Hello everybody!
I’m having some troubles with an USB Bluetooth adapter that I bought this days.
My system can recognize the device, when I type lsusb
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
Bus 001 Device 002: ID 046d:c534 Logitech, Inc. Unifying Receiver
and the bluetooth service is activated, as you can see when I type sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor>
Active: active (running) since Sat 2021-09-18 12:13:59 -03; 21min ago
Docs: man:bluetoothd(8)
Main PID: 2475 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 7014)
Memory: 760.0K
CPU: 30ms
CGroup: /system.slice/bluetooth.service
└─2475 /usr/lib/bluetooth/bluetoothd
set 18 12:13:59 personal systemd[1]: Starting Bluetooth service...
set 18 12:13:59 personal bluetoothd[2475]: Bluetooth daemon 5.61
set 18 12:13:59 personal systemd[1]: Started Bluetooth service.
set 18 12:13:59 personal bluetoothd[2475]: Starting SDP server
set 18 12:13:59 personal bluetoothd[2475]: Bluetooth management interface 1.20 >
But when I try to start bluetooth toggling the button on gnome settings, not happens.
I also tried to run it in terminal, using bluetoothctl power on
and I received:
No default controller available
My system information:
Kernel: 5.13.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=18517985-3763-4583-ae1c-6622ed0bf2fa rw quiet splash apparmor=1
Desktop: GNOME 40.4 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.1
Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K/BR v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 5407 date: 12/31/2019
RAM: total: 5.72 GiB used: 1.82 GiB (31.7%)
Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24) stepping: 1
microcode: 8108109 cache: L2: 2 MiB bogomips: 59109
Speed: 1258 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz):
1: 1258 2: 1259 3: 1258 4: 1259 5: 1259 6: 1258 7: 1259 8: 1258
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Picasso vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 07:00.0 chip-ID: 1002:15d8 class-ID: 0300
Display: wayland server: X.org 1.20.13 compositor: gnome-shell driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa display-ID: 0
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.41.0
5.13.15-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.2.1 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel v: kernel
bus-ID: 07:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK PRIME B450M-A
driver: snd_hda_intel v: kernel bus-ID: 07:00.6 chip-ID: 1022:15e3
class-ID: 0403
Device-3: Afatech GAMDIAS USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-3:2 chip-ID: 1b80:b515
class-ID: 0300
Sound Server-1: ALSA v: k5.13.15-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.35 running: no
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 05:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-6ce42bc37c5c state: down mac: <filter>
IF-ID-2: docker0 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 5-1:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 1.13 TiB used: 19.37 GiB (1.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10
type: HDD rpm: 5400 serial: <filter> rev: 1A04 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS240G2G0A-00JH30 size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0400
scheme: GPT
ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
used: 19.37 GiB (8.9%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: Manjaro
uuid: 18517985-3763-4583-ae1c-6622ed0bf2fa
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
label: SISTEMA EFI uuid: 95C7-263E
ID-1: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: N/A
uuid: 7695760D0589F9E2
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Device-1: 1-3:2 info: Afatech GAMDIAS USB Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1b80:b515 class-ID: 0300
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 3-4:2 info: Unknown Manufacturer hub ports: 4 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a05:7211 class-ID: 0900
Hub-5: 3-4.1:3 info: Unknown Manufacturer hub ports: 4 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 0a05:7211 class-ID: 0900
Device-1: 3-4.3:4 info: SINO WEALTH Gaming KB type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 258a:003a class-ID: 0300
Device-2: 3-4.4:5 info: USB OPTICAL MOUSE type: Mouse,Keyboard
power: 100mA chip-ID: 4e53:5407 class-ID: 0301
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 5-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Hub-8: 6-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 39.6 C mobo: N/A gpu: amdgpu temp: 39.0 C
Processes: 277 Uptime: 4m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1277 pacman: 1274 lib: 404 flatpak: 3
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
Could you help me please?
