Hi,
Anyone update recently and break steam? I searched around a bit today looking for something but could not find anything specific to this. Tried to even just moving $HOME/.steam and $HOME/.local/share/Steam out of the way and let it rebuild them and that didnt change anything. I also tried steam --reset and it will redownload the client etc and update it fine. However after either of that is completed I get the following. I suspect that something the latest steam client update caused this but not sure how else to debug it further.
[2022-11-19 16:14:28] Verifying installation...
[2022-11-19 16:14:28] Performing checksum verification of executable files
[2022-11-19 16:14:29] Verification complete
Loaded SDL version 2.25.0-p7648887
(steam:6108): Gtk-WARNING **: 16:14:30.667: Unable to locate theme engine in module_path: "adwaita",
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf46d2db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf46d1500
Installing breakpad exception handler for appid(steam)/version(1668654564)
steamwebhelper.sh[6119]: Runtime for steamwebhelper: defaulting to /home/fury/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[6119]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 0 milliseconds to initialize
/home/fury/.local/share/Steam/steam.sh: line 798: 6108 Segmentation fault (core dumped) "$STEAMROOT/$STEAMEXEPATH" "$@"
from coredumpctl dump:
PID: 6108 (steam)
UID: 1000 (fury)
GID: 1000 (fury)
Signal: 11 (SEGV)
Timestamp: Sat 2022-11-19 16:14:31 CST (1min 48s ago)
Command Line: /home/fury/.local/share/Steam/ubuntu12_32/steam
Executable: /home/fury/.local/share/Steam/ubuntu12_32/steam
Control Group: /user.slice/user-1000.slice/session-2.scope
Unit: session-2.scope
Slice: user-1000.slice
Session: 2
Owner UID: 1000 (fury)
Boot ID: 0f83f53edb2745dfb8666463ffc4ac82
Machine ID: 35d752cf7c1f41caa9a2cddb46c8d10e
Hostname: fury-ryzen
Storage: /var/lib/systemd/coredump/core.steam.1000.0f83f53edb2745dfb8666463ffc4ac82.6108.1668896071000000.zst (present)
Disk Size: 35.0M
Message: Process 6108 (steam) of user 1000 dumped core.
Module /home/fury/.local/share/Steam/ubuntu12_32/steam with build-id 02f9fa7371c9221ee8674f05999f84e02b021bff
Module /home/fury/.local/share/Steam/ubuntu12_32/steamservice.so with build-id 0bc2953893d5e439e1ce9b879893c8b59a49b03b
Module /home/fury/.local/share/Steam/ubuntu12_32/libaudio.so with build-id 26dfc995ca345d6314b0f46ec493268afa37d161
Module /home/fury/.local/share/Steam/ubuntu12_32/steamclient.so with build-id 881bcc294d81bdebbf22a24989725c9ea7b7e1e6
Module /home/fury/.local/share/Steam/ubuntu12_32/libopenvr_api.so with build-id 694769e324d930c1cb34ad66982c232b0860bc72
Module /home/fury/.local/share/Steam/ubuntu12_32/chromehtml.so with build-id 97b5e7f0e2bc67c4073e649a4a79aa60934978a3
Module /home/fury/.local/share/Steam/ubuntu12_32/vgui2_s.so with build-id a4f842405ae371d83c7f17306e3d1c0134408edf
Module /home/fury/.local/share/Steam/ubuntu12_32/libvpx.so.6 with build-id e7262af22bb742de3a1af404c1fcc02cea202365
Module /home/fury/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libmurrine.so with build-id 65156017a203112e447a7d4871d548ff7c574392
