I have been using a ~5 year old external HDD to hold large files. Around a week ago, I started experiencing issues with loading files onto it. For the first couple GB (varied between around 2-4), transfer would go as normal, and then the process would suddenly stall. It would freeze for a while, and then occasionally pull through a couple hundred MB, and go back to freezing.
If I had Dolphin open to the drive, Dolphin would crash. When I tried using dd status=progress, the status indicator would constantly freeze for between a couple seconds and up to a minute. These issues occured when writing to a LUKS ext4 partition, or just directly to the /dev/sda file, or to a partition like /dev/sda1. It makes me theorize that some sort of IO problem is blocking the programs from functioning. Reading from the drive works perfectly fine, and at good speeds.
These issues occured on Manjaro, but I also have an Ubuntu partition that I tried this on. That partition hasn’t been connected to the internet in months, and it could write just fine a few weeks ago, so a software update couldn’t be the cause. I also haven’t done any firmware updates recently.
SMART tests all came up green, but I figured that the drive had given out in some way, so I ordered a brand new external SSD. Fast forward to now, it arrived, and I am experiencing the same problems. I have tried everything I said about the HDD, plus using different cables and trying all 3 USB-C ports on my computer, with no luck.
I tried using a flash drive, and it worked perfectly well, even with large files that the other two couldn’t handle. However, its write speed is considerably slower than the other two, so that might be the reason?
Update: same issue on flash drive
I am hoping that someone here has any insight before I have to go speak to Dell support about replacing my USB-C ports. They still work fine for my mouse, keyboard, monitor, and reading from drives, but I don’t know what else would cause this besides some strange hardware failure.
System Info
/dev/sdais the flash drive -
/dev/sdbis the new SSD -
/dev/sdcis the old HDD
inxi -v7azy
Kernel: 6.2.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.2-x86_64
root=UUID=d10cb460-c32f-4e3c-b883-afb0d4c1d53d rw quiet
cryptdevice=UUID=4eedbe31-4667-41d3-8f2d-59c2a59f8cd1:luks-4eedbe31-4667-41d3-8f2d-59c2a59f8cd1
root=/dev/mapper/luks-4eedbe31-4667-41d3-8f2d-59c2a59f8cd1
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Dell product: XPS 15 9520 v: N/A
Mobo: Dell model: 0MWGD4 v: A00 serial: <superuser required> UEFI: Dell
v: 1.10.0 date: 12/14/2022
ID-1: BAT0 charge: 22.6 Wh (33.3%) condition: 67.8/84.3 Wh (80.4%)
volts: 11.0 min: 11.4 model: BYD DELL M59JH24 type: Li-poly serial: <filter>
status: discharging
RAM: total: 15.3 GiB used: 4.33 GiB (28.3%)
Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x429
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 2058 high: 2700 min/max: 400/4600:4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 2700 2: 2700 3: 498
4: 2700 5: 2700 6: 2700 7: 604 8: 2700 9: 2700 10: 553 11: 576 12: 2700
13: 500 14: 638 15: 2700 16: 2700 17: 2700 18: 2700 19: 2700 20: 2700
bogomips: 107560
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe
movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes
vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Dell
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 bus-ID: 0000:01:00.0
chip-ID: 10de:25a2 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 3-6:2 chip-ID: 0c45:6a15 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 model: Sharp 0x1515 built: 2021 res: 1920x1200 hz: 60
dpi: 145 gamma: 1.2 size: 336x210mm (13.23x8.27") diag: 396mm (15.6")
ratio: 16:10 modes: 1920x1200
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.2.11-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:3
chip-ID: 8087:0033 class-ID: e001
Device-1: luks-4eedbe31-4667-41d3-8f2d-59c2a59f8cd1 maj-min: 254:0
type: LUKS dm: dm-0 size: 263.61 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 263.61 GiB
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 2.34 TiB used: 58.69 GiB (2.4%)
model: PC SN810 NVMe WDC 512GB size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 61520012 temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Samsung model: Type-C
size: 59.75 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1100
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Samsung model: PSSD T7
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD10SDZW-11UMGS0 size: 931.48 GiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 1021
ID-1: / raw-size: 263.61 GiB size: 258.42 GiB (98.03%)
used: 58.45 GiB (22.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-4eedbe31-4667-41d3-8f2d-59c2a59f8cd1 label: N/A
uuid: d10cb460-c32f-4e3c-b883-afb0d4c1d53d
ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
used: 152.3 MiB (15.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: cdb47359-d9ef-4216-8f7c-0c7c2c160219
