Good morning.
I experience strange behaviour of my Asus MB196C+ external Display connected to a Huawei Matebook 16".
First it simply didn’t work at all, just white blinking monitor led, not displaying anything. I went on to do other work leaving it connected. After several hours it suddenly switched on and worked like nothing had happened for hours. When i disconnected the monitor, shut down the laptop and reconnected the next morning, again nothing. After several hours it switched on, showed the Asus logo and then went to standby (orange led). I left it that way for some time, then disconnected it and reconnected again - white blinking led, nothing on the display until now.
The monitor is connected via USB-C alternate DP using the cable that shipped with the display.
My laptop definitely supports alternate mode and the display works fine on other machines (as mentioned, it occasionally worked on my machine)
I run the latest KDE.
Any help is appreciated, thank you in advance!
inxi -v7azi
Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=478720c4-949e-4824-8800-3f6a3f1a8be0 rw quiet
cryptdevice=UUID=a81334b8-edc5-440f-b459-9bfd1f28edb9:luks-a81334b8-edc5-440f-b459-9bfd1f28edb9
root=/dev/mapper/luks-a81334b8-edc5-440f-b459-9bfd1f28edb9 apparmor=1
security=apparmor
resume=/dev/mapper/luks-5db6c13b-82b3-4ee2-8736-978a907abf66
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HUAWEI product: CREM-WXX9 v: M1010
serial: <superuser required>
Mobo: HUAWEI model: CREM-WXX9-PCB-B1 v: M1010
serial: <superuser required> UEFI: HUAWEI v: 2.16 date: 09/13/2021
ID-1: BATT charge: 76.9 Wh (90.0%) condition: 85.4/83.1 Wh (102.7%)
volts: 12.7 min: 11.5 model: DYNAPACK HB9790T7ECW-32T0 type: Li-ion
serial: <filter> status: N/A cycles: 9
RAM: total: 14.99 GiB used: 7.37 GiB (49.1%)
RAM Report:
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1862 high: 2626 min/max: 1200/4462 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1768 2: 1984
3: 1976 4: 1795 5: 1603 6: 2626 7: 1692 8: 1984 9: 1855 10: 1684 11: 1830
12: 1781 13: 2189 14: 1817 15: 1710 16: 1506 bogomips: 102254
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling
Device-1: AMD Cezanne driver: amdgpu v: kernel arch: GCN 5.1
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:1638
class-ID: 0300
Device-2: ShineTech HD Camera type: USB driver: uvcvideo bus-ID: 1-3:4
chip-ID: 3277:0003 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 2520x1680 s-dpi: 96 s-size: 666x444mm (26.22x17.48")
s-diag: 800mm (31.51")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x092f serial: <filter>
built: 2021 res: 2520x1680 hz: 60 dpi: 189 gamma: 1.2
size: 338x226mm (13.31x8.9") diag: 407mm (16") ratio: 3:2 modes:
max: 2520x1680 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.42 5.15.49-1-MANJARO)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_rn_pci_acp3x
v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: br-82c8e4672336 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: br-9e86c34553a7 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1 all]
IF-ID-3: docker0 state: down mac: <filter>
IF-ID-4: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Message: Output throttled. IPs: 3; Limit: 10; Override: --limit [1-x;-1 all]
IF-ID-5: veth04d1e7b state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: veth4f71ce2 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-7: veth7908114 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-8: vethae83d3c state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-9: vethb3f27b6 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-10: vethc35d2f1 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-11: vethd10019d state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-12: vethd87d8bc state: up speed: 10000 Mbps duplex: full
mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4:5 chip-ID: 8087:0029 class-ID: e001
Device-1: luks-a81334b8-edc5-440f-b459-9bfd1f28edb9 maj-min: 254:0
type: LUKS dm: dm-0 size: 460.15 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 460.15 GiB
Device-2: luks-5db6c13b-82b3-4ee2-8736-978a907abf66 maj-min: 254:1
type: LUKS dm: dm-1 size: 16.48 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 16.49 GiB
Local Storage: total: 476.94 GiB used: 93.23 GiB (19.5%)
model: PC SN730 SDBPNTY-512G size: 476.94 GiB block-size: physical: 512 B
rev: 11120000 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 460.15 GiB size: 451.86 GiB (98.20%)
used: 93.23 GiB (20.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-a81334b8-edc5-440f-b459-9bfd1f28edb9 label: N/A
uuid: 478720c4-949e-4824-8800-3f6a3f1a8be0
used: 472 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 2BB3-13EE
ID-1: swap-1 type: partition size: 16.48 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-5db6c13b-82b3-4ee2-8736-978a907abf66 label: swap
uuid: 84bbf105-051e-4106-ad75-91822030bd0c
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:4 info: ShineTech HD Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 3277:0003
Device-2: 1-4:5 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Shenzhen Goodix Fingerprint Device
type: Communication,CDC-Data driver: N/A interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 27c6:5125 class-ID: 0a00
serial: <filter>
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 35.0 C
Processes: 499 Uptime: 1h 38m wakeups: 6310 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: 1384 pacman: 1373 lib: 350 flatpak: 4 snap: 7 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.19
en Code hier ein
mhwd -l && mhwd -li
0000:03:00.0 (0300:1002:1638) Display controller ATI Technologies Inc:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> Installed PCI configs:
