scratch after update on 06/22/2021 impossible to restart session block force to redo the phone grrrr
Same problem.
If you have some space on a computer, do a backup using jumplink before updating. You can then go back before the update and find the issue or just use it as is and wait for the next one. I use a 32go SD card for backup so if something happen I can plug it in and go has if nothing happen’d
