I found similar topic and used their solution. No hybrid amdgpu nvidia drivers in mhwd after upgrade
Prime appeared, i removed all drivers and installed again from terminal with sudo mhwd -a pci nonfree 0300.
Didn’t help. Prime works just as bumblebee - “gigabyte” label on main monitor and black extra.
I loaded with only main monitor to check current drivers. There are modesetting and prime.
Here is sudo inxi -Fazy
Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=17bb424a-dc17-48af-a2d3-e4ea97264bee rw quiet splash apparmor=1
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Desktop Mobo: Gigabyte model: Z87-HD3 v: x.x serial: N/A
UEFI: American Megatrends v: F8 date: 08/12/2014
Info: Quad Core model: Intel Core i7-4790K bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
L1: 256 KiB L2: 8 MiB L3: 8 MiB
bogomips: 63854
Speed: 4364 MHz min/max: 800/4400 MHz base/boost: 4200/7000 volts: 1.1 V
ext-clock: 100 MHz Core speeds (MHz): 1: 4364 2: 4360 3: 4367 4: 4340
5: 4384 6: 4390 7: 4385 8: 4322
Type: l1tf
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0412
class-ID: 0300
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nvidia v: 460.73.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1c82 class-ID: 0300
Display: server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 460.73.01
direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Device-3: C-Media USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-10:5 chip-ID: 0d8c:0012
class-ID: 0300
Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.26 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 1.24 TiB used: 39.73 GiB (3.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Plextor model: PX-128M5S
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 1.05 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 0010 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD1003FZEX-00K3CA0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A01
scheme: MBR
ID-1: / raw-size: 223.27 GiB size: 218.77 GiB (97.98%)
used: 39.73 GiB (18.2%) fs: ext4 block-size: 4096 B dev: /dev/sdb2
maj-min: 8:18
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
System Temperatures: cpu: 31.0 C mobo: 29.8 C gpu: nvidia temp: 34 C
Fan Speeds (RPM): cpu: 819 fan-2: 0 fan-3: 0 fan-4: 0 fan-5: 0 gpu: nvidia
fan: 45%
Power: 12v: N/A 5v: N/A 3.3v: N/A vbat: 3.24
Processes: 253 Uptime: 6m wakeups: 0 Memory: 15.46 GiB
used: 2.33 GiB (15.1%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: 1332 pacman: 1316 lib: 380 flatpak: 9 snap: 7
Shell: Zsh (sudo) v: 5.8 running-in: gnome-terminal inxi: 3.3.04
