Does Manjaro support DP 1.2 alt mode out of the box? I am attempting to use a USB-C to DisplayPort adapter but the monitor does not appear when I run “xrandr --current”. The laptop specifications say that the device supports DP 1.2 alt mode. My kernel version is 5.9.16-1-MANJARO.
Please post the output of inxi -Gazy
and mhwd -li
Result of inxi -Gazy
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: NVIDIA GP108M [GeForce MX150] driver: N/A
alternate: nouveau, nvidia_drm, nvidia bus ID: 01:00.0 chip ID: 10de:1d10
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam
type: USB driver: uvcvideo bus ID: 1-3:3 chip ID: 05c8:03bc
Display: x11 server: Xorg 1.20.10 compositor: gnome-shell v: 3.38.2
driver: modesetting unloaded: intel resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Result of mhwd -li
Warning: No installed PCI configs!
Both commands were run with the USB-C display adapter connected.
Please run sudo mhwd -a pci nonfree 0300
, then if it succeeded, reboot; and post the output of inxi -Gazy
and xrandr -q
then.
inxi -Gazy
Integrated Webcam
driver: modesetting resolution: <missing: xdpyinfo>
direct render: Yes
xrandr -q
Screen 0: minimum 320 x 200, current 3840 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 60.16*+ 60.01 59.97 59.96 59.93 40.11
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
HDMI-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 496mm x 292mm
1920x1080 60.00*+
1680x1050 59.88
1600x900 60.00
1280x1024 60.02
1440x900 59.90
1280x720 60.00
1024x768 60.00
800x600 60.32
640x480 59.94
720x400 70.08
Please try the following:
# close every application and save your work
sudo systemctl isolate multi-user
# now log in
sudo modprobe nvidia
sudo modprobe nvidia_drm
sudo systemctl isolate graphical
and after that post the output of inxi -Gazy
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Hewlett-Packard
driver: nvidia v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1d10
Integrated Webcam
Display: x11 server: X.org 1.20.10 compositor: gnome-shell v: 3.38.2
direct render: Yes
And now what’s the output of xrandr -q
and xrandr --listproviders
xrandr -q
1400x1050 59.98
1280x1024 60.02
1280x960 60.00
960x720 60.00
928x696 60.05
896x672 60.01
960x600 59.93 60.00
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
1920x1080 60.00*+
1680x1050 59.88
1600x900 60.00
1280x1024 60.02
1440x900 59.90
1280x720 60.00
1024x768 60.00
800x600 60.32
640x480 59.94
720x400 70.08
Providers: number : 1
Provider 0: id: 0x44 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 2 associated providers: 0 name:modesetting
Can you post the output of head -n999 /etc/X11/xorg.conf /etc/X11/xorg.conf.d/*
head: cannot open '/etc/X11/xorg.conf' for reading: No such file or directory
==> /etc/X11/xorg.conf.d/00-keyboard.conf <==
# Written by systemd-localed(8), read by systemd-localed and Xorg. It's
# probably wise not to edit this file manually. Use localectl(1) to
# instruct systemd-localed to update it.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "us"
EndSection
==> /etc/X11/xorg.conf.d/20-displaylink.conf <==
Section "Device"
Identifier "DisplayLink"
Driver "modesetting"
Option "PageFlip" "false"
EndSection
==> /etc/X11/xorg.conf.d/90-mhwd.conf <==
## Generated by mhwd - Manjaro Hardware Detection
Have you created this file?
And can you post the output of the most recent Xorg log from /var/log/
or ~/.local/share/xorg/
Yes, I created that file.
[ 189.163] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[ 189.163] _XSERVTransMakeAllCOTSServerListeners: server already running
[ 189.163] (--) Log file renamed from "/var/log/Xorg.pid-2773.log" to "/var/log/Xorg.1.log"
[ 189.163] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 189.164]
X.Org X Server 1.20.10
[ 189.164] Build Operating System: Linux Manjaro Linux
[ 189.164] Current Operating System: Linux 5.9.16-1-MANJARO #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020 x86_64
[ 189.164] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=76b12bd4-d35b-4cda-8ba5-cad4e2b3dbd1 rw quiet udev.log_priority=3
[ 189.164] Build Date: 16 December 2020 10:33:32PM
[ 189.164]
[ 189.164] Current version of pixman: 0.40.0
[ 189.164] Before reporting problems, check http://wiki.x.org
[ 189.164] Markers: (--) probed, (**) from config file, (==) default setting,
[ 189.164] (==) Log file: "/var/log/Xorg.1.log", Time: Fri Jan 22 11:09:18 2021
[ 189.164] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 189.164] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 189.164] (==) ServerLayout "layout"
[ 189.164] (==) No screen section available. Using defaults.
[ 189.164] (**) |-->Screen "Default Screen Section" (0)
[ 189.164] (**) | |-->Monitor "<default monitor>"
[ 189.164] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 189.164] (**) | |-->Device "DisplayLink"
[ 189.164] (==) No monitor specified for screen "Default Screen Section".
[ 189.164] (==) Automatically adding devices
[ 189.164] (==) Automatically enabling devices
[ 189.164] (==) Automatically adding GPU devices
[ 189.164] (==) Automatically binding GPU devices
[ 189.164] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 189.164] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 189.164] Entry deleted from font path.
[ 189.164] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 189.165] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[ 189.165] Entry deleted from font path.
[ 189.165] (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[ 189.165] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[ 189.165] (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[ 189.165] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 189.165] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 189.165] (II) The server relies on udev to provide the list of input devices.
[ 189.165] (II) Module ABI versions:
[ 189.165] X.Org ANSI C Emulation: 0.4
[ 189.165] X.Org Video Driver: 24.1
[ 189.165] X.Org XInput driver : 24.1
[ 189.165] X.Org Server Extension : 10.0
[ 189.166] (++) using VT number 2
[ 189.255] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_38
[ 189.257] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 189.311] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 12 paused 0
[ 189.313] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 189.338] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 13 paused 0
[ 189.341] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 189.341] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 189.607] (--) PCI:*(0@0:2:0) 8086:5917:103c:84bf rev 7, Mem @ 0xa2000000/16777216, 0xb0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 189.608] (--) PCI: (1@0:0:0) 10de:1d10:103c:84bf rev 161, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00004000/128
[ 189.608] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 189.608] (II) LoadModule: "glx"
[ 189.608] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 189.609] (II) Module glx: vendor="X.Org Foundation"
[ 189.609] compiled for 1.20.10, module version = 1.0.0
[ 189.609] ABI class: X.Org Server Extension, version 10.0
[ 189.609] (II) LoadModule: "modesetting"
[ 189.609] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 189.609] (II) Module modesetting: vendor="X.Org Foundation"
[ 189.609] compiled for 1.20.10, module version = 1.20.10
[ 189.609] Module class: X.Org Video Driver
[ 189.609] ABI class: X.Org Video Driver, version 24.1
[ 189.609] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 189.609] (II) modeset(0): using drv /dev/dri/card0
[ 189.610] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 189.610] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 189.610] (**) modeset(0): Option "PageFlip" "false"
[ 189.610] (==) modeset(0): RGB weight 888
[ 189.610] (==) modeset(0): Default visual is TrueColor
[ 189.610] (II) Loading sub module "glamoregl"
[ 189.610] (II) LoadModule: "glamoregl"
[ 189.610] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 189.612] (II) Module glamoregl: vendor="X.Org Foundation"
[ 189.612] compiled for 1.20.10, module version = 1.0.1
[ 189.612] ABI class: X.Org ANSI C Emulation, version 0.4
[ 189.653] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 620 (KBL GT2)
[ 189.653] (II) modeset(0): glamor initialized
[ 189.654] (II) modeset(0): Output eDP-1 has no monitor section
[ 189.668] (II) modeset(0): Output HDMI-1 has no monitor section
[ 189.669] (II) modeset(0): EDID for output eDP-1
[ 189.669] (II) modeset(0): Manufacturer: AUO Model: 21ed Serial#: 0
[ 189.669] (II) modeset(0): Year: 2017 Week: 0
[ 189.669] (II) modeset(0): EDID Version: 1.4
[ 189.669] (II) modeset(0): Digital Display Input
[ 189.669] (II) modeset(0): 6 bits per channel
[ 189.669] (II) modeset(0): Digital interface is DisplayPort
[ 189.669] (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 189.669] (II) modeset(0): Gamma: 2.20
[ 189.669] (II) modeset(0): No DPMS capabilities specified
[ 189.669] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 189.669] (II) modeset(0): First detailed timing is preferred mode
[ 189.669] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 189.669] (II) modeset(0): Display is continuous-frequency
[ 189.669] (II) modeset(0): redX: 0.578 redY: 0.348 greenX: 0.349 greenY: 0.571
[ 189.669] (II) modeset(0): blueX: 0.158 blueY: 0.116 whiteX: 0.313 whiteY: 0.329
[ 189.669] (II) modeset(0): Manufacturer's mask: 0
[ 189.669] (II) modeset(0): Supported detailed timing:
[ 189.669] (II) modeset(0): clock: 141.0 MHz Image Size: 344 x 193 mm
[ 189.669] (II) modeset(0): h_active: 1920 h_sync: 2028 h_sync_end 2076 h_blank_end 2100 h_border: 0
[ 189.669] (II) modeset(0): v_active: 1080 v_sync: 1090 v_sync_end 1100 v_blanking: 1116 v_border: 0
[ 189.669] (II) modeset(0): clock: 94.0 MHz Image Size: 344 x 193 mm
[ 189.669] (II) modeset(0): Unknown vendor-specific block 2
[ 189.669] (II) modeset(0): EDID (in hex):
[ 189.669] (II) modeset(0): 00ffffffffffff0006afed2100000000
[ 189.669] (II) modeset(0): 001b0104952213780305b59459599228
[ 189.669] (II) modeset(0): 1d505400000001010101010101010101
[ 189.669] (II) modeset(0): 010101010101143780b4703824406c30
[ 189.669] (II) modeset(0): aa0058c110000018b82480b470382440
[ 189.669] (II) modeset(0): 6c30aa0058c110000018000000000000
[ 189.669] (II) modeset(0): 00000000000000000000000000000002
[ 189.669] (II) modeset(0): 001040ff0f3c7d0b10227d202020006b
[ 189.669] (II) modeset(0): Printing probed modes for output eDP-1
[ 189.669] (II) modeset(0): Modeline "1920x1080"x60.2 141.00 1920 2028 2076 2100 1080 1090 1100 1116 -hsync -vsync (67.1 kHz eP)
[ 189.669] (II) modeset(0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 189.669] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 189.669] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 189.669] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 189.669] (II) modeset(0): Modeline "1920x1080"x40.1 94.00 1920 2028 2076 2100 1080 1090 1100 1116 -hsync -vsync (44.8 kHz e)
[ 189.669] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 189.669] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 189.669] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 189.669] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 189.669] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 189.669] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 189.669] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 189.669] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 189.669] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 189.669] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 189.669] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 189.669] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 189.669] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 189.669] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 189.669] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 189.669] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 189.669] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 189.669] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 189.669] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 189.669] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 189.669] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 189.669] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 189.669] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 189.669] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 189.669] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 189.669] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 189.669] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 189.669] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 189.669] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 189.669] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 189.669] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 189.669] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 189.669] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 189.669] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 189.669] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 189.669] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 189.669] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 189.669] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 189.669] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 189.669] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 189.669] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 189.669] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 189.669] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 189.669] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 189.669] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 189.669] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 189.669] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 189.669] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 189.669] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 189.669] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 189.669] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 189.670] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 189.670] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 189.670] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 189.670] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 189.670] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 189.670] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 189.670] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 189.670] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 189.670] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 189.670] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 189.670] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 189.670] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 189.670] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 189.670] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 189.670] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 189.670] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 189.670] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 189.670] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 189.670] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 189.670] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 189.670] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 189.670] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 189.670] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 189.670] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 189.670] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 189.670] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 189.684] (II) modeset(0): EDID for output HDMI-1
