Ok, I had an OpenShot video editor flatpak update this morning, and I followed the instructions you posted there. I run the pamac manager with debug as explained here.
There were no errors, and the run went ok, but the log is almost unreadable due to the prompt thingies… Anyway, I have it if needed, in txt.gz format, that seems I can’t upload here.
I tried again in a dumb terminal… and it’s a bit better, but no error again:
bash log of pamac with gdb
Script started on 2024-09-08 18:07:18+02:00 [TERM="xterm" TTY="/dev/pts/4" COLUMNS="142" LINES="41"]
e[1me[7m%e[27me[1me[0m
e]2;romano@ramoth:~/tmpae]1;~/tmpae]7;file://ramoth/home/romano/tmpa
e[0me[27me[24me[Je[0me[49me[39me[0me[49me[34me[34m~e[0me[34me[49me[34m/e[34mtmpe[0me[34me[49me[34me[0me[34me[49me[34me[0me[34me[49m e[0me[34me[49me[32m>e[0me[32me[49me[32me[0me[32me[49me[30me[0me[30me[49me[39m e[0me[49me[39me[Ke[133Ce[0me[49me[39me[133De[?2004hgdb -q --args pamac-managere[27De[32mge[32mde[32mbe[39me[24Ce[?2004l
e]2;gdb -q --args pamac-managerae]1;aReading symbols from e[32mpamac-managere[m...
Reading symbols from e[32m/usr/lib/debug/usr/bin/pamac-manager.debuge[m...
e[?2004h(gdb) run
e[?2004l
Starting program: e[32m/usr/bin/pamac-managere[m
This GDB supports auto-downloading debuginfo from the following URLs:
<e[32mhttps://debuginfod.archlinux.orge[m>
e[?2004hEnable debuginfod for this session? (y or [n]) y
e[?2004l
Debuginfod has been enabled.
To make this setting permanent, add 'set debuginfod enabled on' to .gdbinit.
Downloading separate debug info for e[32msystem-supplied DSO at 0x7ffff7fc5000e[m
Downloading separate debug info for e[32m/usr/lib/libgio-2.0.so.0e[m
Downloading separate debug info for e[32m/usr/lib/libglib-2.0.so.0e[m
Downloading separate debug info for e[32m/usr/lib/libgobject-2.0.so.0e[m
[Thread debugging using libthread_db enabled]
Using host libthread_db library "e[32m/usr/lib/libthread_db.so.1e[m".
Downloading separate debug info for e[32m/usr/lib/libgmodule-2.0.so.0e[m
Downloading separate debug info for e[32m/usr/lib/libcairo.so.2e[m
Downloading separate debug info for e[32m/usr/lib/libcairo-gobject.so.2e[m
Downloading separate debug info for e[32m/usr/lib/libXi.so.6e[m
Downloading separate debug info for e[32m/usr/lib/libvulkan.so.1e[m
Downloading separate debug info for e[32m/usr/lib/libtiff.so.6e[m
Downloading separate debug info for e[32m/usr/lib/libcairo-script-interpreter.so.2e[m
Downloading separate debug info for e[32m/usr/lib/libalpm.so.14e[m
Downloading separate debug info for e[32m/usr/lib/libsoup-3.0.so.0e[m
Downloading separate debug info for e[32m/usr/lib/libexpat.so.1e[m
Downloading separate debug info for e[32m/usr/lib/libjson-glib-1.0.so.0e[m
Downloading separate debug info for e[32m/usr/lib/libsystemd.so.0e[m
Downloading separate debug info for e[32m/usr/lib/libcrypto.so.3e[m
Downloading separate debug info for e[32m/usr/lib/libnghttp2.so.14e[m
Downloading separate debug info for e[32m/usr/lib/libnghttp3.so.9e[m
Downloading separate debug info for e[32m/usr/lib/libssl.so.3e[m
[New Thread 0x7ffff25ff6c0 (LWP 11695)]
[New Thread 0x7fffebfff6c0 (LWP 11696)]
[New Thread 0x7ffff1dfe6c0 (LWP 11697)]
