I did reboot after the update and never touched glslang.
I’m looking at it right now. For some reason, I have glslang-git package from the AUR instead of the official glslang package.
After replacing glslang-git with glslang, I get another error:
Warning: option --input-x11-keyboard was replaced with --input-vo-keyboard and might be removed in the future.
Warning: option --ass-line-spacing was replaced with --sub-ass-line-spacing and might be removed in the future.
Warning: option --sub-text-shadow-color was replaced with --sub-shadow-color and might be removed in the future.
Error parsing option softvol (option not found)
Setting commandline option --softvol=yes failed.
Exiting... (Fatal error)
I checked SMPlayed config but so far, I couldn’t find this softvol option anywhere.
Note: mplayer is working just fine, only mpv crashes.
Cannot reproduce (and never experienced similar with mpv engine and software volume control) on Unstable branch. Though maybe I should note that the multimedia engine section is set to 'Other' > /usr/bin/mpv for whatever thats worth.
I was facing this issue with mpv a few months ago, where video becomes laggy and sound sync goes off after a pause. (mpv loses audio/sub sync (and laggy video) when pause/resume the video · Issue #10795 · mpv-player/mpv · GitHub)
At that time, I installed pipewire to try and fix it. It didn’t work. I can’t remember but I guess this is when I installed glslang-git, which probably solved the issue at that time.
Now mpv has been updated to use glslang 12 but glslang-git is still version 11, which caused the first issue.
I have no idea where the softvol problem comes from, but I may have broken something when installing pipewire a few months ago. If it works on a fresh install, then it’s definitely a problem on my setup.
I solved the same problem (audio sync) by adding in
~/.config/mpv/mpv.conf
pulse-latency-hacks=yes
but i use pulseaudio and i don’t know if it works with pipewire
you can try if it works by starting a video from terminal with
mpv --pulse-latency-hacks=yes videofilename.mp4
Just to note here - a git package in AUR rarely have their listed version bumped. Rather building or rebuilding the package should source the latest upstream git.
Secondary note - It is common that AUR packages may need to be rebuilt after a regular system upgrade.
