So after todays recent update for the Stable branch every USB device no longer works on my k570ZD laptop, it worked yesterday before i updated so im guessing its something with a kernel or other driver update
Here is the output of inxi -Fxz
Kernel: 5.14.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: GNOME 40.5 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X570ZD_K570ZD
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X570ZD v: 1.0 serial: <filter>
UEFI: American Megatrends v: X570ZD.312 date: 02/25/2020
ID-1: BAT0 charge: 16.3 Wh (41.2%) condition: 39.6/48.1 Wh (82.3%)
volts: 11.7 min: 11.7 model: ASUSTeK ASUS Battery status: Discharging
Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen rev: 0 cache: L2: 2 MiB
bogomips: 31954
Speed: 1569 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz):
1: 1569 2: 1894 3: 1700 4: 2390 5: 1519 6: 1491 7: 2269 8: 1977
Device-1: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: ASUSTeK
driver: nvidia v: 470.63.01 bus-ID: 01:00.0
Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 05:00.0
Display: x11 server: X.org 1.20.13 driver: loaded: modesetting,nvidia
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2
v: 4.6.0 NVIDIA 470.63.01 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 05:00.1
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 05:00.6
Sound Server-1: ALSA v: k5.14.10-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.19 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.38 running: no
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: AzureWave driver: rtw_8822be v: N/A port: e000 bus-ID: 03:00.0
vendor: ASUSTeK driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 387.53 GiB used: 70.05 GiB (18.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLW256HEHP-00000
size: 238.47 GiB temp: 35.9 C
ID-2: /dev/sda vendor: Hitachi model: HTS543216A7A384 size: 149.05 GiB
ID-1: / size: 39.11 GiB used: 16.73 GiB (42.8%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 512 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 191.85 GiB used: 36.04 GiB (18.8%) fs: ext4
dev: /dev/nvme0n1p4
ID-1: swap-1 type: partition size: 1.95 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p3
System Temperatures: cpu: 55.9 C mobo: 55.0 C
Fan Speeds (RPM): cpu: 2200
GPU: device: nvidia screen: :0.0 temp: 56 C device: amdgpu temp: 55.0 C
Processes: 284 Uptime: 10m Memory: 6.73 GiB used: 2.04 GiB (30.3%)
Init: systemd Compilers: gcc: 11.1.0 Packages: 1413 Shell: Zsh v: 5.8
inxi: 3.3.06
Update: It seems to be an issue with the latest 5.14 kernel, as it works just fine on 5.14.7
Update 2: Switching to Xorg seems to fix it, so ill be using it for the time being