Downloading separate debug info for e[32m/usr/lib/libsnapd-glib-2.so.1e[m
Downloading separate debug info for e[32m/usr/lib/libostree-1.so.1e[m
[Detaching after fork from child process 11699]
[Detaching after fork from child process 11700]
[New Thread 0x7ffff13816c0 (LWP 11701)]
[New Thread 0x7ffff0b806c0 (LWP 11702)]
[New Thread 0x7fffeb7fe6c0 (LWP 11703)]
[New Thread 0x7fffeabff6c0 (LWP 11704)]
[New Thread 0x7fffe95fb6c0 (LWP 11705)]
[New Thread 0x7fffe9fff6c0 (LWP 11706)]
[Thread 0x7fffeb7fe6c0 (LWP 11703) exited]
[Thread 0x7ffff13816c0 (LWP 11701) exited]
[New Thread 0x7ffff13816c0 (LWP 11708)]
[New Thread 0x7fffeb7fe6c0 (LWP 11709)]
[Thread 0x7ffff13816c0 (LWP 11708) exited]
[New Thread 0x7ffff13816c0 (LWP 11710)]
[Thread 0x7ffff13816c0 (LWP 11710) exited]
[New Thread 0x7fffe8dfa6c0 (LWP 11711)]
[New Thread 0x7ffff13816c0 (LWP 11712)]
[New Thread 0x7fffcb9ff6c0 (LWP 11713)]
[New Thread 0x7fffcb1fe6c0 (LWP 11714)]
Downloading separate debug info for e[32m/usr/lib/libEGL_mesa.so.0e[m
Downloading separate debug info for e[32m/usr/lib/libgbm.so.1e[m
Downloading separate debug info for e[32m/usr/lib/libglapi.so.0e[m
Downloading separate debug info for e[32m/usr/lib/libdrm.so.2e[m
Downloading separate debug info for e[32m/usr/lib/dri/radeonsi_dri.soe[m
Downloading separate debug info for e[32m/usr/lib/libdrm_radeon.so.1e[m
Downloading separate debug info for e[32m/usr/lib/libdrm_amdgpu.so.1e[m
Downloading separate debug info for e[32m/usr/lib/libdrm_intel.so.1e[m
[Thread 0x7fffcb1fe6c0 (LWP 11714) exited]
[Thread 0x7fffcb9ff6c0 (LWP 11713) exited]
[Thread 0x7ffff13816c0 (LWP 11712) exited]
[Thread 0x7fffe8dfa6c0 (LWP 11711) exited]
[Thread 0x7fffeb7fe6c0 (LWP 11709) exited]
[Thread 0x7ffff0b806c0 (LWP 11702) exited]
[New Thread 0x7ffff0b806c0 (LWP 11715)]
[New Thread 0x7fffcb1fe6c0 (LWP 11716)]
[New Thread 0x7fffe8dfa6c0 (LWP 11717)]
[New Thread 0x7fffcb9ff6c0 (LWP 11718)]
[New Thread 0x7fffc3fff6c0 (LWP 11719)]
[New Thread 0x7fffc37fe6c0 (LWP 11720)]
[New Thread 0x7fffc2ffd6c0 (LWP 11721)]
[New Thread 0x7fffc27fc6c0 (LWP 11722)]
[New Thread 0x7fffc1ffb6c0 (LWP 11723)]
[New Thread 0x7fffc17fa6c0 (LWP 11724)]
[New Thread 0x7fffc0ff96c0 (LWP 11725)]
[New Thread 0x7fffc07f86c0 (LWP 11726)]
[New Thread 0x7fffbf1f76c0 (LWP 11727)]
[New Thread 0x7fffbe9f66c0 (LWP 11737)]
[New Thread 0x7fffbe1f56c0 (LWP 11738)]
[New Thread 0x7fffbd9f46c0 (LWP 11739)]
[Thread 0x7fffbd9f46c0 (LWP 11739) exited]
[Thread 0x7fffbe9f66c0 (LWP 11737) exited]
[Thread 0x7fffbe1f56c0 (LWP 11738) exited]
[New Thread 0x7fffbe1f56c0 (LWP 11741)]
Downloading separate debug info for e[32m/usr/lib/libnss_mymachines.so.2e[m
Downloading separate debug info for e[32m/usr/lib/libnss_resolve.so.2e[m
Downloading separate debug info for e[32m/usr/lib/libnss_myhostname.so.2e[m
[New Thread 0x7fffbe9f66c0 (LWP 11742)]
[Thread 0x7fffbe1f56c0 (LWP 11741) exited]
[Thread 0x7fffbe9f66c0 (LWP 11742) exited]
[New Thread 0x7fffbe9f66c0 (LWP 11758)]
[Detaching after fork from child process 11759]
[Detaching after fork from child process 11760]
[Detaching after fork from child process 11761]
[Detaching after fork from child process 11762]
