Update - could not satisfy dependencies
When I try to update I get this:
could not satisfy dependencies:
- removing lib32-expat breaks dependency 'lib32-expat' required by lib32-fontconfig
- removing lib32-expat breaks dependency 'libexpat.so=1-32' required by lib32-fontconfig
- removing lib32-libffi breaks dependency 'lib32-libffi' required by lib32-glib2
- removing lib32-pcre2 breaks dependency 'lib32-pcre2' required by lib32-glib2
- removing lib32-libffi breaks dependency 'libffi.so=8-32' required by lib32-glib2
- removing lib32-libcap breaks dependency 'lib32-libcap' required by lib32-gstreamer
Since the Konsole (made a different ticket for that) is not starting I can just try to update 50+ updates one by one, most say “failed to synchronize databases”.
Since the marked updates change positions in the list trying them one by one is a HUGE pain.
A fancy joke is that files already exist on the drive and are owned by shadow (whoever that would be):
conflicting files:
- coreutils: /usr/bin/groups already exists in filesystem (owned by shadow)
- coreutils: /usr/share/man/man1/groups.1.gz already exists in filesystem (owned by shadow)
KDE Plasma Version: 6.3.3
KDE Frameworks Version: 6.10.0
Qt Version: 6.8.1
Kernel Version: 6.12.11-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × Intel® Core™ i7-9700K CPU @ 3.60GHz
Memory: 15,6 GiB of RAM
Graphics Processor 1: NVIDIA GeForce RTX 2080/PCIe/SSE2
Graphics Processor 2: NVIDIA GeForce RTX 2080/PCIe/SSE2
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: Z390 AORUS PRO
Have you removed the discontinued community repo from your pacman.conf? If not, you should do that and try the update again.
I have found a post about that and did it. Now it is updating.
Thank you!
Hope it fixes my Konsole as well.