[ 189.684] (II) modeset(0): Manufacturer: HWP Model: 3061 Serial#: 16843009
[ 189.684] (II) modeset(0): Year: 2013 Week: 46
[ 189.684] (II) modeset(0): EDID Version: 1.3
[ 189.684] (II) modeset(0): Digital Display Input
[ 189.684] (II) modeset(0): Max Image Size [cm]: horiz.: 50 vert.: 29
[ 189.684] (II) modeset(0): Gamma: 2.20
[ 189.684] (II) modeset(0): DPMS capabilities: Off
[ 189.684] (II) modeset(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 189.684] (II) modeset(0): Default color space is primary color space
[ 189.684] (II) modeset(0): First detailed timing is preferred mode
[ 189.684] (II) modeset(0): redX: 0.637 redY: 0.330 greenX: 0.310 greenY: 0.620
[ 189.684] (II) modeset(0): blueX: 0.153 blueY: 0.067 whiteX: 0.313 whiteY: 0.329
[ 189.684] (II) modeset(0): Supported established timings:
[ 189.684] (II) modeset(0): 720x400@70Hz
[ 189.684] (II) modeset(0): 640x480@60Hz
[ 189.684] (II) modeset(0): 800x600@60Hz
[ 189.684] (II) modeset(0): 1024x768@60Hz
[ 189.684] (II) modeset(0): Manufacturer's mask: 0
[ 189.684] (II) modeset(0): Supported standard timings:
[ 189.684] (II) modeset(0): #0: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 189.684] (II) modeset(0): #1: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 189.684] (II) modeset(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 189.684] (II) modeset(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 189.684] (II) modeset(0): #4: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 189.684] (II) modeset(0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 189.684] (II) modeset(0): Supported detailed timing:
[ 189.684] (II) modeset(0): clock: 148.5 MHz Image Size: 496 x 292 mm
[ 189.684] (II) modeset(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 189.684] (II) modeset(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 189.684] (II) modeset(0): Ranges: V min: 50 V max: 76 Hz, H min: 24 H max: 94 kHz, PixClock max 175 MHz
[ 189.684] (II) modeset(0): Monitor name: HP E221
[ 189.684] (II) modeset(0): Serial No: CNK3460JS3
[ 189.684] (II) modeset(0): EDID (in hex):
[ 189.684] (II) modeset(0): 00ffffffffffff0022f0613001010101
[ 189.684] (II) modeset(0): 2e17010380321d782e2755a3544f9e27
[ 189.684] (II) modeset(0): 115054a10800d1c081c081809500a9c0
[ 189.684] (II) modeset(0): b30001010101023a801871382d40582c
[ 189.684] (II) modeset(0): 4500f0241100001e000000fd00324c18
[ 189.684] (II) modeset(0): 5e11000a202020202020000000fc0048
[ 189.684] (II) modeset(0): 5020453232310a2020202020000000ff
[ 189.684] (II) modeset(0): 00434e4b333436304a53330a20200078
[ 189.684] (II) modeset(0): Printing probed modes for output HDMI-1
[ 189.684] (II) modeset(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 189.684] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 189.684] (II) modeset(0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 189.684] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 189.684] (II) modeset(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 189.684] (II) modeset(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 189.684] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 189.684] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 189.684] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 189.684] (II) modeset(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 189.684] (II) modeset(0): Output eDP-1 connected
[ 189.684] (II) modeset(0): Output HDMI-1 connected
[ 189.684] (II) modeset(0): Using spanning desktop for initial modes
[ 189.684] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[ 189.684] (II) modeset(0): Output HDMI-1 using initial mode 1920x1080 +1920+0
[ 189.684] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 189.684] (==) modeset(0): DPI set to (96, 96)
[ 189.684] (II) Loading sub module "fb"
[ 189.684] (II) LoadModule: "fb"
[ 189.684] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 189.684] (II) Module fb: vendor="X.Org Foundation"
[ 189.684] compiled for 1.20.10, module version = 1.0.0
[ 189.684] ABI class: X.Org ANSI C Emulation, version 0.4
[ 189.703] (==) modeset(0): Backing store enabled
[ 189.703] (==) modeset(0): Silken mouse disabled
[ 189.913] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 189.914] (==) modeset(0): DPMS enabled
[ 189.914] (II) modeset(0): [DRI2] Setup complete
[ 189.914] (II) modeset(0): [DRI2] DRI driver: iris
[ 189.914] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 189.914] (II) Initializing extension Generic Event Extension
[ 189.914] (II) Initializing extension SHAPE
[ 189.914] (II) Initializing extension MIT-SHM
[ 189.914] (II) Initializing extension XInputExtension
[ 189.915] (II) Initializing extension XTEST
[ 189.915] (II) Initializing extension BIG-REQUESTS
[ 189.915] (II) Initializing extension SYNC
[ 189.915] (II) Initializing extension XKEYBOARD
[ 189.915] (II) Initializing extension XC-MISC
[ 189.915] (II) Initializing extension SECURITY
[ 189.915] (II) Initializing extension XFIXES
[ 189.915] (II) Initializing extension RENDER
[ 189.915] (II) Initializing extension RANDR
[ 189.915] (II) Initializing extension COMPOSITE
[ 189.915] (II) Initializing extension DAMAGE
[ 189.915] (II) Initializing extension MIT-SCREEN-SAVER
[ 189.915] (II) Initializing extension DOUBLE-BUFFER
[ 189.915] (II) Initializing extension RECORD
[ 189.915] (II) Initializing extension DPMS
[ 189.915] (II) Initializing extension Present
[ 189.915] (II) Initializing extension DRI3
[ 189.915] (II) Initializing extension X-Resource
[ 189.915] (II) Initializing extension XVideo
[ 189.915] (II) Initializing extension XVideo-MotionCompensation
[ 189.915] (II) Initializing extension GLX
[ 189.942] (II) AIGLX: Loaded and initialized iris
[ 189.942] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 189.942] (II) Initializing extension XFree86-VidModeExtension
[ 189.942] (II) Initializing extension XFree86-DGA
[ 189.942] (II) Initializing extension XFree86-DRI
[ 189.942] (II) Initializing extension DRI2
[ 189.945] (II) modeset(0): Damage tracking initialized
[ 189.945] (II) modeset(0): Setting screen physical size to 1016 x 285
[ 189.984] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 189.984] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 189.984] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 189.984] (**) Power Button: Applying InputClass "system-keyboard"
[ 189.984] (II) LoadModule: "libinput"
[ 189.984] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 189.985] (II) Module libinput: vendor="X.Org Foundation"
[ 189.985] compiled for 1.20.8, module version = 0.30.0
[ 189.985] Module class: X.Org XInput Driver
[ 189.985] ABI class: X.Org XInput driver, version 24.1
[ 189.985] (II) Using input driver 'libinput' for 'Power Button'
[ 189.990] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 25 paused 0
[ 189.990] (**) Power Button: always reports core events
[ 189.990] (**) Option "Device" "/dev/input/event2"
[ 189.990] (**) Option "_source" "server/udev"
[ 189.991] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 189.991] (II) event2 - Power Button: device is a keyboard
[ 189.991] (II) event2 - Power Button: device removed
[ 189.991] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 189.991] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 189.991] (**) Option "xkb_layout" "us"
[ 189.992] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 189.992] (II) event2 - Power Button: device is a keyboard
[ 189.992] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[ 189.993] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 189.993] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 189.993] (**) Video Bus: Applying InputClass "system-keyboard"
[ 189.993] (II) Using input driver 'libinput' for 'Video Bus'
[ 190.071] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 28 paused 0
[ 190.071] (**) Video Bus: always reports core events
[ 190.071] (**) Option "Device" "/dev/input/event8"
[ 190.071] (**) Option "_source" "server/udev"
[ 190.075] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 190.075] (II) event8 - Video Bus: device is a keyboard
[ 190.076] (II) event8 - Video Bus: device removed
[ 190.076] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10/event8"
[ 190.076] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 190.076] (**) Option "xkb_layout" "us"
[ 190.080] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 190.080] (II) event8 - Video Bus: device is a keyboard
[ 190.082] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[ 190.082] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 190.082] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 190.082] (**) Video Bus: Applying InputClass "system-keyboard"
[ 190.082] (II) Using input driver 'libinput' for 'Video Bus'
[ 190.085] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 29 paused 0
[ 190.085] (**) Video Bus: always reports core events
[ 190.085] (**) Option "Device" "/dev/input/event9"
[ 190.085] (**) Option "_source" "server/udev"
[ 190.089] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 190.090] (II) event9 - Video Bus: device is a keyboard
[ 190.090] (II) event9 - Video Bus: device removed
[ 190.090] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3a/LNXVIDEO:01/input/input11/event9"
[ 190.090] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 190.090] (**) Option "xkb_layout" "us"
[ 190.095] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 190.095] (II) event9 - Video Bus: device is a keyboard
[ 190.097] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 190.097] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 190.097] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 190.097] (**) Power Button: Applying InputClass "system-keyboard"
[ 190.097] (II) Using input driver 'libinput' for 'Power Button'
[ 190.125] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 30 paused 0
[ 190.125] (**) Power Button: always reports core events
[ 190.125] (**) Option "Device" "/dev/input/event1"
[ 190.125] (**) Option "_source" "server/udev"
[ 190.128] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 190.128] (II) event1 - Power Button: device is a keyboard
[ 190.129] (II) event1 - Power Button: device removed
[ 190.129] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 190.129] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 190.129] (**) Option "xkb_layout" "us"
[ 190.133] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 190.133] (II) event1 - Power Button: device is a keyboard
[ 190.135] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 190.135] (II) No input driver specified, ignoring this device.
[ 190.135] (II) This device may have been added with another device file.
[ 190.138] (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event18)
[ 190.138] (**) Razer Razer DeathAdder Essential: Applying InputClass "evdev pointer catchall"
[ 190.138] (**) Razer Razer DeathAdder Essential: Applying InputClass "libinput pointer catchall"
[ 190.138] (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential'
[ 190.196] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 31 paused 0
[ 190.196] (**) Razer Razer DeathAdder Essential: always reports core events
[ 190.196] (**) Option "Device" "/dev/input/event18"
[ 190.196] (**) Option "_source" "server/udev"
[ 190.199] (II) event18 - Razer Razer DeathAdder Essential: is tagged by udev as: Mouse
[ 190.199] (II) event18 - Razer Razer DeathAdder Essential: device is a pointer
[ 190.199] (II) event18 - Razer Razer DeathAdder Essential: device removed
[ 190.199] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:1532:006E.0001/input/input19/event18"
[ 190.199] (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential" (type: MOUSE, id 10)
[ 190.199] (**) Option "AccelerationScheme" "none"
[ 190.199] (**) Razer Razer DeathAdder Essential: (accel) selected scheme none/0
[ 190.199] (**) Razer Razer DeathAdder Essential: (accel) acceleration factor: 2.000
[ 190.199] (**) Razer Razer DeathAdder Essential: (accel) acceleration threshold: 4
[ 190.202] (II) event18 - Razer Razer DeathAdder Essential: is tagged by udev as: Mouse
[ 190.202] (II) event18 - Razer Razer DeathAdder Essential: device is a pointer
[ 190.203] (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/mouse1)
[ 190.203] (II) No input driver specified, ignoring this device.
[ 190.203] (II) This device may have been added with another device file.
