A recent update concluded with an output: ‘cp: cannot stat ‘/var/lib/mhwd/db/pci/graphic_drivers/nvidia-430xx/MHWDCONFIG’: No such file or directory’.
The computer works normally without any problem. Is there something that I need to do?
The pacman log shows the following:
[2020-03-02T19:17:46+0530] [PACMAN] Running ‘pacman --noconfirm --cachedir /var/cache/pacman/pkg --config /opt/mhwd/pacman-mhwd.conf --root / --needed -Sy xf86-video-ati xf86-video-amdgpu xf86-video-intel xf86-video-nouveau vulkan-intel vulkan-radeon libva-mesa-driver libva-vdpau-driver mesa-vdpau lib32-vulkan-intel lib32-vulkan-radeon lib32-libva-vdpau-driver lib32-mesa-vdpau’
[2020-03-02T19:17:46+0530] [PACMAN] synchronizing package lists
[2020-03-02T19:17:46+0530] [ALPM] transaction started
[2020-03-02T19:17:46+0530] [ALPM] installed xf86-video-ati (1:19.1.0-1)
[2020-03-02T19:17:46+0530] [ALPM] installed xf86-video-amdgpu (19.1.0-1)
[2020-03-02T19:17:46+0530] [ALPM] installed libxvmc (1.0.12-2)
[2020-03-02T19:17:47+0530] [ALPM] installed xf86-video-intel (1:2.99.917+899+gf66d3954-1)
[2020-03-02T19:17:47+0530] [ALPM-SCRIPTLET] >>> This driver now uses DRI3 as the default Direct Rendering
[2020-03-02T19:17:47+0530] [ALPM-SCRIPTLET] Infrastructure. You can try falling back to DRI2 if you run
[2020-03-02T19:17:47+0530] [ALPM-SCRIPTLET] into trouble. To do so, save a file with the following
[2020-03-02T19:17:47+0530] [ALPM-SCRIPTLET] content as /etc/X11/xorg.conf.d/20-intel.conf :
[2020-03-02T19:17:47+0530] [ALPM-SCRIPTLET] Section “Device”
[2020-03-02T19:17:47+0530] [ALPM-SCRIPTLET] Identifier “Intel Graphics”
[2020-03-02T19:17:47+0530] [ALPM-SCRIPTLET] Driver “intel”
[2020-03-02T19:17:47+0530] [ALPM-SCRIPTLET] Option “DRI” “2” # DRI3 is now default
[2020-03-02T19:17:47+0530] [ALPM-SCRIPTLET] #Option “AccelMethod” “sna” # default
[2020-03-02T19:17:47+0530] [ALPM-SCRIPTLET] #Option “AccelMethod” “uxa” # fallback
[2020-03-02T19:17:47+0530] [ALPM-SCRIPTLET] EndSection
[2020-03-02T19:17:47+0530] [ALPM] installed xf86-video-nouveau (1.0.16-1)
[2020-03-02T19:17:47+0530] [ALPM] installed vulkan-intel (19.3.4-2)
[2020-03-02T19:17:47+0530] [ALPM] installed vulkan-radeon (19.3.4-2)
[2020-03-02T19:17:47+0530] [ALPM] installed libva-mesa-driver (19.3.4-2)
[2020-03-02T19:17:47+0530] [ALPM] installed libva-vdpau-driver (0.7.4-4)
[2020-03-02T19:17:47+0530] [ALPM] installed mesa-vdpau (19.3.4-2)
[2020-03-02T19:17:47+0530] [ALPM] installed lib32-vulkan-intel (19.3.4-3)
[2020-03-02T19:17:47+0530] [ALPM] installed lib32-vulkan-radeon (19.3.4-3)
[2020-03-02T19:17:47+0530] [ALPM] installed lib32-libva (2.6.0-1)
[2020-03-02T19:17:47+0530] [ALPM] installed lib32-libvdpau (1.3-1)
[2020-03-02T19:17:47+0530] [ALPM] installed lib32-libva-vdpau-driver (0.7.4-6)
[2020-03-02T19:17:47+0530] [ALPM] installed lib32-mesa-vdpau (19.3.4-3)
[2020-03-02T19:18:00+0530] [ALPM] transaction completed
[2020-03-02T19:18:00+0530] [ALPM] running ‘30-systemd-update.hook’…
[2020-03-02T19:18:39+0530] [PACMAN] Running ‘pacman -Syy’
