Updated from stable to unstable and now shutdown doesn’t work
Switched branch to unstable
Updated from stable to unstable and now shutdown doesn’t work.
Select Shutdown from the menu, the selection shut down / cancel comes (with the timer) i select shutdown → Monitor went black, Steam closed but “Manjaro hello” and mouse pointer stay active. Pushing the power button from the computer → shutdown, but computer rebooted directly. Now in Login screen click on “Shutdown”: computer shuts down immediately.
sudo pacman -Syyu - no result
swichted kernel from 9.10 to 9.91. - no result
added in SDDM --force to the power off: have to shutdown with power button - but computer did not reboot.
I have this problem since june:
Seems to only affect x11, still no idea why it doesn’t work or how to fix it.
What happens if you try shutting down from a Terminal? poweroff should suffice.
It will likely help if you post the results of inxi -zv8. :smiley:
Also note that pacman -Syu is normally recommended, rather than -Syyu. Less taxing on the servers.
shutdown -P from terminal is working.
I have a similar issue. Updating on the most recent unstable broke sddm and after fixing that with systemctl enable --force sddm.service shutting down and logging out is completely broken on Xorg. With Wayland this isn’t happening.
My experience is that SDDM did not break on update, and I can reliably shutdown from the application menu button.
A difference I can see, is that I’m using AMD video card currently, no NVIDIA. Another difference, is that I do not have the secondary confirmation prompt when I click the button in application menu (it directly does the action under the button I click in the menu), I changed that setting.
Same on my systems, that countdown timer is superfluous to my needs … :wink: I have all the options I need directly via the Application Launcher. Just needed to widen it to accommodate all 8 option buttons along the bottom.
Maybe that will help with the above issues.
inxi output:
 ~  inxi -zv8         ✔
  Kernel: 6.10.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.10-x86_64
    root=UUID=eee603a8-c2eb-40b1-9a56-b3c547e4a6e9 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
  Type: Desktop Mobo: Micro-Star model: B450 GAMING PLUS (MS-7B86) v: 1.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: 1.J1 date: 05/15/2023
  System RAM: total: 32 GiB available: 31.26 GiB used: 3.08 GiB (9.9%)
    (unregistered) size: 8 GiB speed: 2667 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: BLS8G4D26BFSBK.8FD serial: <filter>
  Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
  Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
    L3: 64 MiB desc: 4x16 MiB
  Speed (MHz): avg: 2978 high: 4275 min/max: 2200/5256 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4275 2: 4275
    3: 2200 4: 2200 5: 2200 6: 4273 7: 2200 8: 2200 9: 4275 10: 4275 11: 2200
    12: 2200 13: 2200 14: 2200 15: 2200 16: 4275 17: 2200 18: 2200 19: 4275
    20: 4275 21: 2200 22: 2200 23: 2200 24: 4275 bogomips: 205318
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
    xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti] vendor: Micro-Star MSI
    driver: nvidia v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: none off: DP-2,DP-3,HDMI-A-1 empty: DP-1
    bus-ID: 26:00.0 chip-ID: 10de:1e04 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5760x1080 s-dpi: 81 s-size: 1806x343mm (71.10x13.50")
    s-diag: 1838mm (72.37")
  Monitor-1: DP-3 pos: primary,left res: 1920x1080 hz: 60 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  Monitor-2: DP-5 pos: right res: 1920x1080 hz: 60 dpi: 82
  Monitor-3: HDMI-0 pos: center res: 1920x1080 hz: 60 dpi: 82
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 555.58.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2080 Ti/PCIe/SSE2
    memory: 10.74 GiB
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 2080 Ti driver: nvidia v: 555.58.02 device-ID: 10de:1e04
    surfaces: xcb,xlib