[ 190.204] (II) config/udev: Adding input device Razer Razer DeathAdder Essential Keyboard (/dev/input/event19)
[ 190.204] (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "evdev keyboard catchall"
[ 190.204] (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "libinput keyboard catchall"
[ 190.204] (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "system-keyboard"
[ 190.204] (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential Keyboard'
[ 190.206] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 32 paused 0
[ 190.206] (**) Razer Razer DeathAdder Essential Keyboard: always reports core events
[ 190.206] (**) Option "Device" "/dev/input/event19"
[ 190.206] (**) Option "_source" "server/udev"
[ 190.208] (II) event19 - Razer Razer DeathAdder Essential Keyboard: is tagged by udev as: Keyboard
[ 190.208] (II) event19 - Razer Razer DeathAdder Essential Keyboard: device is a keyboard
[ 190.208] (II) event19 - Razer Razer DeathAdder Essential Keyboard: device removed
[ 190.209] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:1532:006E.0002/input/input20/event19"
[ 190.209] (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Keyboard" (type: KEYBOARD, id 11)
[ 190.209] (**) Option "xkb_layout" "us"
[ 190.211] (II) event19 - Razer Razer DeathAdder Essential Keyboard: is tagged by udev as: Keyboard
[ 190.211] (II) event19 - Razer Razer DeathAdder Essential Keyboard: device is a keyboard
[ 190.213] (II) config/udev: Adding input device Razer Razer DeathAdder Essential Consumer Control (/dev/input/event20)
[ 190.213] (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 190.213] (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 190.213] (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "system-keyboard"
[ 190.213] (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential Consumer Control'
[ 190.214] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 33 paused 0
[ 190.214] (**) Razer Razer DeathAdder Essential Consumer Control: always reports core events
[ 190.214] (**) Option "Device" "/dev/input/event20"
[ 190.214] (**) Option "_source" "server/udev"
[ 190.216] (II) event20 - Razer Razer DeathAdder Essential Consumer Control: is tagged by udev as: Keyboard
[ 190.217] (II) event20 - Razer Razer DeathAdder Essential Consumer Control: device is a keyboard
[ 190.217] (II) event20 - Razer Razer DeathAdder Essential Consumer Control: device removed
[ 190.217] (II) libinput: Razer Razer DeathAdder Essential Consumer Control: needs a virtual subdevice
[ 190.217] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:1532:006E.0002/input/input21/event20"
[ 190.217] (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Consumer Control" (type: MOUSE, id 12)
[ 190.217] (**) Option "AccelerationScheme" "none"
[ 190.217] (**) Razer Razer DeathAdder Essential Consumer Control: (accel) selected scheme none/0
[ 190.217] (**) Razer Razer DeathAdder Essential Consumer Control: (accel) acceleration factor: 2.000
[ 190.217] (**) Razer Razer DeathAdder Essential Consumer Control: (accel) acceleration threshold: 4
[ 190.220] (II) event20 - Razer Razer DeathAdder Essential Consumer Control: is tagged by udev as: Keyboard
[ 190.220] (II) event20 - Razer Razer DeathAdder Essential Consumer Control: device is a keyboard
[ 190.221] (II) config/udev: Adding input device Razer Razer DeathAdder Essential System Control (/dev/input/event21)
[ 190.221] (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "evdev keyboard catchall"
[ 190.221] (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "libinput keyboard catchall"
[ 190.221] (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "system-keyboard"
[ 190.221] (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential System Control'
[ 190.222] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 34 paused 0
[ 190.222] (**) Razer Razer DeathAdder Essential System Control: always reports core events
[ 190.222] (**) Option "Device" "/dev/input/event21"
[ 190.222] (**) Option "_source" "server/udev"
[ 190.225] (II) event21 - Razer Razer DeathAdder Essential System Control: is tagged by udev as: Keyboard
[ 190.225] (II) event21 - Razer Razer DeathAdder Essential System Control: device is a keyboard
[ 190.225] (II) event21 - Razer Razer DeathAdder Essential System Control: device removed
[ 190.225] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:1532:006E.0002/input/input22/event21"
[ 190.225] (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential System Control" (type: KEYBOARD, id 13)
[ 190.225] (**) Option "xkb_layout" "us"
[ 190.228] (II) event21 - Razer Razer DeathAdder Essential System Control: is tagged by udev as: Keyboard
[ 190.228] (II) event21 - Razer Razer DeathAdder Essential System Control: device is a keyboard
[ 190.229] (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event22)
[ 190.229] (II) No input driver specified, ignoring this device.
[ 190.229] (II) This device may have been added with another device file.
[ 190.230] (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event23)
[ 190.230] (**) Razer Razer DeathAdder Essential: Applying InputClass "evdev keyboard catchall"
[ 190.230] (**) Razer Razer DeathAdder Essential: Applying InputClass "libinput keyboard catchall"
[ 190.230] (**) Razer Razer DeathAdder Essential: Applying InputClass "system-keyboard"
[ 190.230] (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential'
[ 190.231] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 35 paused 0
[ 190.231] (**) Razer Razer DeathAdder Essential: always reports core events
[ 190.231] (**) Option "Device" "/dev/input/event23"
[ 190.231] (**) Option "_source" "server/udev"
[ 190.234] (II) event23 - Razer Razer DeathAdder Essential: is tagged by udev as: Keyboard
[ 190.234] (II) event23 - Razer Razer DeathAdder Essential: device is a keyboard
[ 190.234] (II) event23 - Razer Razer DeathAdder Essential: device removed
[ 190.234] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.2/0003:1532:006E.0003/input/input24/event23"
[ 190.234] (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential" (type: KEYBOARD, id 14)
[ 190.234] (**) Option "xkb_layout" "us"
[ 190.237] (II) event23 - Razer Razer DeathAdder Essential: is tagged by udev as: Keyboard
[ 190.237] (II) event23 - Razer Razer DeathAdder Essential: device is a keyboard
[ 190.239] (II) config/udev: Adding input device USB-HID Keyboard (/dev/input/event24)
[ 190.239] (**) USB-HID Keyboard: Applying InputClass "evdev keyboard catchall"
[ 190.239] (**) USB-HID Keyboard: Applying InputClass "libinput keyboard catchall"
[ 190.239] (**) USB-HID Keyboard: Applying InputClass "system-keyboard"
[ 190.239] (II) Using input driver 'libinput' for 'USB-HID Keyboard'
[ 190.240] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 36 paused 0
[ 190.240] (**) USB-HID Keyboard: always reports core events
[ 190.240] (**) Option "Device" "/dev/input/event24"
[ 190.240] (**) Option "_source" "server/udev"
[ 190.242] (II) event24 - USB-HID Keyboard: is tagged by udev as: Keyboard
[ 190.242] (II) event24 - USB-HID Keyboard: device is a keyboard
[ 190.243] (II) event24 - USB-HID Keyboard: device removed
[ 190.243] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:04D9:0192.0004/input/input25/event24"
[ 190.243] (II) XINPUT: Adding extended input device "USB-HID Keyboard" (type: KEYBOARD, id 15)
[ 190.243] (**) Option "xkb_layout" "us"
[ 190.245] (II) event24 - USB-HID Keyboard: is tagged by udev as: Keyboard
[ 190.245] (II) event24 - USB-HID Keyboard: device is a keyboard
[ 190.247] (II) config/udev: Adding input device USB-HID Keyboard System Control (/dev/input/event26)
[ 190.247] (**) USB-HID Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 190.247] (**) USB-HID Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 190.247] (**) USB-HID Keyboard System Control: Applying InputClass "system-keyboard"
[ 190.247] (II) Using input driver 'libinput' for 'USB-HID Keyboard System Control'
[ 190.248] (II) systemd-logind: got fd for /dev/input/event26 13:90 fd 37 paused 0
[ 190.248] (**) USB-HID Keyboard System Control: always reports core events
[ 190.248] (**) Option "Device" "/dev/input/event26"
[ 190.248] (**) Option "_source" "server/udev"
[ 190.250] (II) event26 - USB-HID Keyboard System Control: is tagged by udev as: Keyboard
[ 190.250] (II) event26 - USB-HID Keyboard System Control: device is a keyboard
[ 190.251] (II) event26 - USB-HID Keyboard System Control: device removed
[ 190.251] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2/1-1.2:1.2/0003:04D9:0192.0006/input/input27/event26"
[ 190.251] (II) XINPUT: Adding extended input device "USB-HID Keyboard System Control" (type: KEYBOARD, id 16)
[ 190.251] (**) Option "xkb_layout" "us"
[ 190.253] (II) event26 - USB-HID Keyboard System Control: is tagged by udev as: Keyboard
[ 190.254] (II) event26 - USB-HID Keyboard System Control: device is a keyboard
[ 190.255] (II) config/udev: Adding input device USB-HID Keyboard Consumer Control (/dev/input/event27)
[ 190.255] (**) USB-HID Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 190.255] (**) USB-HID Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 190.255] (**) USB-HID Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 190.255] (II) Using input driver 'libinput' for 'USB-HID Keyboard Consumer Control'
[ 190.256] (II) systemd-logind: got fd for /dev/input/event27 13:91 fd 38 paused 0
[ 190.256] (**) USB-HID Keyboard Consumer Control: always reports core events
[ 190.256] (**) Option "Device" "/dev/input/event27"
[ 190.256] (**) Option "_source" "server/udev"
[ 190.258] (II) event27 - USB-HID Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 190.258] (II) event27 - USB-HID Keyboard Consumer Control: device is a keyboard
[ 190.258] (II) event27 - USB-HID Keyboard Consumer Control: device removed
[ 190.258] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2/1-1.2:1.2/0003:04D9:0192.0006/input/input28/event27"
[ 190.258] (II) XINPUT: Adding extended input device "USB-HID Keyboard Consumer Control" (type: KEYBOARD, id 17)
[ 190.258] (**) Option "xkb_layout" "us"
[ 190.260] (II) event27 - USB-HID Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 190.260] (II) event27 - USB-HID Keyboard Consumer Control: device is a keyboard
[ 190.261] (II) config/udev: Adding input device USB-HID Keyboard (/dev/input/event28)
[ 190.261] (**) USB-HID Keyboard: Applying InputClass "evdev keyboard catchall"
[ 190.261] (**) USB-HID Keyboard: Applying InputClass "libinput keyboard catchall"
[ 190.261] (**) USB-HID Keyboard: Applying InputClass "system-keyboard"
[ 190.261] (II) Using input driver 'libinput' for 'USB-HID Keyboard'
[ 190.262] (II) systemd-logind: got fd for /dev/input/event28 13:92 fd 39 paused 0
[ 190.262] (**) USB-HID Keyboard: always reports core events
[ 190.262] (**) Option "Device" "/dev/input/event28"
[ 190.262] (**) Option "_source" "server/udev"
[ 190.264] (II) event28 - USB-HID Keyboard: is tagged by udev as: Keyboard
[ 190.264] (II) event28 - USB-HID Keyboard: device is a keyboard
[ 190.264] (II) event28 - USB-HID Keyboard: device removed
[ 190.264] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2/1-1.2:1.2/0003:04D9:0192.0006/input/input29/event28"
[ 190.264] (II) XINPUT: Adding extended input device "USB-HID Keyboard" (type: KEYBOARD, id 18)
[ 190.264] (**) Option "xkb_layout" "us"
[ 190.266] (II) event28 - USB-HID Keyboard: is tagged by udev as: Keyboard
[ 190.266] (II) event28 - USB-HID Keyboard: device is a keyboard
[ 190.267] (II) config/udev: Adding input device HP Wide Vision HD Camera: HP Wi (/dev/input/event25)
[ 190.267] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "evdev keyboard catchall"
[ 190.267] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "libinput keyboard catchall"
[ 190.267] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "system-keyboard"
[ 190.267] (II) Using input driver 'libinput' for 'HP Wide Vision HD Camera: HP Wi'
[ 190.267] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 40 paused 0
[ 190.267] (**) HP Wide Vision HD Camera: HP Wi: always reports core events
[ 190.267] (**) Option "Device" "/dev/input/event25"
[ 190.267] (**) Option "_source" "server/udev"
[ 190.269] (II) event25 - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[ 190.269] (II) event25 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[ 190.269] (II) event25 - HP Wide Vision HD Camera: HP Wi: device removed
[ 190.269] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input26/event25"
[ 190.269] (II) XINPUT: Adding extended input device "HP Wide Vision HD Camera: HP Wi" (type: KEYBOARD, id 19)
[ 190.269] (**) Option "xkb_layout" "us"
[ 190.270] (II) event25 - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[ 190.270] (II) event25 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[ 190.271] (II) config/udev: Adding input device eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00 (/dev/input/event29)
[ 190.271] (**) eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: Applying InputClass "evdev touchscreen catchall"
[ 190.271] (**) eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: Applying InputClass "libinput touchscreen catchall"
[ 190.271] (II) Using input driver 'libinput' for 'eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00'
[ 190.326] (II) systemd-logind: got fd for /dev/input/event29 13:93 fd 41 paused 0
[ 190.326] (**) eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: always reports core events
[ 190.326] (**) Option "Device" "/dev/input/event29"
[ 190.326] (**) Option "_source" "server/udev"
[ 190.330] (II) event29 - eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: is tagged by udev as: Touchscreen
[ 190.330] (II) event29 - eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: device is a touch device
[ 190.331] (II) event29 - eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: device removed
[ 190.331] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:0EEF:C0AE.0007/input/input32/event29"
[ 190.331] (II) XINPUT: Adding extended input device "eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00" (type: TOUCHSCREEN, id 20)
[ 190.331] (**) Option "AccelerationScheme" "none"
[ 190.331] (**) eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: (accel) selected scheme none/0
[ 190.331] (**) eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: (accel) acceleration factor: 2.000
[ 190.331] (**) eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: (accel) acceleration threshold: 4
[ 190.336] (II) event29 - eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: is tagged by udev as: Touchscreen
[ 190.336] (II) event29 - eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: device is a touch device
[ 190.338] (II) config/udev: Adding input device eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00 (/dev/input/mouse2)
[ 190.338] (II) No input driver specified, ignoring this device.
[ 190.338] (II) This device may have been added with another device file.
[ 190.340] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event11)
[ 190.340] (II) No input driver specified, ignoring this device.
