USB Connected External SSD... "uas" errors and possible "quirks" fix?
My Hynix external 2TB SSD arrived yesterday, and all was looking well after I plugged it in…
lsusb -t
/:  Bus 002.Port 001: Dev 001, Class=root_hub, Driver=xhci_hcd/2p, 10000M
    |__ Port 002: Dev 002, If 0, Class=Hub, Driver=hub/3p, 10000M
        |__ Port 001: Dev 003, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
        |__ Port 002: Dev 004, If 0, Class=Mass Storage, Driver=uas, 10000M
I formatted it EXT4, created a mountpoint for it, and set an automount in /etc/fstab
UUID=aea6c0db-984e-4205-9b1b-b5c873b988e3   /data/steamlibrary  ext4	defaults,noatime,noauto,x-systemd.automount,x-systemd.mount-timeout=10 0	0
Created a new Steam Library on the disk and moved all my games over to it… no errors or issues at all… I did test that a couple games could successfully launch and was only inside long enough to verify I could see my saves.
Updated my BackInTime backup tool to backup the steamapps\compatdata folder (save files, etc.) on the drive, and went to bed.
In the morning I launched a game to play for bit… and it froze/crashed in under 5 min. retried a couple more times with the same result; other than freezing even quicker.
Checked the journal and found a lot of kernel I/O error and sd entries related to “read” before the game crashed… the core/important ones I believe are…
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#16 CDB: Read(10) 28 00 bb a4 ee 98 00 00 20 00
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: scsi host0: uas_eh_device_reset_handler start
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: usb 2-2.2: reset SuperSpeed Plus Gen 2x1 USB device number 4 using xhci_hcd
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: scsi host0: uas_eh_device_reset_handler success
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: scsi_io_completion_action: 8 callbacks suppressed
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#14 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=40s
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#14 CDB: Read(10) 28 00 bd bf 17 d0 00 04 00 00
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: blk_print_req_error: 8 callbacks suppressed
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: I/O error, dev sda, sector 3183417296 op 0x0:(READ) flags 0x80700 phys_seg 128 prio class 2
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#13 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=40s
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#13 CDB: Read(10) 28 00 bd bf 15 28 00 02 a8 00
but here is a more exhaustive journal extract
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#29 uas_eh_abort_handler 0 uas-tag 14 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#29 CDB: Write(10) 2a 00 00 00 0e 10 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#28 uas_eh_abort_handler 0 uas-tag 13 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#28 CDB: Write(10) 2a 00 00 00 09 e8 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#27 uas_eh_abort_handler 0 uas-tag 12 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#27 CDB: Write(10) 2a 00 00 00 09 b0 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#26 uas_eh_abort_handler 0 uas-tag 11 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#26 CDB: Write(10) 2a 00 00 00 09 50 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#25 uas_eh_abort_handler 0 uas-tag 9 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#25 CDB: Write(10) 2a 00 c1 c0 08 80 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#24 uas_eh_abort_handler 0 uas-tag 10 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#24 CDB: Write(10) 2a 00 00 00 09 10 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#10 uas_eh_abort_handler 0 uas-tag 24 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#10 CDB: Write(10) 2a 00 3c c0 08 40 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#9 uas_eh_abort_handler 0 uas-tag 23 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#9 CDB: Write(10) 2a 00 3c c0 08 18 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#8 uas_eh_abort_handler 0 uas-tag 22 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#8 CDB: Write(10) 2a 00 35 00 08 38 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#7 uas_eh_abort_handler 0 uas-tag 21 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#7 CDB: Write(10) 2a 00 29 80 08 30 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#6 uas_eh_abort_handler 0 uas-tag 20 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#6 CDB: Write(10) 2a 00 21 80 08 68 