Hey everyone,
I want to connect my Huawei Mate 10 lite via usb to my laptop, but the smartphone is not detected, yet the phone is charging.
The same problem occurs when I try to connect my Tolino Shine, the device is not detected but it starts to charge.
I exchanged the usb cable, but the problem persists.
I also tried to connect 2 separate wireless mouses. The touchpad moves the cursor, but any of the mouses doesn’t…
A loooong google search did not yield any result.
output of lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
output of usb-devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 4
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev=05.15
S: Manufacturer=Linux 5.15.7-1-MANJARO xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=0000:04:00.3
C: #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=10000 MxCh= 4
D: Ver= 3.10 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev=05.15
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
S: SerialNumber=0000:04:00.4
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=10000 MxCh= 1
output of sudo dmesg | tail -n 50
before i connect my phone
[ 6535.256212] audit: type=1130 audit(1640540155.367:226): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6547.358978] pci_bus 0000:01: Allocating resources
[ 6547.358999] pci_bus 0000:02: Allocating resources
[ 6547.359424] pci_bus 0000:03: Allocating resources
[ 6559.399651] audit: type=1334 audit(1640540179.507:227): prog-id=47 op=LOAD
[ 6559.399894] audit: type=1334 audit(1640540179.507:228): prog-id=48 op=LOAD
[ 6559.400048] audit: type=1334 audit(1640540179.507:229): prog-id=49 op=LOAD
[ 6559.504226] audit: type=1130 audit(1640540179.611:230): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6565.293460] audit: type=1131 audit(1640540185.401:231): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6565.331906] audit: type=1334 audit(1640540185.441:232): prog-id=0 op=UNLOAD
[ 6565.331917] audit: type=1334 audit(1640540185.441:233): prog-id=0 op=UNLOAD
[ 6565.331921] audit: type=1334 audit(1640540185.441:234): prog-id=0 op=UNLOAD
[ 6589.567824] audit: type=1131 audit(1640540209.675:235): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6589.662895] audit: type=1334 audit(1640540209.771:236): prog-id=0 op=UNLOAD
[ 6589.662913] audit: type=1334 audit(1640540209.771:237): prog-id=0 op=UNLOAD
[ 6589.662919] audit: type=1334 audit(1640540209.771:238): prog-id=0 op=UNLOAD
[ 6654.558125] rtw_8822be 0000:03:00.0: firmware failed to leave lps state
[ 6690.505009] wlo1: AP 5c:49:79:05:dc:36 changed bandwidth, new config is 2437.000 MHz, width 2 (2447.000/0 MHz)
[ 6690.688278] wlo1: AP 5c:49:79:05:dc:36 changed bandwidth, new config is 2437.000 MHz, width 1 (2437.000/0 MHz)
[ 6695.544775] rtw_8822be 0000:03:00.0: firmware failed to leave lps state
[ 6696.051440] rtw_8822be 0000:03:00.0: failed to get tx report from firmware
[ 6696.291877] rtw_8822be 0000:03:00.0: timed out to flush queue 2
[ 6696.291964] rtw_8822be 0000:03:00.0: sta 5c:49:79:05:dc:36 with macid 0 left
[ 6696.910826] wlo1: authenticate with e8:df:70:21:20:7a
[ 6697.441505] wlo1: send auth to e8:df:70:21:20:7a (try 1/3)
[ 6697.445155] wlo1: authenticated
[ 6697.448141] wlo1: associate with e8:df:70:21:20:7a (try 1/3)
[ 6697.458748] wlo1: RX AssocResp from e8:df:70:21:20:7a (capab=0x1431 status=0 aid=2)
[ 6697.458798] rtw_8822be 0000:03:00.0: sta e8:df:70:21:20:7a joined with macid 0
[ 6697.459099] wlo1: associated
[ 6697.501583] wlo1: Limiting TX power to 20 (20 - 0) dBm as advertised by e8:df:70:21:20:7a
[ 6697.744602] audit: type=1130 audit(1640540317.853:239): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6708.016346] audit: type=1131 audit(1640540328.124:240): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6749.265092] pci_bus 0000:01: Allocating resources
[ 6749.265397] pci_bus 0000:02: Allocating resources
