Update issues, and trouble with lib32-glib2
Hi team -
Usually my updates go without issue but not today.
I’m running kernel 6.12.12-2-MANJARO with plasma 6.2.5
Earlier I saw the posting re: community.db and took care of that, but I wonder if I went too far, since I see (below) there are “no servers configured for repository”. does that look right?
Also, of course, there’s the lib32.glib2 errors.
Your thoughts welcome.
Preparing...
Failed to synchronize databases
Warning: installing libffi (3.4.7-1) breaks dependency 'libffi=3.4.6' required by lib32-libffi
Add lib32-libffi to remove
Warning: installing pcre2 (10.45-1) breaks dependency 'pcre2=10.44' required by lib32-pcre2
Add lib32-pcre2 to remove
Failed to prepare transaction:
could not satisfy dependencies:
- removing lib32-libffi breaks dependency 'lib32-libffi' required by lib32-glib2
- removing lib32-pcre2 breaks dependency 'lib32-pcre2' required by lib32-glib2
- removing lib32-libffi breaks dependency 'libffi.so=8-32' required by lib32-glib2
Resolving dependencies...
Checking inter-conflicts...
As a first step I’d suggest updating your mirrors. I normally use
sudo pacman-mirrors --geoip
but you prefer to specify a location or search for the fastest.
Edited: If you edited pacman.conf you may want to share your current file to allow people to check if it looks sensible.
Good success recently with this one:
sudo pacman-mirrors --continent && sudo pacman -Syu
–geoip only pulls in a single mirror for me… but as always YMMV :wink:
For me it pulls in 3, but as always people should pay attention to the results of any command they are given to run!
Thanks for the really fast replies.
I’ve updated the mirrors re-ran the update (below). The pacman.conf is shown below this:
sudo pamac update
Warning: Building packages as dynamic user
Warning: Setting build directory to /var/cache/pamac
Preparing...
Failed to synchronize AUR database
Error: Failed to prepare transaction:
rsv2@reid-galagopro:~$
rsv2@reid-galagopro:~$ more /etc/pacman.conf
# /etc/pacman.conf
# See the pacman.conf(5) manpage for option and repository directives
# GENERAL OPTIONS
[options]
# The following paths are commented out with their default values listed.
# If you wish to use different paths, uncomment and update the paths.
#RootDir     = /
#DBPath      = /var/lib/pacman/
CacheDir = /var/cache/pacman/pkg/
#LogFile     = /var/log/pacman.log
#GPGDir      = /etc/pacman.d/gnupg/
#HookDir     = /etc/pacman.d/hooks/
HoldPkg      = pacman glibc manjaro-system
#XferCommand = /usr/bin/curl -L -C - -f -o %o %u
#XferCommand = /usr/bin/wget --passive-ftp -c -O %o %u
#CleanMethod = KeepInstalled
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
# We cannot check disk space from within a chroot environment
CheckSpace
#VerbosePkgLists
#ParallelDownloads = 5
# By default, pacman accepts packages signed by keys that its local keyring
# trusts (see pacman-key and its man page), as well as unsigned packages.
SigLevel    = Required DatabaseOptional
LocalFileSigLevel = Optional
#RemoteFileSigLevel = Required
# NOTE: You must run `pacman-key --init` before first using pacman; the local
# keyring can then be populated with the keys of all official Manjaro Linux
# packagers with `pacman-key --populate archlinux manjaro`.
# REPOSITORIES
#   - can be defined here or included from another file
#   - pacman will search repositories in the order defined here
#   - local/custom mirrors can be added here or in separate files
#   - repositories listed first will take precedence when packages
#     have identical names, regardless of version number
#   - URLs will have $repo replaced by the name of the current repo
#   - URLs will have $arch replaced by the name of the architecture
# Repository entries are of the format:
#       [repo-name]
#       Server = ServerName
#       Include = IncludePath
# The header [repo-name] is crucial - it must be present and
# uncommented to enable the repo.
# The testing repositories are disabled by default. To enable, uncomment the
# repo name header and Include lines. You can add preferred servers immediately
# after the header, and they will be used before the default mirrors.
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
# REPOSITORIES
#       [repo-name]
[core]
SigLevel = PackageRequired
Include = /etc/pacman.d/mirrorlist
[extra]
[community]
# If you want to run 32 bit applications on your x86_64 system,
# enable the multilib repositories as required here.
[multilib]
# An example of a custom package repository.  See the pacman manpage for
# tips on creating your own repositories.
#[custom]
#SigLevel = Optional TrustAll
#Server = file:///home/custompkgs
Same problem for me.
Delete this line too.
Ah…that’s the ticket… updating now.
many thank Everyone!!
I’m no expert but you have two sections called [option] which is confusing. To me they look identical so you can probably safely delete one of them, leaving you with something like
# /etc/pacman.conf
# GENERAL OPTIONS
[options]
#RootDir     = /
#UseDelta    = 0.7
Architecture = auto
#IgnorePkg   =
#IgnorePkg   =
#IgnoreGroup =
#NoUpgrade   =
#NoExtract   =
# Misc options
#UseSyslog
#Color
#NoProgressBar
CheckSpace
#VerbosePkgLists
# REPOSITORIES
#       [repo-name]
[core]
[extra]
[multilib]
#[custom]
Of course, you’ll want to keep your current file backed-up in case I am making things worse!
Ok -… I will certainly look at that. Always open to learning.
Of course, I am amazingly good at making things worse, so will try to be careful.
made the change. Saved it and updated. All good.
thx again
