This set of updates today causes an infinite loop of Software Update progress bar moving back & forth & flashing something like wxbase-light-dependencies - it flashes so fast i cant read it, but it continues over & over & never ends.
I rebooted a few times & tried again, but the same result.
pamac update reports ‘checking’ for a long list of items & gets to a point where it starts going crazy with wxbase, which seems like it may continue forever. Terminal seems stuck & I cant q or esc. So I have to close window.
I am sorry I am unable to post the output because the terminal window becomes unusable.
According to software update wxcommon & wxbase-light are not installed.??
Not entirely sure, but I found wxgtk2 & wxgtk-common are required by woeusb-gui
Searching pamac installed for ‘wx’ these are the only 2 that show up.
After reading the other thread AUR - please restrain yourself (& being a semi-professional idiot) ; I realise this is probably my own carelessness.
I must have enabled AUR at some point to browse or acquire a certain software & then left it enabled, so I may have since inadvertently installed AUR software without noticing.
Although I was aware of the AUR risk at the time, i since forgot it was enabled.
