Got a multi monitor/desktop orientation issue, after the update to KDE 6.8.2.
Read 6.8 release had some quirks regarding, that should have been patched in 6.8.2?
After login, sometimes, my primary monitor resolution, orientation and scaling gets bugged.
Looks like it gets mirrored (90* clockwise) to my secondary 15.6" to the side, that is configured in protrait at 1080p and 135% scaled.
Cycling power on both monitors resets resolution, orientation and scaling. But everts all icon placements to default aplhabethical order.
What seems to work as workaround is to disable the secondary monitor using kscreen-doctor in a logout script and enable with a login script. This has survived several logout and login cycles for now.
Does 6.8.2 still have a bug regarding this?
inxi -zv8
Kernel: 7.3.4-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-7.3-x86_64
root=UUID=c2c92475-3f6d-43c2-9ed5-ce58e4c5b93f rw plymouth.enable=0
disablehooks=plymouth quiet splash loglevel=3 rd.udev.log_level=3
sysrq_always_enabled=1 nvme_core.default_ps_max_latency_us=0
amd_pstate=passive amdgpu.dcdebugmask=0x10
amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 6.8.2 tk: Qt v: N/A info: frameworks v: 6.31.0
wm: kwin_wayland vt: 7 dm: N/A Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: Micro-Star model: MAG B850M MORTAR WIFI (MS-7E61) v: 1.0
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: 1.A45 date: 09/10/2025
System RAM: total: 32 GiB available: 30.89 GiB used: 4.81 GiB (15.6%)
Device-1: DIMMA1 type: no module installed
Device-2: DIMMA2 type: DDR5 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 6000 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: N/A
part-no: IR-6400D564L32S/16G serial: <filter>
Device-3: DIMMB1 type: no module installed
Device-4: DIMMB2 type: DDR5 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 976 min/max: 426/5053 boost: enabled scaling:
driver: amd-pstate governor: conservative cores: 1: 976 2: 976 3: 976 4: 976
5: 976 6: 976 7: 976 8: 976 9: 976 10: 976 11: 976 12: 976 13: 976 14: 976
15: 976 16: 976 bogomips: 134400
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid
cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
XT/9070 GRE] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-4
code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
speed: 32 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1
empty: DP-2,HDMI-A-2,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.26 with: Xwayland v: 24.1.15
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu d-rect: 5360x1440 display-ID: 1
Monitor-1: DP-1 pos: primary,left model: AOC CU34G2XP serial: <filter>
built: 2024 res: mode: 3440x1440 hz: 180 scale: 100% (1) dpi: 110 gamma: 1.2
chroma: red: x: 0.678 y: 0.310 green: x: 0.271 y: 0.663 blue: x: 0.153
y: 0.067 white: x: 0.314 y: 0.329 size: 797x334mm (31.38x13.15")
diag: 864mm (34") modes: 3440x1440, 2560x1080, 1920x1080, 1680x1050,
1280x1024, 1440x900, 1280x720, 1024x768, 832x624, 800x600, 720x576,
720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unhandled CEA mode 75 2: parse_edid:
unhandled CEA mode 76 3: parse_edid: unhandled CEA mode 89 4: parse_edid:
unhandled CEA mode 90 5: parse_edid: unknown tag 112
Monitor-2: HDMI-A-1 pos: right model: Invalid Vendor Codename - RTK
421531776 built: 2020 res: mode: 1920x1080 hz: 60 scale: 240% (2.4)
to: 800x1422 dpi: 142 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green:
x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 344x195mm (13.54x7.68") diag: 395mm (15.57") modes: 1920x1080,
1680x1050, 1440x900, 1280x960, 1280x800, 1280x720, 1024x768, 800x600,
640x480
EDID-Warnings: 1: parse_edid: unhandled CEA mode 108 2: parse_edid:
unhandled CEA mode 108 3: parse_edid: unhandled CEA mode 108 4: parse_edid:
unhandled CEA mode 108 5: parse_edid: unhandled CEA mode 108 6: parse_edid:
unhandled CEA mode 108 7: parse_edid: unhandled CEA mode 75 8: parse_edid:
API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: swrast
gbm: drv: radeonsi surfaceless: drv: swrast wayland: drv: swrast x11:
drv: swrast
API: OpenGL v: 4.6 vendor: mesa v: 26.2.7-arch1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 23.1.4 256 bits)
device-ID: ffffffff:ffffffff memory: 30.17 GiB unified: yes
API: Vulkan v: 1.4.363 layers: 12 device: 0 type: discrete-gpu name: AMD
Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 26.2.7-arch1.1
device-ID: 1002:7550 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: amdgpu_top,corectrl wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Ryzen HD Audio
bus-ID: 12:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Texas Instruments PCM2902 Audio Codec
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 08bb:2902 class-ID: 0300
Device-4: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 6-12:6
chip-ID: 0db0:cc78 class-ID: 0300