[ 6749.265582] pci_bus 0000:03: Allocating resources
[ 6811.571454] rtw_8822be 0000:03:00.0: firmware failed to leave lps state
[ 6817.039790] pci_bus 0000:01: Allocating resources
[ 6817.039812] pci_bus 0000:02: Allocating resources
[ 6817.040106] pci_bus 0000:03: Allocating resources
[ 6927.043468] pci_bus 0000:01: Allocating resources
[ 6927.043758] pci_bus 0000:02: Allocating resources
[ 6927.043893] pci_bus 0000:03: Allocating resources
[ 7022.184970] pci_bus 0000:01: Allocating resources
[ 7022.185055] pci_bus 0000:02: Allocating resources
[ 7022.185437] pci_bus 0000:03: Allocating resources
[ 7125.131848] audit: type=1100 audit(1640540745.242:241): pid=16695 uid=1000 auid=1000 ses=4 msg='op=PAM:authentication grantors=pam_unix acct="janst" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 7125.139618] audit: type=1101 audit(1640540745.249:242): pid=16695 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="janst" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 7125.141371] audit: type=1110 audit(1640540745.249:243): pid=16695 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 7125.147420] audit: type=1105 audit(1640540745.255:244): pid=16695 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
and after
[ 7125.166211] audit: type=1106 audit(1640540745.275:245): pid=16695 uid=1000 auid=1000 ses=4 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 7125.166335] audit: type=1104 audit(1640540745.275:246): pid=16695 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 7135.776847] audit: type=1101 audit(1640540755.885:247): pid=16705 uid=1000 auid=1000 ses=4 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="janst" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 7135.778541] audit: type=1110 audit(1640540755.889:248): pid=16705 uid=1000 auid=1000 ses=4 msg='op=PAM:setcred grantors=pam_env,pam_unix acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 7135.784284] audit: type=1105 audit(1640540755.892:249): pid=16705 uid=1000 auid=1000 ses=4 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
edit:
output of journalctl | grep -i usb | tail -n 50
after disconnect and reconnect
Dez 26 16:46:58 jan-pc kernel: usb 1-3: new high-speed USB device number 3 using xhci_hcd
Dez 26 16:46:58 jan-pc kernel: usb 1-3: device descriptor read/all, error -71
Dez 26 16:46:58 jan-pc kernel: usb usb1-port3: attempt power cycle
Dez 26 16:46:58 jan-pc kernel: usb 1-3: new high-speed USB device number 4 using xhci_hcd
Dez 26 16:46:58 jan-pc kernel: usb 1-3: Device not responding to setup address.
Dez 26 16:46:58 jan-pc kernel: usb 1-3: new high-speed USB device number 5 using xhci_hcd
Dez 26 16:46:58 jan-pc kernel: usb 1-3: device descriptor read/8, error -71
Dez 26 16:46:58 jan-pc kernel: usb 1-3: unable to read config index 0 descriptor/start: -71
Dez 26 16:46:58 jan-pc kernel: usb 1-3: can't read configurations, error -71
Dez 26 16:46:58 jan-pc kernel: usb usb1-port3: unable to enumerate USB device
Dez 26 16:46:59 jan-pc kernel: usb 1-4: new high-speed USB device number 6 using xhci_hcd
Dez 26 16:46:59 jan-pc kernel: usbcore: registered new interface driver btusb
Dez 26 16:46:59 jan-pc kernel: usb 1-4: New USB device found, idVendor=04f2, idProduct=b653, bcdDevice=32.58
Dez 26 16:46:59 jan-pc kernel: usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Dez 26 16:46:59 jan-pc kernel: usb 1-4: Product: HP Wide Vision HD Camera
Dez 26 16:46:59 jan-pc kernel: usb 1-4: Manufacturer: Chicony
Dez 26 16:46:59 jan-pc mtp-probe[761]: checking bus 3, device 2: "/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1"
Dez 26 16:46:59 jan-pc mtp-probe[869]: checking bus 1, device 6: "/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-4"
Dez 26 16:47:00 jan-pc kernel: usb 3-1: Found UVC 1.00 device HP IR Camera (04f2:b654)
Dez 26 16:47:00 jan-pc kernel: usb 3-1: Failed to query (GET_INFO) UVC control 2 on unit 1: -32 (exp. 1).