[New Thread 0x7fffbe1f56c0 (LWP 11763)]
[Thread 0x7fffbe1f56c0 (LWP 11763) exited]
[Detaching after fork from child process 11764]
[Detaching after fork from child process 11766]
[Detaching after fork from child process 11768]
[Detaching after fork from child process 11770]
[Detaching after fork from child process 11772]
[Detaching after fork from child process 11774]
[Detaching after fork from child process 11776]
[Thread 0x7fffbe9f66c0 (LWP 11758) exited]
[Thread 0x7fffe9fff6c0 (LWP 11706) exited]
[Thread 0x7fffc07f86c0 (LWP 11726) exited]
[Thread 0x7fffc0ff96c0 (LWP 11725) exited]
[Thread 0x7fffc17fa6c0 (LWP 11724) exited]
[New Thread 0x7fffc17fa6c0 (LWP 11850)]
[Thread 0x7fffc1ffb6c0 (LWP 11723) exited]
[Thread 0x7fffc27fc6c0 (LWP 11722) exited]
[Thread 0x7fffc2ffd6c0 (LWP 11721) exited]
[Thread 0x7fffc37fe6c0 (LWP 11720) exited]
[Thread 0x7fffc3fff6c0 (LWP 11719) exited]
[Thread 0x7fffcb9ff6c0 (LWP 11718) exited]
[Thread 0x7fffe8dfa6c0 (LWP 11717) exited]
[Thread 0x7fffbf1f76c0 (LWP 11727) exited]
[Thread 0x7fffcb1fe6c0 (LWP 11716) exited]
[Thread 0x7ffff0b806c0 (LWP 11715) exited]
[Thread 0x7fffe95fb6c0 (LWP 11705) exited]
[Thread 0x7fffeabff6c0 (LWP 11704) exited]
[Thread 0x7ffff1dfe6c0 (LWP 11697) exited]
[Thread 0x7fffebfff6c0 (LWP 11696) exited]
[Thread 0x7ffff25ff6c0 (LWP 11695) exited]
[Thread 0x7ffff47cce40 (LWP 11637) exited]
[Thread 0x7fffc17fa6c0 (LWP 11850) exited]
[New process 11637]
[Inferior 1 (process 11637) exited normally]
e[?2004he[?2004l
e[?2004h(gdb) exit
e[?2004l
e[0me[27me[24me[Je[0me[49me[39me[0me[49me[34me[34m~e[0me[34me[49me[34m/e[34mtmpe[0me[34me[49me[34me[0me[34me[49me[34me[0me[34me[49m e[0me[34me[49me[32m>e[0me[32me[49me[32me[0me[32me[49me[30me[0me[30me[49me[39m e[0me[49me[39me[Ke[127Ce[0me[49me[33m1m 39se[0me[33me[49me[33me[0me[33me[49me[33me[0me[33me[49me[39me[133De[?2004he[?2004l
e[0me[27me[24me[Je[0me[49me[39me[0me[49me[34me[34m~e[0me[34me[49me[34m/e[34mtmpe[0me[34me[49me[34me[0me[34me[49me[34me[0me[34me[49m e[0me[34me[49me[32m>e[0me[32me[49me[32me[0me[32me[49me[30me[0me[30me[49me[39m e[0me[49me[39me[Ke[133Ce[0me[49me[39me[133De[?2004hle[1me[31mle[0me[39me[1me[31mle[0me[39me[1me[30mse[0me[39me[1me[31mle[1me[31mse[0me[39me[0me[32mle[0me[32mse[39me[?2004l
e]2;ls --color=autoae]1;aCVcomillas.docx lalla.pdf lilla.log lulla.fls OLD_PIP_pkgs.txt whichcompiler.fdb_latexmk wow.log
e[0me[01;31mildulin.ps.gze[0m e[01;31mlalla.synctex.gze[0m lilla.pdf lulla.log pacman-2.txt whichcompiler.fls wow.pdf
lalla.aux lalla.tex e[01;31mlilla.synctex.gze[0m lulla.pdf e[01;31mpamac.txt.gze[0m whichcompiler.log wow.tex
lalla.fdb_latexmk lilla.aux lilla.tex e[01;31mlulla.synctex.gze[0m test2.csv whichcompiler.pdf
lalla.fls lilla.fdb_latexmk lulla.aux lulla.tex test.csv e[01;31mwhichcompiler.synctex.gze[0m
lalla.log lilla.fls lulla.fdb_latexmk OLD_AUR_pkgs.txt whichcompiler.aux wow.aux