API: ALSA v: k7.3.4-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.6.11 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Realtek RTL8126 5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1 port: e000 bus-ID: 0d:00.0
chip-ID: 10ec:8126 class-ID: 0200
IF: enp13s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, smbd, systemd-timesyncd
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 6-11:5 chip-ID: 0489:e10a
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
Local Storage: total: 6.41 TiB used: 2.58 TiB (40.3%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Lexar model: SSD NM620 1TB
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V1.23 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Reletech model: M.2 SSD 1024GB
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM32.1 temp: 27.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 2TB
ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM010-2EP102
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 7200
serial: <filter> fw-rev: 0104 scheme: MBR
ID-1: / raw-size: 857.7 GiB size: 843.16 GiB (98.31%)
used: 463.13 GiB (54.9%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
label: N/A uuid: c2c92475-3f6d-43c2-9ed5-ce58e4c5b93f
used: 344 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
uuid: 4A19-EA19
ID-3: /mnt/data raw-size: 858.48 GiB size: 843.93 GiB (98.31%)
used: 420.89 GiB (49.9%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:4
label: DATA uuid: 74423f52-a944-4f61-9500-f4bc683c2cef
ID-4: /mnt/data2 raw-size: 1.64 TiB size: 1.61 TiB (98.37%)
used: 649.55 GiB (39.4%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: DATA2
uuid: 4de3dfe5-98c9-438d-9fef-7bd41d5bf67f
ID-5: /mnt/data3 raw-size: 1.64 TiB size: 1.61 TiB (98.37%)
used: 651.65 GiB (39.5%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: DATA3
uuid: e14912f2-9e23-418f-9a32-6eca47b43d8f
ID-6: /mnt/storage raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
used: 460.54 GiB (49.4%) fs: btrfs dev: /dev/sdc1 maj-min: 8:33
label: STORAGE uuid: 9e430a82-b613-4665-b4b3-2277d5447e8a
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -1
file: /swapfile
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 1-1:2 info: China Resource Semico USB Gaming Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 1a2c:9400 class-ID: 0301
Device-2: 1-2:3 info: Sharkoon SHARK Force 3 type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 30fa:1440 class-ID: 0300
Device-1: 3-1:2 info: Texas Instruments PCM2902 Audio Codec
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Hub-7: 6-5:2 info: Genesys Logic Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Hub-8: 6-5.4:7 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Device-1: 6-10:3 info: Micro Star MYSTIC LIGHT type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 0db0:0076 class-ID: 0300
serial: <filter>
Device-2: 6-11:5 info: Foxconn / Hon Hai type: bluetooth driver: btusb
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 0489:e10a class-ID: e001
Device-3: 6-12:6 info: Micro Star USB Audio type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 8 rev: 2.0
Hub-9: 7-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-10: 7-5:2 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
Device-1: 7-5.1:3 info: JMS578 based SATA bridge type: mass storage
driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 power: 8mA chip-ID: 0080:a001 class-ID: 0806
serial: <filter>
Hub-11: 7-5.4:5 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
System Temperatures: cpu: 35.5 C mobo: N/A gpu: amdgpu temp: 30.0 C
mem: 52.0 C
Fan Speeds (rpm): cpu: 752 mobo: 746 gpu: amdgpu fan: 0
Power: 12v: 11.90 5v: 4.96 3.3v: 3.30 vbat: 1.84 gpu: amdgpu watts: 23.00
Packages: 1619 pm: pacman pkgs: 1614 libs: 445 tools: pamac pm: flatpak
pkgs: 5
1: https://mirror.koddos.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 407
1: cpu: 41.7% command: firefox pid: 43101 mem: 1207.6 MiB (3.8%)
2: cpu: 23.2% command: kwin_wayland pid: 42718 mem: 370.1 MiB (1.1%)
3: cpu: 12.1% command: plasmashell pid: 42728 mem: 609.6 MiB (1.9%)
4: cpu: 11.5% command: firefox pid: 44288 mem: 401.5 MiB (1.2%)
5: cpu: 5.0% command: konsole pid: 48951 mem: 115.4 MiB (0.3%)
Memory top: 5 of 407
1: mem: 1207.6 MiB (3.8%) command: firefox pid: 43101 cpu: 41.7%
2: mem: 624.4 MiB (1.9%) command: ./steamwebhelper pid: 44932 cpu: 1.6%
3: mem: 609.6 MiB (1.9%) command: plasmashell pid: 42728 cpu: 12.1%
4: mem: 401.5 MiB (1.2%) command: firefox pid: 44288 cpu: 11.5%
5: mem: 373.1 MiB (1.1%) command: steam pid: 43953 cpu: 2.1%
Processes: 407 Power: uptime: 39m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.27 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 262 default: graphical
tool: systemctl
Compilers: clang: 23.1.5 gcc: 16.2.1 Shell: Bash v: 5.3.20
running-in: konsole inxi: 3.3.41