[ 190.340] (II) This device may have been added with another device file.
[ 190.341] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event12)
[ 190.341] (II) No input driver specified, ignoring this device.
[ 190.341] (II) This device may have been added with another device file.
[ 190.342] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[ 190.343] (II) No input driver specified, ignoring this device.
[ 190.343] (II) This device may have been added with another device file.
[ 190.344] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event14)
[ 190.344] (II) No input driver specified, ignoring this device.
[ 190.344] (II) This device may have been added with another device file.
[ 190.345] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event15)
[ 190.345] (II) No input driver specified, ignoring this device.
[ 190.345] (II) This device may have been added with another device file.
[ 190.346] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event16)
[ 190.346] (II) No input driver specified, ignoring this device.
[ 190.346] (II) This device may have been added with another device file.
[ 190.347] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event17)
[ 190.347] (II) No input driver specified, ignoring this device.
[ 190.347] (II) This device may have been added with another device file.
[ 190.348] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 190.348] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 190.348] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 190.348] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 190.349] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 190.350] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 42 paused 0
[ 190.351] (**) AT Translated Set 2 keyboard: always reports core events
[ 190.351] (**) Option "Device" "/dev/input/event3"
[ 190.351] (**) Option "_source" "server/udev"
[ 190.354] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 190.354] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 190.357] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 190.357] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 190.357] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 21)
[ 190.357] (**) Option "xkb_layout" "us"
[ 190.360] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 190.360] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 190.363] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event10)
[ 190.363] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[ 190.363] (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
[ 190.363] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[ 190.364] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 43 paused 0
[ 190.364] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 190.364] (**) Option "Device" "/dev/input/event10"
[ 190.364] (**) Option "_source" "server/udev"
[ 190.365] (II) event10 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 190.367] (II) event10 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 190.367] (II) event10 - ETPS/2 Elantech Touchpad: device removed
[ 190.368] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event10"
[ 190.368] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 22)
[ 190.369] (**) Option "AccelerationScheme" "none"
[ 190.369] (**) ETPS/2 Elantech Touchpad: (accel) selected scheme none/0
[ 190.369] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[ 190.369] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[ 190.370] (II) event10 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 190.372] (II) event10 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 190.373] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse0)
[ 190.373] (II) No input driver specified, ignoring this device.
[ 190.373] (II) This device may have been added with another device file.
[ 190.373] (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/event5)
[ 190.373] (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/js0)
[ 190.374] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 190.374] (II) No input driver specified, ignoring this device.
[ 190.374] (II) This device may have been added with another device file.
[ 190.374] (II) config/udev: Adding input device HP Wireless hotkeys (/dev/input/event4)
[ 190.374] (**) HP Wireless hotkeys: Applying InputClass "evdev keyboard catchall"
[ 190.374] (**) HP Wireless hotkeys: Applying InputClass "libinput keyboard catchall"
[ 190.375] (**) HP Wireless hotkeys: Applying InputClass "system-keyboard"
[ 190.375] (II) Using input driver 'libinput' for 'HP Wireless hotkeys'
[ 190.375] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 44 paused 0
[ 190.375] (**) HP Wireless hotkeys: always reports core events
[ 190.375] (**) Option "Device" "/dev/input/event4"
[ 190.375] (**) Option "_source" "server/udev"
[ 190.376] (II) event4 - HP Wireless hotkeys: is tagged by udev as: Keyboard
[ 190.376] (II) event4 - HP Wireless hotkeys: device is a keyboard
[ 190.376] (II) event4 - HP Wireless hotkeys: device removed
[ 190.376] (**) Option "config_info" "udev:/sys/devices/virtual/input/input5/event4"
[ 190.376] (II) XINPUT: Adding extended input device "HP Wireless hotkeys" (type: KEYBOARD, id 23)
[ 190.376] (**) Option "xkb_layout" "us"
[ 190.377] (II) event4 - HP Wireless hotkeys: is tagged by udev as: Keyboard
[ 190.377] (II) event4 - HP Wireless hotkeys: device is a keyboard
[ 190.377] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event7)
[ 190.377] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 190.378] (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 190.378] (**) HP WMI hotkeys: Applying InputClass "system-keyboard"
[ 190.378] (II) Using input driver 'libinput' for 'HP WMI hotkeys'
[ 190.378] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 45 paused 0
[ 190.378] (**) HP WMI hotkeys: always reports core events
[ 190.378] (**) Option "Device" "/dev/input/event7"
[ 190.378] (**) Option "_source" "server/udev"
[ 190.379] (II) event7 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 190.379] (II) event7 - HP WMI hotkeys: device is a keyboard
[ 190.379] (II) event7 - HP WMI hotkeys: device removed
[ 190.379] (**) Option "config_info" "udev:/sys/devices/virtual/input/input9/event7"
[ 190.379] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 24)
[ 190.379] (**) Option "xkb_layout" "us"
[ 190.380] (II) event7 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 190.380] (II) event7 - HP WMI hotkeys: device is a keyboard
[ 190.397] (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 190.397] (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 190.397] (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "system-keyboard"
[ 190.397] (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential Consumer Control'
[ 190.397] (II) systemd-logind: returning pre-existing fd for /dev/input/event20 13:84
[ 190.397] (**) Razer Razer DeathAdder Essential Consumer Control: always reports core events
[ 190.397] (**) Option "Device" "/dev/input/event20"
[ 190.397] (**) Option "_source" "_driver/libinput"
[ 190.397] (II) libinput: Razer Razer DeathAdder Essential Consumer Control: is a virtual subdevice
[ 190.397] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:1532:006E.0002/input/input21/event20"
[ 190.397] (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Consumer Control" (type: KEYBOARD, id 25)
[ 190.397] (**) Option "xkb_layout" "us"
[ 190.851] (II) modeset(0): EDID vendor "HWP", prod id 12385
[ 190.851] (II) modeset(0): Using EDID range info for horizontal sync
[ 190.851] (II) modeset(0): Using EDID range info for vertical refresh
[ 190.851] (II) modeset(0): Printing DDC gathered Modelines:
[ 190.851] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 190.851] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 190.851] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 190.851] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 190.851] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 190.851] (II) modeset(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 190.851] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 190.851] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 190.851] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 190.851] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 191.965] (II) modeset(0): EDID vendor "HWP", prod id 12385
[ 191.965] (II) modeset(0): Using hsync ranges from config file
[ 191.965] (II) modeset(0): Using vrefresh ranges from config file
[ 191.965] (II) modeset(0): Printing DDC gathered Modelines:
[ 191.965] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 191.965] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 191.965] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 191.965] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 191.965] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 191.965] (II) modeset(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 191.965] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 191.965] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 191.965] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 191.965] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 323.044] (EE) event24 - USB-HID Keyboard: client bug: event processing lagging behind by 21ms, your system is too slow
[ 605.699] (II) modeset(0): EDID vendor "HWP", prod id 12385
[ 605.699] (II) modeset(0): Using hsync ranges from config file
[ 605.699] (II) modeset(0): Using vrefresh ranges from config file
[ 605.699] (II) modeset(0): Printing DDC gathered Modelines:
[ 605.699] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 605.699] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 605.699] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 605.699] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 605.699] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 605.699] (II) modeset(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 605.699] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 605.700] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 605.700] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 605.700] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 713.292] (II) modeset(0): EDID vendor "HWP", prod id 12385
[ 713.292] (II) modeset(0): Using hsync ranges from config file
[ 713.293] (II) modeset(0): Using vrefresh ranges from config file
[ 713.293] (II) modeset(0): Printing DDC gathered Modelines:
[ 713.293] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 713.293] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 713.293] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 713.293] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 713.293] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 713.293] (II) modeset(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 713.293] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 713.293] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 713.293] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 713.293] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 713.310] (II) modeset(0): EDID vendor "HWP", prod id 12385
[ 713.310] (II) modeset(0): Using hsync ranges from config file
[ 713.310] (II) modeset(0): Using vrefresh ranges from config file
[ 713.310] (II) modeset(0): Printing DDC gathered Modelines:
[ 713.310] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 713.310] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 713.310] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 713.310] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 713.311] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 713.311] (II) modeset(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 713.311] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 713.311] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 713.311] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 713.311] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 907.907] (EE) event18 - Razer Razer DeathAdder Essential: client bug: event processing lagging behind by 11ms, your system is too slow
[ 1724.755] (EE) event18 - Razer Razer DeathAdder Essential: client bug: event processing lagging behind by 13ms, your system is too slow
[ 2884.044] (II) modeset(0): EDID vendor "HWP", prod id 12385
[ 2884.044] (II) modeset(0): Using hsync ranges from config file
[ 2884.044] (II) modeset(0): Using vrefresh ranges from config file
[ 2884.044] (II) modeset(0): Printing DDC gathered Modelines:
[ 2884.044] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 2884.044] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 2884.044] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 2884.044] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 2884.044] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 2884.044] (II) modeset(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 2884.044] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 2884.044] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 2884.044] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 2884.044] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 2894.001] (II) modeset(0): EDID vendor "HWP", prod id 12385
[ 2894.002] (II) modeset(0): Using hsync ranges from config file
[ 2894.002] (II) modeset(0): Using vrefresh ranges from config file
[ 2894.002] (II) modeset(0): Printing DDC gathered Modelines:
[ 2894.002] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 2894.002] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 2894.002] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 2894.002] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 2894.002] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 2894.002] (II) modeset(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 2894.002] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 2894.002] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 2894.002] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 2894.002] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 2894.019] (II) modeset(0): EDID vendor "HWP", prod id 12385
[ 2894.019] (II) modeset(0): Using hsync ranges from config file
[ 2894.019] (II) modeset(0): Using vrefresh ranges from config file
[ 2894.019] (II) modeset(0): Printing DDC gathered Modelines:
[ 2894.019] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 2894.019] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 2894.019] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 2894.019] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 2894.019] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 2894.019] (II) modeset(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 2894.019] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 2894.019] (II) modeset(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 2894.019] (II) modeset(0): Modeline "1600x900"x60.0 119.00 1600 1696 1864 2128 900 901 904 932 -hsync +vsync (55.9 kHz e)
[ 2894.019] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 3797.050] (EE) event18 - Razer Razer DeathAdder Essential: client bug: event processing lagging behind by 11ms, your system is too slow
[ 3992.373] (EE) event18 - Razer Razer DeathAdder Essential: client bug: event processing lagging behind by 11ms, your system is too slow
[ 4682.791] (EE) event18 - Razer Razer DeathAdder Essential: client bug: event processing lagging behind by 11ms, your system is too slow
[ 6285.071] (EE) event24 - USB-HID Keyboard: client bug: event processing lagging behind by 39ms, your system is too slow
[ 6411.610] (EE) event24 - USB-HID Keyboard: client bug: event processing lagging behind by 32ms, your system is too slow
[ 6771.275] (EE) event24 - USB-HID Keyboard: client bug: event processing lagging behind by 23ms, your system is too slow
[ 6912.313] (EE) event24 - USB-HID Keyboard: client bug: event processing lagging behind by 21ms, your system is too slow
[ 9497.466] (EE) event24 - USB-HID Keyboard: client bug: event processing lagging behind by 18ms, your system is too slow
[ 9497.466] (EE) event24 - USB-HID Keyboard: WARNING: log rate limit exceeded (5 msgs per 60min). Discarding future messages.
[ 13145.357] (EE) event24 - USB-HID Keyboard: client bug: event processing lagging behind by 26ms, your system is too slow
[ 13847.616] (EE) event18 - Razer Razer DeathAdder Essential: client bug: event processing lagging behind by 12ms, your system is too slow
[ 14020.173] (EE) event18 - Razer Razer DeathAdder Essential: client bug: event processing lagging behind by 11ms, your system is too slow
[ 22123.019] (EE) event18 - Razer Razer DeathAdder Essential: client bug: event processing lagging behind by 14ms, your system is too slow
Interestingly, it seems the NVIDIA Xorg driver is not loaded. Can you post the output of pacman -Q | grep nvidia
and mhwd -li
lib32-nvidia-utils 460.32.03-1
linux44-nvidia 460.32.03-3
linux49-nvidia 460.32.03-3
linux54-nvidia 460.32.03-3
linux59-nvidia 460.32.03-1
mhwd-nvidia 455.45.01-3
mhwd-nvidia-340xx 340.108-1
mhwd-nvidia-390xx 390.138-1
nvidia-prime 1.0-4
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2020.11.30 false PCI
Any ideas?
