USB C Video Output - Silicon Motion USB Display
Hi all!
I’m currently trying to get my new external Monitors ( Triple Boost 14" Pro – Aura ) to run over USB C video output.
Aura (the manufacturer) provides a link to a Linux driver from Silicon Motion, which seems to be the display producer, as the monitor also shows up on lsusb as:
Bus 008 Device 011: ID 090c:0770 Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.) USB Display
But this driver is only available for Ubuntu:
I’ve now extracted the archive inside the run package ( SMIUSBDisplay-driver.2.22.1.0.run --no-exec --keep ) and checked out the contents
I’ve already installed evdi and displayLink after checking the Arch Wiki ( DisplayLink - ArchWiki ).
I’m actually not 100% sure if it’s even using USB C → DisplayLink or whatever, but I’ve talked with Aura and my Laptop Manufacturer (I’m having a Framework 16) said, it should work.
So, it seems, I’m just stuck with my OS of choice and the driver support.
It seems the evdi project is the right path, as it’s also used in the install script of the SMIUSBDisplay driver package, but I’m absolutely missing some udev rules and looking at the install script, as seems to be quite some stuff more.
Maybe I even need to somehow give evdi the specific firmware and bootloader images for this to work.
So, I do see the monitors with lsusb, but I can’t activate a corresponding output in arandr and with xrandr, I don’t see any more connections - or providers:
xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x5b cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 4 outputs: 9 associated providers: 0 name:AMD Radeon 780M @ pci:0000:c1:00.0
And I’m using one of the Expansion Slots, that should support “Display output”, looking at that support page of Framework: Expansion Card Slot functionality on Framework Laptop 16
And also building up on their Support feedback.
I’m currently a bit clueless on how to proceed.
As the Ubuntu variant should work, I could probably try to go through the install script and do the steps by hand or modify it (enough :wink: ) for my system to make it somehow work - if there is not somewhere some binary blob, that only works with this specific Ubuntu version.
But I’d prefer to have something more streamlined and with hopefully a bit more guarantee of success.
For what it’s worth, here some more system information:
Framwork 16 Laptop
CPU: CPU: 8-core AMD Ryzen 9 7940HS
GPU: Radeon 780M Graphics
Kernel: 6.13.9-1-MANJARO
WM: i3WM
GPU Driver: amdgpu
Anyone having some success with such displays and knows what needs to be done?
I guess, I’ll need to at least set up some udev rules, but I’m not entirely sure, what I would like to do in the rule…
Thanks for any suggestions!
And I’ll happily provide any information, that could help someone help me :wink:
First give us some more information about your system.
Open a Terminal and Typing
inxi -zv8
Would be a good start.
Copy the output, and past it into the Edit Box, use the </> button and paste your out put between the multiple back ticks.
Also, there is a Silicon Motion driver in the AUR, I wonder if that is the one you are looking for.
