Try to run
$ sudo btrfs inspect-internal logical-resolve 253952 /
$ sudo btrfs inspect-internal logical-resolve 3037134 /
$ sudo btrfs inspect-internal logical-resolve 180469760 /
Try to run
ERROR: logical ino ioctl: No such file or directory
in each case.
I guess that btrfs-progs tool canāt find or read some file if this file is already gone but its checksum is present. That is why it would be marked as the corrupted file in the Btrfs log.
Edit://
This is my stupid thought, sorry.
Look at the mismatched checksum:
0xc341dc86 =/= 0xc341fc86 ā That looks like d does not match f.
The damaged file must be there.
I think btrfs inspect logical-resolve <logical> <path> has some bug. I will report the bug on btrfs-prog github
I see what you are referring to. As for my immediate situation, is there any way to resolve this? Or do I need to replace the NVME drive?
I can have a look at it too. What is your status? I mean, have you backed up your data i.e. copied over what you need to an external drive? Did you make a bootable Manjaro live stick (or a different distro)?
Testing your hardware is not easy:
Check a cable (NVME PCIe does not use the cable)
Test your RAMs (Remove all RAMs and test every single RAM with test tool for example and copying any large file 10 GB+ on the same filesystem and check it with sha1sum, if both files match correctly. Test 10 times repetitions)memtest
If all RAM tests pass, then replace your disk with another disk
If the problem persists after replacing the drive, the mainboard or the CPU cache is probably the problem.
Letās try to fix whatās there Zesko. Why would you assume RAMās fault?
Did you use Timeshift to Btrfs-snaphot on regular basis? If so, about how often, hourly, daily, weekly, on boot?
A appreciate your willingness to help!
The good news is that almost all of my urgent data is in the cloud and was up to date before this disaster struck. The few items that werenāt in the cloud that have been backed up on a separate USB device. I have a live stick ready. FYI - I use an encrypted LUKS device. The most I might lose is some ancient archived emails in Thunderbird.
My chief worry at this point is if the NVME drive hardware itself is flawed, or if BTRFS was somehow the source of my problem.
I did take snaps regularly, but I canāt remember the preset frequency (it was probably weekly). The latest snap was taken at the beginning of the upgrade process where I ran into this error.
If it is new as you say, it should not be a hardware mistake. Letās try to look at it with btrfs built-in commands.
Therefore please boot the computer into the live environment and tell me when you have, here.
I will do that, but circumstances are such that I have to be away from the machine for a few hours. May I reply to this thread when Iām available again? Again, I GREATLY appreciate your willingness to help me, a total stranger, and I want to be sure to not waste any of your time.
That is not true.
In my real experience, I had bought a new RAM, it had already been damaged (Only 1 random bit is damaged), thanks Btrfs stopped copying my new backup to other hard drive because the backup was corrupted.
Do not trust new hardware after buying it!
And donāt trust old hardware. Every hardware has a lifespan limit.
Huh I was in the same position you are in right now so I appreciate to help (where I can). As said, I will check again into this thread until we have a solution or we are sure we canāt find one.
Plan is to find error messages and then act accordingly. I will be back tomorrow night or Friday too so donāt worry. ![]()
Yes, RAM can be the root of the evil in some cases, true. However there are many errors btrfs can spawn and yours does not seem to liken Adram's.
There are to my knowledge several error scenarios and one should look at which method to fix the filesystem with. I will not recommend anything that is not recommended at Welcome to BTRFS documentation! ā BTRFS documentation
Edit: Oops sorry Zesko your errors are in fact similarā¦
How do I get the strike-through option for text?
Hey, I just wanted to let you know that Iām not going to need your help. Upon further research, the drive has failed and will need to be replaced.
I came to this conclusion after reading this article. My smartctl analysis yielded the same error, and thus itās time to move on. Thank you again for your willingness to help!
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
