNTIME_PM further
# down.
# Default: on (AC), auto (BAT)
#AHCI_RUNTIME_PM_ON_AC=on
#AHCI_RUNTIME_PM_ON_BAT=auto
# Seconds of inactivity before disk is suspended.
# Note: effective only when AHCI_RUNTIME_PM_ON_AC/BAT is activated.
# Default: 15
#AHCI_RUNTIME_PM_TIMEOUT=15
# Power off optical drive in UltraBay/MediaBay: 0=disable, 1=enable.
# Drive can be powered on again by releasing (and reinserting) the eject lever
# or by pressing the disc eject button on newer models.
# Note: an UltraBay/MediaBay hard disk is never powered off.
# Default: 0
#BAY_POWEROFF_ON_AC=0
#BAY_POWEROFF_ON_BAT=0
# Optical drive device to power off
# Default: sr0
#BAY_DEVICE="sr0"
# Set the min/max/turbo frequency for the Intel GPU.
# Possible values depend on your hardware. For available frequencies see
# the output of tlp-stat -g.
# Default: <none>
#INTEL_GPU_MIN_FREQ_ON_AC=0
#INTEL_GPU_MIN_FREQ_ON_BAT=0
#INTEL_GPU_MAX_FREQ_ON_AC=0
#INTEL_GPU_MAX_FREQ_ON_BAT=0
#INTEL_GPU_BOOST_FREQ_ON_AC=0
#INTEL_GPU_BOOST_FREQ_ON_BAT=0
# AMD GPU power management.
# Performance level (DPM): auto, low, high; auto is recommended.
# Note: requires amdgpu or radeon driver.
# Default: auto
#RADEON_DPM_PERF_LEVEL_ON_AC=auto
#RADEON_DPM_PERF_LEVEL_ON_BAT=auto
# Dynamic power management method (DPM): balanced, battery, performance.
# Note: radeon driver only.
# Default: <none>
#RADEON_DPM_STATE_ON_AC=performance
#RADEON_DPM_STATE_ON_BAT=battery
# Graphics clock speed (profile method): low, mid, high, auto, default;
# auto = mid on BAT, high on AC.
# Note: radeon driver on legacy ATI hardware only (where DPM is not available).
# Default: default
#RADEON_POWER_PROFILE_ON_AC=default
#RADEON_POWER_PROFILE_ON_BAT=default
# Wi-Fi power saving mode: on=enable, off=disable.
# Default: off (AC), on (BAT)
#WIFI_PWR_ON_AC=off
#WIFI_PWR_ON_BAT=on
# Disable Wake-on-LAN: Y/N.
# Default: Y
#WOL_DISABLE=Y
# Enable audio power saving for Intel HDA, AC97 devices (timeout in secs).
# A value of 0 disables, >= 1 enables power saving.
# Note: 1 is recommended for Linux desktop environments with PulseAudio,
# systems without PulseAudio may require 10.
# Default: 1
#SOUND_POWER_SAVE_ON_AC=1
#SOUND_POWER_SAVE_ON_BAT=1
# Disable controller too (HDA only): Y/N.
# Note: effective only when SOUND_POWER_SAVE_ON_AC/BAT is activated.
# Default: Y
#SOUND_POWER_SAVE_CONTROLLER=Y
# PCIe Active State Power Management (ASPM):
#   default(*), performance, powersave, powersupersave.
# (*) keeps BIOS ASPM defaults (recommended)
# Default: <none>
#PCIE_ASPM_ON_AC=default
#PCIE_ASPM_ON_BAT=default
# Runtime Power Management for PCIe bus devices: on=disable, auto=enable.
#RUNTIME_PM_ON_AC=on
#RUNTIME_PM_ON_BAT=auto
# Exclude listed PCIe device adresses from Runtime PM.
# Note: this preserves the kernel driver default, to force a certain state
# use RUNTIME_PM_ENABLE/DISABLE instead.
# Separate multiple addresses with spaces.
# Use lspci to get the adresses (1st column).
# Default: <none>
#RUNTIME_PM_DENYLIST="11:22.3 44:55.6"
# Exclude PCIe devices assigned to the listed drivers from Runtime PM.
# Separate multiple drivers with spaces.
# Default: "mei_me nouveau radeon", use "" to disable completely.
#RUNTIME_PM_DRIVER_DENYLIST="mei_me nouveau radeon"
