Hello everyone,
I want to run a full system update. During the dependency checks, the following error occurs:
Checking python-polyglot dependencies...
Error: failed to prepare transaction: Failed to check python-polyglot dependencies
ln: failed to create symbolic link '/var/tmp/pamac/dbs/local': Read-only file system
After that, I can not create new files anymore because the file system is read-only. I can’t even shutdown the system normally but have to use the power button and force a shutdown.
I do not run regular updates on this machine because I only use it from time to time, so the last time I’ve updated the system might be a couple of months ago.
Here is some information about my system:
Global information (inxi -v7azy
Kernel: 5.15.120-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=5ca9ae86-d201-4085-9fbb-6e4001f086f2 rw quiet
cryptdevice=UUID=4086b629-18a7-4f8a-b88e-691b0f119832:luks-4086b629-18a7-4f8a-b88e-691b0f119832
root=/dev/mapper/luks-4086b629-18a7-4f8a-b88e-691b0f119832
resume=/dev/mapper/luks-4086b629-18a7-4f8a-b88e-691b0f119832 apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 23497E5 v: ThinkPad T430
Mobo: LENOVO model: 23497E5 serial: <superuser required>
UEFI-[Legacy]: LENOVO v: G1ET91WW (2.51 ) date: 01/09/2013
ID-1: BAT0 charge: 73.6 Wh (100.0%) condition: 73.6/86.6 Wh (85.0%)
power: 2.0 W volts: 12.6 min: 11.1 model: LGC 45N1011 type: Li-ion
serial: <filter> status: charging
System RAM: total: 8 GiB note: est. available: 7.47 GiB
used: 2.44 GiB (32.6%)
Info: model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2459 high: 2835 min/max: 1200/3300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1960 2: 2471 3: 2835
4: 2573 bogomips: 20761
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1,VGA-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: Chicony Thinkpad T430 camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.6:5 chip-ID: 04f2:b2db
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2624x900 s-dpi: 96 s-size: 694x238mm (27.32x9.37")
s-diag: 734mm (28.88")
Monitor-1: LVDS-1 pos: primary,left model: AU Optronics 0x213e built: 2010
res: 1600x900 hz: 60 dpi: 132 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: 1600x900
Monitor-2: VGA-1 pos: right model: Idek Iiyama BX3814UT serial: <filter>
built: 2002 res: 1024x768 hz: 75 dpi: 86 gamma: 0.35
size: 304x228mm (11.97x8.98") diag: 386mm (15.2") ratio: 4:3 modes:
max: 1024x768 min: 720x400
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo 7
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
API: ALSA v: k5.15.120-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.73 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:0085 class-ID: 0280
Device-1: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad] driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4:4
chip-ID: 0a5c:21e6 class-ID: fe01 serial: <filter>
Device-1: luks-4086b629-18a7-4f8a-b88e-691b0f119832 maj-min: 254:0
type: LUKS dm: dm-0 size: 167.68 GiB
Components:
p-1: sda1 maj-min: 8:1 size: 167.68 GiB
Local Storage: total: 167.68 GiB used: 89.92 GiB (53.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Intel model: SSDSC2BW180A3L
size: 167.68 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: LF1i scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT50N rev: LT20
dev-links: N/A
ID-1: / raw-size: 167.68 GiB size: 163.98 GiB (97.80%)
used: 89.92 GiB (54.8%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-4086b629-18a7-4f8a-b88e-691b0f119832 label: N/A
uuid: 5ca9ae86-d201-4085-9fbb-6e4001f086f2
Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.3:3 info: Upek TouchChip Fingerprint Coprocessor (WBF
advanced mode) type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1
chip-ID: 147e:2020 class-ID: 0000
Device-2: 1-1.4:4 info: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad]
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a5c:21e6
Device-3: 1-1.6:5 info: Chicony Thinkpad T430 camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 200mA chip-ID: 04f2:b2db class-ID: 0e02
Hub-3: 2-0:1 info: full speed or root hub ports: 3 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 3778
Processes: 222 Uptime: 45m wakeups: 2 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1951 libs: 490 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.1.16
running-in: gnome-terminal inxi: 3.3.28
Kernels (mhwd-kernel -li
* linux515 (running)
* linux54
Manjaro version (lsb_release -sirc
ManjaroLinux 23.0.0 UltimaThule
Storage uses (LANG=C df -h
Filesystem Size Used Avail Use% Mounted on
dev 3,8G 0 3,8G 0% /dev
run 3,8G 1,4M 3,8G 1% /run
/dev/dm-0 164G 90G 66G 58% /
tmpfs 3,8G 103M 3,7G 3% /dev/shm
tmpfs 3,8G 16M 3,8G 1% /tmp
tmpfs 765M 84K 765M 1% /run/user/1000
It would be awesome if someone could help me!
All the best,
David
