When trying to update, I get this error message;
"could not satisfy dependencies:
installing libxml2 (2.14.2-2) breaks dependency ‘libxml2.so=2-64’ required by rest
if possible, remove rest and retry"
Another thread suggested to run “sudo pacman -R lib32-rest” but that didn’t work for me; I got;
“error: target not found: lib32-rest”
I can’t find anything called “rest” on my system. Any idea how to fix this? thanks.
Is there an actual issue to fix? rest was removed from the repos. It looks like you no longer have rest or lib32-rest on your system. This Pamac command will list any installed packages containing the text string rest in the name or description:
pamac search -i rest
If no rest packages are installed (if the result includes timeshift, that is only because it contains the word restore in its description - it is not a rest package), then you should be able to update successfully. Maybe try updating via a terminal instead of the GUI:
sudo pacman -Syu
If you encounter any errors, please post the entire output from running that command here.
Please always paste command output as preformatted text.
As mentioned in another topic:
To workaroud the issue;
1. Check if rest is actually installed;
pacman -Qi rest
2. If rest is installed, remove it;
sudo pacman -Rns rest
3. Try updating again;
sudo pacman -Syu
Note that this strategy can also be used in other cases.
Example:
A recent update attempt revealed;
:: Synchronising package databases...
core is up to date
extra is up to date
multilib is up to date
resolving dependencies
:: installing libxml2 (2.14.2-2) breaks dependency 'libxml2.so=2-64' required by electron32
:: installing libxml2 (2.14.2-2) breaks dependency 'libxml2.so=2-64' required by electron33
This was overcome by removing the electron packages;
sudo pacman -R electron32 electron33
after which the sync/update could continue normally.
I no longer needed those specific electron packages, but if I did, I could have built electron32-bin or electron33-bin from the AUR, for example.