ID-3: /boot/efi raw-size: 240 MiB size: 236 MiB (98.33%)
used: 93.4 MiB (39.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: ESP
uuid: C8BF-C023
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 15 GiB fs: ext4 label: N/A
uuid: 47163614-89c9-4fa0-988d-ab87851f704c
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 20 Gb/s
Device-1: 2-2:4 info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 304mA chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:6 info: Samsung PSSD T7 type: Mass Storage driver: uas
interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA chip-ID: 04e8:4001
Hub-4: 3-3:7 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2211 class-ID: 0900
Device-1: 3-3.2:8 info: Dell DA20 Adapter type: Billboard driver: N/A
interfaces: 1 rev: 2.1 speed: 12 Mb/s power: 2mA chip-ID: 413c:b080
class-ID: 1100 serial: <filter>
Device-2: 3-6:2 info: Microdia Integrated_Webcam_HD type: Video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-3: 3-10:3 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 4-1:2 info: VIA Labs USB3.0 Hub ports: 1 rev: 3.1 speed: 5 Gb/s
chip-ID: 2109:0211 class-ID: 0900
Device-1: 4-1.1:3 info: Western Digital My Passport (WD20NMVW)
power: 896mA chip-ID: 1058:25e1 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 39.0 C mobo: N/A
Processes: 397 Uptime: 42m wakeups: 52074 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1239 pm: pacman pkgs: 1216 libs: 318 tools: pamac,yay pm: flatpak
pkgs: 23 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.26
smartctl -x -d scsi /dev/sda
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.2.11-1-MANJARO] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Vendor: Samsung
Product: Type-C
Revision: 1100
Compliance: SPC-4
User Capacity: 64,160,400,896 bytes [64.1 GB]
Logical block size: 512 bytes
scsiModePageOffset: response length too short, resp_len=4 offset=4 bd_len=0
Logical Unit id: 0x534d490033323830
Serial number: AA00000000000489
Device type: disk
Local Time is: Tue Apr 18 17:00:19 2023 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Disabled
Temperature Warning: Disabled or Not Supported
Read Cache is: Enabled
Writeback Cache is: Disabled
=== START OF READ SMART DATA SECTION ===
SMART Health Status: OK
Current Drive Temperature: 0 C
Drive Trip Temperature: 0 C
Error Counter logging not supported
Device does not support Self Test logging
Device does not support Background scan results logging
smartctl -x -d sntasmedia /dev/sdb
Model Number: Samsung Portable SSD T7
Serial Number: S6X9NS0TC01713D
Firmware Version: FXG42P2Q
PCI Vendor/Subsystem ID: 0x144d
IEEE OUI Identifier: 0x002538
Total NVM Capacity: 1,000,204,886,016 [1.00 TB]
Unallocated NVM Capacity: 0
Controller ID: 5
NVMe Version: 1.3
Number of Namespaces: 1
Namespace 1 Size/Capacity: 1,000,204,886,016 [1.00 TB]
Namespace 1 Utilization: 22,558,265,344 [22.5 GB]
Namespace 1 Formatted LBA Size: 512
Local Time is: Tue Apr 18 16:57:23 2023 EDT
Firmware Updates (0x16): 3 Slots, no Reset required
Optional Admin Commands (0x0007): Security Format Frmw_DL
Optional NVM Commands (0x001f): Comp Wr_Unc DS_Mngmt Wr_Zero Sav/Sel_Feat
Log Page Attributes (0x03): S/H_per_NS Cmd_Eff_Lg
Maximum Data Transfer Size: 512 Pages
Warning Comp. Temp. Threshold: 52 Celsius
Critical Comp. Temp. Threshold: 56 Celsius
Supported Power States
St Op Max Active Idle RL RT WL WT Ent_Lat Ex_Lat
0 + 4.83W - - 0 0 0 0 0 0
1 + 3.54W - - 1 1 1 1 0 0
2 + 3.04W - - 2 2 2 2 0 0
3 - 0.0500W - - 3 3 3 3 26000 1000
Supported LBA Sizes (NSID 0x1)
Id Fmt Data Metadt Rel_Perf
0 + 512 0 0
=== START OF SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
SMART/Health Information (NVMe Log 0x02)
Critical Warning: 0x00
Temperature: 25 Celsius
Available Spare: 100%
Available Spare Threshold: 10%
Percentage Used: 0%
Data Units Read: 78 [39.9 MB]
Data Units Written: 61,737 [31.6 GB]
Host Read Commands: 6,302
Host Write Commands: 242,946
Controller Busy Time: 0
Power Cycles: 10
Power On Hours: 0
Unsafe Shutdowns: 5
Media and Data Integrity Errors: 0
Error Information Log Entries: 0
Warning Comp. Temperature Time: 0
Critical Comp. Temperature Time: 0
Temperature Sensor 1: 25 Celsius
Temperature Sensor 2: 26 Celsius
Warning: NVMe Get Log truncated to 0x200 bytes, 0x200 bytes zero filled
Error Information (NVMe Log 0x01, 16 of 64 entries)
No Errors Logged
smartctl -x /dev/sdc
Device Model: WDC WD10SDZW-11UMGS0
Serial Number: WD-WXB1A28NFY12
LU WWN Device Id: 5 0014ee 6087e2fe0
Firmware Version: 01.01A01
User Capacity: 1,000,171,331,584 bytes [1.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 2.5 inches
TRIM Command: Available, deterministic
Device is: Not in smartctl database 7.3/5319
ATA Version is: ACS-3 T13/2161-D revision 5
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Apr 18 16:56:13 2023 EDT
SMART support is: Enabled
AAM feature is: Unavailable
APM level is: 128 (minimum power consumption without standby)
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (11280) seconds.
