I have manjaro xfce version, new installation. everything updated.
The problem is when i insert a usb device it’s not working, not showing anywhere including “lsusb”. But when i restart my PC; everything is working. I need to restart the PC everytime i plug a usb device.
Any suggestion?
Olli
1 March 2021 16:43
2
please may you post the output of ‘inxi -Fxz’ to get a better overview.
here “inxi -Fxz” results:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: Xfce 4.16.0 Distro: Manjaro Linux
Type: Desktop Mobo: ASUSTeK model: M3A v: Rev 1.xx serial: <filter>
BIOS: American Megatrends v: 1206 date: 06/11/2010
Info: Quad Core model: AMD Phenom 9500 bits: 64 type: MCP arch: K10 rev: 2
L2 cache: 2 MiB
flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 17611
Speed: 1100 MHz min/max: 1100/2200 MHz Core speeds (MHz): 1: 2200 2: 1100
3: 1100 4: 1100
Device-1: AMD RV630 PRO [Radeon HD 2600 PRO] vendor: PC Partner Limited
driver: radeon v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.10 driver: loaded: ati,radeon
unloaded: modesetting resolution: 1024x768~60Hz
OpenGL: renderer: AMD RV630 (DRM 2.50.0 / 5.9.16-1-MANJARO LLVM 11.1.0)
v: 3.3 Mesa 20.3.4 direct render: Yes
Device-1: AMD SBx00 Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:14.2
Device-2: AMD RV630 HDMI Audio [Radeon HD 2600 PRO/XT / HD 3610]
vendor: PC Partner Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Qualcomm Atheros Attansic L1 Gigabit Ethernet
vendor: ASUSTeK P5B-MX/WiFi-AP P5KPL-VM driver: atl1 v: kernel port: e000
bus ID: 02:00.0
Device-2: Realtek RTL8192CU 802.11n WLAN Adapter type: USB
driver: rtl8192cu bus ID: 1-4:4
IF: wlp0s19f5u4 state: up mac: <filter>
Local Storage: total: 298.09 GiB used: 18.37 GiB (6.2%)
ID-1: /dev/sda vendor: Samsung model: HD321KJ size: 298.09 GiB
ID-1: / size: 277.61 GiB used: 18.37 GiB (6.6%) fs: ext4 dev: /dev/sda1
ID-1: swap-1 type: partition size: 15.04 GiB used: 0 KiB (0.0%)
dev: /dev/sda2
System Temperatures: cpu: 56.0 C mobo: 32.0 C gpu: radeon temp: 69.0 C
Fan Speeds (RPM): cpu: 2689 psu: 0 case-1: 0
Power: 12v: 11.71 5v: N/A 3.3v: 3.28 vbat: N/A
Processes: 183 Uptime: 32m Memory: 2.92 GiB used: 1.36 GiB (46.7%)
Init: systemd Compilers: gcc: 10.2.0 Packages: 1189 Shell: Bash v: 5.1.0
inxi: 3.3.01
I have the same problem running KDE Plasma on a Lenovo ThinkPad T495, so it could be related to the hardware not the desktop. Any similarities?
If it works after a reboot, maybe you did a system update before? If the kernel is updated, you have to reboot.