Module /home/fury/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libpixmap.so with build-id a7f25bf3f3136905ee762be4694b065e73136776
Module /home/fury/.local/share/Steam/ubuntu12_32/filesystem_stdio.so with build-id eb2c2717df95bcf670e5876e8495969efdbc1997
Module /home/fury/.local/share/Steam/ubuntu12_32/libicuuc.so with build-id 7bca947cbb088c5ea46ae03b4e96f2ff4efc8253
Module /home/fury/.local/share/Steam/ubuntu12_32/libicui18n.so with build-id 88bf0deef8375bf4848f1fd853b1da471cfa8b7b
Module /home/fury/.local/share/Steam/ubuntu12_32/libvorbis.so.0 with build-id cb40c3a2fd4c2e54822da9789d01113970595af6
Module /home/fury/.local/share/Steam/ubuntu12_32/libvorbisenc.so.2 with build-id 5de455f0c9fcd36426e121b47995d9a75bfcecbf
Module /home/fury/.local/share/Steam/ubuntu12_32/libvideo.so with build-id a9b99fe9ce37edd387d553f7683c977593ab1a25
Module /home/fury/.local/share/Steam/ubuntu12_32/libswscale.so.5 with build-id 899463f29a2dc17e253fdc44d8c5c1f857d3790d
Module /home/fury/.local/share/Steam/ubuntu12_32/libavformat.so.58 with build-id f2588eeac146259fed0991e2c626bbf0fe466f53
Module /home/fury/.local/share/Steam/ubuntu12_32/libavutil.so.56 with build-id abf85a06683a34855e1a1d62a1ca36a1e0b461d6
Module /home/fury/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/gtk-2.0/modules/libcanberra-gtk-module.so with build-id 6c208073297de265758fd93cf5f92e7e2b839f9b
Module /home/fury/.local/share/Steam/ubuntu12_32/steam-runtime/lib/i386-linux-gnu/libdbus-1.so.3.5.8 with build-id bea6597c238951c70269c034fdf4097216e2c970
Module /home/fury/.local/share/Steam/ubuntu12_32/libavcodec.so.58 with build-id 148cef6f617f420f9e8332878f0ec4d229f9776c
Module /home/fury/.local/share/Steam/ubuntu12_32/steam-runtime/lib/i386-linux-gnu/libudev.so.0.13.0 with build-id cf2498d52231d623047c965a5b0ca03e2084464f
Module /home/fury/.local/share/Steam/ubuntu12_32/libogg.so.0 with build-id 4c91d8f0dd8581b0ba6780e60808dc1db9ff5151
Module /home/fury/.local/share/Steam/ubuntu12_32/libSDL2-2.0.so.0 with build-id 3d8fb8793e9cf9d2678e74e2d4aa572278268c1c
Module /home/fury/.local/share/Steam/ubuntu12_32/libv8.so with build-id c46f89eda7dcdedd846d2d6879a7d51e17ee8f64
Module /home/fury/.local/share/Steam/ubuntu12_32/libvstdlib_s.so with build-id 6f64b47509106d2908178cff0096b8fb346bdca0
Module /home/fury/.local/share/Steam/ubuntu12_32/steamui.so with build-id 3ee94d149c61fc8a72a54ebbb2b5c2143f172757
Module /home/fury/.local/share/Steam/ubuntu12_32/libavresample.so.4 with build-id 0e506657c7e0388a8d89e6f13c694ba77ab1587b
Module /home/fury/.local/share/Steam/ubuntu12_32/libtier0_s.so with build-id 1eae7e683877951c64f967b495131e05a529cc21
Module /home/fury/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0.2400.10 with build-id 48830dfc7e581fa5fbb5e7a2d2956b980a1e8ccc
Module /home/fury/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libdbusmenu-glib.so.4.0.13 with build-id 2d09183a661a81cdf7be0291101109ef60158d54
Module /home/fury/.local/share/Steam/ubuntu12_32/steam-runtime/usr/lib/i386-linux-gnu/libdbusmenu-gtk.so.4.0.13 with build-id 6e7466e1f39bdb6f5178c100f15cc1ebd73d0a40