Thanks for the fast response, here you go:
  Kernel: 6.13.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.13-x86_64
    root=UUID=c4b23a26-242f-4cab-9ade-6393ea9ff8cb rw rootflags=subvol=@
  Desktop: i3 v: 4.24 with: i3bar tools: avail: i3lock,xautolock dm: LightDM
    v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: Framework product: Laptop 16 (AMD Ryzen 7040 Series)
    v: AJ serial: <filter> Chassis: type: 10 v: AJ serial: <filter>
  Mobo: Framework model: FRANMZCP09 v: A9 serial: <filter>
    part-nu: FRAGAACP0J uuid: 3ee7d5cc-faf6-ee11-9e4b-229330700005 UEFI: INSYDE
    v: 03.05 date: 11/13/2024
  ID-1: BAT1 charge: 62.0 Wh (75.6%) condition: 82.0/85.1 Wh (96.4%)
    volts: 16.2 min: 15.5 model: NVT FRANDBA type: Li-ion serial: <filter>
    status: discharging cycles: 53
  System RAM: total: 64 GiB available: 60.64 GiB used: 5.43 GiB (9.0%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 32 GiB speed: 5600 MT/s volts: curr: 1.1 min: 1.1
    max: 1.1 width (bits): data: 64 total: 64 manufacturer: A-DATA Technology
    part-no: AD5S560032G-SFW serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Slot: N/A type: N/A status: available info: M.2, JWLAN length: short
    volts: 3.3 bus-ID: 00:02.2 children: 1: 01:00.0 class-ID: 0280 type: network
  Slot: N/A type: N/A status: available info: M.2, JSSD1 length: short
    volts: 3.3 bus-ID: 00:02.4 children: 1: 02:00.0 class-ID: 0108
    type: mass-storage
  Slot: N/A type: N/A status: available info: M.2, JSSD2 length: short
    volts: 3.3 bus-ID: 00:01.2
  Slot: 1 type: PCIe status: available length: short volts: 3.3
    bus-ID: 00:01.1
  Info: model: AMD Ryzen 9 7940HS w/ Radeon 780M Graphics socket: FP8 bits: 64
    type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check built: 2022+
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x74 (116) stepping: 1
    microcode: 0xA704107
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1097 min/max: 400/5263 boost: enabled
    base/boost: 4000/5250 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 1097 2: 1097 3: 1097 4: 1097
    5: 1097 6: 1097 7: 1097 8: 1097 9: 1097 10: 1097 11: 1097 12: 1097
    13: 1097 14: 1097 15: 1097 16: 1097 bogomips: 127759
    apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
    avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
    avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero
    cmov cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
    vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave
    xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
    BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Framework
    driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8, Writeback-1
    bus-ID: c1:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 44.0 C
  Display: x11 server: X.Org v: 21.1.16 compositor: Picom v: 12.5 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43")
  Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0bc9 built: 2022 res:
    mode: 2560x1600 hz: 165 scale: 100% (1) dpi: 188 gamma: 1.2 chroma: red:
    x: 0.682 y: 0.314 green: x: 0.263 y: 0.694 blue: x: 0.145 y: 0.055 white:
    x: 0.314 y: 0.329 size: 345x215mm (13.58x8.46") diag: 407mm (16")
    ratio: 16:10 modes: 2560x1600, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
    640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.5-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi phoenix
    LLVM 19.1.7 DRM 3.61 6.13.9-1-MANJARO) device-ID: 1002:15bf
    memory: 1.95 GiB unified: no
  API: Vulkan v: 1.4.313 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon 780M (RADV PHOENIX) driver: mesa radv v: 25.0.5-arch1.1
    device-ID: 1002:15bf surfaces: N/A
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio vendor: Framework driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: c1:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] ACP/ACP3X/ACP6x Audio Coprocessor
    vendor: Framework driver: snd_pci_ps v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: c1:00.5 chip-ID: 1022:15e2 class-ID: 0480
    speed: 16 GT/s lanes: 16 bus-ID: c1:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.13.9-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.2 status: n/a (root, process) with:
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 01:00.0 chip-ID: 14c3:0616 class-ID: 0280
  Device-2: Realtek USB 10/100/1G/2.5G LAN driver: r8152 type: USB rev: 3.2
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1:3 chip-ID: 0bda:8156
    class-ID: 0000 serial: <filter>
  IF: enp193s0f3u1 state: down mac: <filter>
  IF-ID-1: wg0 state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> type: noprefixroute scope: global
  Info: services: NetworkManager,wpa_supplicant
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:5 chip-ID: 0e8d:e616
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
    lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c
  Device-1: luks-28ec45ad-e957-4f3c-9d7f-e99a2b5fb73c maj-min: 254:0
    type: LUKS dm: dm-0 size: 1.08 TiB
  Components:
  p-1: nvme0n1p6 maj-min: 259:6 size: 1.08 TiB
  Local Storage: total: 1.82 TiB used: 999.98 GiB (53.7%)
    model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 620361WD temp: 43.9 C scheme: GPT
  ID-1: / raw-size: 500 GiB size: 500 GiB (100.00%) used: 125.33 GiB (25.1%)
    fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
    uuid: c4b23a26-242f-4cab-9ade-6393ea9ff8cb
  ID-2: /boot/efi raw-size: 2 GiB size: 2 GiB (99.80%) used: 584 KiB (0.0%)
    fs: vfat block-size: 512 B dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: 9B49-4F6C
  ID-3: /home raw-size: 1.08 TiB size: 1.07 TiB (98.33%)
    used: 874.64 GiB (80.1%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: luks-28ec45ad-e957-4f3c-9d7f-e99a2b5fb73c
    label: N/A uuid: 5aa2261b-01db-42c6-bea1-89797084e89d
  ID-4: /var/cache raw-size: 500 GiB size: 500 GiB (100.00%)
    used: 125.33 GiB (25.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
    maj-min: 259:7 label: N/A uuid: c4b23a26-242f-4cab-9ade-6393ea9ff8cb
  ID-5: /var/log raw-size: 500 GiB size: 500 GiB (100.00%)
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: AA17-54A4
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 249.13 GiB fs: ntfs label: N/A
    uuid: 6EA21E24A21DF177
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 775 MiB fs: ntfs label: N/A
    uuid: B412206C12203630
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Hub-3: 1-3:3 info: Genesys Logic Hub ports: 3 rev: 2.0
  Hub-4: 1-4:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-4.1:6 info: Shenzhen Goodix Fingerprint USB Device
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 27c6:609c class-ID: ef00 serial: <filter>
  Device-2: 1-4.3:7 info: Framework Laptop 16 Keyboard Module - ISO
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 4 rev: 2.1
    chip-ID: 32ac:0018 class-ID: 0300 serial: <filter>
  Device-3: 1-5:5 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:e616 class-ID: e001 serial: <filter>
  Hub-5: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Device-1: 2-1:3 info: Realtek USB 10/100/1G/2.5G LAN type: Network
    driver: r8152 interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 256mA chip-ID: 0bda:8156 class-ID: 0000
    serial: <filter>
  Hub-6: 2-2:2 info: Genesys Logic USB3.2 Hub ports: 3 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 05e3:0625
  Hub-7: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: Framework HDMI Expansion Card type: billboard,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 32ac:0002 class-ID: 0300
    serial: <filter>
  Hub-10: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-11: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-12: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 89.8 C mobo: 46.9 C gpu: amdgpu temp: 46.0 C
  Fan Speeds (rpm): fan-1: 1261 fan-2: 1222
  Packages: pm: pacman pkgs: 1953 libs: 534 tools: pamac,yay pm: rpm pkgs: 0
    1: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    2: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    3: https://mirror.23m.com/manjaro/stable/$repo/$arch
    4: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    5: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    6: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    7: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    8: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
Processes:
  CPU top: 5 of 412
  1: cpu: 4.5% command: fprintd pid: 228613 mem: 13.0 MiB (0.0%)
  2: cpu: 3.4% command: zed-editor pid: 224227 mem: 387.0 MiB (0.6%)
  3: cpu: 2.5% command: firefox pid: 162286 mem: 584.9 MiB (0.9%)
  4: cpu: 2.1% command: bumblebee-status started-by: python3 pid: 1571
    mem: 21.4 MiB (0.0%)
  5: cpu: 2.0% command: firefox pid: 162905 mem: 280.0 MiB (0.4%)
  Memory top: 5 of 412
  1: mem: 719.2 MiB (1.1%) command: thunderbird pid: 31252 cpu: 0.6%
  2: mem: 626.2 MiB (1.0%) command: soffice.bin pid: 173095 cpu: 0.3%
  3: mem: 584.9 MiB (0.9%) command: firefox pid: 162286 cpu: 2.5%
  4: mem: 492.3 MiB (0.7%) command: clangd pid: 224499 cpu: 1.2%
  5: mem: 387.0 MiB (0.6%) command: zed-editor pid: 224227 cpu: 3.4%
  Processes: 412 Power: uptime: 5h 17m states: freeze,mem,disk suspend: s2idle
    image: 24.24 GiB services: upowerd,xfce4-power-manager Init: systemd
    v: 257 default: graphical tool: systemctl
  Compilers: clang: 19.1.7 gcc: 15.1.1 Shell: Sudo (sudo) v: 1.9.16p2
    default: Bash v: 5.2.37 running-in: alacritty inxi: 3.3.38
Regarding said driver:
I only found that one:
aur/xf86-video-siliconmotion 1.7.9-1 (+1 0.00) (Orphaned)
    X.org siliconmotion video driver
And as it’s said to be orphaned, I wasn’t very inclined to use that…
Did I miss a package?
