The compromised certificates have been removed/invalidated with ca-certificates-mozilla ≥ 3.131.1-1.
Without an update to this central certificate bundle, systems are susceptible to man-in-the-middle attacks. As such, we urge everyone to upgrade their systems immediately.
Update to php ≥ 8.5.12 and/or php-legacy ≥ 8.3.36 to prevent remote code execution
2026-10-21 - David Runge
PHP versions prior to 8.5.12 and 8.3.36 are affected by CVE-2026-109618 and CVE-2026-109619, which allow for remote code execution.
For any system publicly exposing a PHP application with the help of a prior version of PHP, we urge users to upgrade those systems to the latest available version of PHP (php ≥ 8.5.12 and php-legacy ≥ 8.3.36) immediately.
Support for starting X11 sessions in Plasma 6.8 is being retired
If you are using an X11 session, before updating switch to a Wayland session or a TTY (virtual console) before updating. Virtual consoles are usually accessible by pressing Ctrl+Alt+F1 through Ctrl+Alt+F6.
You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.13.so.
Rebuild them all at once:*
checkrebuild
Info about AUR packages
AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcements topics are off-topic and will be flagged, moved or removed without warning.
:: Début de la mise à jour complète du système…
résolution des dépendances…
recherche des conflits entre paquets…
erreur : la préparation de la transaction a échoué (la satisfaction des dépendances a échoué)
:: l’installation de hwinfo (26.0-1) casse la dépendance « hwinfo<=26 » requise par manjaro-settings-manager
I see there is an update to plymouth-theme-manjaro 2.2-6 -> 2.2-7 extra
Can I please know what’s the change, I couldn’t find the git repo…
I have a copy of that theme with a custom Image injected, just wanna know whats changed.
Updating it wont affect my copy theme, but last time there were some important changes like font and stuff for disk encryption or something, so I updated my theme to be based on new version.
I am running Xfce Unstable formatted ext4. I am able to boot successfully with GRUB 2.16, however, I don’t have an entry for UEFI firmware settings. All I see on cold boot are:
Manjaro Linux
Advanced options for Manjaro Linux.
I have added the parameters as noted by Stephane. With those suggested parameters I see UEFI firmware settings in EOS and Arch Virtual Machines. My entries are as follows:
sudo update-grub
[sudo] password for jrichard:
Found linux image: /boot/vmlinuz-7.2-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-7.2-x86_64.img
Found linux image: /boot/vmlinuz-6.18-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.18-x86_64.img
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
done
Update:
The following was missing from the end of the 30_uefi-firmware file in /etc/grub.d
if [ "\$?" = 0 ]; then
menuentry '$LABEL' \$menuentry_id_option 'uefi-firmware' ${allowed_user_list}{
fwsetup
fi
I added the above, sudo update-grub and reboot fixed the issue.
The update wants to change:
from: GRUB_CMDLINE_LINUX_DEFAULT="udev.log_priority=3 acpi_backlight=native resume=UUID=9f921366-4ebb-4b6b-aa6e-1fa19d252abc"
to: GRUB_CMDLINE_LINUX_DEFAULT="loglevel=3 quiet rd.udev.log_level=3"
The final sould be: GRUB_CMDLINE_LINUX_DEFAULT="loglevel=3 quiet rd.udev.log_level=3 acpi_backlight=native resume=UUID=9f921366-4ebb-4b6b-aa6e-1fa19d252abc"
Note that this only seems to work if both quiet and loglevel=level are used, and they must be in that order (quiet first). The loglevel parameter will only change that which is printed to the console, the levels of dmesg itself will not be affected and will still be available through the journal as well as dmesg. For more information, see kernel parameters.
hello,
can anyone point me to the changes from gnome-shell 51.0-1 to 51.0-2.
51.0-1 crashed a lot when playing/decoding video files and mouse-over the player (eg chrome, mpv …).
51.0-2 fixed everything and arch still only lists 51.0-1, just wondering what caused the problems.
Normally, a change from -1 to -2 does not signify any change to the code, but rather a repackaging and/or a rebuild, e.g. due to a change in one or several dependencies.
For anyone who uses sleep then hibernate with kernel 7.2.x, and suffers from total black screen with frozen and unresponsive system, this helped me fixing the problem:
