Running Gnome 40.4.0 on 5.14.13-1-MANJARO. It has NVIDIA GeForce GTX 650 Ti/PCIe/SSE2.
When I tried to upgrade using sudo pacman -Syyu, it produced an error:
sudo pacman -Syyu
installing nvidia-utils (470.82.00-1) breaks dependency 'nvidia-utils=470.74' required by linux512-nvidia
What should I do to proceed with the update?
You should uninstall your kernel 5.12 as it is EOL.
@maycne.sonahoz Sorry for replying so late.
But uninstalling Kernel 5.12 did solve the problem.
Thanks.
Man this is ridiculous… I think MSM should have a periodic job checking for EOL kernels installed on a user’s machine and notifying if found any… So many “issues” could have been “resolved” with a feature as simple as that.
AFAIK it already has.