Module /home/fury/.local/share/Steam/ubuntu12_32/crashhandler.so with build-id a03e91b15fb5e89fe18c0dc623d469a3ea9a2f97
Module linux-gate.so.1 with build-id b3c00cbecdda4afbf16ee079d5432e11689f2167
Module libplc4.so with build-id 162073353f543114bf438d07c26fe1ca4c810123
Module libplds4.so with build-id f64cc0912fddfc4b12c2fe05cbaaf93a6da4988a
Module libnssutil3.so with build-id 667a7e8014410271a3a5236758300ecf7f0bd2e4
Module libnspr4.so with build-id 79547ae369a9767120733d11ab5e607adff970ee
Module libnss3.so with build-id 2064e9834a1db91ca3e9de8cd935f54481c3fb47
Module libsmime3.so with build-id 5ca079eb3cd16efc90abbb8cff0760c99193b546
Module libudev.so.1 with build-id 42d4c526143ad115507de83ce39db45031f68967
Module libnm.so.0 with build-id 2e804ae341fcd55a122ed95726062101f37e5aa9
Module libltdl.so.7 with build-id 72bb7e92048e9d6a83330b8cfb9d98007c74d994
Module libtdb.so.1 with build-id f42d6f7f5ec3de1b96e5176ff6978e068205bcea
Module libvorbisfile.so.3 with build-id 4e73b2b22779d9987f3a258577392848fd90616b
Module libcanberra.so.0 with build-id e71559a6eca2c69d910be317ba2977d18b3cb14b
Module libcanberra-gtk.so.0 with build-id 7cca37ba05bdae684938b5504bae8a088c43a107
Module libuuid.so.1 with build-id cd66031432a77fcb9c2bf642cfd879aa170ffafe
Module libICE.so.6 with build-id 5c398351eae18b0185f2b9512647e40c97f4e068
Module libSM.so.6 with build-id 1cb4b8ce8ba49d0d98da7968de9ee574ed44fe6e
Module libopenal.so.1 with build-id c52c9460942f9bfb1540f5fe85c6cc9b4f4f3a02
Module libgpg-error.so.0 with build-id 0fd62fa62d9713a0946ae272215c6ffeb6f84b89
Module libgcrypt.so.20 with build-id 8ece9a72febf606ba62e6071765e3cc597a6edf0
Module libopus.so.0 with build-id e51af9f0b271bc2ba66d7b413a97df4aa21d1228
Module libFLAC.so.12 with build-id 1b4a90a984494dfe62c6b6abf3e2ac8dc7a3787a
Module libasyncns.so.0 with build-id 86b65d9623f0f8aba78d1be22e34b99ff38a7691
Module libsystemd.so.0 with build-id 83120485f4be799ffb3875da81588d8fd5a63b20
Module libsndfile.so.1 with build-id 54c2955a39f2e236c8bf27f9770ce98dd74735f4
Module libpulsecommon-16.1.so with build-id d1f892a3bc37a602d769b0664e50a7acb2257e5a
Module libvdpau.so.1 with build-id d42369090aa9fdf14c505ef29ac87c80b12daeae
Module libva-x11.so.2 with build-id 213a0284fc1993b631a30fe23de2c0203d6a21b7
Module libva-drm.so.2 with build-id 4f27714d60f8f29b39c0e45d888f72cdcd977cfc
Module libva.so.2 with build-id 619b6dac52609b82664fec7b26809889cf4229f6
Module libstdc++.so.6 with build-id 34d09c8eaf9352168f54bade53ee445983e7b634
Module libpulse.so.0 with build-id 8802cdae09ed16b8f9a246a1188bcc8dd26e09f9
Module libpipewire-0.3.so.0 with build-id 5eb3ac0ad2666cf2b1248c070f5281a4288254d9
Module libXtst.so.6 with build-id 18b05444aa91f84c95409860e0155b091e705675
Module libbrotlicommon.so.1 with build-id 6a6095e57c732bdc9f52c5b401ccd78412b34650
Module libbrotlidec.so.1 with build-id d217b0d877303a399de12d974671e442aaf58832
Module libbz2.so.1.0 with build-id 3e5d97f5bb82cda221ccd14318bfae2ac77b815e
Module libdatrie.so.1 with build-id 505ee6a7fcb465c1a484c8c813508515e415f19b
Module liblzma.so.5 with build-id a6705a420df4b1dc4a207a91982543c85bc9b1e1