Please remove (back up) /etc/X11/xorg.conf.d/20-displaylink.conf
, and then create /etc/X11/xorg.conf.d/10-intel-nvidia.conf
Section "ServerLayout"
Identifier "layout"
Screen 0 "intel"
Inactive "nvidia"
Option "AllowNVIDIAGPUScreens"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
Section "Screen"
Identifier "nvidia"
Device "nvidia"
EndSection
Section "Device"
Identifier "intel"
Driver "modesetting"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "intel"
Device "intel"
EndSection
and the reboot.
This is what I see now:
xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x1b8 cap: 0x1, Source Output crtcs: 0 outputs: 0 associated providers: 1 name:NVIDIA-0
Provider 1: id: 0x1dd cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 2 associated providers: 1 name:modesetting
xrandr --current
Screen 0: minimum 8 x 8, current 3843 x 1080, maximum 32767 x 32767
eDP-1-1 connected primary 1920x1080+1923+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 60.16*+ 60.01 59.97 59.96 59.93 40.11
1680x1050 59.95 59.88
1400x1050 59.98
1600x900 59.99 59.94 59.95 59.82
1280x1024 60.02
1400x900 59.96 59.88
1280x960 60.00
1440x810 60.00 59.97
1368x768 59.88 59.85
1280x800 59.99 59.97 59.81 59.91
1280x720 60.00 59.99 59.86 59.74
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
1024x576 59.95 59.96 59.90 59.82
960x600 59.93 60.00
960x540 59.96 59.99 59.63 59.82
800x600 60.00 60.32 56.25
840x525 60.01 59.88
864x486 59.92 59.57
700x525 59.98
800x450 59.95 59.82
640x512 60.02
700x450 59.96 59.88
640x480 60.00 59.94
720x405 59.51 58.99
684x384 59.88 59.85
640x400 59.88 59.98
640x360 59.86 59.83 59.84 59.32
512x384 60.00
512x288 60.00 59.92
480x270 59.63 59.82
400x300 60.32 56.34
432x243 59.92 59.57
320x240 60.05
360x202 59.51 59.13
320x180 59.84 59.32
HDMI-1-1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 496mm x 292mm
1920x1080 60.00*+
1680x1050 59.88
1600x900 60.00
1280x1024 60.02
1440x900 59.90
1280x720 60.00
1024x768 60.00
800x600 60.32
640x480 59.94
720x400 70.08
Still no third display, unfortunately.
Could you post the latest Xorg log?
[ 117.227] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[ 117.227] _XSERVTransMakeAllCOTSServerListeners: server already running
[ 117.228] (--) Log file renamed from "/var/log/Xorg.pid-1565.log" to "/var/log/Xorg.1.log"
[ 117.228] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 117.228]
X.Org X Server 1.20.10
[ 117.228] Build Operating System: Linux Manjaro Linux
[ 117.228] Current Operating System: Linux lugnut 5.9.16-1-MANJARO #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020 x86_64
[ 117.228] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=76b12bd4-d35b-4cda-8ba5-cad4e2b3dbd1 rw quiet udev.log_priority=3
[ 117.228] Build Date: 16 December 2020 10:33:32PM
[ 117.228]
[ 117.228] Current version of pixman: 0.40.0
[ 117.228] Before reporting problems, check http://wiki.x.org
[ 117.228] Markers: (--) probed, (**) from config file, (==) default setting,
[ 117.228] (==) Log file: "/var/log/Xorg.1.log", Time: Sun Feb 7 19:07:26 2021
[ 117.228] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 117.228] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 117.229] (==) ServerLayout "layout"
[ 117.229] (**) |-->Screen "nvidia" (0)
[ 117.229] (**) | |-->Monitor "<default monitor>"
[ 117.229] (**) | |-->Device "nvidia"
[ 117.229] (**) | |-->GPUDevice "intel"
[ 117.229] (==) No monitor specified for screen "nvidia".
[ 117.229] (==) Automatically adding devices
[ 117.229] (==) Automatically enabling devices
[ 117.229] (==) Automatically adding GPU devices
[ 117.229] (==) Automatically binding GPU devices
[ 117.229] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 117.229] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 117.229] Entry deleted from font path.
[ 117.229] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 117.229] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[ 117.229] (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[ 117.229] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[ 117.229] (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[ 117.229] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 117.229] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 117.229] (II) The server relies on udev to provide the list of input devices.
[ 117.229] (II) Module ABI versions:
[ 117.229] X.Org ANSI C Emulation: 0.4
[ 117.229] X.Org Video Driver: 24.1
[ 117.229] X.Org XInput driver : 24.1
[ 117.229] X.Org Server Extension : 10.0
[ 117.230] (++) using VT number 2
[ 117.231] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[ 117.232] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 117.232] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 12 paused 0
[ 117.233] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 117.233] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 13 paused 0
[ 117.234] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 117.234] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 117.235] (--) PCI:*(0@0:2:0) 8086:5917:103c:84bf rev 7, Mem @ 0xa2000000/16777216, 0xb0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 117.235] (--) PCI: (1@0:0:0) 10de:1d10:103c:84bf rev 161, Mem @ 0xa3000000/16777216, 0x90000000/268435456, 0xa0000000/33554432, I/O @ 0x00004000/128
[ 117.235] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 117.235] (II) LoadModule: "glx"
[ 117.236] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 117.237] (II) Module glx: vendor="X.Org Foundation"
[ 117.237] compiled for 1.20.10, module version = 1.0.0
[ 117.237] ABI class: X.Org Server Extension, version 10.0
[ 117.237] (II) LoadModule: "nvidia"
[ 117.237] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 117.237] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 117.237] compiled for 1.6.99.901, module version = 1.0.0
[ 117.237] Module class: X.Org Video Driver
[ 117.237] (II) LoadModule: "modesetting"
[ 117.237] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 117.238] (II) Module modesetting: vendor="X.Org Foundation"
[ 117.238] compiled for 1.20.10, module version = 1.20.10
[ 117.238] Module class: X.Org Video Driver
[ 117.238] ABI class: X.Org Video Driver, version 24.1
[ 117.238] (II) NVIDIA dlloader X Driver 460.32.03 Sun Dec 27 18:56:00 UTC 2020
[ 117.238] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 117.238] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 117.238] (II) systemd-logind: releasing fd for 226:0
[ 117.239] (II) Loading sub module "fb"
[ 117.239] (II) LoadModule: "fb"
[ 117.239] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 117.239] (II) Module fb: vendor="X.Org Foundation"
[ 117.239] compiled for 1.20.10, module version = 1.0.0
[ 117.239] ABI class: X.Org ANSI C Emulation, version 0.4
[ 117.239] (II) Loading sub module "wfb"
[ 117.239] (II) LoadModule: "wfb"
[ 117.239] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 117.239] (II) Module wfb: vendor="X.Org Foundation"
[ 117.239] (II) Loading sub module "ramdac"
[ 117.239] (II) LoadModule: "ramdac"
[ 117.239] (II) Module "ramdac" already built-in
[ 117.240] (II) modeset(G0): using drv /dev/dri/card1
[ 117.240] (II) NVIDIA(0): Creating default Display subsection in Screen section
"nvidia" for depth/fbbpp 24/32
[ 117.240] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 117.240] (==) NVIDIA(0): RGB weight 888
[ 117.240] (==) NVIDIA(0): Default visual is TrueColor
[ 117.240] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 117.240] (**) Option "AllowNVIDIAGpuScreens"
[ 117.240] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 117.240] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 117.240] (**) NVIDIA(0): Enabling 2D acceleration
[ 117.240] (II) Loading sub module "glxserver_nvidia"
[ 117.240] (II) LoadModule: "glxserver_nvidia"
[ 117.240] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 117.247] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 117.247] compiled for 1.6.99.901, module version = 1.0.0
[ 117.247] Module class: X.Org Server Extension
[ 117.247] (II) NVIDIA GLX Module 460.32.03 Sun Dec 27 18:53:34 UTC 2020
[ 117.247] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 117.248] (II) NVIDIA(0): NVIDIA GPU GeForce MX150 (GP108-A) at PCI:1:0:0 (GPU-0)
[ 117.248] (--) NVIDIA(0): Memory: 4194304 kBytes
[ 117.248] (--) NVIDIA(0): VideoBIOS: 86.08.27.00.07
[ 117.248] (II) NVIDIA(0): Detected PCI Express Link width: 4X
[ 117.249] (II) NVIDIA(0): Validated MetaModes:
[ 117.249] (II) NVIDIA(0): "NULL"
[ 117.249] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 117.249] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 117.249] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 117.249] (==) modeset(G0): Depth 24, (==) framebuffer bpp 32
[ 117.249] (==) modeset(G0): RGB weight 888
[ 117.249] (==) modeset(G0): Default visual is TrueColor
[ 117.249] (II) Loading sub module "glamoregl"
[ 117.249] (II) LoadModule: "glamoregl"
[ 117.249] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 117.253] (II) Module glamoregl: vendor="X.Org Foundation"
[ 117.253] compiled for 1.20.10, module version = 1.0.1
[ 117.253] ABI class: X.Org ANSI C Emulation, version 0.4
[ 117.300] (II) modeset(G0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics 620 (KBL GT2)
[ 117.300] (II) modeset(G0): glamor initialized
[ 117.301] (II) modeset(G0): Output eDP-1-1 has no monitor section
[ 117.315] (II) modeset(G0): Output HDMI-1-1 has no monitor section
[ 117.316] (II) modeset(G0): EDID for output eDP-1-1
[ 117.316] (II) modeset(G0): Manufacturer: AUO Model: 21ed Serial#: 0
[ 117.316] (II) modeset(G0): Year: 2017 Week: 0
[ 117.316] (II) modeset(G0): EDID Version: 1.4
[ 117.316] (II) modeset(G0): Digital Display Input
[ 117.316] (II) modeset(G0): 6 bits per channel
[ 117.316] (II) modeset(G0): Digital interface is DisplayPort
[ 117.316] (II) modeset(G0): Max Image Size [cm]: horiz.: 34 vert.: 19
[ 117.316] (II) modeset(G0): Gamma: 2.20
[ 117.316] (II) modeset(G0): No DPMS capabilities specified
[ 117.316] (II) modeset(G0): Supported color encodings: RGB 4:4:4
[ 117.316] (II) modeset(G0): First detailed timing is preferred mode
[ 117.316] (II) modeset(G0): Preferred mode is native pixel format and refresh rate
[ 117.316] (II) modeset(G0): Display is continuous-frequency
[ 117.316] (II) modeset(G0): redX: 0.578 redY: 0.348 greenX: 0.349 greenY: 0.571
[ 117.316] (II) modeset(G0): blueX: 0.158 blueY: 0.116 whiteX: 0.313 whiteY: 0.329
[ 117.316] (II) modeset(G0): Manufacturer's mask: 0
[ 117.316] (II) modeset(G0): Supported detailed timing:
[ 117.316] (II) modeset(G0): clock: 141.0 MHz Image Size: 344 x 193 mm
[ 117.316] (II) modeset(G0): h_active: 1920 h_sync: 2028 h_sync_end 2076 h_blank_end 2100 h_border: 0
[ 117.316] (II) modeset(G0): v_active: 1080 v_sync: 1090 v_sync_end 1100 v_blanking: 1116 v_border: 0
[ 117.316] (II) modeset(G0): clock: 94.0 MHz Image Size: 344 x 193 mm
[ 117.316] (II) modeset(G0): Unknown vendor-specific block 2
[ 117.316] (II) modeset(G0): EDID (in hex):
[ 117.316] (II) modeset(G0): 00ffffffffffff0006afed2100000000
[ 117.316] (II) modeset(G0): 001b0104952213780305b59459599228
[ 117.316] (II) modeset(G0): 1d505400000001010101010101010101
[ 117.316] (II) modeset(G0): 010101010101143780b4703824406c30
[ 117.316] (II) modeset(G0): aa0058c110000018b82480b470382440
[ 117.316] (II) modeset(G0): 6c30aa0058c110000018000000000000
[ 117.316] (II) modeset(G0): 00000000000000000000000000000002
[ 117.316] (II) modeset(G0): 001040ff0f3c7d0b10227d202020006b
[ 117.316] (II) modeset(G0): Printing probed modes for output eDP-1-1
[ 117.316] (II) modeset(G0): Modeline "1920x1080"x60.2 141.00 1920 2028 2076 2100 1080 1090 1100 1116 -hsync -vsync (67.1 kHz eP)
[ 117.316] (II) modeset(G0): Modeline "1920x1080"x120.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1920x1080"x40.1 94.00 1920 2028 2076 2100 1080 1090 1100 1116 -hsync -vsync (44.8 kHz e)