# Permanently enable/disable Runtime PM for listed PCIe device addresses
# (independent of the power source). This has priority over all preceding
# Runtime PM settings. Separate multiple addresses with spaces.
# Default: <none>
#RUNTIME_PM_ENABLE="11:22.3"
#RUNTIME_PM_DISABLE="44:55.6"
# Set to 0 to disable, 1 to enable USB autosuspend feature.
# Default: 1
USB_AUTOSUSPEND=1
# Exclude listed devices from USB autosuspend (separate with spaces).
# Use lsusb to get the ids.
# Note: input devices (usbhid) and libsane-supported scanners are excluded
# automatically.
# Default: <none>
#USB_DENYLIST="1111:2222 3333:4444"
# Exclude audio devices from USB autosuspend:
#   0=do not exclude, 1=exclude.
# Default: 1
#USB_EXCLUDE_AUDIO=1
# Exclude bluetooth devices from USB autosuspend:
# Default: 0
USB_EXCLUDE_BTUSB=0
# Exclude phone devices from USB autosuspend:
#   0=do not exclude, 1=exclude (enable charging).
# Default: 0
USB_EXCLUDE_PHONE=0
# Exclude printers from USB autosuspend:
# Default: 1
#USB_EXCLUDE_PRINTER=1
# Exclude WWAN devices from USB autosuspend:
# Default: 0
USB_EXCLUDE_WWAN=0
# Allow USB autosuspend for listed devices even if already denylisted or
# excluded above (separate with spaces). Use lsusb to get the ids.
# Default: 0
#USB_ALLOWLIST="1111:2222 3333:4444"
# Set to 1 to disable autosuspend before shutdown, 0 to do nothing
# Note: use as a workaround for USB devices that cause shutdown problems.
# Default: 0
#USB_AUTOSUSPEND_DISABLE_ON_SHUTDOWN=0
# Restore radio device state (Bluetooth, WiFi, WWAN) from previous shutdown
# on system startup: 0=disable, 1=enable.
# Note: the parameters DEVICES_TO_DISABLE/ENABLE_ON_STARTUP/SHUTDOWN below
# are ignored when this is enabled.
# Default: 0
#RESTORE_DEVICE_STATE_ON_STARTUP=0
# Radio devices to disable on startup: bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_DISABLE_ON_STARTUP="bluetooth nfc wifi wwan"
# Radio devices to enable on startup: bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_ENABLE_ON_STARTUP="wifi"
# Radio devices to disable on shutdown: bluetooth, nfc, wifi, wwan.
# Note: use as a workaround for devices that are blocking shutdown.
# Default: <none>
#DEVICES_TO_DISABLE_ON_SHUTDOWN="bluetooth nfc wifi wwan"
# Radio devices to enable on shutdown: bluetooth, nfc, wifi, wwan.
# (to prevent other operating systems from missing radios).
# Default: <none>
#DEVICES_TO_ENABLE_ON_SHUTDOWN="wwan"
# Radio devices to enable on AC: bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_ENABLE_ON_AC="bluetooth nfc wifi wwan"
# Radio devices to disable on battery: bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_DISABLE_ON_BAT="bluetooth nfc wifi wwan"
# Radio devices to disable on battery when not in use (not connected):
#   bluetooth, nfc, wifi, wwan.
# Default: <none>
#DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth nfc wifi wwan"