Module libzstd.so.1 with build-id 442775044f6163f8c14265443311007e63d5d3e0
Module libblkid.so.1 with build-id afea748906b270df7b0dace3a37d063cc79bc9aa
Module libexpat.so.1 with build-id 51186e45c8908c8fdf0df3cab01de6edcbefdb2c
Module libpixman-1.so.0 with build-id ca9f1994f9c5a584743b148024ed15070c2f9950
Module libxcb-shm.so.0 with build-id c478bab45d8cef998d3d744755528b23dd9c445b
Module libxcb-render.so.0 with build-id 42eaec8c69b7df78937c6b9e664a98c457e5db18
Module libfreetype.so.6 with build-id ac10dea7fcb0e1dbc52d6989bfd34abbd814c1bf
Module libharfbuzz.so.0 with build-id 692d865127ddc9d9301557dc45164e5fc437206a
Module libthai.so.0 with build-id 55fe252092b25fc34ec252789c21a4f1702bfef1
Module libfribidi.so.0 with build-id 2789c21c3223584b3251e2339b80f76ef6202729
Module libXdamage.so.1 with build-id 55dd5fb5193b4ee5207ecad0d19cc6e9d7af5aa9
Module libXcomposite.so.1 with build-id 9e8c1fe3c65614cf3fb6b4bb74acffc8ab0a5e0e
Module libXcursor.so.1 with build-id ae3c97e2f155847562267b1707c75fb9884a2350
Module libXrandr.so.2 with build-id 3295bdef0e30b5fd9da27c99bf5d6fd1c14551aa
Module libXi.so.6 with build-id ae19d465b15227ab5e08de671bc16532450e384f
Module libXinerama.so.1 with build-id 8114c68a0060f3c58be35d6946c2fc17a5757a3b
Module libXrender.so.1 with build-id c63f9f4c64193140b1e10f34ebb93af72d1b96a3
Module libtiff.so.5 with build-id 3140b027caba04296b50ef36babf4e8fbf7172e4
Module libjpeg.so.8 with build-id bb111e5fbcc1c25bced2abacbc856a6410f8ad9b
Module libpng16.so.16 with build-id 35e22a878f521a80406ac89f93906e7c45fb16aa
Module libpcre2-8.so.0 with build-id 5e23dd060ea8921ba6fb211fc1f71cbf2199da34
Module libffi.so.8 with build-id 2452ba05aae2a48a7f68f0176692a6d127dd21ae
Module libmount.so.1 with build-id 1a0b51691abe9353156e69de06814b70d8f9f5f9
Module libz.so.1 with build-id f5c1a976688d07abac2e9ae289833072ba0d7820
Module libfontconfig.so.1 with build-id 3f3f437ff626bcdbbb64d86cc2f4ce8ea598dcc6
Module libpangoft2-1.0.so.0 with build-id 859ef18ef4411aaf39a894632e6dbb1513f3b4e6
Module libcairo.so.2 with build-id dd8d673a0e6ca9a8454e6712ef7c6d792288a7eb
Module libXfixes.so.3 with build-id d04e7cb05d21774a5403cdea89e8023c4e2dbd78
Module libpangocairo-1.0.so.0 with build-id 66cba204cdc77bbb337b6ca32e2264df08da6348
Module libatk-1.0.so.0 with build-id 2902156461a70a6958390c9c12dfa8965b6d58dc
Module libpango-1.0.so.0 with build-id f78655d941d31d3281b4fc5a851e56a09aa86e9f
Module libgdk-x11-2.0.so.0 with build-id 10aac81e0e0a4dd07b36d3ba3b34e5a124c4893c
Module libgmodule-2.0.so.0 with build-id a15156d84885df4346e3009961401714efc568de
Module libgdk_pixbuf-2.0.so.0 with build-id e5ac6959506f0baae58c10681783b2be9d494285
Module libglib-2.0.so.0 with build-id a5614d32b867e35024524953b7e6db3b52c7d731
Module libgobject-2.0.so.0 with build-id d7152e19ad94d8b74314e68308fa560f51b4e3a2
Module libgio-2.0.so.0 with build-id 20cb834af1486f3ddbbaa2a7cb34ce26ac44b9c1
Module libindicator.so.7 with build-id cb38ddcb8f426b4809ef119f0bd60130dd01e70d
Module libappindicator.so.1 with build-id b45ce0354a3c2e26bf64fa5d9dd1c6cf4bff39fd
Module libnss_myhostname.so.2 with build-id 7fe8c0407b7a26102b54ba56e3fc2f79a84c8369
