Recently formatted a 128 GB Kexin USB to be multiboot via Ventoy, in the middle of a copy thunar closed and the USB has been unmountable/recognizable by any OS.
It refuses to show up in GParted, in disk manager (On windows).
It shows up in LSBLK for about 60 seconds then disappears as if it was kicked out or ejected by the host.
Kernel: 5.10.70-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=8ba57404-e263-4322-9676-1e9b8d434d03 rw intel_iommu=on iommu=pt
pcie_aspm.policy=performance rd.driver.pre=vfio_pci vfio-pci.ids=
video=vesafb:off,efifb:off quiet apparmor=1 security=apparmor
resume=UUID=862427bd-c72a-4e7e-afcf-7c33291eb2ce udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
Type: Desktop Mobo: Gigabyte model: Z590 AORUS ELITE AX v: x.x
serial: <filter> UEFI: American Megatrends LLC. v: F3 date: 01/20/2021
RAM: total: 31.15 GiB used: 3.31 GiB (10.6%)
Info: 6-Core model: 11th Gen Intel Core i5-11600K bits: 64 type: MT MCP
arch: Rocket Lake family: 6 model-id: A7 (167) stepping: 1 microcode: 40
cache: L2: 12 MiB bogomips: 93924
Speed: 800 MHz min/max: 800/4900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good sdbg
sep sha_ni smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes
vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Device-1: Intel RocketLake-S GT1 [UHD Graphics 750] vendor: Gigabyte
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:4c8a class-ID: 0300
Device-2: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:67df
class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 5760x1080 s-dpi: 96 s-size: 1524x286mm (60.0x11.3")
s-diag: 1551mm (61")
Monitor-1: HDMI-2 res: 1920x1080 hz: 60 dpi: 102
size: 476x268mm (18.7x10.6") diag: 546mm (21.5")
Monitor-2: DP-1-3 res: 1920x1080 hz: 60 dpi: 103
size: 475x267mm (18.7x10.5") diag: 545mm (21.5")
Monitor-3: HDMI-1-1 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
OpenGL: renderer: Mesa Intel Graphics (RKL GT1) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:43c8
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: no
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
port: 5000 bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8125 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
bus-ID: 1-14:10 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Device-1: luks-bf411ced-f63f-4984-87c4-e2d70482f671 maj-min: 254:0
type: LUKS dm: dm-0 size: 1.82 TiB
Components:
p-1: sda1 maj-min: 8:1 size: 1.82 TiB
Hardware-1: Intel Device driver: ahci v: 3.0 port: 5060 bus-ID: 00:17.0
chip-ID: 8086.43d6 rev: 11 class-ID: 0104
Local Storage: total: 5.46 TiB used: 407.01 GiB (7.3%)
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 613000WD temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST31000524AS
type: HDD rpm: 7200 serial: <filter> rev: JC4A scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD2002FYPS-01U1B0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 5G05 scheme: MBR
ID-1: / raw-size: 899.22 GiB size: 884.03 GiB (98.31%)
used: 28.78 GiB (3.3%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 8ba57404-e263-4322-9676-1e9b8d434d03
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 6E8B-578F
ID-3: /home raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 378.23 GiB (20.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-bf411ced-f63f-4984-87c4-e2d70482f671 label: N/A
uuid: 20cd3e50-e7b9-46e9-a8dd-e341c97f7d1f
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 862427bd-c72a-4e7e-afcf-7c33291eb2ce
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Hub-2: 1-11:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-11.1:4 info: Razer USA RZ01-0321 Gaming Mouse [DeathAdder V2]
type: Mouse,Keyboard driver: razermouse,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 1532:0084 class-ID: 0300
Device-2: 1-11.2:6 info: Logitech USB Receiver type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 046d:c541 class-ID: 0300
Hub-3: 1-11.3:8 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-4: 1-12:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-13:9 info: Integrated Express Љ type: N/A driver: N/A rev: 2.0
speed: 12 Mb/s chip-ID: 048d:5702 class-ID: 0000
Device-2: 1-14:10 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 9 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 16.8 C mobo: 16.8 C gpu: amdgpu temp: 42.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 802
Processes: 360 Uptime: 1h 4m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1222 pacman: 1217 lib: 337 flatpak: 0
snap: 5 Shell: Bash v: 5.1.8 running-in: xfce4-terminal inxi: 3.3.06
lspci -nnk
