Can someone tell me how to fix this so i can actually update my system .Since the updates broke .
Enter a number (default=1): 1
warning: removing ‘opencolorio’ from target list because it conflicts with ‘opencolorio1’
:: opencolorio1 and opencolorio are in conflict. Remove opencolorio? [y/N] y
:: dbus-python and python2-dbus are in conflict. Remove python2-dbus? [y/N] y
:: removing python2-dbus breaks dependency ‘python2-dbus’ required by oblogout-manjaro
remove the file - reinstall when sync has succeeded
most likely this is caused by manually installing the extension - to avoid those issues in the future - always use the package manager to install packages.