Dez 26 16:47:00 jan-pc kernel: usb 3-1: Failed to query (GET_INFO) UVC control 4 on unit 1: -32 (exp. 1).
Dez 26 16:47:00 jan-pc kernel: input: HP IR Camera: HP IR Camera as /devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1:1.0/input/input25
Dez 26 16:47:00 jan-pc kernel: usb 1-4: Found UVC 1.00 device HP Wide Vision HD Camera (04f2:b653)
Dez 26 16:47:00 jan-pc kernel: input: HP Wide Vision HD Camera: HP Wi as /devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-4/1-4:1.0/input/input26
Dez 26 16:47:00 jan-pc kernel: usbcore: registered new interface driver uvcvideo
Dez 26 16:47:00 jan-pc mtp-probe[1063]: checking bus 1, device 6: "/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-4"
Dez 26 16:47:01 jan-pc /usr/lib/gdm-x-session[1074]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.3/usb1/1-4/1-4:1.0/input/input26/event17"
Dez 26 16:47:01 jan-pc /usr/lib/gdm-x-session[1074]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:08.1/0000:04:00.4/usb3/3-1/3-1:1.0/input/input25/event16"
Dez 26 16:47:03 jan-pc upowerd[1208]: did not recognise USB path /sys/devices/platform/USBC000:00/power_supply/ucsi-source-psy-USBC000:001, please report
Dez 26 16:47:03 jan-pc /usr/lib/gdm-x-session[1094]: dbus-daemon[1094]: [session uid=120 pid=1094] Activating service name='org.gnome.ScreenSaver' requested by ':1.13' (uid=120 pid=1266 comm="/usr/lib/gsd-usb-protection ")
Dez 26 16:47:03 jan-pc gsd-usb-protect[1266]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Dez 26 16:47:05 jan-pc kernel: xhci_hcd 0000:04:00.3: USBSTS: HCHalted HSE
Dez 26 16:47:05 jan-pc kernel: xhci_hcd 0000:04:00.4: USBSTS: HCHalted HSE
Dez 26 16:47:05 jan-pc kernel: usb 1-4: USB disconnect, device number 6
Dez 26 16:47:05 jan-pc kernel: usb 3-1: USB disconnect, device number 2
Dez 26 16:47:05 jan-pc kernel: usb 3-2: USB disconnect, device number 3
Dez 26 16:47:23 jan-pc systemd[1544]: Starting GNOME USB protection service...
Dez 26 16:47:23 jan-pc systemd[1544]: Started GNOME USB protection service.
Dez 26 16:47:23 jan-pc systemd[1544]: Reached target GNOME USB protection target.
