Unsupported kernel, 5.17.15-1
Hey guys, I just got a nitification on manjaro kernel, I’m using 5.17.15-1 and it says that this version is unsupported, I was wondering which I should install and run.
Thanks in advance.
yes 5.17 is EOL and needs to be uninstalled, use the 5.15 - install it, reboot select it in grub menu, uninstall 5.17
Hi @ikkako,
5.17 is EOL, and was removed with the last update:
So install a new one, I recommend 5.15 as it’s LTS:
mhwd-kernel --install linux515
Then reboot into it, and uninstalll 5.17:
mhwd-kernel --remove linux517
For more information, see:
Hope this helps!
Use commands in previous post
Or use GUI - Settings > Manjaro Settings Manager > Kernel
manjaro-settings-manager -m msm_kernel
Manjaro Settings Manager - Manjaro
thanks worked perfectly
Install the 5.18 and 5.15 LTS. Run the 5.18 and keep the 5.15 just in case.