  Device-1: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
    bus-ID: 26:00.1 chip-ID: 10de:10f7 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
    bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.10.0-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 3.19 TiB used: 88.34 GiB (2.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
    model: MZVLQ256HBJD-00BH1 size: 238.47 GiB block-size: physical: 512 B
    fw-rev: HPS1NFAV temp: 35.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR013 temp: 31.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 Series
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: AB0Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Chipsbank model: Chipsbnk UDisk
    size: 3.76 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 5.00
    scheme: MBR
  ID-1: / raw-size: 238.17 GiB size: 233.38 GiB (97.99%)
    used: 88.34 GiB (37.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7
    label: N/A uuid: eee603a8-c2eb-40b1-9a56-b3c547e4a6e9
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6 label: N/A
    uuid: 4F53-9ACA
  ID-1: swap-1 type: file size: 1024 MiB used: 0 KiB (0.0%) priority: -2
    file: /home/swapfile
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 2A0C-720D
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 930.65 GiB fs: ntfs
    label: System uuid: E4EA29BFEA298EBC
  ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 770 MiB fs: ntfs label: N/A
    uuid: 7CCA523DCA51F3BC
  ID-5: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
  ID-6: /dev/sda2 maj-min: 8:2 size: 232.87 GiB fs: ntfs label: Gaming
    uuid: B88AA4838AA4402C
  ID-7: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
  ID-8: /dev/sdb2 maj-min: 8:18 size: 1.82 TiB fs: ntfs label: Daten
    uuid: 8A2A172A2A171335
  ID-9: /dev/sdc1 maj-min: 8:33 size: 3.76 GiB fs: ntfs label: Stickgruen
    uuid: 003A40173A400BDA
  Device-1: 1-7:2 info: LogiLink UDisk flash drive type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: abcd:1234 class-ID: 0806
    serial: <filter>
  Device-2: 1-8:3 info: Primax HP USB Multimedia Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 0461:4dd7 class-ID: 0300
  Device-3: 1-9:4 info: Logitech Corded Tilt-Wheel Mouse type: mouse
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 046d:c040 class-ID: 0301
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 35.9 C mobo: N/A gpu: nvidia temp: 43 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 28%
  Packages: pm: pacman pkgs: 1379 libs: 458 tools: pamac pm: flatpak pkgs: 0
    1: https://manjaro.ynh.ovh/unstable/$repo/$arch
    2: https://mirror1.sox.rs/manjaro/unstable/$repo/$arch
    3: https://ask4.mm.fcix.net/manjaro/unstable/$repo/$arch
    4: https://mirror.math.princeton.edu/pub/manjaro/unstable/$repo/$arch
    5: https://codingflyboy.mm.fcix.net/manjaro/unstable/$repo/$arch
Processes:
  CPU top: 5 of 495
  1: cpu: 100% command: ps pid: 2451 mem: 3.46 MiB (0.0%)
  2: cpu: 15.2% command: firefox pid: 1941 mem: 544.7 MiB (1.7%)
  3: cpu: 6.8% command: Xorg pid: 885 mem: 93.9 MiB (0.2%)
  4: cpu: 6.4% command: steamwebhelper pid: 1857 mem: 398.9 MiB (1.2%)
  5: cpu: 5.2% command: plasmashell pid: 1090 mem: 435.6 MiB (1.3%)
  Memory top: 5 of 495
  1: mem: 544.7 MiB (1.7%) command: firefox pid: 1941 cpu: 15.2%
  2: mem: 435.6 MiB (1.3%) command: plasmashell pid: 1090 cpu: 5.2%
  3: mem: 398.9 MiB (1.2%) command: steamwebhelper pid: 1857 cpu: 6.4%
  4: mem: 274.9 MiB (0.8%) command: ./steamwebhelper pid: 1777 cpu: 1.8%
  5: mem: 234.8 MiB (0.7%) command: manjaro-hello started-by: python3
    pid: 1271 cpu: 1.4%
  Processes: 495 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.35
Please edit your post and do not QUOTE the terminal output, but use the CODE button </>, it is unreadable like that.
Sees to be an X11 problem - switched to wayland and shutdown works as expected.
Indeed, it seems Nvidia 555 has various issues on Unstable currently [Unstable Update] July 2024 Edition - #11 by annoying_daniel
