I have a USB 3.0 Hub that I’ve had for several years that works fine under Windows and I could have sworn worked fine previously under various Linux kernels with this same laptop…though I can’t remember that last one it would have worked under. It is the Syba 7 port SY-HUB20078 - has 2 USB 3.0 ports and 5 USB 2.0 ports on it. My laptop is a Lenovo Yoga 730-15ikb.
I’ve just installed Manjaro, with everything up-to-date, and for whatever reason when I plug this hub in only USB 2.0 speeds are detected.
- USB3 devices do not work in the USB3 ports, dmesg doesn’t even display anything happening.
- If I plug a USB2 device into one of the USB3 ports on the hub it is properly detected as a USB2 device
- When I plug in a USB3 device into a USB2 port on the hub the device works fine, albeit at USB2 speeds
I’ve attempted various solutions such as use_both_schemes=y and old_scheme_first=y modprobe options suggested in a similar post, but no change. I’ve also seen other various kernel options such as pci=nomsi and intel_iommu=on iommu=pt suggested but those don’t seem to change behavior as well.
If I plug a USB3 device directly into the USB3 port on my laptop it is properly identified as a SuperSpeed (USB3) device. Listing of lsusb -t -v and dmesg with a Thumbdrive plugged into the port:
[vader ~]# lsusb -t -v
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 5000M
ID 1d6b:0003 Linux Foundation 3.0 root hub
|__ Port 1: Dev 3, If 0, Class=Vendor Specific Class, Driver=ax88179_178a, 5000M
ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet
|__ Port 2: Dev 4, If 0, Class=Mass Storage, Driver=usb-storage, 5000M
ID 13fe:5500 Kingston Technology Company Inc. Flash drive
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/12p, 480M
ID 1d6b:0002 Linux Foundation 2.0 root hub
|__ Port 5: Dev 3, If 1, Class=Video, Driver=uvcvideo, 480M
ID 13d3:56b2 IMC Networks
|__ Port 5: Dev 3, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 6: Dev 5, If 0, Class=Vendor Specific Class, Driver=, 12M
ID 06cb:0081 Synaptics, Inc.
|__ Port 7: Dev 7, If 0, Class=Wireless, Driver=btusb, 12M
ID 0bda:b023 Realtek Semiconductor Corp. RTL8822BE Bluetooth 4.2 Adapter
|__ Port 7: Dev 7, If 1, Class=Wireless, Driver=btusb, 12M
[ 881.392043] usb 2-2: new SuperSpeed Gen 1 USB device number 4 using xhci_hcd
[ 881.421444] usb 2-2: New USB device found, idVendor=13fe, idProduct=5500, bcdDevice= 1.00
[ 881.421476] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 881.421481] usb 2-2: Product: Silicon-Power32G
[ 881.421484] usb 2-2: Manufacturer: UFD 3.0
[ 881.421487] usb 2-2: SerialNumber: P1401199070B448DB6271C52
[ 882.030925] usb-storage 2-2:1.0: USB Mass Storage device detected
[ 882.031062] scsi host0: usb-storage 2-2:1.0
[ 882.031129] usbcore: registered new interface driver usb-storage
[ 882.033782] usbcore: registered new interface driver uas
[ 883.098834] scsi 0:0:0:0: Direct-Access UFD 3.0 Silicon-Power32G PMAP PQ: 0 ANSI: 6
Listing of lsusb -t -v and dmesg when USB3 hub plugged in:
|__ Port 2: Dev 12, If 0, Class=Hub, Driver=hub/4p, 480M
ID 2109:3431 VIA Labs, Inc. Hub
|__ Port 4: Dev 14, If 0, Class=Hub, Driver=hub/4p, 480M
ID 0409:005a NEC Corp. HighSpeed Hub
[ 1042.505231] usb 1-2: new high-speed USB device number 24 using xhci_hcd
[ 1042.646987] usb 1-2: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 2.88
[ 1042.646995] usb 1-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1042.646999] usb 1-2: Product: USB2.0 Hub
[ 1042.649894] hub 1-2:1.0: USB hub found
[ 1042.650058] hub 1-2:1.0: 4 ports detected
[ 1042.938621] usb 1-2.4: new high-speed USB device number 25 using xhci_hcd
[ 1043.029102] usb 1-2.4: New USB device found, idVendor=0409, idProduct=005a, bcdDevice= 1.00
[ 1043.029109] usb 1-2.4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1043.030332] hub 1-2.4:1.0: USB hub found
[ 1043.030434] hub 1-2.4:1.0: 4 ports detected
I’m out of ideas at this point and any help would be appreciated!
