Updates are signaled in KDE Tray but not found in Pamac
Helly Everyone,
for about 3-4 Weeks the KDE System Tray signals that there are updates available. When i click on the icon to launch pamac, it says, the system is up to date and there are no updates at all. The sign in the tray won’t go away, even if i try
pacman -Syyu
I’ve activated the AUR Support to get shure, the updates don’t belong to this repository, but also no no updates are shown.
What can i do to get rid of the problem?
Thank you
Furby
Please do not post meaningless and unnecessary screenshots.
Please check in a terminal (this will only provide intel on official repo packages) (part of package pacman-contrib)
checkupdates
You can copy the text and paste it in your original topic for reference.
For pamac you can use
pamac update --dry-run --no-aur
And to see if custom build scripts has been changed
pamac update --dry-run --aur
The obvious method is to disable update nagging :slight_smile: - personally I am no fan of updating to often, and nagging has often disturbed my working focus :grin:
Sorry, i’ll fix it
to check repository and AUR:
pamac checkupdates -a
Have you checked to make sure software mode has not been enabled in Pamac.
Hello Everyone,
i don’t know how, but this evenig the upgrade warning dialog only showed 3 updates and after finding and installing them in pamac the update warning sign is gone :face_with_raised_eyebrow:. I don’t know what did the magic, but now my problem is gone.
After all, the following line from @linux-aarhus showed 4 packages from the AUR-Repository:
but the update sign is still gone.
Thank you all for your support. This case can be closed.
Furby
