Update attempt fails in error: Failed to prepare transaction, target not found: libblockdev-loop.
Any help with this will be greatly appreciated.
Kernel: 6.1.77-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=837c4445-d72c-4f7d-85c9-da3a06e79088 rw quiet splash
resume=UUID=28e59c87-02a4-44b7-bba3-d5bcc321aa68 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Mobo: ASUSTeK model: PRIME Z690-A v: Rev 1.xx serial: <superuser required>
part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 2403
date: 05/11/2023
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
status: discharging
System RAM: total: 64 GiB available: 62.54 GiB used: 3.61 GiB (5.8%)
Array-1: capacity: 256 GiB slots: 4 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: Controller0-DIMM0 type: no module installed
Device-2: Controller0-DIMM1 type: DDR5 detail: synchronous size: 32 GiB
speed: 4800 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Crucial Technology
part-no: CT32G48C40U5.M16A1 serial: <filter>
Device-3: Controller1-DIMM0 type: no module installed
Device-4: Controller1-DIMM1 type: DDR5 detail: synchronous size: 32 GiB
Info: model: 12th Gen Intel Core i7-12700 bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x32
Topology: cpus: 1x cores: 12 mt: 8 tpc: 2 st: 4 threads: 20 smt: enabled
cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32 KiB, 4x64 KiB
L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
Speed (MHz): avg: 800 min/max: 800/4800:4900:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 84500
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pconfig pdcm
rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow
tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300 temp: 52.0 C
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.4
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
s-diag: 1064mm (41.9") monitors: <missing: xrandr>
Monitor-1: DVI-D-1 model: Samsung SyncMaster serial: <filter> built: 2007
res: 1920x1200 dpi: 94 gamma: 1.6 chroma: red: x: 0.639 y: 0.329 green:
x: 0.298 y: 0.608 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10
modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
1280x960, 1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600,
640x480, 720x400
Monitor-2: HDMI-A-1 model: Acer G276HL serial: <filter> built: 2016
res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.643 y: 0.333 green:
x: 0.290 y: 0.635 blue: x: 0.153 y: 0.043 white: x: 0.314 y: 0.329
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
1152x864, 1280x720, 1024x768, 832x624, 800x600, 640x480, 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.5-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
polaris10 LLVM 16.0.6 DRM 3.49 6.1.77-2-MANJARO) device-ID: 1002:67df
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.276 layers: N/A device: 0 type: discrete-gpu name: AMD
Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv
v: 23.3.5-manjaro1.1 device-ID: 1002:67df surfaces: xcb,xlib
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7ad0
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 1002:aaf0
class-ID: 0403
API: ALSA v: k6.1.77-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 5.46 TiB used: 630.47 GiB (11.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 35.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 2000GB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 04RL scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD20SDRW-11VUUS0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1034 scheme: GPT
Optical-1: /dev/sr0 vendor: ASUS model: DRW-24B1ST a rev: 1.04
dev-links: cdrom
Optical-2: /dev/sr1 vendor: TSSTcorp model: CD/DVDW SH-S183L rev: SB03
dev-links: N/A
ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.37%) used: 96.38 GiB (5.3%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 837c4445-d72c-4f7d-85c9-da3a06e79088
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 8D44-BE96
ID-3: /run/media/chas/attic raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 534.09 GiB (29.1%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: attic
uuid: 91039440-2cde-4e0c-abe0-5d76dc558502
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 28e59c87-02a4-44b7-bba3-d5bcc321aa68
ID-1: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ext4 label: easystore
uuid: d1ec5187-ff6a-40d7-837d-03e2c59cf507
Hub-2: 1-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
chip-ID: 174c:2074 class-ID: 0900
Device-1: 1-2.1:4 info: HP LaserJet 2300d type: printer driver: usblp
interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
chip-ID: 03f0:0b17 class-ID: 0701 serial: <filter>
Hub-3: 1-2.2:6 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-2.2.1:8 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-2.2.3:9 info: Holtek Keyboard [Diatec Filco Majestouch 2]
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 04d9:1818 class-ID: 0301
Device-3: 1-4:3 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
serial: <filter>
Device-4: 1-7:5 info: Elan Micro type: keyboard driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
power: 100mA chip-ID: 04f3:0104 class-ID: 0301
Device-5: 1-10:7 info: Wacom PTZ-630 [Intuos3 (6x8)] type: mouse
driver: usbhid,wacom interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 300mA chip-ID: 056a:00b1 class-ID: 0301
Hub-4: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
Device-1: 2-4:2 info: Western Digital easystore 2648 type: mass storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 1058:2648 class-ID: 0806
serial: <filter>
Hub-5: 2-9:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 174c:3074 class-ID: 0900
System Temperatures: cpu: 23.0 C mobo: N/A gpu: amdgpu temp: 52.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 890
Packages: pm: pacman pkgs: 1398 libs: 415 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
3: https://mirror.easyname.at/manjaro/stable/$repo/$arch
4: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
5: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
6: http://manjaro.mirror.ac.za/stable/$repo/$arch
7: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
8: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 381
1: cpu: 4.0% command: brave pid: 3759 mem: 238.8 MiB (0.3%)
2: cpu: 1.7% command: brave pid: 3371 mem: 256.5 MiB (0.4%)
3: cpu: 1.3% command: Xorg pid: 908 mem: 113.2 MiB (0.1%)
4: cpu: 1.2% command: brave pid: 3051 mem: 523.9 MiB (0.8%)
5: cpu: 1.0% command: brave pid: 3099 mem: 287.5 MiB (0.4%)
Memory top: 5 of 381
1: mem: 523.9 MiB (0.8%) command: brave pid: 3051 cpu: 1.2%
2: mem: 509.1 MiB (0.7%) command: soffice.bin pid: 2961 cpu: 0.1%
3: mem: 393.5 MiB (0.6%) command: plasmashell pid: 1137 cpu: 0.2%
4: mem: 329.8 MiB (0.5%) command: thunderbird pid: 1615 cpu: 0.8%
5: mem: 287.5 MiB (0.4%) command: brave pid: 3099 cpu: 1.0%
Processes: 381 Power: uptime: 40m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.01 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.33
