Hi, I recently tried to upgrade my system using pamac and I got a couple of errors and warnings resulting in the following symptom:
[ludo@garuda ~]$ sudo pacman -Syvv manjaro-keyring
[sudo] password for ludo:
error: GPGME error: No data
Root : /
Conf File : /etc/pacman.conf
DB Path : /var/lib/pacman/
Cache Dirs: /var/cache/pacman/pkg/
Hook Dirs : /usr/share/libalpm/hooks/ /etc/pacman.d/hooks/
Lock File : /var/lib/pacman/db.lck
Log File : /var/log/pacman.log
GPG Dir : /etc/pacman.d/gnupg/
Targets : manjaro-keyring
core 169,4 KiB 822 KiB/s 00:00 [##################################] 100%
extra 1915,2 KiB 1553 KiB/s 00:01 [##################################] 100%
community 6,8 MiB 2005 KiB/s 00:03 [##################################] 100%
multilib 175,5 KiB 1097 KiB/s 00:00 [##################################] 100%
error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
From the parabola wiki (Pacman troubleshooting), it seems like there is a problem with some downloaded packages.
(Note: sorry I’ve got a couple of links to show some solutions/information I found on the web but I’m not allowed to publish links :-/ )
I tried to apply the usual solution concerning keyring problems (see Olli’s post in “Update: Error while configuring manjaro-keyring” [Manjaro forum]) but it did not work.
I finally fix the problem by cleaning the folder “/var/lib/pacman/sync/” (I removed the pamac files “.files" & ".db.*” (inspired by answer#2 in “[SOLVED] Error updating system (error: GPGME error: No data)” [Arch forum]).
Yet, I’m not satisfied by the solution as 1) I’m not really sure what happens, 2) each time I try to upgrade using pamac (terminal or GUI), I’ve got the same problem again (even if I try to upgrade a single program through the GUI, whatever it can be: zoom, awaita-qt, android-emulator…).
So, what should I do to find the origin of and solve the problem?
- can it be a pamac problem?
- can it be a contributor untrusted key or a corrupted package from the AUR that trigger the whole problem (even if I don’t ask to upgrade it)? If so, How can I detect it (maybe I can just uninstall it and problem solve?).
Any help would be welcome
