Update killed system sounds on manjaro cinnamon
just did an update today October 28 2026. everything updated well but everything is not well. my system sounds are gone! i don't know where to start.
manjaro cinnamon. anything else needed please ask. everything worked well before update. thought i’d ask you who know a lot more than me . sigh
I think I might know why… :face_with_peeking_eye:
Look for an updated cinnamon-sounds 1:1.9.4-2 package once I resolve the issue.
i cannot find such a package. where are you finding this “cinnamon-sounds 1:1.9.4-2”?
I just pushed it to all branches just now–hence why I said look for it once I’ve resolved the issue in future tense. :wink:
just to confirm; this is only for system sounds i don’t have. sounds in general are working. i can play music. i have sound youtube, etc. but no SYSTEM sounds. i used to have login and logout. and other sounds.. now, no!
Yes, I’m aware. I realized what caused the problem, so I fixed the issue and verified the system sounds are working again in a Manjaro Cinnamon VM.
do you have a link to that fix? i guess i need better glasses lol
You currently have cinnamon-sounds 1:1.9.4-1 installed. Once your mirrors sync, the next time you update you will receive cinnamon-sounds 1:1.9.4-2.
ok i found the update. updated and still no system sounds :frowning: … where do i go from here?
Try logging out and logging back in again.
i did. i’ll do it again
no joy. im stumped … where is this cinnamon-sounds file located?
It’s a package, not a file.
What’s the output of:
pacman -Qi cinnamon-sounds
Version         : 1:1.9.4-2
Description     : Linux Mint sounds for the Cinnamon desktop.
Architecture    : any
URL             : https://www.linuxmint.com
Licenses        : GPL-3.0-or-later
Groups          : None
Provides        : None
Depends On      : cinnamon
Optional Deps   : None
Required By     : None
Optional For    : manjaro-cinnamon-settings
Conflicts With  : None
Replaces        : None
Installed Size  : 1845.03 KiB
Packager        : Mark Wagie <mark@manjaro.org>
Build Date      : Wed 28 Oct 2026 05:07:05 PM CDT
Install Date    : Wed 28 Oct 2026 05:34:35 PM CDT
Install Reason  : Explicitly installed
Install Script  : No
Validated By    : Signature
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Have you rebooted since the Stable Update earlier? There were kernel and grub updates, so you should anyway.
Either way, you can also check System Settings > Hardware > Sound > Sounds tab (or just search for Sounds in the menu) and review what sounds you have set; i.e., login.oga for Login and logout.ogg for Logout.
Note that I added formatting to your reply above, see my note at the bottom.
ok i fixed the fix. i went into sound settings. clicked on “sounds” and reset each of the sound files. it works now… thank you so much Yochanan! :slight_smile:
