Updating the system failed
Hello
I did not use Manjaro for a few weeks and found some updates after logging in. I get the following error a few times when using the graphical installer (pamac):
Error: failed retrieving file 'webkitgtk-6.0-2.52.3-1-x86_64.pkg.tar.zst.sig' from cofractal-ewr.mm.fcix.net : Connection timed out after 10000 milliseconds
How do I solve this?
Try changing your mirrors. The Global CDN ones are very reliable & always up-to-date, with datacentres on every continent:
sudo pacman-mirrors --country Global
Then run your update:
sudo pacman -Syu
I ran the commands and it seems to have succeeded.
Thanks.
