That is not the full output - it’s not all of it.
formatted full output looks like this (on my Manjaro VM):
inxi --filter --verbosity=8
Kernel: 6.12.20-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
clocksource: kvm-clock avail: tsc,acpi_pm
root=UUID=373ef7bb-ae65-4d7f-8f08-d7b429466940 rw quiet
cryptdevice=UUID=2aefff29-916e-47fe-959e-2213881b5487:luks-2aefff29-916e-47fe-959e-2213881b5487
root=/dev/mapper/luks-2aefff29-916e-47fe-959e-2213881b5487 splash
udev.log_priority=3
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Kvm System: QEMU product: Standard PC (Q35 + ICH9, 2009) v: pc-q35-6.2
serial: <superuser required> Chassis: type: 1 v: pc-q35-6.2
Mobo: N/A model: N/A serial: N/A uuid: <superuser required> UEFI: EFI
Development Kit II / OVMF v: 0.0.0 date: 02/06/2015
System RAM: total: 4 GiB available: 3.82 GiB used: 698.3 MiB (17.9%)
Array-1: capacity: 4 GiB slots: 1 modules: 1 EC: Multi-bit ECC
max-module-size: 4 GiB note: est.
Device-1: DIMM 0 type: RAM detail: N/A size: 4 GiB speed: N/A volts: N/A
width: N/A manufacturer: Qemu part-no: N/A serial: N/A
Info: model: Intel Core i3-3110M bits: 64 type: SMP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
Topology: cpus: 4x dies: 1 clusters: 1 cores: 1 smt: <unsupported> cache:
L1: 4x 64 KiB (256 KiB) desc: d-1x32 KiB; i-1x32 KiB L2: 4x 4 MiB (16 MiB)
desc: 1x4 MiB L3: 4x 16 MiB (64 MiB) desc: 1x16 MiB
Speed (MHz): avg: 2395 min/max: N/A cores: 1: 2395 2: 2395 3: 2395 4: 2395
bogomips: 19166
Flags: apic arat arch_capabilities arch_perfmon avx clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ept erms f16c flexpriority fpu
fsgsbase fxsr hypervisor ibpb ibrs lahf_lm lm mca mce md_clear mmx msr
mtrr nopl nx pae pat pcid pclmulqdq pdcm pge pni popcnt pse pse36 pti
rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
vme vmx vnmi vpid x2apic xsave xsaveopt xtopology
disabled
Type: mds mitigation: Clear CPU buffers; SMT Host state unknown
STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Retpoline
Device-1: Red Hat Virtio 1.0 GPU driver: virtio-pci v: 1 ports:
active: Virtual-1 empty: none bus-ID: 00:01.0 chip-ID: 1af4:1050
class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 compositor: xfwm4 v: 4.20.0 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: virtio-pci
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1024x768 s-dpi: 96 s-size: 271x204mm (10.67x8.03")
s-diag: 339mm (13.35")
Monitor-1: Virtual-1 model: QEMU Monitor built: 2014 res: mode: 1024x768
hz: 75 scale: 100% (1) dpi: 100 gamma: 1.2 chroma: red: x: 0.639 y: 0.329
green: x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 260x195mm (10.24x7.68") diag: 325mm (12.8") ratio: 4:3
modes: 1024x768, 5120x2160, 4096x2160, 3840x2160, 1920x1440, 2560x1080,
1856x1392, 1792x1344, 2048x1152, 1920x1200, 1920x1080, 1600x1200,
1680x1050, 1400x1050, 1280x1024, 1440x900, 1280x960, 1360x768, 1280x768,
800x600, 640x480
EDID-Warnings: 1: parse_edid: unknown flag 247 2: parse_edid: unhandled
CEA mode 125 3: parse_edid: unhandled CEA mode 101 4: parse_edid:
unhandled CEA mode 96 5: parse_edid: unhandled CEA mode 89
API: EGL v: 1.5 platforms: device: 0 drv: kms_swrast device: 1 drv: swrast
gbm: drv: kms_swrast surfaceless: drv: kms_swrast x11: drv: swrast
inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 25.0.2-arch1.2 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 19.1.7 256 bits)
device-ID: ffffffff:ffffffff memory: 3.73 GiB unified: yes
x11: xdpyinfo, xprop, xrandr