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#5 uas_eh_abort_handler 0 uas-tag 19 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#5 CDB: Write(10) 2a 00 00 01 36 c8 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#4 uas_eh_abort_handler 0 uas-tag 18 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#4 CDB: Write(10) 2a 00 00 01 36 60 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#3 uas_eh_abort_handler 0 uas-tag 17 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#3 CDB: Write(10) 2a 00 00 01 35 90 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#2 uas_eh_abort_handler 0 uas-tag 16 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#2 CDB: Write(10) 2a 00 00 01 33 f0 00 00 08 00
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#1 uas_eh_abort_handler 0 uas-tag 15 inflight: CMD OUT
Feb 19 08:55:49 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#1 CDB: Write(10) 2a 00 00 00 0f 68 00 00 08 00
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#16 uas_eh_abort_handler 0 uas-tag 25 inflight: CMD IN
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: I/O error, dev sda, sector 3183416616 op 0x0:(READ) flags 0x80700 phys_seg 85 prio class 2
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#12 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=40s
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#12 CDB: Read(10) 28 00 bd bf 15 00 00 00 18 00
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: I/O error, dev sda, sector 3183416576 op 0x0:(READ) flags 0x80700 phys_seg 3 prio class 2
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#23 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=40s
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#23 CDB: Read(10) 28 00 c1 3f 2c d8 00 00 48 00
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: I/O error, dev sda, sector 3242142936 op 0x0:(READ) flags 0x80700 phys_seg 9 prio class 2
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#20 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=40s
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#20 CDB: Read(10) 28 00 c1 3f 2d 20 00 00 60 00
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: I/O error, dev sda, sector 3242143008 op 0x0:(READ) flags 0x80700 phys_seg 12 prio class 2
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=37s
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#0 CDB: Read(10) 28 00 bb a2 bb b0 00 00 08 00
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: I/O error, dev sda, sector 3148004272 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: sd 0:0:0:0: [sda] tag#16 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=30s
Feb 19 08:55:51 AMD-Ryzen9-7940HS kernel: I/O error, dev sda, sector 3148148376 op 0x0:(READ) flags 0x80700 phys_seg 4 prio class 2
Feb 19 08:55:52 AMD-Ryzen9-7940HS systemd-coredump[1077932]: [🡕] Process 1069367 (Unity Main Thre) of user 1000 dumped core.
                                                             Stack trace of thread 1069493:
                                                             #0  0x00007ff2ac8dbc5a n/a (n/a + 0x0)
Feb 19 08:55:52 AMD-Ryzen9-7940HS systemd[1]: systemd-coredump@9-49153-1077926_135221464-0.service: Deactivated successfully.
Feb 19 08:55:52 AMD-Ryzen9-7940HS systemd[1]: systemd-coredump@9-49153-1077926_135221464-0.service: Consumed 8.516s CPU time, 3.1G memory peak.
Feb 19 08:55:53 AMD-Ryzen9-7940HS steam[4067374]: Game Recording - game stopped [gameid=1371980]
Feb 19 08:55:53 AMD-Ryzen9-7940HS steam[4067374]: Removing process 1069588 for gameID 1371980
Then I noticed the first read error was not when I launched a game, but earlier (while I was sleeping) when my BackInTime backup was trying to backup the steamapps\compatdata folder.
So there were failures trying to read from the device… but apparently none when I was writing 1T of data to it… really odd.
I started searching the web for some of the error messages and stumbled upon [SOLVED] external usb drive fails during writing / Newbie Corner / Arch Linux Forums
I almost dismissed this post because my issue was read and theirs was write… but I gleamed what I could from it which gave me my first hint to uas not always being the best driver from some usb attached storage devices.
The more I searched, the more convinced I was this was my issue as well… and mixing a bit of the information from the above link and How to force USB 3 device to use mass-storage driver using quirks? - MOX HW problems - Turris forum and Cloud Native Topics | How to bind to the right USB storage driver … I proceeded to:
  1. shutdown Steam2.
