Hi,
I have a weird issue with a new Samsung SSD on a throwaway Lenovo laptop.
On a warm reboot, the Samsung SSD is not recognized in the BIOS and the OS does not boot.
(cold boot works every time though)
Wanted to see if updating the Samsung SSD firmware would fix the above issue.
Would it be possible to update Samsung SSD firmware on Manjaro KDE Linux?
It’s a Samsung 870 EVO 500GB SSD…
Let me know, thanks!
Jesse
You may want to try fwupd and since you’re using KDE, you would use Discover.
https://fwupd.org/lvfs/docs/users
Or fwupd in the terminal.
https://wiki.archlinux.org/title/fwupd
You can download the SSD firmware on this side:
Download Samsung Magician, tools & software for Samsung SSDs, Data Migration Software, Firmware, Driver, Data Center Toolkit, Activation Software.
Hi,
Thanks for the help.
I installed KDE “Discover” application, but don’t know how to proceed.
Jesse
Hi,
as far I can see, update of Samsung SSDs is not supported by fwupd.
I also have several Samsung SSDs and I can’t update them with fwupd.
Please check the link provided by @Keruskerfuerst in previous post.
There also a guide for firmware update of SSDs is provided.
Update with direct link to update guide:
Samsung SSD Firmware Update Guide
You only need to download the iso image for the SSD and write it to an USB stick.
Hi,
Ok, updated the firmware of the Samsung SSD.
Still have same issue though:
On warm reboot, Samsung SSD is not seen by BIOS and Manjaro fails to boot?
Anything else I can try?
Thanks!
Jesse
Bios update of the Laptop ?
The BIOS of the Lenovo laptop is up to date…
I don’t know Lenovo laptops.
Is it possible to change in BIOS, what mode for SATA controller should be used?
There is an older post, where the SATA controller had been changed to AHCI:
SSD no longer detected in BIOS, but after reboot from Windows
There is also another post, where it is suggested to reset BIOS configuration to default values:
post as of Jan. 8, 2014