[ 117.316] (II) modeset(G0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 117.316] (II) modeset(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 117.316] (II) modeset(G0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 117.316] (II) modeset(G0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 117.317] (II) modeset(G0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 117.317] (II) modeset(G0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 117.317] (II) modeset(G0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 117.317] (II) modeset(G0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 117.317] (II) modeset(G0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 117.317] (II) modeset(G0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 117.317] (II) modeset(G0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 117.317] (II) modeset(G0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 117.317] (II) modeset(G0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 117.317] (II) modeset(G0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 117.317] (II) modeset(G0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 117.317] (II) modeset(G0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 117.317] (II) modeset(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 117.317] (II) modeset(G0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 117.317] (II) modeset(G0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 117.317] (II) modeset(G0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 117.317] (II) modeset(G0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 117.317] (II) modeset(G0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 117.317] (II) modeset(G0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 117.317] (II) modeset(G0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 117.317] (II) modeset(G0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 117.317] (II) modeset(G0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 117.317] (II) modeset(G0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 117.317] (II) modeset(G0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 117.317] (II) modeset(G0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 117.317] (II) modeset(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 117.317] (II) modeset(G0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 117.317] (II) modeset(G0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 117.317] (II) modeset(G0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 117.317] (II) modeset(G0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 117.317] (II) modeset(G0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 117.317] (II) modeset(G0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 117.317] (II) modeset(G0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 117.317] (II) modeset(G0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 117.317] (II) modeset(G0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 117.317] (II) modeset(G0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 117.317] (II) modeset(G0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 117.317] (II) modeset(G0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 117.317] (II) modeset(G0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 117.317] (II) modeset(G0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 117.317] (II) modeset(G0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 117.317] (II) modeset(G0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 117.317] (II) modeset(G0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 117.317] (II) modeset(G0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 117.317] (II) modeset(G0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 117.317] (II) modeset(G0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 117.317] (II) modeset(G0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 117.317] (II) modeset(G0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 117.317] (II) modeset(G0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 117.317] (II) modeset(G0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 117.331] (II) modeset(G0): EDID for output HDMI-1-1
[ 117.331] (II) modeset(G0): Manufacturer: HWP Model: 3061 Serial#: 16843009
[ 117.331] (II) modeset(G0): Year: 2013 Week: 46
[ 117.331] (II) modeset(G0): EDID Version: 1.3
[ 117.331] (II) modeset(G0): Digital Display Input
[ 117.331] (II) modeset(G0): Max Image Size [cm]: horiz.: 50 vert.: 29
[ 117.331] (II) modeset(G0): Gamma: 2.20
[ 117.331] (II) modeset(G0): DPMS capabilities: Off
[ 117.331] (II) modeset(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 117.331] (II) modeset(G0): Default color space is primary color space
[ 117.331] (II) modeset(G0): First detailed timing is preferred mode
[ 117.331] (II) modeset(G0): redX: 0.637 redY: 0.330 greenX: 0.310 greenY: 0.620
[ 117.331] (II) modeset(G0): blueX: 0.153 blueY: 0.067 whiteX: 0.313 whiteY: 0.329
[ 117.331] (II) modeset(G0): Supported established timings:
[ 117.331] (II) modeset(G0): 720x400@70Hz
[ 117.331] (II) modeset(G0): 640x480@60Hz
[ 117.331] (II) modeset(G0): 800x600@60Hz
[ 117.331] (II) modeset(G0): 1024x768@60Hz
[ 117.331] (II) modeset(G0): Manufacturer's mask: 0
[ 117.331] (II) modeset(G0): Supported standard timings:
[ 117.331] (II) modeset(G0): #0: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 117.331] (II) modeset(G0): #1: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 117.331] (II) modeset(G0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 117.331] (II) modeset(G0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 117.331] (II) modeset(G0): #4: hsize: 1600 vsize 900 refresh: 60 vid: 49321
[ 117.331] (II) modeset(G0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 117.331] (II) modeset(G0): Supported detailed timing:
[ 117.331] (II) modeset(G0): clock: 148.5 MHz Image Size: 496 x 292 mm
[ 117.331] (II) modeset(G0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 117.331] (II) modeset(G0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 117.331] (II) modeset(G0): Ranges: V min: 50 V max: 76 Hz, H min: 24 H max: 94 kHz, PixClock max 175 MHz
[ 117.331] (II) modeset(G0): Monitor name: HP E221
[ 117.331] (II) modeset(G0): Serial No: CNK3460JS3
[ 117.331] (II) modeset(G0): EDID (in hex):
[ 117.331] (II) modeset(G0): 00ffffffffffff0022f0613001010101
[ 117.331] (II) modeset(G0): 2e17010380321d782e2755a3544f9e27
[ 117.331] (II) modeset(G0): 115054a10800d1c081c081809500a9c0
[ 117.331] (II) modeset(G0): b30001010101023a801871382d40582c
[ 117.331] (II) modeset(G0): 4500f0241100001e000000fd00324c18
[ 117.331] (II) modeset(G0): 5e11000a202020202020000000fc0048
[ 117.331] (II) modeset(G0): 5020453232310a2020202020000000ff
[ 117.331] (II) modeset(G0): 00434e4b333436304a53330a20200078
[ 117.331] (II) modeset(G0): Printing probed modes for output HDMI-1-1
[ 117.331] (II) modeset(G0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 117.331] (II) modeset(G0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 117.331] (II) modeset(G0): Modeline "1600x900"x60.0 108.00 1600 1624 1704 1800 900 901 904 1000 +hsync +vsync (60.0 kHz e)
[ 117.331] (II) modeset(G0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 117.331] (II) modeset(G0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 117.331] (II) modeset(G0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 117.331] (II) modeset(G0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 117.331] (II) modeset(G0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 117.331] (II) modeset(G0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 117.332] (II) modeset(G0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 117.332] (==) modeset(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 117.332] (==) modeset(G0): DPI set to (96, 96)
[ 117.332] (II) Loading sub module "fb"
[ 117.332] (II) LoadModule: "fb"
[ 117.332] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 117.332] (II) Module fb: vendor="X.Org Foundation"
[ 117.332] compiled for 1.20.10, module version = 1.0.0
[ 117.332] ABI class: X.Org ANSI C Emulation, version 0.4
[ 117.332] (II) NVIDIA: Using 24576.00 MB of virtual memory for indirect memory
[ 117.332] (II) NVIDIA: access.
[ 117.335] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 117.335] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 117.335] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 117.335] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 117.335] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 117.335] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 117.335] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 117.335] (II) NVIDIA(0): Config Options in the README.
[ 117.349] (II) NVIDIA(0): Setting mode "NULL"
[ 117.352] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 117.352] (==) NVIDIA(0): Backing store enabled
[ 117.352] (==) NVIDIA(0): Silken mouse disabled
[ 117.352] (==) NVIDIA(0): DPMS enabled
[ 117.352] (II) Loading sub module "dri2"
[ 117.352] (II) LoadModule: "dri2"
[ 117.352] (II) Module "dri2" already built-in
[ 117.352] (II) NVIDIA(0): [DRI2] Setup complete
[ 117.352] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 117.368] (==) modeset(G0): Backing store enabled
[ 117.368] (==) modeset(G0): Silken mouse disabled
[ 117.598] (II) modeset(G0): Initializing kms color map for depth 24, 8 bpc.
[ 117.598] (==) modeset(G0): DPMS enabled
[ 117.599] (II) modeset(G0): [DRI2] Setup complete
[ 117.599] (II) modeset(G0): [DRI2] DRI driver: iris
[ 117.599] (II) modeset(G0): [DRI2] VDPAU driver: va_gl
[ 117.599] (II) Initializing extension Generic Event Extension
[ 117.599] (II) Initializing extension SHAPE
[ 117.599] (II) Initializing extension MIT-SHM
[ 117.599] (II) Initializing extension XInputExtension
[ 117.599] (II) Initializing extension XTEST
[ 117.600] (II) Initializing extension BIG-REQUESTS
[ 117.600] (II) Initializing extension SYNC
[ 117.600] (II) Initializing extension XKEYBOARD
[ 117.600] (II) Initializing extension XC-MISC
[ 117.600] (II) Initializing extension SECURITY
[ 117.600] (II) Initializing extension XFIXES
[ 117.600] (II) Initializing extension RENDER
[ 117.600] (II) Initializing extension RANDR
[ 117.600] (II) Initializing extension COMPOSITE
[ 117.600] (II) Initializing extension DAMAGE
[ 117.600] (II) Initializing extension MIT-SCREEN-SAVER
[ 117.600] (II) Initializing extension DOUBLE-BUFFER
[ 117.600] (II) Initializing extension RECORD
[ 117.600] (II) Initializing extension DPMS
[ 117.600] (II) Initializing extension Present
[ 117.600] (II) Initializing extension DRI3
[ 117.600] (II) Initializing extension X-Resource
[ 117.600] (II) Initializing extension XVideo
[ 117.600] (II) Initializing extension XVideo-MotionCompensation
[ 117.600] (II) Initializing extension GLX
[ 117.600] (II) Indirect GLX disabled.
[ 117.601] (II) GLX: Another vendor is already registered for screen 0
[ 117.601] (II) Initializing extension XFree86-VidModeExtension
[ 117.601] (II) Initializing extension XFree86-DGA
[ 117.601] (II) Initializing extension XFree86-DRI
[ 117.601] (II) Initializing extension DRI2
[ 117.601] (II) Initializing extension NV-GLX
[ 117.601] (II) Initializing extension NV-CONTROL
[ 117.902] (II) modeset(G0): Damage tracking initialized
[ 117.945] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 117.945] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 117.945] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 117.945] (**) Power Button: Applying InputClass "system-keyboard"
[ 117.945] (II) LoadModule: "libinput"
[ 117.945] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 117.947] (II) Module libinput: vendor="X.Org Foundation"
[ 117.947] compiled for 1.20.8, module version = 0.30.0
[ 117.947] Module class: X.Org XInput Driver
[ 117.947] ABI class: X.Org XInput driver, version 24.1
[ 117.947] (II) Using input driver 'libinput' for 'Power Button'
[ 118.000] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 40 paused 0
[ 118.000] (**) Power Button: always reports core events
[ 118.000] (**) Option "Device" "/dev/input/event2"
[ 118.000] (**) Option "_source" "server/udev"
[ 118.003] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 118.003] (II) event2 - Power Button: device is a keyboard
[ 118.004] (II) event2 - Power Button: device removed
[ 118.004] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 118.004] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 118.004] (**) Option "xkb_layout" "us"
[ 118.005] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 118.005] (II) event2 - Power Button: device is a keyboard
[ 118.007] (II) config/udev: Adding input device Video Bus (/dev/input/event8)
[ 118.007] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 118.007] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 118.007] (**) Video Bus: Applying InputClass "system-keyboard"
[ 118.007] (II) Using input driver 'libinput' for 'Video Bus'
[ 118.042] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 43 paused 0
[ 118.042] (**) Video Bus: always reports core events
[ 118.042] (**) Option "Device" "/dev/input/event8"
[ 118.042] (**) Option "_source" "server/udev"
[ 118.046] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 118.046] (II) event8 - Video Bus: device is a keyboard
[ 118.046] (II) event8 - Video Bus: device removed
[ 118.046] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10/event8"
[ 118.046] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 118.046] (**) Option "xkb_layout" "us"
[ 118.050] (II) event8 - Video Bus: is tagged by udev as: Keyboard
[ 118.050] (II) event8 - Video Bus: device is a keyboard
[ 118.053] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[ 118.053] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 118.053] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 118.053] (**) Video Bus: Applying InputClass "system-keyboard"
[ 118.053] (II) Using input driver 'libinput' for 'Video Bus'
[ 118.122] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 44 paused 0
[ 118.122] (**) Video Bus: always reports core events
[ 118.122] (**) Option "Device" "/dev/input/event9"
[ 118.122] (**) Option "_source" "server/udev"
[ 118.127] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 118.128] (II) event9 - Video Bus: device is a keyboard
[ 118.128] (II) event9 - Video Bus: device removed
[ 118.128] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:3a/LNXVIDEO:01/input/input11/event9"
[ 118.128] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 118.129] (**) Option "xkb_layout" "us"
[ 118.133] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 118.133] (II) event9 - Video Bus: device is a keyboard
[ 118.135] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 118.135] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 118.135] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 118.135] (**) Power Button: Applying InputClass "system-keyboard"
[ 118.135] (II) Using input driver 'libinput' for 'Power Button'
[ 118.175] (II) systemd-logind: got fd for /dev/input/event1 13:65 fd 45 paused 0
[ 118.175] (**) Power Button: always reports core events
[ 118.175] (**) Option "Device" "/dev/input/event1"
[ 118.175] (**) Option "_source" "server/udev"
[ 118.178] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 118.179] (II) event1 - Power Button: device is a keyboard
[ 118.179] (II) event1 - Power Button: device removed
[ 118.179] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1/event1"
[ 118.179] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 118.179] (**) Option "xkb_layout" "us"
[ 118.183] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 118.183] (II) event1 - Power Button: device is a keyboard
[ 118.185] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 118.185] (II) No input driver specified, ignoring this device.
