see title
can’t install libnvme so I can’t update
Update your mirrors first, then do an update.
sudo pacman-mirrors --geoip
pamac update --force-refresh
Nope
I’ll try different mirrors
Same error with CLI
Tried three different mirrors, Global, Taiwan. US and refreshing databases each time
always same error
Which error?
https://packages.manjaro.org/?query=libnvme
$ pamac search libnvme
libnvme 1.5-1 extra
C Library for NVM Express on Linux
target not found: libnvme
every time i get this
sudo pacman -Syu libnvme worked
it installed all the other updates
then libnvme installed from package manager
My hunch is that you tried to install using pacman -S libnvme and therefore the metadata (package dataabase) was not up-to-date.
That is why pacman -Syu libnvme worked - the y sync metadata and u updates the system.
Lesson learned - always use -Syu when syncing new packages to the system - so you get the correct metadata and the updated system packages.
pacman -Syu libnvme
didn’t work for me. I did
and got
https://repo.skni.umcs.pl/manjaro/stable/extra/x86_64/ttf-hack-3.003-6-any.pkg.tar.zst: HTTP/2 Error: NO_ERROR
Error: Operation failed: could not download some files
sudo pacman -Syu
throws
error: failed to prepare transaction (cannot resolve the dependencies)
:: installation of nvidia-utils (535.54.03-1) breakes dependecies of 'nvidia-utils=530.41.03' which are required by linux62-nvidia.
I get the same error after pacman -Syu libnvme
You should first update your system and clear up the dependecy issues, then you can continue installing new packages.
But this what I tried to do - update the system and this is when I get the error ‘target not found: libnvme’. I wrote about it: https://forum.manjaro.org/t/target-not-found-libnvme/143891 but you kind of redirected me here. So I did what has been suggested here.
See papajoke’s response to sicklepause1’s identical error message:
So, removing the linux62 did the trick and I was able to update the system. Thanks.
