i have an issue where this package is causing an issue with the update.
i have tried removing each package, but it just won’t remove them.
this is not the same machine from my other post.
can someone point me in the right direction?
Before doing your update, you should first remove the 3 packages via the CLI:
sudo pacman -Rns lib32-dav1d lib32-libavif lib32-imlib2
You should then be able to do your update.
If you cannot remove those packages via the CLI, please post the output from the terminal.
hmmmm…
❯ sudo pacman -Rns lib32-dav1d lib32-libavif lib32-imlib2
[sudo] password for Aeryn :
error: target not found: lib32-dav1d
error: target not found: lib32-libavif
lol, this update has been a wild one for me.
Try sudo pacman -Rns lib32-imlib2
[sudo] password for Aeryn:
checking dependencies…
:: removing lib32-imlib2 breaks dependency ‘lib32-imlib2’ required by lib32-libcaca
Ok, lets have a look at the reverse dependency tree.
# make sure pactree is installed
sudo pacman -S pacman-contrib
pactree -r lib32-imlib2
Alternatively you could just keep working your way through the errors until you’ve found the root cause.
sudo pacman -Rns lib32-libcaca
\[sudo\] password for Aeryn:
resolving dependencies...
Packages (1) pacman-contrib-1.13.1-2
Total Download Size: 0.05 MiB
Total Installed Size: 0.12 MiB
:: Proceed with installation? \[Y/n\] y
:: Retrieving packages...
pacman-contrib-1.13.1-2-x86_64 53.8 KiB 277 KiB/s 00:00 \[####################################\] 100%
(1/1) checking keys in keyring \[####################################\] 100%
(1/1) checking package integrity \[####################################\] 100%
(1/1) loading package files \[####################################\] 100%
(1/1) checking for file conflicts \[####################################\] 100%
(1/1) checking available disk space \[####################################\] 100%
(1/1) installing pacman-contrib \[####################################\] 100%
removed '/usr/share/man/man8/rankmirrors.8.gz'
'/usr/share/man/man8/rankmirrors.8.gz' -> '/usr/share/man/man8/pacman-mirrors.8.gz'
Optional dependencies for pacman-contrib
diffutils: for pacdiff \[installed\]
fakeroot: for checkupdates \[installed\]
findutils: for pacdiff --find \[installed\]
mlocate: for pacdiff --locate
plocate: faster mlocate alternative
perl: for pacsearch \[installed\]
sudo: privilege elevation for several scripts \[installed\]
vim: default diff program for pacdiff \[installed\]
neovim: default diff program for pacdiff if EDITOR=nvim
(1/2) Reloading system manager configuration...
(2/2) Arming ConditionNeedsUpdate...
❯ pactree -r lib32-imlib2
zsh: correct 'pactree' to 'abctree' \[nyae\]? n
lib32-imlib2
└─lib32-libcaca
└─steam-native-runtime
Mod Edit: Fixed formatting
Ok so remove steam-native-runtime then update and if necessary reinstall steam-native-runtime.
sudo pacman -Rns steam-native-runtime
sudo pacman -Syu
i think i’ll try removing steam. i can always reinstall it afterwards.
lol, i was just writing this as you posted, will let you know.
that did work, thank you for your help!!
I am pretty sure steam recently received an update to finally be 64 bit so that 32 bit duplication nightmare stops. Literally nothing else needs 32bit anymore. So hopefully it is the last time it happens and next time you could remove all 32 subsystem.
Indeed steam-native-runtime now requires libcaca instead of lib32-libcaca, so none of those packages will be pulled in again.
Of course the user will have to uninstall the now orphaned lib32 everything. That will work, unless something else from the aur requires them (and here starts the discussion about branches, aur usage and orphans…;))
FYI, steam-native-runtime is no longer helpful since Steam mostly relies on it’s included runtimes, that’s why it was dropped from the repos to the AUR. Install steam instead.
Well the packages mentioned in this thread are already gone, but they might have others. ![]()
