TheG
May 8, 2021, 5:56am
1
Hi guys,
New to manjaro and am enjoying it.
Right now im trying to get my bose speaker connected via usb to output audio but according to aslamixer it’s being interpreted as a sound card and no audio is being outputed
I’ve tried to edit the default.pa and client.conf in /etc/pulse but no luck.
Any ideas
Thanks
Welcome to Manjaro forum
Please post more information about system hardware
inxi -Fazy --no-host
and more information about PulseAudio
pacmd dump
Please use the preformatted text button </> when pasting the terminal responses
TheG
May 8, 2021, 10:22am
3
Hi Mate
Sure,
Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=d2f1e0d7-41e3-4e38-bce5-dbbac2caf899 rw quiet udev.log_priority=3
Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Desktop System: Micro-Star product: MS-7B98 v: 1.0 serial: <filter>
Mobo: Micro-Star model: Z390-A PRO (MS-7B98) v: 1.0 serial: <filter>
UEFI-[Legacy]: American Megatrends v: 1.70 date: 08/13/2019
RAM: total: 15.57 GiB used: 2.98 GiB (19.2%)
Info: 6-Core model: Intel Core i5-9600KF bits: 64 type: MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: D (13) microcode: DE
cache: L2: 9 MiB bogomips: 44412
Speed: 800 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: eVga.com.
driver: nvidia v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1f06 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
OpenGL: renderer: GeForce RTX 2060 SUPER/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-3: Bose Bose Revolve SoundLink type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:7 chip-ID: 05a7:40fa
class-ID: 0300 serial: <filter>
Device-4: SYDNEY USB SYDNEY USB type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:4 chip-ID: 3212:1a01
Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
Device-2: Broadcom vendor: ASUSTeK driver: brcmfmac v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 14e4:43c3 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
Local Storage: total: 232.89 GiB used: 14.28 GiB (6.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 3B6Q scheme: MBR
ID-1: / raw-size: 232.88 GiB size: 228.17 GiB (97.98%)
used: 14.28 GiB (6.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: d2f1e0d7-41e3-4e38-bce5-dbbac2caf899
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-2:2 info: Microsoft Basic Optical Mouse v2.0 type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 045e:00cb class-ID: 0301
Device-2: 1-3:7 info: Bose Bose Revolve SoundLink type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 05a7:40fa class-ID: 0300
serial: <filter>
Device-3: 1-5:4 info: SYDNEY USB SYDNEY USB type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 3212:1a01 class-ID: 0300
serial: <filter>
Device-4: 1-6:5 info: Holtek USB-HID Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:0295 class-ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.1
speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 32.0 C mobo: N/A gpu: nvidia temp: 34 C
Processes: 227 Uptime: 1h 27m wakeups: 1 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1228 lib: 316
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.04
╭─-ms7b98 ~
╰─➤ pacmd dump
### Configuration dump generated at Sat May 8 20:20:58 2021
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="3" name="usb-SYDNEY_USB_SYDNEY_USB_20200521-00" card_name="alsa_card.usb-SYDNEY_USB_SYDNEY_USB_20200521-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-alsa-card device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-x11-publish display=:0 xauthority=/home/adrian/.Xauthority
load-module module-x11-xsmp display=:0 xauthority=/home/adrian/.Xauthority session_manager=local/adrian-ms7b98:@/tmp/.ICE-unix/1018,unix/adrian-ms7b98:/tmp/.ICE-unix/1018
load-module module-alsa-card device_id="2" name="usb-Bose_Corporation_Bose_Revolve_SoundLink_Q9218012609742956KD0510-00" card_name="alsa_card.usb-Bose_Corporation_Bose_Revolve_SoundLink_Q9218012609742956KD0510-00" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_1f.3.analog-stereo 0x8ccd
set-sink-mute alsa_output.pci-0000_00_1f.3.analog-stereo no
suspend-sink alsa_output.pci-0000_00_1f.3.analog-stereo yes
set-sink-volume alsa_output.usb-Bose_Corporation_Bose_Revolve_SoundLink_Q9218012609742956KD0510-00.iec958-stereo 0x70a4
set-sink-mute alsa_output.usb-Bose_Corporation_Bose_Revolve_SoundLink_Q9218012609742956KD0510-00.iec958-stereo no
suspend-sink alsa_output.usb-Bose_Corporation_Bose_Revolve_SoundLink_Q9218012609742956KD0510-00.iec958-stereo yes
set-source-volume alsa_input.usb-SYDNEY_USB_SYDNEY_USB_20200521-00.mono-fallback 0x10000
set-source-mute alsa_input.usb-SYDNEY_USB_SYDNEY_USB_20200521-00.mono-fallback no
suspend-source alsa_input.usb-SYDNEY_USB_SYDNEY_USB_20200521-00.mono-fallback yes
set-source-volume alsa_output.pci-0000_00_1f.3.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1f.3.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1f.3.analog-stereo.monitor yes
set-source-volume alsa_output.usb-Bose_Corporation_Bose_Revolve_SoundLink_Q9218012609742956KD0510-00.iec958-stereo.monitor 0x10000
set-source-mute alsa_output.usb-Bose_Corporation_Bose_Revolve_SoundLink_Q9218012609742956KD0510-00.iec958-stereo.monitor no
suspend-source alsa_output.usb-Bose_Corporation_Bose_Revolve_SoundLink_Q9218012609742956KD0510-00.iec958-stereo.monitor yes
set-card-profile alsa_card.pci-0000_01_00.1 off
set-card-profile alsa_card.usb-SYDNEY_USB_SYDNEY_USB_20200521-00 input:mono-fallback
set-card-profile alsa_card.pci-0000_00_1f.3 output:analog-stereo
set-card-profile alsa_card.usb-Bose_Corporation_Bose_Revolve_SoundLink_Q9218012609742956KD0510-00 output:iec958-stereo
set-default-sink alsa_output.pci-0000_00_1f.3.analog-stereo
set-default-source alsa_input.usb-SYDNEY_USB_SYDNEY_USB_20200521-00.mono-fallback
### EOF
Yes, of course. All USB speakers (and microphones) work that way. What you have to learn is how audio routing works in KDE Plasma (which basically just a PulseAudio wrapper).
I don’t think this option below is set by default:
which is used to behave like some other OSes out there, explanation should be straightforward. Check that if you want that behavior.
Otherwise, go to previous page:
and select which device you want to use for audio output.
Also available from the volume control widget (just click it):
TheG
May 8, 2021, 11:44pm
5
Hi Mate,
I’ve tried to tinker with the configuration settings as you’ve stated but still no sound
I’ve selected “play all audio through this device” and have also toggled between iec985 -stereo-output and analog in the pavu config. Not sure if its a bose soundlink specific issue.
Try checking in alsamixer, sometimes the volume at pulseaudio level doesn’t correctly reflect the actual one in the hardware. Also try playing something and check the output device tab in pavucontrol, even if you can’t hear anything, does the monitor bar shows a signal change?
TheG
May 10, 2021, 6:25am
7
Alright, I removed manjaro-pulse and ran sudo pacman -Rdd pavucontrol pulseaudio pulseaudio-alsa
Then installed pipewire and increased DB in alsamixer to 100 and everything is working LOL
system
Closed
May 25, 2021, 6:25am
8
