I’m trying to create a Live PuppyLinux USB stick. Have a load of sticks which keep throwing wobblers when I use dd. Usually says that the operation has been completed in 3 seconds which I know isn’t possible.
Looking in KDE PartitionManager I can see that its reporting a partition labelled “/dev/loop0” Mount point is /run/media/chris/CDROM. Looking in that directory I can see 6 instances labelled CDROM1,2,3 etc. Each instance “allegedly” contains a copy of the Puppy ISO i have been trying to copy to USB.
I have tried removing each of the instances using
sudo rm -rf /run/media/chris/CDROM
Output is rm: cannot remove '/run/media/chris/CDROM': Is a directory
just insert the stick,
do not mount it (though it may not be important if that happens automatically …),
check the device name which it got assigned
(lsblk or lsusb should tell you that)
then run your dd command so that it writes to that device
No loop mount is needed.
Perhaps share the command that you used to write the iso (not it’s contents!) to the USB device?
No matter what is on the USB device - it will be overwritten when using dd
I’d make sure the device isn’t mounted - or unmount it if it get’s mounted automatically.
I don’t use KDE and don’t know it’s settings or how to possibly change that if wanted.