  2. unmounted the drive
  3. confirmed it’s vendor/device ID’s
hwinfo --scsi
50: SCSI 00.0: 10600 Disk
  [Created at block.255]
  Unique ID: yNup.zJ+25RsMm5D
  Parent ID: Kf+8.w4XuK8Xu536
  SysFS ID: /class/block/sda
  SysFS BusID: 0:0:0:0
  SysFS Device Link: /devices/pci0000:00/0000:00:08.1/0000:c5:00.3/usb2/2-2/2-2.2/2-2.2:1.0/host0/target0:0:0/0:0:0:0
  Hardware Class: disk
  Model: "Hynix PSSD X31"
  Vendor: usb 0x152e "Hynix"
  Device: usb 0x7001 "PSSD X31"
  Revision: "0"
  Serial ID: "SSDX31###############"
  Driver: "uas", "sd"
  Driver Modules: "uas"
  Device File: /dev/sda
  Device Files: /dev/sda, /dev/disk/by-path/pci-0000:c5:00.3-usb-0:2.2:1.0-scsi-0:0:0:0, /dev/disk/by-id/usb-Hynix_PSSD_X31_SSDX31CHM24102400063-0:0, /dev/disk/by-path/pci-0000:c5:00.3-usbv3-0:2.2:1.0-scsi-0:0:0:0, /dev/disk/by-diskseq/3
  Device Number: block 8:0-8:15
  Module Alias: "usb:v152Ep7001d0100dc00dsc00dp00ic08isc06ip62in00"
  Driver Info #0:
    Driver Status: uas is active
    Driver Activation Cmd: "modprobe uas"
  Drive status: no medium
  Config Status: cfg=new, avail=yes, need=no, active=unknown
  Attached to: #5 (USB Controller)
Note: I guess something in the drive enclosure is “LG” to get this vendor id… Hopefully this is an authoritative site … http://www.linux-usb.org/usb.ids
lsusb
Bus 002 Device 005: ID 152e:7001 LG (HLDS) PSSD X31
  1. disconnected the drive
  2. typed the following in a terminal to “quickly” (without reboot) add a “quirk” for my drive
$ su
# echo "152e:7001:u" > /sys/module/usb_storage/parameters/quirks
# exit
$ cat /sys/module/usb_storage/parameters/quirks
152e:7001:u
  1. reconnected the drive
  2. checked lsusb -t and confirmed the driver change to usb-storage (from uas)
        |__ Port 002: Dev 005, If 0, Class=Mass Storage, Driver=usb-storage, 10000M
  1. remounted the drive
  2. restarted Steam
  3. launched the same game and played for 20+ minutes without issue.
So I hope the last step now is to make this quirk persistent… following Kernel module - ArchWiki, is it better/safer to:
  1. create a /etc/modprobe.d/no_uas_hynix_ssd.conf
    which I think would look like this…
#options module_name param1=value1 param2=value2a,value2b …
options usb_storage quirks=152e:7001:u
  1. update /etc/default/grub (requiring sudo update-grub and sudo mkinitcpio -P)
GRUB_CMDLINE_LINUX_DEFAULT="udev.log_priority=3 sysrq_always_enabled=1 usb-storage.quirks=152e:7001:u"
I’m leaning towards option 1 as it feels simpler and provides an opportunity to learn more about systemd… but I’m open to opinions as either way is doable.
Also, it would be encouraging to know if I actually stumbled into the right “solution” and whether my approach is complete or needs further steps or refinement.
Thank You!
For what it’s worth, this at least indicates that the device should be supported with Linux; the page also lists computers that the device is included with:
Perhaps something here may be useful.
That’s all I have to offer at this time.
thanks for the link… if I’m reading it right, i find it interesting that the driver I’m using now is on that list from the kernel 2,6 era.
perhaps this is an issue that I need to log with the uas upstream.
for now I’m going to see how the driver performs/operates with the usb-storage driver… and if that fails, I’ll likely decide to just return/refund the devise.
It could also be a flaky controller, though I’m not familiar enough with this device to say so with any certainty.
On the chance that there actually are filesystem problems, have you checked it yet for consistency?
Mini-HowTo: Check filesystem integrity
1. Boot with a live ISO; example: Manjaro Installer ISO.
  • Important: Do not enter a chroot environment for filesystem repair operations – the target partitions should not be mounted.
2. Locate the system disk and partition to be checked:
Disk type Disk identifier (example) Description
HDD/SDD /dev/sdXY X: Disk node order (a, b, c, d …)
Y: Partition number
NVMe /dev/nvme0n1p2 0: Controller number
n1: Namespace number
p2: Partition number
List all block devices:
lsblk -f
See also: Linux block device names explained
3. Use the appropriate tool/command for your filesystem.
BTRFSbtrfsck/btrfs check:
EXT4fsck:
I’ll chime in again if I think of anything potentially useful.
Good call… I assumed it would be okay as the errors were on read (not write)… but confirmed okay…
e2fsck 1.47.3 (8-Jul-2025)
SteamLibrary: clean, 248982/125026304 files, 268307999/500099328 blocks
======== SOLUTION ========
Some interesting update posts that ended up having nothing to do with the solution
Update: a post I read at https://forum.odroid.com/viewtopic.php?t=39566 suggests a possible reason/answer…
This also depends on the kernel version. Certain USB enclosures are buggy and are/should be blocked for UAS for stability, so if for example a newer kernel blocks UAS for a specific model there may be a good reason for it…
I block uas via a long usb-storage.quirks=… options line for all my Seagate Backup Plus externals
And I guess I found one of the drives with a buggy enclosure… at any rate, if it performs well with the older driver, I’ll be okay with it.