# Battery Care -- Charge thresholds
# Charging starts when the charger is connected and the charge level
# is below the start threshold. Charging stops when the charge level
# is above the stop threshold.
# Required hardware: Lenovo ThinkPads and select other laptop brands
# are driven via specific plugins
# - Active plugin and support status are shown by tlp-stat -b
# - Vendor specific threshold levels are shown by tlp-stat -b, some
#   laptops support only 1 (on)/ 0 (off) instead of a percentage level
# - When your hardware supports a start *and* a stop threshold, you must
#   specify both, otherwise TLP will refuse to apply the single threshold
# - When your hardware supports only a stop threshold, set the start
#   value to 0
# - Older ThinkPads may require an external kernel module, refer to the
#   output of tlp-stat -b
# For further explanation and vendor specific details refer to
# - https://linrunner.de/tlp/settings/battery.html
# - https://linrunner.de/tlp/settings/bc-vendors.html
# BAT0: Primary / Main / Internal battery
# Note: also use for batteries BATC, BATT and CMB0
# Default: <none>
# Battery charge level below which charging will begin.
#START_CHARGE_THRESH_BAT0=75
# Battery charge level above which charging will stop.
#STOP_CHARGE_THRESH_BAT0=80
# BAT1: Secondary / Ultrabay / Slice / Replaceable battery
# Note: primary on some laptops
# Default: <none>
#START_CHARGE_THRESH_BAT1=75
#STOP_CHARGE_THRESH_BAT1=80
# Restore charge thresholds when AC is unplugged: 0=disable, 1=enable.
# Default: 0
#RESTORE_THRESHOLDS_ON_BAT=1
# Control battery care drivers: 0=disable, 1=enable.
# Default: 1 (all)
#NATACPI_ENABLE=1
#TPACPI_ENABLE=1
#TPSMAPI_ENABLE=1
# tlp-rdw - Parameters for the radio device wizard
# Possible devices: bluetooth, wifi, wwan.
# Separate multiple radio devices with spaces.
# Default: <none> (for all parameters below)
# Radio devices to disable on connect.
#DEVICES_TO_DISABLE_ON_LAN_CONNECT="wifi wwan"
#DEVICES_TO_DISABLE_ON_WIFI_CONNECT="wwan"
#DEVICES_TO_DISABLE_ON_WWAN_CONNECT="wifi"
# Radio devices to enable on disconnect.
#DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi wwan"
#DEVICES_TO_ENABLE_ON_WIFI_DISCONNECT=""
#DEVICES_TO_ENABLE_ON_WWAN_DISCONNECT=""
# Radio devices to enable/disable when docked.
#DEVICES_TO_ENABLE_ON_DOCK=""
#DEVICES_TO_DISABLE_ON_DOCK=""
# Radio devices to enable/disable when undocked.
#DEVICES_TO_ENABLE_ON_UNDOCK="wifi"
#DEVICES_TO_DISABLE_ON_UNDOCK=""
don’t make us hunt for the changes you made
these are your changes, you should know what they are doing to your system.
I ended undoing all changes as they didn’t solve the problem.
I played them just because ChatGPT suggest me to apply them, but I am not sure what they are doing.
What about Google (or any other search engine)
… I still think that Google is good at what it is supposed to do …
Why people would use β€œAI” instead of their own capacity to read and understand and ultimately know
I’ll likely never understand.
It’s your system.
You need to understand.
Not the β€œAI” - which might only pretend to β€œunderstand” …
Use your brain, your own capacity to think …
do not outsource it :wink:
@anon33601770, you are totally right,
I know this experience will help me to start getting that knowledge
It is actually enabled…?!
@megavolt, you’re right, that is the current value.
Rebooting temporarily solves the problem only if USB_AUTOSUSPEND=1.
I found out that I don’t need to fully charge my battery to get the error. Any time I disconnect my charger, I get the same problem.
It’s interesting that the problem also interrupts any video I could be watching. But that’s not a huge deal as I just need to reload the page to continue working as usual. However, that could also be a clue.
Try setting that to 0:
USB_AUTOSUSPEND=0
Restart the PC (I don’t know the service name, so the PC it is.) Test if it’s better.
What @Mirdarthos said - set it to 0
The description clearly says:
# Default: 1
Same with all the other β€œchanges” you made:
you did in fact change nothing!
All you did is to uncomment the option (you just removed the # in front of the line)
But these are the defaults already.
You need to actually change the number from 1 to 0 or vice versa - to change what is already the default.
okay… but makes no sense.
hm… usually it should continue working until you re-plugin the usb device on battery mode…
Saving power also affects the CPU/GPU. Certainly it’s pretty aggressive by default. On low budget systems it would have a visible impact on performance.
PROBLEM SOLVED
I was certain that this was a problem related to battery management. To confirm this, I disabled all TLP settings by TEMPORALLY changing TLP_ENABLE from 1 to 0 in the /etc/tlp.conf file, as explained in the Troubleshooting Guide and it worked.
I set the following options in TLPUI, as I don’t really need to stop any USB devices based on battery level.
Then, I found a really good description of the problem I am facing in the Frequently Asked Questions section from USB Devices. The solution was to apply the next two lines in the /etc/tlp.conf:
  1. Disable runtime power management for USB3 controllers by adding xhci_hcd
RUNTIME_PM_DRIVER_DENYLIST="mei_me nouveau radeon xhci_hcd"
This step was really interesting as the last line of sudo dmesg | tail showed [ 2861.187526] xhci_hcd 0000:05:00.3: WARNING: Host System Error, so I knew that I was getting closer to solving the problem.
I rebooted my machine, but that didn’t solve the problem, so I applied the second step:
  1. Disable runtime power management for AHCI devices by changing the next line in the /etc/tlp.conf
AHCI_RUNTIME_PM_ON_BAT=on
Now, after rebooting the machine, THE PROBLEM WAS SOLVED.
Thanks for helping me think through this problem.
Switching off the USB_AUTOSUSPEND option as shown in the GUI (your posted image) is exactly the same as the resolution that @Mirdarthos has already given to you to change in /etc/tlp.conf.
However, I suppose the other settings also contributed. Cheers.