Module libnss_resolve.so.2 with build-id 054ded18f575108b6d4d38721784b84846f15e43
Module libgcc_s.so.1 with build-id 4aa4ab5f15cd88f4008add230edd3da832876123
Module libcap.so.2 with build-id c78b82cd8dffa983442506c2f589c832159b3b5d
Module libnss_mymachines.so.2 with build-id 8bfd02af28500e5c5dc887509d216df08babb34b
Module libdrm.so.2 with build-id 398be193b1c103b75d64f565f73da7c3c1c98258
Module libxcb-glx.so.0 with build-id 817fea1247bcd2ed52775646ce5e5ad22768f3cf
Module libXext.so.6 with build-id 207b13d2377687e3ab3d831ba017a0bdbf297986
Module libnvidia-glcore.so.520.56.06 with build-id 5897abf0eeca895da50dcc8d316df99d755cc2cb
Module libnvidia-tls.so.520.56.06 with build-id a701b3620d4361cf6f858a587b3c03b88821dd4c
Module libnvidia-glsi.so.520.56.06 with build-id a60f3d4b4f88c4d05d41d6c9269c27e9498dc621
Module libGLX_nvidia.so.0 with build-id 3851207a2a89af7c38f3019873e1751bf8b21e24
Module libGLX.so.0 with build-id b50c9687f10ef138cf159f831d067396ec2e07ea
Module libGLdispatch.so.0 with build-id 42aa31219782672b1f71f308141ffa7636f525f4
Module libGL.so.1 with build-id 422501c22bf954ffd2b4f6227e251a5845c88454
Module libXdmcp.so.6 with build-id d6d2063b49e333551fb395c4699ce68908342ca2
Module libXau.so.6 with build-id c5cf058688fa36360ea55bd5fc4d77f907ac2399
Module libxcb.so.1 with build-id 4187de5462ea94547789043cd82a227550b36d73
Module ld-linux.so.2 with build-id d9821b338b72b86d2caf20bb5a1c7a825348bd01
Module libc.so.6 with build-id f9a1d140ee2962bbbc75e17ade27bf1f684eaf1c
Module libpthread.so.0 with build-id 8995ebfb2098a4668599bc8b6ae45d0557058e3c
Module libm.so.6 with build-id 5d48ca924eef7b1c81b8e09804045f06a55c9541
Module libX11.so.6 with build-id f403a20e166de698bf44f8f9d557d9f5b43aa342
Module librt.so.1 with build-id 822e5e6a09ff97cc5249cb865341cbfddedc2aac
Module libdl.so.2 with build-id d7233d1f60c516f28df08daecfb1e8399ad96b65
Stack trace of thread 6221:
#0 0x00000000e9780987 n/a (/home/fury/.local/share/Steam/ubuntu12_32/libaudio.so + 0x19987)
#1 0x00000000f2cf46d9 n/a (libpulse.so.0 + 0x216d9)
#2 0x00000000ef7aa618 n/a (libpulsecommon-16.1.so + 0x3d618)
#3 0x00000000ef7ab87f pa_pdispatch_run (libpulsecommon-16.1.so + 0x3e87f)
#4 0x00000000f2ce2493 n/a (libpulse.so.0 + 0xf493)
#5 0x00000000ef7b098a n/a (libpulsecommon-16.1.so + 0x4398a)
#6 0x00000000ef7b181d n/a (libpulsecommon-16.1.so + 0x4481d)
#7 0x00000000f2cf6374 pa_mainloop_dispatch (libpulse.so.0 + 0x23374)
#8 0x00000000f2cf6b23 pa_mainloop_iterate (libpulse.so.0 + 0x23b23)
#9 0x00000000f2cf6bdd pa_mainloop_run (libpulse.so.0 + 0x23bdd)
#10 0x00000000f2d07eb9 n/a (libpulse.so.0 + 0x34eb9)
#11 0x00000000ef7c4c84 n/a (libpulsecommon-16.1.so + 0x57c84)
#12 0x00000000f7a87485 n/a (libc.so.6 + 0x87485)
#13 0x00000000f7b24efc n/a (libc.so.6 + 0x124efc)
Stack trace of thread 6108:
#0 0x00000000f7f05549 __kernel_vsyscall (linux-gate.so.1 + 0x549)
#1 0x00000000f7b136d7 __poll (libc.so.6 + 0x1136d7)
#2 0x00000000f032400b n/a (/home/fury/.local/share/Steam/ubuntu12_32/steam-runtime/lib/i386-linux-gnu/libdbus-1.so.3.5.8 + 0x2f00b)
ELF object binary architecture: Intel 80386