capabilities: (0x51) SMART execute Offline immediate.
No Auto Offline data collection support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 187) minutes.
SCT capabilities: (0x7035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 170 162 021 - 2483
4 Start_Stop_Count -O--CK 100 100 000 - 236
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 100 100 000 - 101
10 Spin_Retry_Count -O--CK 100 100 000 - 0
11 Calibration_Retry_Count -O--CK 100 100 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 129
192 Power-Off_Retract_Count -O--CK 200 200 000 - 32
193 Load_Cycle_Count -O--CK 200 200 000 - 909
194 Temperature_Celsius -O---K 119 096 000 - 24
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 100 253 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x24 GPL R/O 288 Current Device Internal Status Data log
0x30 GPL,SL R/O 9 IDENTIFY DEVICE data log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb6 GPL,SL VS 1 Device vendor specific log
0xb7 GPL,SL VS 74 Device vendor specific log
0xb9 GPL,SL VS 4 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xcf GPL VS 65535 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 1
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 1 [0] occurred at disk power-on lifetime: 50 hours (2 days + 2 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 51 01 00 00 00 11 77 6f 28 40 00 Error: UNC 256 sectors at LBA = 0x11776f28 = 293039912
Commands leading to the command that caused the error were:
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
25 00 00 01 00 00 00 11 77 6f 08 40 00 00:09:35.263 READ DMA EXT
25 00 00 01 00 00 00 11 77 6e 08 40 00 00:09:35.262 READ DMA EXT
25 00 00 01 00 00 00 11 77 6d 08 40 00 00:09:35.261 READ DMA EXT
25 00 00 01 00 00 00 11 77 6c 08 40 00 00:09:35.260 READ DMA EXT
25 00 00 01 00 00 00 11 77 6b 08 40 00 00:09:35.259 READ DMA EXT
SMART Extended Self-test Log Version: 1 (1 sectors)
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Aborted by host 90% 101 -
# 2 Short offline Completed without error 00% 101 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
Device State: Active (0)
Current Temperature: 23 Celsius
Power Cycle Min/Max Temperature: 23/23 Celsius
Lifetime Min/Max Temperature: 16/47 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 128 (59)
Index Estimated Time Temperature Celsius
60 2023-04-18 14:49 33 **************
61 2023-04-18 14:50 34 ***************
62 2023-04-18 14:51 34 ***************
63 2023-04-18 14:52 33 **************
64 2023-04-18 14:53 33 **************
65 2023-04-18 14:54 ? -
66 2023-04-18 14:55 21 **
67 2023-04-18 14:56 21 **
68 2023-04-18 14:57 23 ****
69 2023-04-18 14:58 25 ******
70 2023-04-18 14:59 ? -
71 2023-04-18 15:00 21 **
72 2023-04-18 15:01 ? -
73 2023-04-18 15:02 21 **
74 2023-04-18 15:03 22 ***
75 2023-04-18 15:04 24 *****
76 2023-04-18 15:05 26 *******
77 2023-04-18 15:06 27 ********
78 2023-04-18 15:07 28 *********
79 2023-04-18 15:08 29 **********
80 2023-04-18 15:09 30 ***********
81 2023-04-18 15:10 31 ************
82 2023-04-18 15:11 ? -
83 2023-04-18 15:12 32 *************
84 2023-04-18 15:13 32 *************
85 2023-04-18 15:14 32 *************
86 2023-04-18 15:15 33 **************
87 2023-04-18 15:16 34 ***************
88 2023-04-18 15:17 34 ***************
89 2023-04-18 15:18 35 ****************
90 2023-04-18 15:19 35 ****************