00:00.0 Host bridge [0600]: Intel Corporation Device [8086:4c53] (rev 01)
DeviceName: Onboard - Other
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5000]
00:01.0 PCI bridge [0604]: Intel Corporation Device [8086:4c01] (rev 01)
Kernel driver in use: pcieport
00:02.0 VGA compatible controller [0300]: Intel Corporation RocketLake-S GT1 [UHD Graphics 750] [8086:4c8a] (rev 04)
DeviceName: Onboard - Video
Subsystem: Gigabyte Technology Co., Ltd Device [1458:d000]
Kernel driver in use: i915
Kernel modules: i915
00:06.0 PCI bridge [0604]: Intel Corporation Device [8086:4c09] (rev 01)
00:14.0 USB controller [0c03]: Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller [8086:43ed] (rev 11)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5007]
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 RAM memory [0500]: Intel Corporation Tiger Lake-H Shared SRAM [8086:43ef] (rev 11)
00:14.3 Network controller [0280]: Intel Corporation Tiger Lake PCH CNVi WiFi [8086:43f0] (rev 11)
DeviceName: Onboard - Ethernet
Subsystem: Intel Corporation Wi-Fi 6 AX201 160MHz [8086:0074]
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00:16.0 Communication controller [0780]: Intel Corporation Tiger Lake-H Management Engine Interface [8086:43e0] (rev 11)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:1c3a]
Kernel driver in use: mei_me
Kernel modules: mei_me
00:17.0 RAID bus controller [0104]: Intel Corporation Device [8086:43d6] (rev 11)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:b005]
Kernel driver in use: ahci
00:1b.0 PCI bridge [0604]: Intel Corporation Device [8086:43c0] (rev 11)
00:1b.2 PCI bridge [0604]: Intel Corporation Device [8086:43c2] (rev 11)
00:1b.4 PCI bridge [0604]: Intel Corporation Device [8086:43c4] (rev 11)
00:1c.0 PCI bridge [0604]: Intel Corporation Device [8086:43b8] (rev 11)
00:1c.4 PCI bridge [0604]: Intel Corporation Tiger Lake-H PCI Express Root Port #5 [8086:43bc] (rev 11)
00:1d.0 PCI bridge [0604]: Intel Corporation Tiger Lake-H PCI Express Root Port #9 [8086:43b0] (rev 11)
00:1d.4 PCI bridge [0604]: Intel Corporation Device [8086:43b4] (rev 11)
00:1f.0 ISA bridge [0601]: Intel Corporation Device [8086:4385] (rev 11)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:5001]
00:1f.3 Audio device [0403]: Intel Corporation Tiger Lake-H HD Audio Controller [8086:43c8] (rev 11)
DeviceName: Onboard - Sound
Subsystem: Gigabyte Technology Co., Ltd Device [1458:a0c3]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_sof_pci
00:1f.4 SMBus [0c05]: Intel Corporation Tiger Lake-H SMBus Controller [8086:43a3] (rev 11)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation Tiger Lake-H SPI Controller [8086:43a4] (rev 11)
Kernel driver in use: intel-spi
Kernel modules: intel_spi_pci
01:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere [Radeon RX 470/480/570/570X/580/580X/590] [1002:67df] (rev e7)
Subsystem: XFX Pine Group Inc. Radeon RX 580 [1682:c580]
Kernel driver in use: amdgpu
Kernel modules: amdgpu
01:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590] [1002:aaf0]
Subsystem: XFX Pine Group Inc. Device [1682:aaf0]
02:00.0 Non-Volatile memory controller [0108]: Sandisk Corp WD Black SN850 [15b7:5011] (rev 01)
Subsystem: Sandisk Corp WD Black SN850 [15b7:5011]
Kernel driver in use: nvme
04:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8125 2.5GbE Controller [10ec:8125] (rev 05)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:e000]
Kernel driver in use: r8169
Kernel modules: r8169
lsblk -o model,name,size,fstype,label,mountpoint
MODEL NAME SIZE FSTYPE LABEL MOUNTPOINT
loop0 55.4M squashfs /var/lib/snapd/snap/core18/2074
loop1 55.4M squashfs /var/lib/snapd/snap/core18/2128
loop2 61.8M squashfs /var/lib/snapd/snap/core20/1169
loop3 32.3M squashfs /var/lib/snapd/snap/snapd/12883
loop4 32.3M squashfs /var/lib/snapd/snap/snapd/13170
loop5 4K squashfs /var/lib/snapd/snap/bare/5
loop6 61.8M squashfs /var/lib/snapd/snap/core20/1081
ST2000DM008-2FR102 sda 1.8T
└─sda1 1.8T crypto_LUKS
└─luks-bf411ced-f63f-4984-87c4-e2d70482f671 1.8T ext4 /run/timeshift/backup
ST31000524AS sdb 931.5G
WDC WD2002FYPS-01U1B0 sdc 1.8T
USB Flash Disk sdd 116.1G
WDS100T1X0E-00AFY0 nvme0n1 931.5G
├─nvme0n1p1 300M vfat NO_LABEL /boot/efi
├─nvme0n1p2 32G swap [SWAP]
└─nvme0n1p3 899.2G ext4 /
EDIT: tried wiping the device in terminal with
sudo dd if=/dev/zero of=/dev/sdd bs=1k count=2048
It now shows up as a 2MB device in GParted.
EDIT: Its probably too late for me to be working on this because I just realized that the previous command would just create the file in /dev, which is what happened.
this is also why GParted could see it.
