Update to Grub2.12.r260... ==> counts down five to zero - menu stays visible until Desktop
Updating from grub 2.12-3 to grub2.12.r260…
Had to add GRUB_RECORDFAIL_TIMEOUT=5
Counts down to zero;
BUT counter stops at “0” - menu stays visible until desktop is loaded (autologin).
Where should I look?
(Plymouth is disabled and removed)
/etc/default/grub
# GRUB boot loader configuration
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
# 0 führt zu 10s
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet iommu=pt amd_pstate.shared_mem=1 amd_pstate=passive apparmor=1 security=apparmor udev.log_priority=3"
GRUB_CMDLINE_LINUX=""
#GRUB_ENABLE_CRYPTODISK=y
# Set to 'countdown' or 'menu' to change timeout behavior,
# press ESC key to display menu.
# GRUB_TIMEOUT_STYLE=hidden
GRUB_TIMEOUT_STYLE=menu
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
# GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
# GRUB_BACKGROUND="/usr/share/grub/background.png"
GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
# setting 'GRUB_DEFAULT=saved' above.
GRUB_SAVEDEFAULT=true
# Uncomment to disable submenus in boot menu
# GRUB_DISABLE_SUBMENU=y
# GRUB_DISABLE_OS_PROBER=false
# Uncomment to ensure that the root filesystem is mounted read-only so that
# systemd-fsck can run the check automatically. We use 'fsck' by default, which
# needs 'rw' as boot parameter, to avoid delay in boot-time. 'fsck' needs to be
# removed from 'mkinitcpio.conf' to make 'systemd-fsck' work.
# See also Arch-Wiki: https://wiki.archlinux.org/index.php/Fsck#Boot_time_checking
GRUB_ROOT_FS_RO=true
# wegen hook microcode
# GRUB_EARLY_INITRD_LINUX_STOCK=""
I bet on a discrete video card and missing KMS hook in mkinitcpio.conf
is it in unstable only ?
It has been like that for some time now since the patches that forced us to add GRUB_RECORDFAIL_TIMEOUT setting in GRUB config. At least for me it has been multiple weeks I think.
Grub 2.12-3 is o.K. - any other Version since has this issue :smiling_face_with_tear:
EDIT:
what happened to grub-common.service???
Yes i saw in the unstable thread. It is a change/bug introduced a month ago. I just hope it will not reach stable in this form, but then again it should have not reached testing after a month…
Count-Down-Error is solved by GRUB 2.16
But you have to edit /etc/default/grub and insert:
GRUB_DISABLE_BOOTNEXT=true
after: GRUB_DISABLE_OS_PROBER=false
(do not forget: sudo update-grub )
And: to remove message “loading ramdisk”:
Edit /etc/grub.d/10_linux
uncomment two lines:
# echo '$(echo "$message" | grub_quote)'
and
# message="$(gettext_printf "Loading initial ramdisk ...")"