Update 2: https://www.rshtech.com/blog/common-problems-in-the-use-of-usap-5 suggests a better explanation than “buggy enclosure”…
UASP (USB Attached SCSI Protocol) replaced the BOT (Bulk-Only Transfer), and requires 3 things…
  1. The USB controller on your computer needs to support UASP.
To check if Linux is using UASP or BOT, run Isusb -t and look for “driver = uas” instead of “driver = usb-storage
  1. Your USB 3.0 device supports UASP.
  2. Your computer has installed the correct driver.
It’s possible that the drive/enclosure (despite being USB3) does not fully support UASP (bi-directional data transfer)… I checked for firmware updates, but none were reported.
I’m also using kernel 6.18… I suppose I could see if kernel 6.12 behaves any different in case this is a kernel/driver issue.
Update 3: [SOLVED] How to check UASP support? / Kernel & Hardware / Arch Linux Forums offers a bit more information and mentions that some chips/tech were created before UASP was fully standardized… so some “early adopter” components may not work and/or meet the final specification.
Windows and Linux enable UAS on any USB controller that isn’t blacklisted. The Asmedia ASM1042 was the only chip for which Windows 7 support could be found and is now blacklisted by all OS due to chip bugs so Windows 7 does not support UASP.
To get UASP you need 3 components.
  1. OS Support: Windows 8, Windows 10, Linux
  2. USB controller support: Any USB 2 or 3+ interface that doesn’t have UASP blacklisted.
  3. UASP ready peripherals: UASP standards solidified near the end of USB 3.0 development so most USB 3.0 storage products are not UASP compatible. Some buggy chips were produced so some products claiming UASP support have been blacklisted. Hopefully most USB 3.1 products will include UASP support.
My disk supports USB 3.2 … but i guess that doesn’t mean it fully supports UASP.
I started looking for similar issues/solutions that may also be related to my Framework 16 Laptop and found Framework 16 USB Confusion - Community Support - Framework Community which revealed (reminded me?) that not all module ports are created equally (especially around power delivery)… and using a “higher” powered port allows for some devices to work that didn’t when connected to lower powered ones.
Expansion Card Slot functionality on Framework Laptop 16 (AMD Ryzen™ 7040 Series) states that…
Ports 1,2,4,5 are shared on a first come first serve basis. So they are 1.5A by default, but one port from any of these can negotiate 3A over PD. Once that is taken, the other ports are limited to 1.5A. Ports 3,6 are 900mA.
Hmm, so 2 ports are low (900mA) powered and so I thought I’d be a really fast confirmation if I tested the 1,5A ports with my new cell phone that I’d recently reported an issue about… Kernel errors connecting newer android cell via USB-A to C - #4 by Daniel-I … and connecting it to a non-port 3 or 6 port (900 mA) yielded a working connection, and a phone that prompted for debugging mode! Well hurray for learning about avoiding low powered ports.
And guess which port my new external SSD is connected to? yep, on the port 3,6 (900 mA) line.
So I:
  1. shutdown Steam
  2. safely ejected the drive
  3. unplugged the drive
  4. undid the “quick” quirk
$ su
# echo "" > /sys/module/usb_storage/parameters/quirks
# cat /sys/module/usb_storage/parameters/quirks
# exit
  1. shuffled my mouse and controller down to fill ports 3 & 6
  2. reconnected the drive to a 1.5A port and confirmed UASP mode
$ lsusb -t
    |__ Port 001: Dev 007, If 0, Class=Mass Storage, Driver=uas, 10000M
  1. mounted the drive
  2. started Steam
  3. played a full Crucible run in No Rest for the Wicked for ~20 min and Cyberpunk for ~40 min without any issues!
So the lesson learned is… know your hardware’s requirements, capabilities, and limitations… and ensure devices that need full power are connected on a port that can deliver it.
Update: No errors the next morning in the journal… so backup ran smoothly as well… all issues experienced seem to be resolved by choosing the properly powered port with a USB module for my FW16.