[ 118.185] (II) This device may have been added with another device file.
[ 118.188] (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event18)
[ 118.188] (**) Razer Razer DeathAdder Essential: Applying InputClass "evdev pointer catchall"
[ 118.188] (**) Razer Razer DeathAdder Essential: Applying InputClass "libinput pointer catchall"
[ 118.188] (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential'
[ 118.283] (II) systemd-logind: got fd for /dev/input/event18 13:82 fd 46 paused 0
[ 118.283] (**) Razer Razer DeathAdder Essential: always reports core events
[ 118.283] (**) Option "Device" "/dev/input/event18"
[ 118.283] (**) Option "_source" "server/udev"
[ 118.289] (II) event18 - Razer Razer DeathAdder Essential: is tagged by udev as: Mouse
[ 118.290] (II) event18 - Razer Razer DeathAdder Essential: device is a pointer
[ 118.291] (II) event18 - Razer Razer DeathAdder Essential: device removed
[ 118.291] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:1532:006E.0001/input/input19/event18"
[ 118.291] (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential" (type: MOUSE, id 10)
[ 118.291] (**) Option "AccelerationScheme" "none"
[ 118.291] (**) Razer Razer DeathAdder Essential: (accel) selected scheme none/0
[ 118.291] (**) Razer Razer DeathAdder Essential: (accel) acceleration factor: 2.000
[ 118.291] (**) Razer Razer DeathAdder Essential: (accel) acceleration threshold: 4
[ 118.294] (II) event18 - Razer Razer DeathAdder Essential: is tagged by udev as: Mouse
[ 118.295] (II) event18 - Razer Razer DeathAdder Essential: device is a pointer
[ 118.295] (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/mouse1)
[ 118.295] (II) No input driver specified, ignoring this device.
[ 118.295] (II) This device may have been added with another device file.
[ 118.296] (II) config/udev: Adding input device Razer Razer DeathAdder Essential Keyboard (/dev/input/event19)
[ 118.296] (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "evdev keyboard catchall"
[ 118.296] (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "libinput keyboard catchall"
[ 118.296] (**) Razer Razer DeathAdder Essential Keyboard: Applying InputClass "system-keyboard"
[ 118.296] (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential Keyboard'
[ 118.297] (II) systemd-logind: got fd for /dev/input/event19 13:83 fd 47 paused 0
[ 118.297] (**) Razer Razer DeathAdder Essential Keyboard: always reports core events
[ 118.297] (**) Option "Device" "/dev/input/event19"
[ 118.297] (**) Option "_source" "server/udev"
[ 118.299] (II) event19 - Razer Razer DeathAdder Essential Keyboard: is tagged by udev as: Keyboard
[ 118.299] (II) event19 - Razer Razer DeathAdder Essential Keyboard: device is a keyboard
[ 118.299] (II) event19 - Razer Razer DeathAdder Essential Keyboard: device removed
[ 118.299] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:1532:006E.0002/input/input20/event19"
[ 118.299] (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Keyboard" (type: KEYBOARD, id 11)
[ 118.299] (**) Option "xkb_layout" "us"
[ 118.301] (II) event19 - Razer Razer DeathAdder Essential Keyboard: is tagged by udev as: Keyboard
[ 118.301] (II) event19 - Razer Razer DeathAdder Essential Keyboard: device is a keyboard
[ 118.302] (II) config/udev: Adding input device Razer Razer DeathAdder Essential Consumer Control (/dev/input/event20)
[ 118.302] (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 118.302] (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 118.302] (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "system-keyboard"
[ 118.302] (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential Consumer Control'
[ 118.303] (II) systemd-logind: got fd for /dev/input/event20 13:84 fd 48 paused 0
[ 118.303] (**) Razer Razer DeathAdder Essential Consumer Control: always reports core events
[ 118.303] (**) Option "Device" "/dev/input/event20"
[ 118.303] (**) Option "_source" "server/udev"
[ 118.305] (II) event20 - Razer Razer DeathAdder Essential Consumer Control: is tagged by udev as: Keyboard
[ 118.305] (II) event20 - Razer Razer DeathAdder Essential Consumer Control: device is a keyboard
[ 118.305] (II) event20 - Razer Razer DeathAdder Essential Consumer Control: device removed
[ 118.305] (II) libinput: Razer Razer DeathAdder Essential Consumer Control: needs a virtual subdevice
[ 118.305] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:1532:006E.0002/input/input21/event20"
[ 118.305] (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Consumer Control" (type: MOUSE, id 12)
[ 118.305] (**) Option "AccelerationScheme" "none"
[ 118.305] (**) Razer Razer DeathAdder Essential Consumer Control: (accel) selected scheme none/0
[ 118.305] (**) Razer Razer DeathAdder Essential Consumer Control: (accel) acceleration factor: 2.000
[ 118.305] (**) Razer Razer DeathAdder Essential Consumer Control: (accel) acceleration threshold: 4
[ 118.307] (II) event20 - Razer Razer DeathAdder Essential Consumer Control: is tagged by udev as: Keyboard
[ 118.307] (II) event20 - Razer Razer DeathAdder Essential Consumer Control: device is a keyboard
[ 118.308] (II) config/udev: Adding input device Razer Razer DeathAdder Essential System Control (/dev/input/event21)
[ 118.308] (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "evdev keyboard catchall"
[ 118.308] (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "libinput keyboard catchall"
[ 118.308] (**) Razer Razer DeathAdder Essential System Control: Applying InputClass "system-keyboard"
[ 118.308] (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential System Control'
[ 118.309] (II) systemd-logind: got fd for /dev/input/event21 13:85 fd 49 paused 0
[ 118.309] (**) Razer Razer DeathAdder Essential System Control: always reports core events
[ 118.309] (**) Option "Device" "/dev/input/event21"
[ 118.309] (**) Option "_source" "server/udev"
[ 118.311] (II) event21 - Razer Razer DeathAdder Essential System Control: is tagged by udev as: Keyboard
[ 118.311] (II) event21 - Razer Razer DeathAdder Essential System Control: device is a keyboard
[ 118.311] (II) event21 - Razer Razer DeathAdder Essential System Control: device removed
[ 118.311] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:1532:006E.0002/input/input22/event21"
[ 118.311] (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential System Control" (type: KEYBOARD, id 13)
[ 118.311] (**) Option "xkb_layout" "us"
[ 118.313] (II) event21 - Razer Razer DeathAdder Essential System Control: is tagged by udev as: Keyboard
[ 118.313] (II) event21 - Razer Razer DeathAdder Essential System Control: device is a keyboard
[ 118.314] (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event22)
[ 118.314] (II) No input driver specified, ignoring this device.
[ 118.314] (II) This device may have been added with another device file.
[ 118.315] (II) config/udev: Adding input device Razer Razer DeathAdder Essential (/dev/input/event23)
[ 118.315] (**) Razer Razer DeathAdder Essential: Applying InputClass "evdev keyboard catchall"
[ 118.315] (**) Razer Razer DeathAdder Essential: Applying InputClass "libinput keyboard catchall"
[ 118.315] (**) Razer Razer DeathAdder Essential: Applying InputClass "system-keyboard"
[ 118.315] (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential'
[ 118.316] (II) systemd-logind: got fd for /dev/input/event23 13:87 fd 50 paused 0
[ 118.316] (**) Razer Razer DeathAdder Essential: always reports core events
[ 118.316] (**) Option "Device" "/dev/input/event23"
[ 118.316] (**) Option "_source" "server/udev"
[ 118.317] (II) event23 - Razer Razer DeathAdder Essential: is tagged by udev as: Keyboard
[ 118.318] (II) event23 - Razer Razer DeathAdder Essential: device is a keyboard
[ 118.318] (II) event23 - Razer Razer DeathAdder Essential: device removed
[ 118.318] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.2/0003:1532:006E.0003/input/input24/event23"
[ 118.318] (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential" (type: KEYBOARD, id 14)
[ 118.318] (**) Option "xkb_layout" "us"
[ 118.320] (II) event23 - Razer Razer DeathAdder Essential: is tagged by udev as: Keyboard
[ 118.320] (II) event23 - Razer Razer DeathAdder Essential: device is a keyboard
[ 118.321] (II) config/udev: Adding input device USB-HID Keyboard (/dev/input/event24)
[ 118.321] (**) USB-HID Keyboard: Applying InputClass "evdev keyboard catchall"
[ 118.321] (**) USB-HID Keyboard: Applying InputClass "libinput keyboard catchall"
[ 118.321] (**) USB-HID Keyboard: Applying InputClass "system-keyboard"
[ 118.321] (II) Using input driver 'libinput' for 'USB-HID Keyboard'
[ 118.321] (II) systemd-logind: got fd for /dev/input/event24 13:88 fd 51 paused 0
[ 118.321] (**) USB-HID Keyboard: always reports core events
[ 118.321] (**) Option "Device" "/dev/input/event24"
[ 118.321] (**) Option "_source" "server/udev"
[ 118.323] (II) event24 - USB-HID Keyboard: is tagged by udev as: Keyboard
[ 118.323] (II) event24 - USB-HID Keyboard: device is a keyboard
[ 118.323] (II) event24 - USB-HID Keyboard: device removed
[ 118.323] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:04D9:0192.0004/input/input25/event24"
[ 118.323] (II) XINPUT: Adding extended input device "USB-HID Keyboard" (type: KEYBOARD, id 15)
[ 118.323] (**) Option "xkb_layout" "us"
[ 118.325] (II) event24 - USB-HID Keyboard: is tagged by udev as: Keyboard
[ 118.325] (II) event24 - USB-HID Keyboard: device is a keyboard
[ 118.326] (II) config/udev: Adding input device USB-HID Keyboard System Control (/dev/input/event26)
[ 118.326] (**) USB-HID Keyboard System Control: Applying InputClass "evdev keyboard catchall"
[ 118.326] (**) USB-HID Keyboard System Control: Applying InputClass "libinput keyboard catchall"
[ 118.326] (**) USB-HID Keyboard System Control: Applying InputClass "system-keyboard"
[ 118.326] (II) Using input driver 'libinput' for 'USB-HID Keyboard System Control'
[ 118.326] (II) systemd-logind: got fd for /dev/input/event26 13:90 fd 52 paused 0
[ 118.326] (**) USB-HID Keyboard System Control: always reports core events
[ 118.326] (**) Option "Device" "/dev/input/event26"
[ 118.326] (**) Option "_source" "server/udev"
[ 118.328] (II) event26 - USB-HID Keyboard System Control: is tagged by udev as: Keyboard
[ 118.328] (II) event26 - USB-HID Keyboard System Control: device is a keyboard
[ 118.328] (II) event26 - USB-HID Keyboard System Control: device removed
[ 118.328] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2/1-1.2:1.2/0003:04D9:0192.0006/input/input27/event26"
[ 118.328] (II) XINPUT: Adding extended input device "USB-HID Keyboard System Control" (type: KEYBOARD, id 16)
[ 118.328] (**) Option "xkb_layout" "us"
[ 118.330] (II) event26 - USB-HID Keyboard System Control: is tagged by udev as: Keyboard
[ 118.330] (II) event26 - USB-HID Keyboard System Control: device is a keyboard
[ 118.331] (II) config/udev: Adding input device USB-HID Keyboard Consumer Control (/dev/input/event27)
[ 118.331] (**) USB-HID Keyboard Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 118.331] (**) USB-HID Keyboard Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 118.331] (**) USB-HID Keyboard Consumer Control: Applying InputClass "system-keyboard"
[ 118.331] (II) Using input driver 'libinput' for 'USB-HID Keyboard Consumer Control'
[ 118.331] (II) systemd-logind: got fd for /dev/input/event27 13:91 fd 53 paused 0
[ 118.331] (**) USB-HID Keyboard Consumer Control: always reports core events
[ 118.331] (**) Option "Device" "/dev/input/event27"
[ 118.331] (**) Option "_source" "server/udev"
[ 118.333] (II) event27 - USB-HID Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 118.333] (II) event27 - USB-HID Keyboard Consumer Control: device is a keyboard
[ 118.333] (II) event27 - USB-HID Keyboard Consumer Control: device removed
[ 118.333] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2/1-1.2:1.2/0003:04D9:0192.0006/input/input28/event27"
[ 118.333] (II) XINPUT: Adding extended input device "USB-HID Keyboard Consumer Control" (type: KEYBOARD, id 17)
[ 118.333] (**) Option "xkb_layout" "us"
[ 118.334] (II) event27 - USB-HID Keyboard Consumer Control: is tagged by udev as: Keyboard
[ 118.334] (II) event27 - USB-HID Keyboard Consumer Control: device is a keyboard
[ 118.335] (II) config/udev: Adding input device USB-HID Keyboard (/dev/input/event28)
[ 118.335] (**) USB-HID Keyboard: Applying InputClass "evdev keyboard catchall"
[ 118.335] (**) USB-HID Keyboard: Applying InputClass "libinput keyboard catchall"
[ 118.335] (**) USB-HID Keyboard: Applying InputClass "system-keyboard"