e[0me[27me[24me[Je[0me[49me[39me[0me[49me[34me[34m~e[0me[34me[49me[34m/e[34mtmpe[0me[34me[49me[34me[0me[34me[49me[34me[0me[34me[49m e[0me[34me[49me[32m>e[0me[32me[49me[32me[0me[32me[49me[30me[0me[30me[49me[39m e[0me[49me[39me[Ke[133Ce[0me[49me[39me[133De[?2004hle[1me[31mle[0me[39me[1me[31mle[0me[39me[1me[30mse[0me[39me[1me[31mle[1me[31mee[0me[39me[1me[30mss teaching.clse[0me[39me[15De[1me[31mle[1me[31mee[1me[31mse[0me[39me[1me[31mse[1me[31mse[0me[39me[0me[32mle[0me[32mee[0me[32mse[0me[32mse[39me[32mse[0me[32m e[39me[32mse[39me[39m e[0me[39mpe[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[11De[4mpe[24me[1me[30mgflibraryarrows.meta.code.texe[0me[39me[29De[4mpe[0me[39me[4mae[24me[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[0me[39m e[28De[1me[30msswd.pacnewe[0me[39me[11De[4mae[0me[39me[4mce[0me[39me[4mme[0me[39me[4mae[0me[39me[4mne[0me[39me[4m-e[0me[39me[4m2e[0me[39me[4m.e[0me[39me[4mte[0me[39me[4mxe[0me[39me[4mte[24me[0me[39m
e[Je[7mpacman-2.txte[0m e[Je[01;31mpamac.txt.gze[0me[Je[Ae[0me[27me[24me[0me[39me[49m
e[8Ce[32mlesse[39m e[4mpacman-2.txte[24me[Ke[116Ce[0me[49me[39me[0me[39me[49me[116D
e[Je[Ae[25Ce[1m e[0me[0m e[?2004l
e[Je]2;less pacman-2.txtae]1;ae[?1he=
Script started on 2024-09-08 18:07:18+02:00 [TERM="xterm" TTY="/dev/pts/4" COLUMNS="142" LINES="41"]e[m
e[1me[7m%e[27me[1me[0m e[m e[1me[7me[27me[1me[0me[01;47;34m^Me[0m e[01;47;34m^Me[0momano@ramoth:~/tmpe[01;47;34m^Ge[0m/tmpe[01;47;34m^Ge[0mile://ramoth/home/romano/tmpe[01;47;34m^G^Me[0me[0me[27me[24me[0me[49me[39me[0me[49me[34me[34m~e[0me[34me[49me[34m/e[34mtmpe[0me[34me[49me[34me[0me[34me[49me[34me[0me[34me[49m e[0me[34me[49me[32m>e[0me[32me[49me[32me[0me[32me[49me[30me[0me[30me[49me[39m e[0me[49me[39me[0me[49me[39mgdb -q --args pamac-managere[32mge[32mde[32mbe[39me[m
db -q --args pamac-managere[01;47;34m^Ge[0mReading symbols from e[32mpamac-managere[m...e[m
Reading symbols from e[32m/usr/lib/debug/usr/bin/pamac-manager.debuge[m...e[m
(gdb) rune[m
e[01;47;34m^Me[0mStarting program: e[32m/usr/bin/pamac-managere[m e[m
e[m
This GDB supports auto-downloading debuginfo from the following URLs:e[m
<e[32mhttps://debuginfod.archlinux.orge[m>e[m
Enable debuginfod for this session? (y or [n]) ye[m
e[01;47;34m^Me[0mDebuginfod has been enabled.e[m
To make this setting permanent, add 'set debuginfod enabled on' to .gdbinit.e[m
Downloading separate debug info for e[32msystem-supplied DSO at 0x7ffff7fc5000e[me[m
e[01;47;34m^Me[0m[### ]e[m e[01;47;34m^Me[0m e[m e[01;47;34m^Me[0mDownloading separate debug info for e[32m/usr/lib/libgio-2.0.so.0e[me[m
e[01;47;34m^Me[0m[### ]e[m e[01;47;34m^Me[0m e[m e[01;47;34m^Me[0mDownloading separate debug info for e[32m/usr/lib/libglib-2.0.so.0e[me[m
e[01;47;34m^Me[0m[### ]e[m e[01;47;34m^Me[0m e[m e[01;47;34m^Me[0mDownloading separate debug info for e[32m/usr/lib/libgobject-2.0.so.0e[me[m
e[01;47;34m^Me[0m[### ]e[m e[01;47;34m^Me[0m e[m e[01;47;34m^Me[0m[Thread debugging using libthread_db enabled]e[m
Using host libthread_db library "e[32m/usr/lib/libthread_db.so.1e[m".e[m
Downloading separate debug info for e[32m/usr/lib/libgmodule-2.0.so.0e[me[m
e[01;47;34m^Me[0m[### ]e[m e[01;47;34m^Me[0m e[m e[01;47;34m^Me[0mDownloading separate debug info for e[32m/usr/lib/libcairo.so.2e[me[m
Again, the icon is still red and it still indicates the need of an update,
but the update seems done:
flatpak list | grep -i openshot 1|1 ✘
