After updating urxvt
won’t start (which is a bit of a pain when it’s your default terminal in i3wm
). Gives the error:
urxvt: error while loading shared libraries: libperl.so: cannot open shared object file: No such file or directory
The package is urxvt-perls 2.3-2
from the extra
repository.
Might be the case that rxvt-unicode-pixbuf
from the AUR has managed to fix this, otherwise I guess we have to wait?
First I would make sure you are fully aligned with the repo’s by
sudo pacman-mirrors -f 5 && sudo pacman -Syyuu perl
This command will also perform downgrades if needed.
Afterwards, reboot.
Make sure to always update when installing a new package to avoid dependency inconsistencies.
I was already up to date with perl-5.38.0-1
, but ran this anyway to check. Unfortunately the same error remains.
(I’ve been doing a full upgrade since being scolded about it previously)
I installed rxvt-unicode-pixbuf
from the AUR instead – looks like this works.