[ 118.335] (II) Using input driver 'libinput' for 'USB-HID Keyboard'
[ 118.336] (II) systemd-logind: got fd for /dev/input/event28 13:92 fd 54 paused 0
[ 118.336] (**) USB-HID Keyboard: always reports core events
[ 118.336] (**) Option "Device" "/dev/input/event28"
[ 118.336] (**) Option "_source" "server/udev"
[ 118.337] (II) event28 - USB-HID Keyboard: is tagged by udev as: Keyboard
[ 118.337] (II) event28 - USB-HID Keyboard: device is a keyboard
[ 118.338] (II) event28 - USB-HID Keyboard: device removed
[ 118.338] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.2/1-1.2:1.2/0003:04D9:0192.0006/input/input29/event28"
[ 118.338] (II) XINPUT: Adding extended input device "USB-HID Keyboard" (type: KEYBOARD, id 18)
[ 118.338] (**) Option "xkb_layout" "us"
[ 118.339] (II) event28 - USB-HID Keyboard: is tagged by udev as: Keyboard
[ 118.339] (II) event28 - USB-HID Keyboard: device is a keyboard
[ 118.340] (II) config/udev: Adding input device HP Wide Vision HD Camera: HP Wi (/dev/input/event25)
[ 118.340] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "evdev keyboard catchall"
[ 118.340] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "libinput keyboard catchall"
[ 118.340] (**) HP Wide Vision HD Camera: HP Wi: Applying InputClass "system-keyboard"
[ 118.340] (II) Using input driver 'libinput' for 'HP Wide Vision HD Camera: HP Wi'
[ 118.340] (II) systemd-logind: got fd for /dev/input/event25 13:89 fd 55 paused 0
[ 118.340] (**) HP Wide Vision HD Camera: HP Wi: always reports core events
[ 118.340] (**) Option "Device" "/dev/input/event25"
[ 118.340] (**) Option "_source" "server/udev"
[ 118.342] (II) event25 - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[ 118.342] (II) event25 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[ 118.342] (II) event25 - HP Wide Vision HD Camera: HP Wi: device removed
[ 118.342] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input26/event25"
[ 118.342] (II) XINPUT: Adding extended input device "HP Wide Vision HD Camera: HP Wi" (type: KEYBOARD, id 19)
[ 118.342] (**) Option "xkb_layout" "us"
[ 118.343] (II) event25 - HP Wide Vision HD Camera: HP Wi: is tagged by udev as: Keyboard
[ 118.343] (II) event25 - HP Wide Vision HD Camera: HP Wi: device is a keyboard
[ 118.343] (II) config/udev: Adding input device eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00 (/dev/input/event29)
[ 118.343] (**) eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: Applying InputClass "evdev touchscreen catchall"
[ 118.343] (**) eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: Applying InputClass "libinput touchscreen catchall"
[ 118.343] (II) Using input driver 'libinput' for 'eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00'
[ 118.399] (II) systemd-logind: got fd for /dev/input/event29 13:93 fd 56 paused 0
[ 118.399] (**) eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: always reports core events
[ 118.399] (**) Option "Device" "/dev/input/event29"
[ 118.399] (**) Option "_source" "server/udev"
[ 118.402] (II) event29 - eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: is tagged by udev as: Touchscreen
[ 118.402] (II) event29 - eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: device is a touch device
[ 118.403] (II) event29 - eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: device removed
[ 118.403] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/0003:0EEF:C0AE.0007/input/input32/event29"
[ 118.403] (II) XINPUT: Adding extended input device "eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00" (type: TOUCHSCREEN, id 20)
[ 118.403] (**) Option "AccelerationScheme" "none"
[ 118.403] (**) eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: (accel) selected scheme none/0
[ 118.403] (**) eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: (accel) acceleration factor: 2.000
[ 118.403] (**) eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: (accel) acceleration threshold: 4
[ 118.406] (II) event29 - eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: is tagged by udev as: Touchscreen
[ 118.406] (II) event29 - eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00: device is a touch device
[ 118.408] (II) config/udev: Adding input device eGalax Inc. eGalaxTouch EXC3200-2505-09.00.00 (/dev/input/mouse2)
[ 118.408] (II) No input driver specified, ignoring this device.
[ 118.408] (II) This device may have been added with another device file.
[ 118.409] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event11)
[ 118.409] (II) No input driver specified, ignoring this device.
[ 118.409] (II) This device may have been added with another device file.
[ 118.409] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event12)
[ 118.410] (II) No input driver specified, ignoring this device.
[ 118.410] (II) This device may have been added with another device file.
[ 118.410] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event13)
[ 118.411] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event14)
[ 118.411] (II) No input driver specified, ignoring this device.
[ 118.411] (II) This device may have been added with another device file.
[ 118.412] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event15)
[ 118.412] (II) No input driver specified, ignoring this device.
[ 118.412] (II) This device may have been added with another device file.
[ 118.412] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event16)
[ 118.413] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event17)
[ 118.413] (II) No input driver specified, ignoring this device.
[ 118.413] (II) This device may have been added with another device file.
[ 118.414] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 118.414] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 118.414] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 118.414] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 118.414] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 118.415] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 57 paused 0
[ 118.416] (**) AT Translated Set 2 keyboard: always reports core events
[ 118.416] (**) Option "Device" "/dev/input/event3"
[ 118.416] (**) Option "_source" "server/udev"
[ 118.418] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 118.418] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 118.420] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 118.420] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 118.420] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 21)
[ 118.420] (**) Option "xkb_layout" "us"
[ 118.423] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 118.423] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 118.426] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event10)
[ 118.426] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[ 118.426] (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
[ 118.426] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[ 118.427] (II) systemd-logind: got fd for /dev/input/event10 13:74 fd 58 paused 0
[ 118.428] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 118.428] (**) Option "Device" "/dev/input/event10"
[ 118.428] (**) Option "_source" "server/udev"
[ 118.430] (II) event10 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 118.432] (II) event10 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 118.432] (II) event10 - ETPS/2 Elantech Touchpad: device removed
[ 118.433] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input8/event10"
[ 118.433] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 22)
[ 118.434] (**) Option "AccelerationScheme" "none"
[ 118.434] (**) ETPS/2 Elantech Touchpad: (accel) selected scheme none/0
[ 118.434] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[ 118.434] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[ 118.436] (II) event10 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 118.438] (II) event10 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 118.439] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse0)
[ 118.439] (II) No input driver specified, ignoring this device.
[ 118.439] (II) This device may have been added with another device file.
[ 118.439] (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/event5)
[ 118.440] (II) config/udev: Adding input device ST LIS3LV02DL Accelerometer (/dev/input/js0)
[ 118.440] (II) No input driver specified, ignoring this device.
[ 118.440] (II) This device may have been added with another device file.
[ 118.440] (II) config/udev: Adding input device PC Speaker (/dev/input/event6)
[ 118.441] (II) config/udev: Adding input device HP Wireless hotkeys (/dev/input/event4)
[ 118.441] (**) HP Wireless hotkeys: Applying InputClass "evdev keyboard catchall"
[ 118.441] (**) HP Wireless hotkeys: Applying InputClass "libinput keyboard catchall"
[ 118.441] (**) HP Wireless hotkeys: Applying InputClass "system-keyboard"
[ 118.441] (II) Using input driver 'libinput' for 'HP Wireless hotkeys'
[ 118.442] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 59 paused 0
[ 118.442] (**) HP Wireless hotkeys: always reports core events
[ 118.442] (**) Option "Device" "/dev/input/event4"
[ 118.442] (**) Option "_source" "server/udev"
[ 118.442] (II) event4 - HP Wireless hotkeys: is tagged by udev as: Keyboard
[ 118.442] (II) event4 - HP Wireless hotkeys: device is a keyboard
[ 118.443] (II) event4 - HP Wireless hotkeys: device removed
[ 118.443] (**) Option "config_info" "udev:/sys/devices/virtual/input/input5/event4"
[ 118.443] (II) XINPUT: Adding extended input device "HP Wireless hotkeys" (type: KEYBOARD, id 23)
[ 118.443] (**) Option "xkb_layout" "us"
[ 118.444] (II) event4 - HP Wireless hotkeys: is tagged by udev as: Keyboard
[ 118.444] (II) event4 - HP Wireless hotkeys: device is a keyboard
[ 118.444] (II) config/udev: Adding input device HP WMI hotkeys (/dev/input/event7)
[ 118.444] (**) HP WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 118.444] (**) HP WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 118.444] (**) HP WMI hotkeys: Applying InputClass "system-keyboard"
[ 118.444] (II) Using input driver 'libinput' for 'HP WMI hotkeys'
[ 118.445] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 60 paused 0
[ 118.445] (**) HP WMI hotkeys: always reports core events
[ 118.445] (**) Option "Device" "/dev/input/event7"
[ 118.445] (**) Option "_source" "server/udev"
[ 118.446] (II) event7 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 118.446] (II) event7 - HP WMI hotkeys: device is a keyboard
[ 118.446] (II) event7 - HP WMI hotkeys: device removed
[ 118.446] (**) Option "config_info" "udev:/sys/devices/virtual/input/input9/event7"
[ 118.446] (II) XINPUT: Adding extended input device "HP WMI hotkeys" (type: KEYBOARD, id 24)
[ 118.446] (**) Option "xkb_layout" "us"
[ 118.447] (II) event7 - HP WMI hotkeys: is tagged by udev as: Keyboard Switch
[ 118.447] (II) event7 - HP WMI hotkeys: device is a keyboard
[ 118.451] (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "evdev keyboard catchall"
[ 118.451] (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "libinput keyboard catchall"
[ 118.451] (**) Razer Razer DeathAdder Essential Consumer Control: Applying InputClass "system-keyboard"
[ 118.451] (II) Using input driver 'libinput' for 'Razer Razer DeathAdder Essential Consumer Control'
[ 118.451] (II) systemd-logind: returning pre-existing fd for /dev/input/event20 13:84
[ 118.451] (**) Razer Razer DeathAdder Essential Consumer Control: always reports core events
[ 118.451] (**) Option "Device" "/dev/input/event20"
[ 118.451] (**) Option "_source" "_driver/libinput"
[ 118.451] (II) libinput: Razer Razer DeathAdder Essential Consumer Control: is a virtual subdevice
[ 118.451] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:1532:006E.0002/input/input21/event20"
[ 118.451] (II) XINPUT: Adding extended input device "Razer Razer DeathAdder Essential Consumer Control" (type: KEYBOARD, id 25)
[ 118.451] (**) Option "xkb_layout" "us"
[ 119.108] randr: falling back to unsynchronized pixmap sharing
[ 119.462] randr: falling back to unsynchronized pixmap sharing
[ 121.567] (EE) event18 - Razer Razer DeathAdder Essential: client bug: event processing lagging behind by 16ms, your system is too slow
[ 124.867] (EE) event18 - Razer Razer DeathAdder Essential: client bug: event processing lagging behind by 12ms, your system is too slow
[ 160.999] (EE) event18 - Razer Razer DeathAdder Essential: client bug: event processing lagging behind by 12ms, your system is too slow
[ 1196.259] (EE) event18 - Razer Razer DeathAdder Essential: client bug: event processing lagging behind by 14ms, your system is too slow