OpenShot Video Editor org.openshot.OpenShot 3.2.1 stable flathub system
Although issuing sudo flatpak update by hand gives another story:
sudo flatpak update summary
sudo flatpak update 1 ✘ 3s
Looking for updates…
Info: runtime org.kde.Platform branch 6.4 is end-of-life, with reason:
We strongly recommend moving to the latest stable version of the Plaform and SDK
Info: runtime org.kde.Platform branch 5.15-21.08 is end-of-life, with reason:
We strongly recommend moving to the latest stable version of the Platform and SDK
Info: runtime org.kde.Platform branch 5.15 is end-of-life, with reason:
Info: applications using this runtime:
org.adi.Scopy
Info: runtime org.gnome.Platform branch 44 is end-of-life, with reason:
The GNOME 44 runtime is no longer supported as of March 20, 2024. Please ask your application developer to migrate to a supported platform.
Info: runtime org.gnome.Platform branch 43 is end-of-life, with reason:
The GNOME 43 runtime is no longer supported as of September 20, 2023. Please ask your application developer to migrate to a supported platform.
Info: runtime org.gnome.Platform branch 42 is end-of-life, with reason:
The GNOME 42 runtime is no longer supported as of March 21, 2023. Please ask your application developer to migrate to a supported platform.
Info: runtime org.freedesktop.Platform.GL.default branch 21.08 is end-of-life, with reason:
org.freedesktop.Platform 21.08 is no longer receiving fixes and security updates. Please update to a supported runtime version.
Info: runtime org.freedesktop.Platform.GL.default branch 20.08 is end-of-life, with reason:
org.freedesktop.Platform 20.08 is no longer receiving fixes and security updates. Please update to a supported runtime version.
Info: applications using this extension:
org.adi.Scopy
ID Branch Op Remote Download
1. org.kde.PlatformTheme.QGnomePlatform 5.15-21.08 i flathub < 10.6 MB
2. org.kde.PlatformTheme.QGnomePlatform 5.15-23.08 i flathub < 10.6 MB
3. org.kde.PlatformTheme.QGnomePlatform 6.4 i flathub < 9.6 MB
4. org.kde.PlatformTheme.QGnomePlatform 6.6 i flathub < 9.7 MB
5. org.kde.PlatformTheme.QtSNI 5.15-21.08 i flathub < 1.3 MB
6. org.kde.WaylandDecoration.QAdwaitaDecorations 5.15-23.08 i flathub < 956.6 kB
7. org.kde.WaylandDecoration.QAdwaitaDecorations 6.6 i flathub < 1.2 MB
8. org.kde.WaylandDecoration.QAdwaitaDecorations 6.7 i flathub < 1.2 MB
9. org.kde.WaylandDecoration.QGnomePlatform-decoration 5.15-21.08 i flathub < 11.1 MB
10. org.kde.WaylandDecoration.QGnomePlatform-decoration 5.15-23.08 i flathub < 11.1 MB
11. org.kde.WaylandDecoration.QGnomePlatform-decoration 6.4 i flathub < 10.2 MB
12. org.freedesktop.Platform.GL.default 21.08 r
13. org.gnome.Platform.Locale 42 r
14. org.gnome.Platform.Locale 43 r
15. org.gnome.Platform.Locale 44 r
16. org.gnome.Platform 42 r
17. org.gnome.Platform 43 r
18. org.gnome.Platform 44 r
19. org.kde.Platform.Locale 5.15-21.08 r
20. org.kde.Platform.Locale 6.4 r
21. org.kde.Platform 5.15-21.08 r
22. org.kde.Platform 6.4 r
Proceed with these changes to the system installation? [Y/n]:
answering yes it works, but the red icons keeps saying that I have to update openshot…