And trying to install said package gives me this error:
 -> No AUR package found for X-ABI-VIDEODRV_VERSION=24.0
 -> could not find all required packages: X-ABI-VIDEODRV_VERSION =24.0
Here also a dmesg output, when I connect the monitor:
[14523.947806] usb 7-1: new high-speed USB device number 9 using xhci_hcd
[14524.080711] usb 7-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.63
[14524.080719] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[14524.080721] usb 7-1: Product: USB2.1 Hub
[14524.080723] usb 7-1: Manufacturer: GenesysLogic
[14524.120495] hub 7-1:1.0: USB hub found
[14524.121200] hub 7-1:1.0: 4 ports detected
[14524.190181] usb 8-1: new SuperSpeed USB device number 20 using xhci_hcd
[14524.211197] usb 8-1: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
[14524.211205] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[14524.211207] usb 8-1: Product: USB3.1 Hub
[14524.211208] usb 8-1: Manufacturer: GenesysLogic
[14524.233135] hub 8-1:1.0: USB hub found
[14524.233971] hub 8-1:1.0: 4 ports detected
[14524.721739] ucsi_acpi USBC000:00: unknown error 256
[14524.721755] ucsi_acpi USBC000:00: GET_CABLE_PROPERTY failed (-5)
[14525.131563] usb 8-1: USB disconnect, device number 20
[14525.556059] amdgpu 0000:c1:00.0: [drm] *ERROR* lttpr_caps phy_repeater_cnt is 0x0, forcing it to 0x80.
[14525.862481] usb 8-1: new SuperSpeed USB device number 21 using xhci_hcd
[14525.881051] usb 8-1: New USB device found, idVendor=05e3, idProduct=0626, bcdDevice= 6.63
[14525.881062] usb 8-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[14525.881068] usb 8-1: Product: USB3.1 Hub
[14525.881073] usb 8-1: Manufacturer: GenesysLogic
[14525.914027] hub 8-1:1.0: USB hub found
[14525.914857] hub 8-1:1.0: 4 ports detected
[14526.314996] usb 8-1.3: new SuperSpeed USB device number 22 using xhci_hcd
[14526.336802] usb 8-1.3: New USB device found, idVendor=090c, idProduct=0770, bcdDevice= 0.ff
[14526.336813] usb 8-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[14526.336820] usb 8-1.3: Product: USB Display
[14526.336825] usb 8-1.3: Manufacturer: Silicon_Motion
[14526.336829] usb 8-1.3: SerialNumber: C81F6643A8F8DD9DA2960000
[14526.584584] usb 8-1.3: Warning! Unlikely big volume range (=511), cval->res is probably wrong.
[14526.584593] usb 8-1.3: [19] FU [SMI USB Audio Playback Volume] ch = 2, val = -8176/0/16
[14526.598058] usb 8-1.3: Warning! Unlikely big volume range (=767), cval->res is probably wrong.
[14526.598064] usb 8-1.3: [23] FU [Mic Capture Volume] ch = 1, val = -4592/7680/16
[14526.601926] usbhid 8-1.3:1.3: couldn't find an input interrupt endpoint
EDIT: Added some more stuff and saw that some things in inxi required root.
Although I’m not really happy with sharing that much information about my system, I’m hoping it actually helps someone to make some more sense of it
Thanks in advance!
No that was it.
So long as the information doesn’t reveal anything that identifies you. There are no issues. Those who can help you need that information and maybe more, so they can provide that help. Otherwise they are simply guessing.
