Hi everyone and happy new year!
I just ran sudo pacman -Syyu
. It found one update manjaro-system-20210101-2
, but the update failed with:
core 167.6 KiB 1397 KiB/s 00:00 [######################] 100%
extra 1994.5 KiB 3.72 MiB/s 00:01 [######################] 100%
community 6.3 MiB 6.02 MiB/s 00:01 [######################] 100%
multilib 182.0 KiB 6.58 MiB/s 00:00 [######################] 100%
:: Some packages should be upgraded first…
resolving dependencies…
looking for conflicting packages…Packages (1) manjaro-system-20210101-2
Total Download Size: 0.02 MiB
Total Installed Size: 0.00 MiB
Net Upgrade Size: 0.00 MiB:: Proceed with installation? [Y/n] Y
:: Retrieving packages…
manjaro-system-2… 21.0 KiB 0.00 B/s 00:00 [######################] 100%
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
:: Processing package changes…
(1/1) upgrading manjaro-system [######################] 100%
error: command failed to execute correctly
:: Running post-transaction hooks…
(1/1) Arming ConditionNeedsUpdate…
I ran sudo pacman -S manjaro-system
and it tried update again, but with the same result. Then I ran the following script again only to make sure that it hasn’t something to do with the mirrors:
#!/bin/bash
sudo pacman-mirrors --api --proto https ftps --method rank --continent
#sudo pacman-mirrors --api --proto https ftps --method rank --country Germanysleep 3
sudo pacman -Syyu
That resulted in: Nothing to do.
Installed is the new version. How do I downgrade to the previous version?
