I’m thinking of upgrading my 10 year PC from Intel to AMD Ryzen (haven’t decided on which processor yet) What should I change in my system to make it fully compatible with AMD? I really don’t want to do a fresh install, here’s some info:
[manjaro@manjaro ~]$ inxi -F
System: Host: manjaro Kernel: 5.4.142-1-MANJARO x86_64 bits: 64 Desktop: i3 4.19.1 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: H71M-DGS serial: <superuser required> BIOS: American Megatrends v: P1.50
date: 01/31/2013
CPU: Info: Quad Core model: Intel Core i5-3470 bits: 64 type: MCP cache: L2: 6 MiB
Speed: 1597 MHz min/max: 1600/3600 MHz Core speeds (MHz): 1: 1597 2: 1597 3: 1597 4: 1597
Graphics: Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics driver: i915 v: kernel
Display: x11 server: X.org 1.20.13 driver: loaded: modesetting resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa DRI Intel HD Graphics 2500 (IVB GT1) v: 4.2 Mesa 21.2.1
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio driver: snd_hda_intel
Device-2: SAVITECH FiiO USB DAC K1 type: USB driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.4.142-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: eth0 state: down mac: bc:5f:f4:ba:39:b8
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB driver: r8188eu
IF: wlan0 state: up mac: 98:de:d0:18:23:0a
Drives: Local Storage: total: 465.76 GiB used: 149.74 GiB (32.1%)
ID-1: /dev/sda vendor: Western Digital model: WD5000AZLX-60K2TA0 size: 465.76 GiB
Partition: ID-1: / size: 200.72 GiB used: 41.27 GiB (20.6%) fs: ext4 dev: /dev/sda5
Swap: ID-1: swap-1 type: partition size: 255 MiB used: 53.8 MiB (21.1%) dev: /dev/sda7
Sensors: System Temperatures: cpu: 35.0 C mobo: 37.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 2295 fan-3: 0 fan-4: 0 fan-5: 0
Info: Processes: 218 Uptime: 21d 19h 22m Memory: 7.48 GiB used: 4.57 GiB (61.0%) Shell: Bash inxi: 3.3.06