Device-1: Intel 82801I HD Audio vendor: Red Hat QEMU Virtual Machine
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e
class-ID: 0403
API: ALSA v: k6.12.20-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
Device-1: Red Hat Virtio 1.0 network driver: virtio-pci v: 1 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0 chip-ID: 1af4:1041
class-ID: 0200
IF-ID-1: enp1s0 state: up speed: -1 duplex: unknown mac: <filter>
Device-1: luks-2aefff29-916e-47fe-959e-2213881b5487 maj-min: 253:0
type: LUKS dm: dm-0 size: 34.7 GiB
Components:
p-1: vda2 maj-min: 254:2 size: 34.71 GiB
Local Storage: total: 45 GiB used: 7.25 GiB (16.1%)
ID-1: /dev/vda maj-min: 254:0 model: N/A size: 35 GiB block-size:
physical: 512 B logical: 512 B speed: <unknown> tech: N/A serial: N/A
scheme: GPT
ID-2: /dev/vdb maj-min: 254:16 model: N/A size: 10 GiB block-size:
physical: 512 B logical: 512 B tech: N/A serial: N/A scheme: MBR
Optical-1: /dev/sr0 vendor: QEMU model: QEMU DVD-ROM rev: 2.5+
dev-links: cdrom
Features: speed: 4 multisession: yes audio: yes dvd: yes rw: none
state: running
ID-1: / raw-size: 34.7 GiB size: 33.86 GiB (97.57%) used: 6.14 GiB (18.1%)
fs: ext4 dev: /dev/dm-0 maj-min: 253:0
mapped: luks-2aefff29-916e-47fe-959e-2213881b5487 label: N/A
uuid: 373ef7bb-ae65-4d7f-8f08-d7b429466940
used: 448 KiB (0.1%) fs: vfat dev: /dev/vda1 maj-min: 254:1 label: N/A
uuid: 2630-51D3
ID-3: /var/cache/pacman/pkg raw-size: 10 GiB size: 9.76 GiB (97.59%)
used: 1.11 GiB (11.4%) fs: ext4 dev: /dev/vdb1 maj-min: 254:17
label: pacmancache uuid: 98195df8-0bc0-4b79-abb7-8ea21d40999f
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 15 rev: 2.0
Device-1: 1-1:2 info: Adomax QEMU Tablet type: HID
chip-ID: 0627:0001 class-ID: 0300 serial: <filter>
Hub-2: 2-0:1 info: super-speed hub ports: 15 rev: 3.0
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Packages: pm: pacman pkgs: 931 libs: 282 tools: pamac
1: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
2: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
3: https://mirror.23m.com/manjaro/stable/$repo/$arch
4: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
5: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
6: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
7: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
8: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
9: https://manjaro.kurdy.org/stable/$repo/$arch
Processes:
CPU top: 5 of 226
1: cpu: 50.0% command: ps pid: 1145 mem: 3.75 MiB (0.0%)
2: cpu: 3.0% command: xfdesktop pid: 833 mem: 58.8 MiB (1.5%)
3: cpu: 3.0% command: xfce4-terminal pid: 1110 mem: 51.1 MiB (1.3%)
4: cpu: 2.1% command: xfwm4 pid: 795 mem: 93.4 MiB (2.3%)
5: cpu: 2.1% command: xfsettingsd pid: 1119 mem: 32.8 MiB (0.8%)
Memory top: 5 of 226
1: mem: 93.4 MiB (2.3%) command: xfwm4 pid: 795 cpu: 2.1%
2: mem: 71.9 MiB (1.8%) command: Xorg pid: 607 cpu: 2.0%
3: mem: 58.8 MiB (1.5%) command: xfdesktop pid: 833 cpu: 3.0%
4: mem: 54.1 MiB (1.3%) command: nm-applet pid: 915 cpu: 1.0%
5: mem: 51.1 MiB (1.3%) command: xfce4-terminal pid: 1110 cpu: 3.0%
Processes: 226 Power: uptime: 3m states: freeze,mem,disk suspend: s2idle
wakeups: 0 hibernate: shutdown avail: reboot,suspend,test_resume
image: 1.51 GiB services: upowerd,xfce4-power-manager Init: systemd v: 257
Compilers: N/A Shell: Bash v: 5.2.37 running-in: xfce4-terminal
inxi: 3.3.37
Please don’t use pictures - they can’t be searched/pased.
Just copy/paste and format it as “Preformatted text” → this button: </>