91 2023-04-18 15:20 35 ****************
92 2023-04-18 15:21 ? -
93 2023-04-18 15:22 21 **
94 2023-04-18 15:23 22 ***
95 2023-04-18 15:24 24 *****
96 2023-04-18 15:25 25 ******
97 2023-04-18 15:26 27 ********
98 2023-04-18 15:27 ? -
99 2023-04-18 15:28 22 ***
100 2023-04-18 15:29 23 ****
101 2023-04-18 15:30 25 ******
102 2023-04-18 15:31 26 *******
103 2023-04-18 15:32 ? -
104 2023-04-18 15:33 22 ***
105 2023-04-18 15:34 23 ****
106 2023-04-18 15:35 25 ******
107 2023-04-18 15:36 26 *******
108 2023-04-18 15:37 28 *********
109 2023-04-18 15:38 ? -
110 2023-04-18 15:39 21 **
111 2023-04-18 15:40 ? -
112 2023-04-18 15:41 26 *******
113 2023-04-18 15:42 ? -
114 2023-04-18 15:43 26 *******
115 2023-04-18 15:44 27 ********
116 2023-04-18 15:45 28 *********
117 2023-04-18 15:46 29 **********
118 2023-04-18 15:47 30 ***********
119 2023-04-18 15:48 31 ************
... ..( 2 skipped). .. ************
122 2023-04-18 15:51 31 ************
123 2023-04-18 15:52 32 *************
124 2023-04-18 15:53 32 *************
125 2023-04-18 15:54 ? -
126 2023-04-18 15:55 34 ***************
127 2023-04-18 15:56 34 ***************
0 2023-04-18 15:57 34 ***************
1 2023-04-18 15:58 ? -
2 2023-04-18 15:59 33 **************
3 2023-04-18 16:00 33 **************
4 2023-04-18 16:01 33 **************
5 2023-04-18 16:02 34 ***************
... ..( 2 skipped). .. ***************
8 2023-04-18 16:05 34 ***************
9 2023-04-18 16:06 35 ****************
10 2023-04-18 16:07 35 ****************
11 2023-04-18 16:08 35 ****************
12 2023-04-18 16:09 ? -
13 2023-04-18 16:10 34 ***************
16 2023-04-18 16:13 34 ***************
17 2023-04-18 16:14 35 ****************
18 2023-04-18 16:15 36 *****************
19 2023-04-18 16:16 36 *****************
20 2023-04-18 16:17 35 ****************
... ..( 2 skipped). .. ****************
23 2023-04-18 16:20 35 ****************
24 2023-04-18 16:21 34 ***************
25 2023-04-18 16:22 35 ****************
26 2023-04-18 16:23 35 ****************
27 2023-04-18 16:24 36 *****************
28 2023-04-18 16:25 36 *****************
29 2023-04-18 16:26 37 ******************
30 2023-04-18 16:27 37 ******************
31 2023-04-18 16:28 38 *******************
32 2023-04-18 16:29 38 *******************
33 2023-04-18 16:30 ? -
34 2023-04-18 16:31 39 ********************
35 2023-04-18 16:32 ? -
36 2023-04-18 16:33 37 ******************
37 2023-04-18 16:34 ? -
38 2023-04-18 16:35 38 *******************
39 2023-04-18 16:36 ? -
40 2023-04-18 16:37 38 *******************
41 2023-04-18 16:38 ? -
42 2023-04-18 16:39 22 ***
43 2023-04-18 16:40 22 ***
44 2023-04-18 16:41 24 *****
45 2023-04-18 16:42 25 ******
46 2023-04-18 16:43 26 *******
47 2023-04-18 16:44 27 ********
48 2023-04-18 16:45 29 **********
49 2023-04-18 16:46 29 **********
50 2023-04-18 16:47 29 **********
51 2023-04-18 16:48 30 ***********
52 2023-04-18 16:49 30 ***********
53 2023-04-18 16:50 31 ************
54 2023-04-18 16:51 32 *************
55 2023-04-18 16:52 ? -
56 2023-04-18 16:53 22 ***
57 2023-04-18 16:54 ? -
58 2023-04-18 16:55 23 ****
59 2023-04-18 16:56 23 ****
SCT Error Recovery Control command not supported
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 0 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 1 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000d 2 0 Non-CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 99 Vendor specific
