I’m having issues with my system, which appears to be due to the upower service not able to start. If I reinstall upower, the problems seem to go away temporarily.
It may be related to gitlab.freedesktop.org/upower/upower/-/issues/104 , but i’m not sure how CONFIG_USER_NS is meant to be set.
Started again this morning, here is the result of trying to start it manually:
[user@system-name ~]$ sudo systemctl start upower
Job for upower.service failed because a timeout was exceeded.
See "systemctl status upower.service" and "journalctl -xe" for details.
[user@system-name ~]$ sudo systemctl status upower
● upower.service - Daemon for power management
Loaded: loaded (/usr/lib/systemd/system/upower.service; disabled; vendor preset: disabled)
Active: activating (start) since Sat 2020-10-17 07:06:01 AEST; 1min 16s ago
Docs: man:upowerd(8)
Main PID: 6746 (upowerd)
Tasks: 4 (limit: 38464)
Memory: 2.8M
CGroup: /system.slice/upower.service
└─6746 /usr/lib/upowerd
Oct 17 07:06:01 system-name systemd[1]: Starting Daemon for power management...
journalctl -p3 -b
-- Logs begin at Thu 2020-06-25 22:58:34 AEST, end at Sat 2020-10-17 07:08:54 AEST. --
Oct 17 07:01:40 system-name kernel: logitech-hidpp-device 0003:046D:C086.0008: Device not connected
Oct 17 07:02:50 system-name sddm-helper[1169]: gkr-pam: unable to locate daemon control file
Oct 17 07:02:52 system-name libvirtd[592]: operation failed: pool 'default' already exists with uuid 3b841165-d199-403a-a575-850512950cd2
Oct 17 07:03:00 system-name systemd[1]: Failed to start Daemon for power management.
Oct 17 07:03:02 system-name kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Oct 17 07:03:06 system-name kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Oct 17 07:03:10 system-name kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Oct 17 07:03:14 system-name kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Oct 17 07:04:31 system-name systemd[1]: Failed to start Daemon for power management.
Oct 17 07:04:31 system-name kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Oct 17 07:06:01 system-name systemd[1]: Failed to start Daemon for power management.
Oct 17 07:06:04 system-name kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
Oct 17 07:07:31 system-name systemd[1]: Failed to start Daemon for power management.
Oct 17 07:07:33 system-name kernel: usb usb2-port1: Cannot enable. Maybe the USB cable is bad?