Dez 26 16:47:24 jan-pc dbus-daemon[1579]: [session uid=1000 pid=1579] Activating service name='org.gnome.ScreenSaver' requested by ':1.56' (uid=1000 pid=1901 comm="/usr/lib/gsd-usb-protection ")
Dez 26 16:47:24 jan-pc gsd-usb-protect[1901]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Dez 26 16:47:26 jan-pc gsd-usb-protect[1266]: Error releasing name org.gnome.SettingsDaemon.UsbProtection: The connection is closed
Dez 26 16:47:40 jan-pc kernel: Modules linked in: ccm uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc ip6table_filter ip6_tables iptable_filter cmac algif_hash algif_skcipher af_alg amdgpu bnep snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio snd_hda_codec_hdmi snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec snd_hda_core hid_sensor_magn_3d hid_sensor_accel_3d snd_hwdep hid_sensor_trigger snd_pcm industrialio_triggered_buffer kfifo_buf snd_timer hid_sensor_iio_common industrialio qrtr gpu_sched snd intel_rapl_msr ns drm_ttm_helper hid_sensor_hub intel_rapl_common ttm soundcore amd_sfh btusb edac_mce_amd btrtl mousedev joydev rtw88_8822be btbcm rtw88_8822b btintel tun rtw88_pci kvm_amd bluetooth hp_wmi rtw88_core ccp sparse_keymap ecdh_generic wmi_bmof platform_profile hid_multitouch mac80211 kvm irqbypass libarc4 crct10dif_pclmul crc32_pclmul ghash_clmulni_intel vfat aesni_intel fat cfg80211 crypto_simd ucsi_acpi sp5100_tco cryptd rapl
Dez 26 17:46:36 jan-pc dbus-daemon[414]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.188' (uid=0 pid=10610 comm="sudo nano /etc/usb_modeswitch.conf ")
Dez 26 17:46:36 jan-pc sudo[10610]: janst : TTY=pts/0 ; PWD=/home/janst ; USER=root ; COMMAND=/usr/bin/nano /etc/usb_modeswitch.conf
Dez 26 18:04:13 jan-pc dbus-daemon[414]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.200' (uid=0 pid=11954 comm="sudo find / -name gsd-usb-protection ")
Dez 26 18:04:13 jan-pc sudo[11954]: janst : TTY=pts/0 ; PWD=/home/janst ; USER=root ; COMMAND=/usr/bin/find / -name gsd-usb-protection
Dez 26 18:05:40 jan-pc dbus-daemon[414]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.201' (uid=0 pid=11975 comm="sudo gsd-usb-protection ")
Dez 26 18:30:42 jan-pc kernel: Modules linked in: ccm uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc ip6table_filter ip6_tables iptable_filter cmac algif_hash algif_skcipher af_alg amdgpu bnep snd_hda_codec_realtek snd_hda_codec_generic ledtrig_audio snd_hda_codec_hdmi snd_hda_intel snd_intel_dspcfg snd_intel_sdw_acpi snd_hda_codec snd_hda_core hid_sensor_magn_3d hid_sensor_accel_3d snd_hwdep hid_sensor_trigger snd_pcm industrialio_triggered_buffer kfifo_buf snd_timer hid_sensor_iio_common industrialio qrtr gpu_sched snd intel_rapl_msr ns drm_ttm_helper hid_sensor_hub intel_rapl_common ttm soundcore amd_sfh btusb edac_mce_amd btrtl mousedev joydev rtw88_8822be btbcm rtw88_8822b btintel tun rtw88_pci kvm_amd bluetooth hp_wmi rtw88_core ccp sparse_keymap ecdh_generic wmi_bmof platform_profile hid_multitouch mac80211 kvm irqbypass libarc4 crct10dif_pclmul crc32_pclmul ghash_clmulni_intel vfat aesni_intel fat cfg80211 crypto_simd ucsi_acpi sp5100_tco cryptd rapl
I noticed several errors in this log.
Firstly, Dez 26 16:47:03 jan-pc gsd-usb-protect[1266]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
although I don’t remember ever installing USBguard.
Secondly: Dez 26 16:47:00 jan-pc kernel: usb 3-1: Failed to query (GET_INFO) UVC control 2 on unit 1: -32 (exp. 1)
Thirdly: Dez 26 16:46:58 jan-pc kernel: usb 1-3: Device not responding to setup address
Device: HP Envy x360 Convertible 13-ag0xxx
Kernel-Version: 5.15.7-1
DE: Gnome
Thank you in advance for your help
