I upgraded my system using pacman -Syu
because I was running into some issues with gdb
(GNU debugger) saying it couldn’t find the shared object file libpython3.10.so.1.0
. I’m thinking, “Alright. I haven’t upgraded in awhile. I’ll try that.” So, I upgraded and was able to make gdb
work! However, after the upgrade was completed , I tried opening vim
and now I get this:
vim: error while loading shared libraries: libpython3.9.so.1.0: cannot open shared object file: No such file or directory
I’m also running into issues with NeoVim because when I run nvim
I get this error:
Error detected while processing /home/czar/.vim/plugged/vim-fugitive/plugin/fugitive.vim:
line 471:
E1208: -complete used without -nargs
and when I close out neovim, I get this
function remote#define#AutocmdBootstrap[1]..remote#host#Require[10]..provider#pythonx#Require[12]..provider#Poll, line 7
Vim(if):Error invoking 'poll' on channel 4:^@ch 4 was closed by the client
Error detected while processing function remote#define#AutocmdBootstrap[1]..remote#host#Require[10]..provider#pythonx#Require[12]..provi
der#Poll:
line 17:
E605: Exception not caught: Failed to load python3 host. You can try to see what happened by starting nvim with $NVIM_PYTHON_LOG_FILE se
t and opening the generated log file. Also, the host stderr is available in messages.
Error detected while processing function remote#define#AutocmdBootstrap[1]..remote#host#Require:
line 10:
E171: Missing :endif
I have no idea where to even look in the first place to even ATTEMPT to solve this issue. My best guess so far is it has something to do with some python dependencies (libpython3.-*.so and such?). And it’s not so much vim and neovim I care about, but really just making everything work after upgrading my system.
How can I resolve these dependency issues? Please let me know what information I should provide. I’m completely out of my element here. Thank you in advance!
I’m running on kernel 5.11.22
