Update crashed my system (maybe solved)
Comparto lo que escribí en el foro de Mabox (mi sistema) ayer, 30 de noviembre:
No pude leer el mensaje de error.
Y pregunto: ¿no se puede dosificar una actualización tan grande?
Abrazos desde Argentina.
:people_hugging: :argentina:
I share what I wrote on the Mabox forum (my system) yesterday, November 30.
I couldn’t read the error message.
And I ask: can’t you dose such a big update?
Manjaro updates come in bigger chunks, but less frequent.
That is how Manjaro stable branch works.
You could change to testing or unstable - the updates will be much more frequent, but each one not as big.
I don’t use pamac or the graphical pamac-manager - I much prefer pacman.
Before an update, you can use:
sudo pacman-mirrors --continent yourlocation
or
sudo pacman-mirrors -c yourcoutry
or
sudo pacman-mirrors -f
and then
sudo pacman -Syuw
the effect of -w is that nothing will be done, only all the needed packages will be fetched
so everything needed for the update will be there.
Then you can do the update, knowing that everything is already there.
sudo pacman -Syu
Do the update, especially large ones, in a TTY - not in your graphical session.
If the machine crashes during the update for whatever reason, in the best case scenario, you end up with no kernel.
It could be worse.
The repair is usually easy:
boot from USB iso and:
manjaro-chroot -a
and finish the update there and install a kernel
pacman -Syu linuxXYZ
mkinitcpio -P linux
update-grub
There where a few posts similar to yours here today and in the last few days - look there as well.
Hope that helps.
@anon33601770, por favor, sólo publique artículos en español en la sección en español.
I used pacman, exactly as you say. I don’t know why the error was made.
Bilingual post.
Sorry for the mistake, if you like, in the next one I will put the English text first and then the Spanish text. To avoid duplication with a post in English and another in Spanish. If don’t, please let me know.
No sé español, pero él obviamente sabe inglés, así que no me molesté.
En este punto, por favor, utilice sólo el español. Esta sección se introdujo con este fin.
Si el inglés también está bien, por favor publique en la sección de soporte «normal», gracias.
Las contribuciones bilingües son difíciles de moderar, ya que los moderadores que sólo hablan inglés tendrían que traducir primero ellos mismos los textos en español.
OK. My reasoning was as follows: writing in both languages ​​would get me more solutions, so I then proposed to put the text in English first and then in Spanish. I understand what you say about moderators who only speak English. Little by little I will learn the mechanics of the forum.
Greetings.
Comprensible, pero no es el objetivo de la sección española. A partir de ahora, por favor, utilice sólo el español aquí.
